or1ksim: Updated results from RTEMS Tester
Hesham Moustafa heshamelmatary at gmail.com
Fri Sep 19 14:56:29 UTC 2014
Hi,
I run another test for or1ksim BSP yesterday via RTEMS Tester and got the
following results:
Passed:   432
Failed:     4
Timeouts:  67
Invalid:    0
Total:    503
Average test time: 0:00:23.380789
Testing time     : 3:16:00.537058
However, when I tested failures and timeouts separately, most of them work
on QEMU, the others miss the trailing end-of-test line, which exists when I
run them on or1ksim simulator.
By running the other failed, timed-outs tests separately (on both qemu and
or1ksim) and re-calculating the previous test results, I got the following:
Passed:   496
Failed:     0
Timeouts:  7
Invalid:    0
Total:    503
List of failures/timeouts (on both qemu and or1ksim) with their output:
______________________________
sptls01.exe
*** BEGIN OF TEST SPTLS 1 ***
Fatal Error 5.1 Halted
Note: TLS is not supported yet.
spintrcritical20.exe
*** BEGIN OF TEST SPINTRCRITICAL 20 ***
../../../../../../../rtems/c/src/../../testsuites/sptests/spintrcritical20/init.c:
146 ctx->thread_queue_was_null
Fatal Error 5.0 Halted
sp37.exe
*** BEGIN OF TEST SP 37 ***
../../../../../../../rtems/c/src/../../testsuites/sptests/sp37/init.c: 113
ctx.actual_level == current
psxconfig01.exe
*** BEGIN OF TEST PSXCONFIG 1 ***
used blocks = 50, largest used block = 16464, used space = 90760
free blocks = 1, largest free block = 91216, free space = 91216
rtems_partition_create FAILED -- expected (RTEMS_SUCCESSFUL) got
(RTEMS_INVALID_ADDRESS)
Fatal Error 5.9 Halted
fsfseeko01.exe
*** BEGIN OF TEST FSFSEEKO 1 ***
../../../../../../../rtems/c/src/../../testsuites/fstests/fsfseeko01/init.c:
67 actual_long_off == -1L
sp20.exe
*** BEGIN OF TEST SP 20 ***
TA1 - rtems_rate_monotonic_create id = 0x42010001
TA1 - rtems_rate_monotonic_ident id = 0x42010001
TA1 - (0x42010001) period 2
TA2 - rtems_rate_monotonic_create id = 0x42010002
TA2 - rtems_rate_monotonic_ident id = 0x42010002
TA2 - (0x42010002) period 2
TA3 - rtems_rate_monotonic_create id = 0x42010003
TA3 - rtems_rate_monotonic_ident id = 0x42010003
TA3 - (0x42010003) period 2
TA4 - rtems_rate_monotonic_create id = 0x42010004
TA4 - rtems_rate_monotonic_ident id = 0x42010004
TA4 - (0x42010004) period 2
TA5 - rtems_rate_monotonic_create id = 0x42010005
TA5 - rtems_rate_monotonic_ident id = 0x42010005
TA5 - (0x42010005) period 100
TA6 - rtems_rate_monotonic_create id = 0x42010006
TA6 - rtems_rate_monotonic_ident id = 0x42010006
TA6 - (0x42010006) period 0
TA5 - PERIODS CHECK OK (1)
TA5 - PERIODS CHECK OK (2)
TA5 - PERIODS CHECK OK (3)
TA5 - PERIODS CHECK OK (4)
TA5 - PERIODS CHECK OK (5)
TA6 - Actual: 10 Expected: 10 - OK
TA6 - Actual: 20 Expected: 20 - OK
TA6 - Actual: 30 Expected: 30 - OK
TA6 - Actual: 40 Expected: 40 - OK
TA6 - Actual: 50 Expected: 50 - OK
TA6 - Actual: 60 Expected: 60 - OK
TA6 - Actual: 70 Expected: 70 - OK
TA6 - Actual: 80 Expected: 80 - OK
TA6 - Actual: 90 Expected: 90 - OK
TA6 - Actual: 100 Expected: 100 - OK
rtems_rate_monotonic_period FAILED -- expected (RTEMS_SUCCESSFUL) got
(RTEMS_TIMEOUT)
Fatal Error 5.6 Halted
spintrcritical21.exe
*** BEGIN OF TEST SPINTRCRITICAL 21 ***
Event sent from ISR hitting synchronization point has NOT occurred
../../../../../../../rtems/c/src/../../testsuites/sptests/spintrcritical21/init.c:
147 case_hit
Notes:
spcontext01.exe should not return if the context validate works properly,
so it should be always timed-out.
minimum.exe should not give any output, but it's considered from time-out
Hope this is a good state of the port.
Regards,
Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140919/65128cd6/attachment.html>
