[PATCH] RTEMS: Update contrib/config-list.mk
Wed Sep 17 15:52:34 UTC 2014
On 9/17/2014 10:41 AM, Sebastian Huber wrote:
> On 09/17/2014 04:45 PM, Jan-Benedict Glaw wrote:
>> On Wed, 2014-09-17 15:37:32 +0200, Sebastian Huber<sebastian.huber at embedded-brains.de>  wrote:
>>>> contrib/ChangeLog
>>>> 2014-09-17  Sebastian Huber<sebastian.huber at embedded-brains.de>
>>>> 	* config-list.mk (LIST): Add arm-rtems.
>>>> 	Add nios2-rtems.  Remove extra option from powerpc-rtems.
>> What's the rationale for removing --enable-threads=yes here, as well
>> as the specific version number?
> The version number can be arbitrary.  All the other RTEMS targets in
> this list omit it.
> The --enable-threads=yes is not specific to PowerPC for RTEMS.  So all
> RTEMS targets should have it or none.  With a recent commit this option
> is superfluous.
I was noticing that at least the v850 is not represented
by any target.  Other than that, it looks like all the RTEMS
targets except that the or1k (which is not in the FSF tree
yet) are included.  I didn't review against the list of *-elf
targets though.
What is the rationale for inclusion on the list? Should
v850-elf and v850-rtems also be added?
And is this the input to your buildbot? :)
