[stm32f4] status of the bsp
Tomasz Gregorek
tomasz.gregorek at gmail.com
Fri Sep 19 07:43:36 UTC 2014
Hi Chris
Yes, I am very interested.
I guess you have interrupts working there?
Do you mind your code or work based on it to end up under RTEMS licence on
the git repository?
Thanks
2014-09-19 6:00 GMT+02:00 Chris Nott <chrisn at vl.com.au>:
> Hi, I was fiddling with this platform and got as far as a project
> implementing a USB device. If you are interested I could send you the code.
> It hasn't been touched for a while, it may or may not have bit rot.
> Sent with AquaMail for Android
> http://www.aqua-mail.com
> On 18 September 2014 12:12:21 Tomasz Gregorek <tomasz.gregorek at gmail.com>
> wrote:
>> Hello
>> I am interested in development of the stm32f4 bsp.
>> We have small project based on the STM32F429 MCPU which we would like to
>> run RTEMS on.
>> From the current code one could say there is not much. Only UART in
>> polling, started I2C, some defines and few registers descriptions,
>> interrupts just touched.
>> Is anyone working on this so I would not double the work?
>> What is current status of the work?
>> Who can I contact for some initial information about bsps?
>> Still a lot of reading to do...
>> Best regards
>> Tomasz
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140919/1c8c174f/attachment-0001.html>
