[PATCH] RTEMS: Update contrib/config-list.mk
Thu Sep 18 15:27:24 UTC 2014
I committed this to 4.9 and head.
Sebastian.. please double check that it is OK please.
I had some issues with applying it to the head and
manually did it.
--joel
On 9/17/2014 8:37 AM, Sebastian Huber wrote:
> contrib/ChangeLog
> 2014-09-17  Sebastian Huber  <sebastian.huber at embedded-brains.de>
> 	* config-list.mk (LIST): Add arm-rtems.
> 	Add nios2-rtems.  Remove extra option from powerpc-rtems.
>  contrib/config-list.mk | 6 +++---
>  1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/contrib/config-list.mk b/contrib/config-list.mk
> index 4345487..056fbf0 100644
> --- a/contrib/config-list.mk
> +++ b/contrib/config-list.mk
> @@ -17,7 +17,7 @@ LIST = aarch64-elf aarch64-linux-gnu \
>    arc-elf32OPT-with-cpu=arc600 arc-elf32OPT-with-cpu=arc700 \
>    arc-linux-uclibcOPT-with-cpu=arc700 arceb-linux-uclibcOPT-with-cpu=arc700 \
>    arm-wrs-vxworks arm-netbsdelf \
> -  arm-linux-androideabi arm-uclinux_eabi arm-eabi \
> +  arm-linux-androideabi arm-uclinux_eabi arm-eabi arm-rtems \
>    arm-symbianelf avr-rtems avr-elf \
>    bfin-elf bfin-uclinux bfin-linux-uclibc bfin-rtems bfin-openbsd \
>    c6x-elf c6x-uclinux cr16-elf cris-elf cris-linux crisv32-elf crisv32-linux \
> @@ -48,13 +48,13 @@ LIST = aarch64-elf aarch64-linux-gnu \
>    moxie-uclinux moxie-rtems \
>    msp430-elf \
>    nds32le-elf nds32be-elf \
> -  nios2-elf nios2-linux-gnu \
> +  nios2-elf nios2-linux-gnu nios2-rtems \
>    pdp11-aout picochip-elfOPT-enable-obsolete \
>    powerpc-darwin8 \
>    powerpc-darwin7 powerpc64-darwin powerpc-freebsd6 powerpc-netbsd \
>    powerpc-eabispe powerpc-eabisimaltivec powerpc-eabisim ppc-elf \
>    powerpc-eabialtivec powerpc-xilinx-eabi powerpc-eabi \
> -  powerpc-rtems4.11OPT-enable-threads=yes powerpc-linux_spe \
> +  powerpc-rtems powerpc-linux_spe \
>    powerpc-linux_paired powerpc64-linux_altivec \
>    powerpc-wrs-vxworks powerpc-wrs-vxworksae powerpc-lynxos powerpcle-elf \
>    powerpcle-eabisim powerpcle-eabi rs6000-ibm-aix4.3 rs6000-ibm-aix5.1.0 \
