or1k test was .. Re: [PATCH] or1k: New cache manager.
    Hesham Moustafa
    heshamelmatary at gmail.com
    Tue Sep 16 19:45:59 UTC 2014
Breakpoint 2, 0x00000600 in _unalign ()
(gdb) bt
#0  0x00000600 in _unalign ()
#1  0x0002ec4c in _RBTree_Next (
    node=0x40890, dir=RBT_RIGHT)
    at ../../../../../../rtems/c/src/../../cpukit/score/src/rbtreenext.c:35
#2  0x0002e2f4 in _RBTree_Successor (
    node=0x40890)
    at ../../cpukit/../../../or1ksim/lib/include/rtems/score/rbtree.h:512
#3  0x0002e8c0 in _RBTree_Extract (
    the_rbtree=0x4198c,
    the_node=0x40890)
    at ../../../../../../rtems/c/src/../../cpukit/score/src/rbtreeextract.c:106
#4  0x00021524 in _RBTree_Get (
    the_rbtree=0x4198c, dir=RBT_LEFT)
    at ../../cpukit/../../../or1ksim/lib/include/rtems/score/rbtree.h:540
#5  0x000215c8 in _Thread_queue_Dequeue
    (the_thread_queue=0x4198c)
---Type <return> to continue, or q <return> to quit---
    at ../../../../../../rtems/c/src/../../cpukit/score/src/threadqdequeue.c:51
#6  0x00017c14 in _CORE_semaphore_Surrender (the_semaphore=0x4198c,
    id=436273153,
    api_semaphore_mp_support=0x0)
    at ../../../../../../rtems/c/src/../../cpukit/score/src/coresemsurrender.c:37
#7  0x00014868 in rtems_semaphore_release (id=436273153)
    at ../../../../../../rtems/c/src/../../cpukit/rtems/src/semrelease.c:102
#8  0x00026cfc in rtems_libio_unlock ()
    at ../../cpukit/../../../or1ksim/lib/include/rtems/libio_.h:253
#9  0x00026d5c in rtems_filesystem_default_unlock (mt_entry=0x49ce0)
    at ../../../../../../rtems/c/src/../../cpukit/libfs/src/defaults/default_loc---Type
k_and_unlock.c:39
#10 0x0002920c in rtems_filesystem_instance_unlock (loc=0x49c5c)
    at ../../cpukit/../../../or1ksim/lib/include/rtems/libio_.h:292
#11 0x00029268 in rtems_filesystem_location_free (loc=0x49c5c)
    at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/freenode.c:29
#12 0x00029734 in rtems_libio_free (
    iop=0x49c50)
    at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/libio.c:136
#13 0x0002912c in close (fd=0)
    at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/close.c:38
#14 0x000064b0 in rtems_libio_exit ()
    at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/libio_exit.c:31
#15 0x0003b058 in _exit (status=0)
    at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:46
#16 0x00034798 in exit (code=0)
    at ../../../../../gcc-4.8.3/newlib/libc/stdlib/exit.c:70
#17 0x00002e3c in Test_task (unused=1)
    at ../../../../../../../rtems/c/src/../../testsuites/samples/ticker/tasks.c:41
#18 0x000340f0 in _Thread_Handler ()
    at ../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:192
#19 0x00034078 in _User_extensions_Thread_exitted (executing=0x40890)
    at ../../cpukit/../../../or1ksim/lib/include/rtems/score/userextimpl.h:243
Backtrace stopped: frame did not save the PC
(gdb)
It breaks at _RBTree_Next specifically at the following line:
 while ( ( current = current->child[ opp_dir ] ) != NULL )
(gdb) p current->child[ opp_dir ]
Cannot access memory at address 0xa010006
(gdb) p current
$1 = (RBTree_Node *) 0xa010002
This address is invalid, the current memory length should be only 32
MB (0x2000000)
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds#n20
So I guest current->child is overwritten somehow?
On Tue, Sep 16, 2014 at 9:21 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 9/16/2014 2:17 PM, Hesham Moustafa wrote:
>> On Tue, Sep 16, 2014 at 8:42 PM, Joel Sherrill
>>> On 9/16/2014 1:34 PM, Hesham Moustafa wrote:
>>>> On Tue, Sep 16, 2014 at 8:15 PM, Joel Sherrill
>>>>> On 9/16/2014 12:54 PM, Hesham Moustafa wrote:
>>>>>> Hi
>>>>>> On Tue, Sep 16, 2014 at 7:47 PM, Joel Sherrill
>>>>>>> I don't understand this but I got it applied.
>>>>>>> I manually edited the saved email to delete the preinstall.am
>>>>>>> changes.  I committed the rest. Then I ran bootstrap -p myself
>>>>>>> and folded that into the rest of your patch.
>>>>>>> It should all be committed now.
>>>>>> Thanks for doing this, me too do not know what's wrong. BTW, commits
>>>>>> are not mirrored on github since 4 days ago.
>>>>>>> How about some new test results. :)
>>>>>> I did run one last night, no big progress since previous results :( Is
>>>>>> there any tool, script, utility program or whatever that I can use to
>>>>>> detect wrong memory access (i.e, stack overwrite, heap corruption,
>>>>>> access to another task context)? I tried to add -fstack-protector-all
>>>>>> to gcc, but QEMU did not get anything or core-dump, ticker just hangs.
>>>>> I haven't checked into how gcc does its stack overwrite protection.
>>>>> The tests by themselves don't have these problems. The first
>>>>> possible source is incorrect layout of sections to memory by
>>>>> the linker script. There is some debug code in boot
>>>>> There used to be debug printk's in bspgetworkarea.c so you
>>>>> could check if areas overlapped. That usually causes bad issues
>>>>> though. Let's go through some basics:
>>>>> + Does hello world run and exit cleanly?
>>>> The output of Hello World is:
>>>> *** BEGIN OF TEST HELLO WORLD ***
>>>> Hello World
>>>> *** END OF TEST HELLO WORLD ***
>>>> Fatal Error 5.0 Halted
>>>>   From GDB:
>>>> Breakpoint 1, _Terminate (
>>>>       the_source=RTEMS_FATAL_SOURCE_EXIT, is_internal=false,
>>>> the_error=0)
>>>>       at
>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:39
>>>> 39  _ISR_Disable_without_giant( level );
>>>> (gdb) bt
>>>> #0  _Terminate (
>>>> the_error=0)
>>>>       at
>>>> #1  0x0003b5f8 in rtems_shutdown_executive (result=0)
>>>>       at
>>>> ../../../../../../rtems/c/src/../../cpukit/sapi/src/exshutdown.c:21
>>>> #2  0x0003b350 in _exit (status=0)
>>>>       at
>>>> ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:47
>>>> #3  0x0002cc30 in exit (code=0)
>>>> #4  0x00002184 in Init (ignored=253816)
>>>>       at
>>>> ../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:33
>>>> #5  0x0002c5b8 in _Thread_Handler ()
>>>>       at
>>>> #6  0x0002c540 in _User_extensions_Thread_exitted (executing=0x40080)
>>>>       at
>>> This is normal and OK. Look at the arguments to _Terminate.
>>>>> + How far does ticker get?
>>>> Ticker goes to the end:
>>>> *** BEGIN OF TEST CLOCK TICK ***
>>>> TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
>>>> TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
>>>> TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
>>>> TA1  - rtems_clock_get_tod - 09:00:05   12/31/1988
>>>> TA2  - rtems_clock_get_tod - 09:00:10   12/31/1988
>>>> TA1  - rtems_clock_get_tod - 09:00:10   12/31/1988
>>>> TA3  - rtems_clock_get_tod - 09:00:15   12/31/1988
>>>> TA1  - rtems_clock_get_tod - 09:00:15   12/31/1988
>>>> TA2  - rtems_clock_get_tod - 09:00:20   12/31/1988
>>>> TA1  - rtems_clock_get_tod - 09:00:20   12/31/1988
>>>> TA1  - rtems_clock_get_tod - 09:00:25   12/31/1988
>>>> TA3  - rtems_clock_get_tod - 09:00:30   12/31/1988
>>>> TA2  - rtems_clock_get_tod - 09:00:30   12/31/1988
>>>> TA1  - rtems_clock_get_tod - 09:00:30   12/31/1988
>>>> *** END OF TEST CLOCK TICK ***
>>>> Fatal Error 9.276564 Halted
>>>>   From GDB:
>>>> (gdb) break _Terminate
>>>> Breakpoint 1 at 0x19a68: file
>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c, line
>>>> 39.
>>>> (gdb) break _OR1K_Exception_default
>>>> Breakpoint 2 at 0x2686c: file
>>>> ../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c,
>>>> line 22.
>>>> (gdb) c
>>>> The program is not being run.
>>>> (gdb) target remote :50001
>>>> Remote debugging using :50001
>>>> 0x00000100 in _reset ()
>>>> (gdb) c
>>>> Continuing.
>>>> Breakpoint 2, _OR1K_Exception_default (vector=6, frame=0x43854) at
>>>> ../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c:22
>>>> 22  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame
>>>> (gdb) bt
>>>> #0  _OR1K_Exception_default (vector=6, frame=0x43854) at
>>>> #1  0x00026980 in jump_to_c_handler ()
>>>> vector 6 is _unalign exception.
>>> Set a break point at exit() (I think) and rtems_shutdown_executive(). You
>>> could start in the task which calls whatever kicks off the shutdown
>>> sequence.
>>> It looks like something in the shutdown procedure trips over something.
>>> This might be easy to debug.
>> I did add just a function call to _CPU_Exception_frame_print(frame);
>>   from _OR1K_Exception_default(uint32_t vector, CPU_Exception_frame
>> *frame)
>> And ticker exits normally without even entering
>> _OR1K_Exception_defaul as it did before. This is very weird. Does this
>> mean that some areas of the code are overlapped from the linker
>> script?
> I doubt it. I suspect something unitialized or not aligned properly.
> Set a breakpoint at
> http://git.rtems.org/rtems/tree/testsuites/samples/ticker/tasks.c#n40
> next over the print and then step through rtems_test_exit() and see
> where it faults.
>>> If the fault address is in the exception data, you can map that back to
>>> the
>>> nm file and see what file that was in, then that might help.
>>>>> + Have you tried the trick I suggested earlier to disable the
>>>>> real clock tick driver, use the simulator idle tick code, and
>>>>> disable all the tests that are known to fail that way. This
>>>>> will eliminate the ISR code as an issue because you won't
>>>>> have any (if console output if polled).  See h8sim for
>>>>> an example. Should be a Makefile.am change, adding
>>>>> an include to the testsuite configuration file, building
>>>>> and running.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
