[PATCH] cpukit: Move zlib into librtemcpu.a and do not install libz.a.
Wed Sep 17 05:30:26 UTC 2014
On 17/09/14 02:26, Chris Johns wrote:
> The JFFS2 file system can optionally use zlib as a compressor and
> if this is the only reference to zlib the application will not link.
> Adding -lz does not work because librtemscpu.a is added to the end of
> ld's command line via the bsp_specs hack and user added libraries
> appear before this.
If we remove libz.a then this will break all application Makefiles, that assume
that RTEMS provides it.  I would still provide libz.a.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
