[PATCH] RTEMS: Add -lz and -lm to LIB_SPECS
Sebastian Huber
Thu Sep 18 13:22:11 UTC 2014
RTEMS core libraries depend on libz and libm. This patch should be
applied to all open GCC branches.
gcc/ChangeLog
2014-09-18 Sebastian Huber <sebastian.huber at embedded-brains.de>
* config/rtems.h (LIB_SPECS): Add -lz and -lm to qrtems.
gcc/config/rtems.h | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/gcc/config/rtems.h b/gcc/config/rtems.h
index 4d94f82..5ecab01 100644
--- a/gcc/config/rtems.h
+++ b/gcc/config/rtems.h
@@ -40,6 +40,6 @@ along with GCC; see the file COPYING3. If not see
#define LIB_SPEC "%{!qrtems: " STD_LIB_SPEC "} " \
"%{!nostdlib: %{qrtems: --start-group \
-lrtemsbsp -lrtemscpu \
- -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
+ -lz -lm -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
#define TARGET_POSIX_IO
1.8.4.5
