[stm32f4] status of the bsp
Chris Nott
chrisn at vl.com.au
Fri Sep 19 16:26:54 UTC 2014
Interrupts working yes.
No I don't mind. It's a bit of a mess though, I was in the process of doing
another cleaner USB device implementation for BeagleBone Black, which I was
then going to backport to STM32F4 and eventually maybe work towards some
sort of general RTEMS USB device framework.
Actually I got the BB black code enumerating as well, I just ran out of
time to work on it.
I'll send the STM32 project to you soon, I will be travelling for the next
week so if I don't get a chance tonight it will probably be in a week or so.
Regards,
Chris.
Sent with AquaMail for Android
http://www.aqua-mail.com
On 19 September 2014 00:43:59 Tomasz Gregorek <tomasz.gregorek at gmail.com>
wrote:
> Hi Chris
> Yes, I am very interested.
> I guess you have interrupts working there?
> Do you mind your code or work based on it to end up under RTEMS licence on
> the git repository?
> Thanks
> 2014-09-19 6:00 GMT+02:00 Chris Nott <chrisn at vl.com.au>:
> > Hi, I was fiddling with this platform and got as far as a project
> > implementing a USB device. If you are interested I could send you the code.
> > It hasn't been touched for a while, it may or may not have bit rot.
> > On 18 September 2014 12:12:21 Tomasz Gregorek <tomasz.gregorek at gmail.com>
> > wrote:
> >> Hello
> >> I am interested in development of the stm32f4 bsp.
> >> We have small project based on the STM32F429 MCPU which we would like to
> >> run RTEMS on.
> >> From the current code one could say there is not much. Only UART in
> >> polling, started I2C, some defines and few registers descriptions,
> >> interrupts just touched.
> >> Is anyone working on this so I would not double the work?
> >> What is current status of the work?
> >> Who can I contact for some initial information about bsps?
> >> Still a lot of reading to do...
> >> Best regards
> >> Tomasz
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140919/57e86f19/attachment-0001.html>
