[PATCH] redirector: Rename rtems_stdio_redirect_t
Sebastian Huber
Wed Sep 17 05:24:00 UTC 2014
Rename rtems_stdio_redirect_t to rtems_stdio_redirect since the
namespace *_t is reserved by POSIX, see also The Open Group Base
Specifications Issue 6 IEEE Std 1003.1, 2004 Edition, 2.2.2 The Name
Space.
cpukit/libmisc/redirector/stdio-redirect.c | 26 +++++++++++++-------------
cpukit/libmisc/redirector/stdio-redirect.h | 24 ++++++++++++------------
2 files changed, 25 insertions(+), 25 deletions(-)
diff --git a/cpukit/libmisc/redirector/stdio-redirect.c b/cpukit/libmisc/redirector/stdio-redirect.c
index e6610cb..05a263d 100644
--- a/cpukit/libmisc/redirector/stdio-redirect.c
+++ b/cpukit/libmisc/redirector/stdio-redirect.c
@@ -31,7 +31,7 @@
#define RTEMS_STDIO_REDIRECT_FINISHED (1 << 1)
static bool
-rtems_stdio_redirect_lock(rtems_stdio_redirect_t* sr)
+rtems_stdio_redirect_lock(rtems_stdio_redirect* sr)
rtems_status_code sc = rtems_semaphore_obtain (sr->lock,
RTEMS_WAIT,
@@ -45,7 +45,7 @@ rtems_stdio_redirect_lock(rtems_stdio_redirect_t* sr)
static bool
-rtems_stdio_redirect_unlock(rtems_stdio_redirect_t* sr)
+rtems_stdio_redirect_unlock(rtems_stdio_redirect* sr)
rtems_status_code sc = rtems_semaphore_release (sr->lock);
if (sc != RTEMS_SUCCESSFUL)
@@ -57,7 +57,7 @@ rtems_stdio_redirect_unlock(rtems_stdio_redirect_t* sr)
static bool
-rtems_stdio_redirect_write (rtems_stdio_redirect_t* sr, const char* buf, ssize_t len)
+rtems_stdio_redirect_write (rtems_stdio_redirect* sr, const char* buf, ssize_t len)
if (!rtems_stdio_redirect_lock(sr))
return false;
@@ -99,7 +99,7 @@ rtems_stdio_redirect_write (rtems_stdio_redirect_t* sr, const char* buf, ssize_t
static rtems_task
rtems_stdio_redirect_reader(rtems_task_argument arg)
- rtems_stdio_redirect_t* sr = (rtems_stdio_redirect_t*) arg;
+ rtems_stdio_redirect* sr = (rtems_stdio_redirect*) arg;
while (sr->state & RTEMS_STDIO_REDIRECT_RUNNING)
@@ -120,7 +120,7 @@ rtems_stdio_redirect_reader(rtems_task_argument arg)
rtems_task_delete(RTEMS_SELF);
-rtems_stdio_redirect_t*
+rtems_stdio_redirect*
rtems_stdio_redirect_open(int fd,
rtems_task_priority priority,
size_t stack_size,
@@ -129,11 +129,11 @@ rtems_stdio_redirect_open(int fd,
bool echo,
rtems_stdio_redirect_handler handler)
- rtems_stdio_redirect_t* sr;
- rtems_name name;
- rtems_status_code sc;
+ rtems_stdio_redirect* sr;
+ rtems_name name;
+ rtems_status_code sc;
- sr = malloc(sizeof(rtems_stdio_redirect_t));
+ sr = malloc(sizeof(*sr));
if (!sr)
fprintf(stderr, "error: stdio-redirect: no memory\n");
@@ -248,7 +248,7 @@ rtems_stdio_redirect_open(int fd,
void
-rtems_stdio_redirect_close(rtems_stdio_redirect_t* sr)
+rtems_stdio_redirect_close(rtems_stdio_redirect* sr)
if (rtems_stdio_redirect_lock(sr))
@@ -278,9 +278,9 @@ rtems_stdio_redirect_close(rtems_stdio_redirect_t* sr)
ssize_t
-rtems_stdio_redirect_read(rtems_stdio_redirect_t* sr,
- char* buffer,
- ssize_t length)
+rtems_stdio_redirect_read(rtems_stdio_redirect* sr,
+ char* buffer,
+ ssize_t length)
ssize_t written = 0;
diff --git a/cpukit/libmisc/redirector/stdio-redirect.h b/cpukit/libmisc/redirector/stdio-redirect.h
index cf3d0cf..6f1d4cd 100644
--- a/cpukit/libmisc/redirector/stdio-redirect.h
+++ b/cpukit/libmisc/redirector/stdio-redirect.h
@@ -75,7 +75,7 @@ typedef struct
bool full; /**< The buffer is full. */
bool echo; /**< Echo the data out the existing path. */
rtems_stdio_redirect_handler handler; /**< Redirected data handler. */
-} rtems_stdio_redirect_t;
+} rtems_stdio_redirect;
* Open a redirector returning the handle to it.
@@ -83,18 +83,18 @@ typedef struct
* @param fd The file descriptor to redirect.
* @param priority The priority of the reader thread.
-rtems_stdio_redirect_t* rtems_stdio_redirect_open(int fd,
- rtems_task_priority priority,
- size_t stack_size,
- ssize_t input_size,
- ssize_t buffer_size,
- bool echo,
- rtems_stdio_redirect_handler handler);
+rtems_stdio_redirect* rtems_stdio_redirect_open(int fd,
+ rtems_task_priority priority,
+ size_t stack_size,
+ ssize_t input_size,
+ ssize_t buffer_size,
+ bool echo,
+ rtems_stdio_redirect_handler handler);
* Close the redirector.
-void rtems_stdio_redirect_close(rtems_stdio_redirect_t* sr);
+void rtems_stdio_redirect_close(rtems_stdio_redirect* sr);
* Get data from the capture buffer. Data read is removed from the buffer.
@@ -104,9 +104,9 @@ void rtems_stdio_redirect_close(rtems_stdio_redirect_t* sr);
* @param length The size of the buffer.
* @return ssize_t The amount of data written and -1 or an error.
-ssize_t rtems_stdio_redirect_read(rtems_stdio_redirect_t* sr,
- char* buffer,
- ssize_t length);
+ssize_t rtems_stdio_redirect_read(rtems_stdio_redirect* sr,
+ char* buffer,
+ ssize_t length);
#ifdef __cplusplus
1.8.4.5
