[stm32f4] status of the bsp
Tomasz Gregorek
tomasz.gregorek at gmail.com
Fri Sep 19 16:43:03 UTC 2014
2014-09-19 18:37 GMT+02:00 Gedare Bloom <gedare at rtems.org>:
> On Fri, Sep 19, 2014 at 12:26 PM, Chris Nott <chrisn at vl.com.au> wrote:
> > Interrupts working yes.
> > No I don't mind. It's a bit of a mess though, I was in the process of
> doing
> > another cleaner USB device implementation for BeagleBone Black, which I
> was
> > then going to backport to STM32F4 and eventually maybe work towards some
> > sort of general RTEMS USB device framework.
> There is some support for USB in the BSD stack which is probably the
> best place to put efforts toward improving. I don't personally know
> the state of USB there.
> That's a good idea.
Thanks Gedare
(PS. sending with rtems-devel)
> > Actually I got the BB black code enumerating as well, I just ran out of
> time
> > to work on it.
> > I'll send the STM32 project to you soon, I will be travelling for the
> next
> > week so if I don't get a chance tonight it will probably be in a week or
> so.
> > Regards,
> > Chris.
> > Sent with AquaMail for Android
> > http://www.aqua-mail.com
> > On 19 September 2014 00:43:59 Tomasz Gregorek <tomasz.gregorek at gmail.com
> > wrote:
> >> Hi Chris
> >> Yes, I am very interested.
> >> I guess you have interrupts working there?
> >> Do you mind your code or work based on it to end up under RTEMS licence
> on
> >> the git repository?
> >> Thanks
> >> 2014-09-19 6:00 GMT+02:00 Chris Nott <chrisn at vl.com.au>:
> >>> Hi, I was fiddling with this platform and got as far as a project
> >>> implementing a USB device. If you are interested I could send you the
> code.
> >>> It hasn't been touched for a while, it may or may not have bit rot.
> >>> On 18 September 2014 12:12:21 Tomasz Gregorek <
> tomasz.gregorek at gmail.com>
> >>> wrote:
> >>>> Hello
> >>>> I am interested in development of the stm32f4 bsp.
> >>>> We have small project based on the STM32F429 MCPU which we would like
> to
> >>>> run RTEMS on.
> >>>> From the current code one could say there is not much. Only UART in
> >>>> polling, started I2C, some defines and few registers descriptions,
> >>>> interrupts just touched.
> >>>> Is anyone working on this so I would not double the work?
> >>>> What is current status of the work?
> >>>> Who can I contact for some initial information about bsps?
> >>>> Still a lot of reading to do...
> >>>> Best regards
> >>>> Tomasz
> >>>> _______________________________________________
> >>>> devel mailing list
> >>>> devel at rtems.org
> >>>> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140919/6fdaaed3/attachment.html>
