or1k test was .. Re: [PATCH] or1k: New cache manager.
Wed Sep 17 19:44:46 UTC 2014
On 9/17/2014 12:44 PM, Hesham Moustafa wrote:
> On Tue, Sep 16, 2014 at 11:08 PM, Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>> wrote:
>     Gedare.. cc'ed you for help in spotting an empty rbtree
>     in gdb. See below.
>     On 9/16/2014 2:45 PM, Hesham Moustafa wrote:
>      > Breakpoint 2, 0x00000600 in _unalign ()
>      > (gdb) bt
>      > #0  0x00000600 in _unalign ()
>      > #1  0x0002ec4c in _RBTree_Next (
>      >     node=0x40890, dir=RBT_RIGHT)
>      >     at ../../../../../../rtems/c/src/../../cpukit/score/src/rbtreenext.c:35
>      > #2  0x0002e2f4 in _RBTree_Successor (
>      >     node=0x40890)
>      >     at ../../cpukit/../../../or1ksim/lib/include/rtems/score/rbtree.h:512
>      > #3  0x0002e8c0 in _RBTree_Extract (
>      >     the_rbtree=0x4198c,
>      >     the_node=0x40890)
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/score/src/rbtreeextract.c:106
>      > #4  0x00021524 in _RBTree_Get (
>      >     the_rbtree=0x4198c, dir=RBT_LEFT)
>      >     at ../../cpukit/../../../or1ksim/lib/include/rtems/score/rbtree.h:540
>      > #5  0x000215c8 in _Thread_queue_Dequeue
>      >     (the_thread_queue=0x4198c)
>      > ---Type <return> to continue, or q <return> to quit---
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/score/src/threadqdequeue.c:51
>      > #6  0x00017c14 in _CORE_semaphore_Surrender (the_semaphore=0x4198c,
>      >     id=436273153,
>      >     api_semaphore_mp_support=0x0)
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/score/src/coresemsurrender.c:37
>      > #7  0x00014868 in rtems_semaphore_release (id=436273153)
>      >     at ../../../../../../rtems/c/src/../../cpukit/rtems/src/semrelease.c:102
>      > #8  0x00026cfc in rtems_libio_unlock ()
>      >     at ../../cpukit/../../../or1ksim/lib/include/rtems/libio_.h:253
>      > #9  0x00026d5c in rtems_filesystem_default_unlock (mt_entry=0x49ce0)
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/libfs/src/defaults/default_loc---Type
>      > k_and_unlock.c:39
>      > #10 0x0002920c in rtems_filesystem_instance_unlock (loc=0x49c5c)
>      >     at ../../cpukit/../../../or1ksim/lib/include/rtems/libio_.h:292
>      > #11 0x00029268 in rtems_filesystem_location_free (loc=0x49c5c)
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/freenode.c:29
>      > #12 0x00029734 in rtems_libio_free (
>      >     iop=0x49c50)
>      >     at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/libio.c:136
>      > #13 0x0002912c in close (fd=0)
>      >     at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/close.c:38
>      > #14 0x000064b0 in rtems_libio_exit ()
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/libio_exit.c:31
>      > #15 0x0003b058 in _exit (status=0)
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:46
>      > #16 0x00034798 in exit (code=0)
>      >     at ../../../../../gcc-4.8.3/newlib/libc/stdlib/exit.c:70
>      > #17 0x00002e3c in Test_task (unused=1)
>      >     at
>     ../../../../../../../rtems/c/src/../../testsuites/samples/ticker/tasks.c:41
>      > #18 0x000340f0 in _Thread_Handler ()
>      >     at
>     ../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:192
>      > #19 0x00034078 in _User_extensions_Thread_exitted (executing=0x40890)
>      >     at
>     ../../cpukit/../../../or1ksim/lib/include/rtems/score/userextimpl.h:243
>      > Backtrace stopped: frame did not save the PC
>      > (gdb)
>      > It breaks at _RBTree_Next specifically at the following line:
>      >  while ( ( current = current->child[ opp_dir ] ) != NULL )
>      > (gdb) p current->child[ opp_dir ]
>      > Cannot access memory at address 0xa010006
>      > (gdb) p current
>      > $1 = (RBTree_Node *) 0xa010002
>     These look like object ids.
>     > This address is invalid, the current memory length should be only 32
>     > MB (0x2000000)
>     >http://git.rtems.org/rtems/tree/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds#n20
>     > So I guest current->child is overwritten somehow?
>     Yep.  Two approaches.
>     + Set a watchpoint in gdb if it is supported. But even if supported,
>     it will likely slow the run tremendously.
> There is no HW watchpoint supported.
>     + Break selectively and more or less binary search for where it is
>     overwritten.  I would break at the first call to _ISR_Dispatch
>     (or whatever you called it) and see if it gets clobbered.
>     That could be clobbered VERY early in the program. It could be
>     a blown stack. But it could just be a stray write. Check the value
>     of that semaphore's rbtree when you get to Init and just
>     break periodically and see where it is corrupt.
> That's what I did. As you assumed, it's clobbered very early.
> Breakpoint 1, _Objects_Extend_information (
>      information=0x3e26c <_RTEMS_tasks_Information>)
>      at
> ../../../../../../rtems/c/src/../../cpukit/score/src/objectextendinformation.c:67
> 67 do_extend     = true;
> (gdb) bt
> #0  _Objects_Extend_information (
>      at
> #1  0x0001b554 in _Objects_Initialize_information (
>      information=0x3e26c <_RTEMS_tasks_Information>,
>      the_api=OBJECTS_CLASSIC_API, the_class=1, maximum=4,
>      size=1424, is_string=false, maximum_name_length=4)
>      at
> ../../../../../../rtems/c/src/../../cpukit/score/src/objectinitializeinformation.c:126
> #2  0x0002c688 in _RTEMS_tasks_Manager_initialization ()
>      at ../../../../../../rtems/c/src/../../cpukit/rtems/src/tasks.c:197
> #3  0x00015bd4 in _RTEMS_API_Initialize ()
>      at ../../../../../../rtems/c/src/../../cpukit/sapi/src/rtemsapi.c:59
> #4  0x0001590c in rtems_initialize_data_structures ()
>      at ../../../../../../rtems/c/src/../../cpukit/sapi/src/exinit.c:140
> #5  0x0000333c in boot_card (cmdline=0x0)
>      at
> ../../../../../../../../rtems/c/src/lib/libbsp/or1k/or1ksim/../../shared/bootcard.c:92
> #6  0x00000000 in ?? ()
> (gdb)
> Specifically, here
> http://git.rtems.org/rtems/tree/cpukit/score/src/objectextendinformation.c#n261
I think this is the first time it is initialized. What's the next time
it is modified?
But this looking like task manager class information and not a semaphore
like the crash so this is odd. :(
>     I cc'ed Gedare because I don't know how to spot that the rbtree
>     is empty in gdb.
>     You need to see where that memory is overwritten.
>     Again running all tests with the simulator clock tick could
>     eliminate the ISR code as the culprit. :)
>      > On Tue, Sep 16, 2014 at 9:21 PM, Joel Sherrill
>      > <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>      >> On 9/16/2014 2:17 PM, Hesham Moustafa wrote:
>      >>> On Tue, Sep 16, 2014 at 8:42 PM, Joel Sherrill
>      >>>> On 9/16/2014 1:34 PM, Hesham Moustafa wrote:
>      >>>>> On Tue, Sep 16, 2014 at 8:15 PM, Joel Sherrill
>      >>>>>> On 9/16/2014 12:54 PM, Hesham Moustafa wrote:
>      >>>>>>> Hi
>      >>>>>>> On Tue, Sep 16, 2014 at 7:47 PM, Joel Sherrill
>      >>>>>>>> I don't understand this but I got it applied.
>      >>>>>>>> I manually edited the saved email to delete the preinstall.am
>     <http://preinstall.am>
>      >>>>>>>> changes.  I committed the rest. Then I ran bootstrap -p myself
>      >>>>>>>> and folded that into the rest of your patch.
>      >>>>>>>> It should all be committed now.
>      >>>>>>> Thanks for doing this, me too do not know what's wrong. BTW, commits
>      >>>>>>> are not mirrored on github since 4 days ago.
>      >>>>>>>> How about some new test results. :)
>      >>>>>>> I did run one last night, no big progress since previous results :( Is
>      >>>>>>> there any tool, script, utility program or whatever that I can use to
>      >>>>>>> detect wrong memory access (i.e, stack overwrite, heap corruption,
>      >>>>>>> access to another task context)? I tried to add -fstack-protector-all
>      >>>>>>> to gcc, but QEMU did not get anything or core-dump, ticker just hangs.
>      >>>>>> I haven't checked into how gcc does its stack overwrite protection.
>      >>>>>> The tests by themselves don't have these problems. The first
>      >>>>>> possible source is incorrect layout of sections to memory by
>      >>>>>> the linker script. There is some debug code in boot
>      >>>>>> There used to be debug printk's in bspgetworkarea.c so you
>      >>>>>> could check if areas overlapped. That usually causes bad issues
>      >>>>>> though. Let's go through some basics:
>      >>>>>> + Does hello world run and exit cleanly?
>      >>>>> The output of Hello World is:
>      >>>>> *** BEGIN OF TEST HELLO WORLD ***
>      >>>>> Hello World
>      >>>>> *** END OF TEST HELLO WORLD ***
>      >>>>> Fatal Error 5.0 Halted
>      >>>>>   From GDB:
>      >>>>> Breakpoint 1, _Terminate (
>      >>>>>       the_source=RTEMS_FATAL_SOURCE_EXIT, is_internal=false,
>      >>>>> the_error=0)
>      >>>>>       at
>      >>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:39
>      >>>>> 39  _ISR_Disable_without_giant( level );
>      >>>>> (gdb) bt
>      >>>>> #0  _Terminate (
>      >>>>> the_error=0)
>      >>>>>       at
>      >>>>> #1  0x0003b5f8 in rtems_shutdown_executive (result=0)
>      >>>>>       at
>      >>>>> ../../../../../../rtems/c/src/../../cpukit/sapi/src/exshutdown.c:21
>      >>>>> #2  0x0003b350 in _exit (status=0)
>      >>>>>       at
>     ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:47
>      >>>>> #3  0x0002cc30 in exit (code=0)
>      >>>>> #4  0x00002184 in Init (ignored=253816)
>      >>>>>       at
>      >>>>> ../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:33
>      >>>>> #5  0x0002c5b8 in _Thread_Handler ()
>      >>>>>       at
>      >>>>> #6  0x0002c540 in _User_extensions_Thread_exitted (executing=0x40080)
>      >>>>>       at
>      >>>> This is normal and OK. Look at the arguments to _Terminate.
>      >>>>>> + How far does ticker get?
>      >>>>> Ticker goes to the end:
>      >>>>> *** BEGIN OF TEST CLOCK TICK ***
>      >>>>> TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
>      >>>>> TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
>      >>>>> TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
>      >>>>> TA1  - rtems_clock_get_tod - 09:00:05   12/31/1988
>      >>>>> TA2  - rtems_clock_get_tod - 09:00:10   12/31/1988
>      >>>>> TA1  - rtems_clock_get_tod - 09:00:10   12/31/1988
>      >>>>> TA3  - rtems_clock_get_tod - 09:00:15   12/31/1988
>      >>>>> TA1  - rtems_clock_get_tod - 09:00:15   12/31/1988
>      >>>>> TA2  - rtems_clock_get_tod - 09:00:20   12/31/1988
>      >>>>> TA1  - rtems_clock_get_tod - 09:00:20   12/31/1988
>      >>>>> TA1  - rtems_clock_get_tod - 09:00:25   12/31/1988
>      >>>>> TA3  - rtems_clock_get_tod - 09:00:30   12/31/1988
>      >>>>> TA2  - rtems_clock_get_tod - 09:00:30   12/31/1988
>      >>>>> TA1  - rtems_clock_get_tod - 09:00:30   12/31/1988
>      >>>>> *** END OF TEST CLOCK TICK ***
>      >>>>> Fatal Error 9.276564 Halted
>      >>>>>   From GDB:
>      >>>>> (gdb) break _Terminate
>      >>>>> Breakpoint 1 at 0x19a68: file
>      >>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c, line
>      >>>>> 39.
>      >>>>> (gdb) break _OR1K_Exception_default
>      >>>>> Breakpoint 2 at 0x2686c: file
>     ../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c,
>      >>>>> line 22.
>      >>>>> (gdb) c
>      >>>>> The program is not being run.
>      >>>>> (gdb) target remote :50001
>      >>>>> Remote debugging using :50001
>      >>>>> 0x00000100 in _reset ()
>      >>>>> (gdb) c
>      >>>>> Continuing.
>      >>>>> Breakpoint 2, _OR1K_Exception_default (vector=6, frame=0x43854) at
>     ../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c:22
>      >>>>> 22  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame
>      >>>>> (gdb) bt
>      >>>>> #0  _OR1K_Exception_default (vector=6, frame=0x43854) at
>      >>>>> #1  0x00026980 in jump_to_c_handler ()
>      >>>>> vector 6 is _unalign exception.
>      >>>> Set a break point at exit() (I think) and rtems_shutdown_executive(). You
>      >>>> could start in the task which calls whatever kicks off the shutdown
>      >>>> sequence.
>      >>>> It looks like something in the shutdown procedure trips over something.
>      >>>> This might be easy to debug.
>      >>> I did add just a function call to _CPU_Exception_frame_print(frame);
>      >>>   from _OR1K_Exception_default(uint32_t vector, CPU_Exception_frame
>      >>> *frame)
>      >>> And ticker exits normally without even entering
>      >>> _OR1K_Exception_defaul as it did before. This is very weird. Does this
>      >>> mean that some areas of the code are overlapped from the linker
>      >>> script?
>      >> I doubt it. I suspect something unitialized or not aligned properly.
>      >> Set a breakpoint at
>      >> http://git.rtems.org/rtems/tree/testsuites/samples/ticker/tasks.c#n40
>      >> next over the print and then step through rtems_test_exit() and see
>      >> where it faults.
>      >>>> If the fault address is in the exception data, you can map that back to
>      >>>> the
>      >>>> nm file and see what file that was in, then that might help.
>      >>>>>> + Have you tried the trick I suggested earlier to disable the
>      >>>>>> real clock tick driver, use the simulator idle tick code, and
>      >>>>>> disable all the tests that are known to fail that way. This
>      >>>>>> will eliminate the ISR code as an issue because you won't
>      >>>>>> have any (if console output if polled).  See h8sim for
>      >>>>>> an example. Should be a Makefile.am change, adding
>      >>>>>> an include to the testsuite configuration file, building
>      >>>>>> and running.
>      >> Joel Sherrill, Ph.D.             Director of Research & Development
>      >> joel.sherrill at OARcorp.com        On-Line Applications Research
>      >> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>      >> Support Available                (256) 722-9985
