[PATCH] bsp/tms570: implemented and tested initialization of Cortex-R performance counters.
Daniel Gutson
daniel.gutson at tallertechnologies.com
Thu Sep 18 16:08:04 UTC 2014
Hi folks,
could you please give us an update of the shape of this BSP?
There's a project that uses the TMS570, and I'd like to convince some
people to move to RTEMS. How far do you consider the BSP is from the
"industrial" status?
I don't see much progress details in its wiki, such as stability and
drivers status.
Thanks!
Daniel.
On Fri, Aug 22, 2014 at 12:25 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Pushed.
> Followups can just be subsequent patches.
> On 8/22/2014 10:20 AM, Pavel Pisa wrote:
>> The code is written as BSP specific now but it should work for all
>> Cortex-A and R based CPUs and can be moved to ARM generic place in future.
>> StackOverflow suggested sequences of writes to the registers required
>> to start counters is used.
>> http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
>> c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c | 88 +++++++++++++++++++++--
>> 1 file changed, 84 insertions(+), 4 deletions(-)
>> diff --git a/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c b/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
>> index f25380c..3ce2f63 100644
>> --- a/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
>> +++ b/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
>> @@ -3,7 +3,14 @@
>> * @ingroup tms570_clocks
>> - * @brief System clocks.
>> + * @brief Cortex-R performace counters
>> + * The counters setup functions are these which has been suggested
>> + * on StackOverflow
>> + * Code is probably for use on Cortex-A without modifications as well.
>> + * http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
>> @@ -14,9 +21,6 @@
>> * 166 36 Praha 6
>> * Czech Republic
>> - * Based on LPC24xx and LPC1768 BSP
>> - * by embedded brains GmbH and others
>> * The license and distribution terms for this file may be
>> * found in the file LICENSE in this distribution or at
>> * http://www.rtems.org/license/LICENSE.
>> @@ -27,6 +31,79 @@
>> #include <rtems.h>
>> #include <bsp.h>
>> +static int cpu_counter_initialized;
>> + * @brief set mode of Cortex-R performance counters
>> + * Based on example found on http://stackoverflow.com
>> + * @param[in] do_reset if set, values of the counters are reset
>> + * @param[in] enable_divider if set, CCNT counts clocks divided by 64
>> + * @retval Void
>> +static inline void _CPU_Counter_init_perfcounters(
>> + int32_t do_reset,
>> + int32_t enable_divider
>> + /* in general enable all counters (including cycle counter) */
>> + int32_t value = 1;
>> + /* peform reset */
>> + if (do_reset)
>> + value |= 2; /* reset all counters to zero */
>> + value |= 4; /* reset cycle counter to zero */
>> + if (enable_divider)
>> + value |= 8; /* enable "by 64" divider for CCNT */
>> + value |= 16;
>> + /* program the performance-counter control-register */
>> + asm volatile ("mcr p15, 0, %0, c9, c12, 0\t\n" :: "r"(value));
>> + /* enable all counters */
>> + asm volatile ("mcr p15, 0, %0, c9, c12, 1\t\n" :: "r"(0x8000000f));
>> + /* clear overflows */
>> + asm volatile ("mcr p15, 0, %0, c9, c12, 3\t\n" :: "r"(0x8000000f));
>> + * @brief initialize Cortex-R performance counters subsystem
>> + * @retval Void
>> +static void _CPU_Counter_initialize(void)
>> + rtems_interrupt_level level;
>> + rtems_interrupt_disable(level);
>> + if ( cpu_counter_initialized ) {
>> + rtems_interrupt_enable(level);
>> + return;
>> + /* enable user-mode access to the performance counter */
>> + asm volatile ("mcr p15, 0, %0, c9, c14, 0\n\t" :: "r"(1));
>> + /* disable counter overflow interrupts (just in case) */
>> + asm volatile ("mcr p15, 0, %0, c9, c14, 2\n\t" :: "r"(0x8000000f));
>> + _CPU_Counter_init_perfcounters(false, false);
>> + cpu_counter_initialized = 1;
>> * @brief returns the actual value of Cortex-R cycle counter register
>> @@ -39,6 +116,9 @@
>> CPU_Counter_ticks _CPU_Counter_read(void)
>> uint32_t ticks;
>> + if ( !cpu_counter_initialized ) {
>> + _CPU_Counter_initialize();
>> asm volatile ("mrc p15, 0, %0, c9, c13, 0\n": "=r" (ticks));
>> return ticks;
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> devel mailing list
> devel at rtems.org
Daniel F. Gutson
Chief Engineering Officer, SPD
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211
Skype: dgutson
