[PATCH] bsp:stm32f4XXXX system clock configuration
Tomasz Gregorek tomasz.gregorek at gmail.com
Sat Sep 20 18:20:44 UTC 2014
sorry, ignore this one.
2014-09-20 20:15 GMT+02:00 <tomasz.gregorek at gmail.com>:
> From: Tomasz Gregorek <tomasz.gregorek at gmail.com>
> Added simple math to caclulate register values for the PLL
> and for the prescalers. It will try to keep 48MHz for the USB OTG FS.
> Also it will slow down Flash memory for the high speeds.
>  c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h     |  10 +
>  .../libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h |  45 +++++
>  .../libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h   |  94 +++++++++
>  c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c    | 211
>  4 files changed, 360 insertions(+)
>  create mode 100644
> c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> index 59d13ef..d26f914 100644
> --- a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> +++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> @@ -55,6 +55,16 @@
> + * @name STM32F4XXXX FLASH
> +#include <bsp/stm32f4xxxx_flash.h>
> +#define STM32F4_FLASH ((volatile stm32f4_flash *) (STM32F4_BASE +
> 0x40023C00))
>  #include <bsp/stm32_i2c.h>
> diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> new file mode 100644
> index 0000000..ed08d76
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h
> @@ -0,0 +1,45 @@
> + * @file
> + * @ingroup stm32f4_flash
> + * @brief STM32F4XXXX FLASH support.
> + * Copyright (c) 2012 Sebastian Huber.  All rights reserved.
> + *  embedded brains GmbH
> + *  Obere Lagerstr. 30
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
> +#define LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H
> +#include <bsp/utility.h>
> + * @defgroup stm32f10xxx_flash STM32F4XXXX FLASH Support
> + * @brief STM32F4FXXX FLASH Support
> +typedef struct {
> +       uint32_t acr;
> +       uint32_t keyr;
> +       uint32_t optkeyr;
> +       uint32_t sr;
> +       uint32_t cr;
> +       uint32_t optcr;
> +       uint32_t optcr1;
> +} stm32f4_flash;
> +#endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_FLASH_H */
> diff --git a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> index 8126340..ce85b8e 100644
> --- a/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> +++ b/c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h
> @@ -56,4 +56,98 @@ typedef struct {
> +#define RCC_CR_HSION      BSP_BIT32(0)
> +#define RCC_CR_HSIRDY     BSP_BIT32(1)
> +#define RCC_CR_HSITRIM    3
> +#define RCC_CR_HSICAL     8
> +#define RCC_CR_HSEON      BSP_BIT32(16)
> +#define RCC_CR_HSERDY     BSP_BIT32(17)
> +#define RCC_CR_HSEBYP     BSP_BIT32(18)
> +#define RCC_CR_CSSON      BSP_BIT32(19)
> +#define RCC_CR_PLLON      BSP_BIT32(24)
> +#define RCC_CR_PLLRDY     BSP_BIT32(25)
> +#define RCC_CR_PLLI2SON   BSP_BIT32(26)
> +#define RCC_CR_PLLI2SRDY  BSP_BIT32(27)
> +#define RCC_PLLCFGR_PLLM    0
> +#define RCC_PLLCFGR_PLLN    6
> +#define RCC_PLLCFGR_PLLP    16
> +#define RCC_PLLCFGR_PLLSRC_HSE BSP_BIT32(22)
> +#define RCC_PLLCFGR_PLLSRC_HSI 0
> +#define RCC_PLLCFGR_PLLQ     24
> +#define RCC_CFGR_SW          0
> +#define RCC_CFGR_SW_MASK     3
> +#define RCC_CFGR_SW_HSI      0
> +#define RCC_CFGR_SW_HSE      1
> +#define RCC_CFGR_SW_PLL      2
> +#define RCC_CFGR_SWS         2
> +#define RCC_CFGR_SWS_MASK    (3 << RCC_CFGR_SWS)
> +#define RCC_CFGR_SWS_HSI     0
> +#define RCC_CFGR_SWS_HSE     (1 << RCC_CFGR_SWS)
> +#define RCC_CFGR_SWS_PLL     (2 << RCC_CFGR_SWS)
> +#define RCC_CFGR_HPRE        4
> +#define RCC_CFGR_HPRE_BY_1     0
> +#define RCC_CFGR_HPRE_BY_2   ( 8 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_HPRE_BY_4   ( 9 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_HPRE_BY_8   (10 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_HPRE_BY_16  (11 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_HPRE_BY_64  (12 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_HPRE_BY_128 (13 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_HPRE_BY_256 (14 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_HPRE_BY_512 (15 << RCC_CFGR_HPRE)
> +#define RCC_CFGR_PPRE1        10
> +#define RCC_CFGR_PPRE1_BY_1   0
> +#define RCC_CFGR_PPRE1_BY_2   (4 << RCC_CFGR_PPRE1)
> +#define RCC_CFGR_PPRE1_BY_4   (5 << RCC_CFGR_PPRE1)
> +#define RCC_CFGR_PPRE1_BY_8   (6 << RCC_CFGR_PPRE1)
> +#define RCC_CFGR_PPRE1_BY_16  (7 << RCC_CFGR_PPRE1)
> +#define RCC_CFGR_PPRE2        13
> +#define RCC_CFGR_PPRE2_BY_1   0
> +#define RCC_CFGR_PPRE2_BY_2   (4 << RCC_CFGR_PPRE2)
> +#define RCC_CFGR_PPRE2_BY_4   (5 << RCC_CFGR_PPRE2)
> +#define RCC_CFGR_PPRE2_BY_8   (6 << RCC_CFGR_PPRE2)
> +#define RCC_CFGR_PPRE2_BY_16  (7 << RCC_CFGR_PPRE2)
> +#define RCC_CFGR_RTCPRE       16
> +#define RCC_CFGR_RTCPRE_SET(a) (a << RCC_CFGR_RTCPRE)
> +#define RCC_CFGR_MCO1          21
> +#define RCC_CFGR_MCO1_HSI      0
> +#define RCC_CFGR_MCO1_LSE      (1 << RCC_CFGR_MCO1)
> +#define RCC_CFGR_MCO1_HSE      (2 << RCC_CFGR_MCO1)
> +#define RCC_CFGR_MCO1_PLL      (3 << RCC_CFGR_MCO1)
> +#define RCC_CFGR_I2SSRC         BSP_BIT32(23)
> +#define RCC_CFGR_MCO1PRE        24
> +#define RCC_CFGR_MCO1PRE_BY_1   0
> +#define RCC_CFGR_MCO1PRE_BY_2   (4 << RCC_CFGR_MCO1PRE)
> +#define RCC_CFGR_MCO1PRE_BY_3   (5 << RCC_CFGR_MCO1PRE)
> +#define RCC_CFGR_MCO1PRE_BY_4   (6 << RCC_CFGR_MCO1PRE)
> +#define RCC_CFGR_MCO1PRE_BY_5   (7 << RCC_CFGR_MCO1PRE)
> +#define RCC_CFGR_MCO2PRE        27
> +#define RCC_CFGR_MCO2PRE_BY_1   0
> +#define RCC_CFGR_MCO2PRE_BY_2   (4 << RCC_CFGR_MCO2PRE)
> +#define RCC_CFGR_MCO2PRE_BY_3   (5 << RCC_CFGR_MCO2PRE)
> +#define RCC_CFGR_MCO2PRE_BY_4   (6 << RCC_CFGR_MCO2PRE)
> +#define RCC_CFGR_MCO2PRE_BY_5   (7 << RCC_CFGR_MCO2PRE)
> +#define RCC_CFGR_MCO2           30
> +#define RCC_CFGR_MCO2_SYSCLK    0
> +#define RCC_CFGR_MCO2_PLLI2S    (1 << RCC_CFGR_MCO2)
> +#define RCC_CFGR_MCO2_HSE       (2 << RCC_CFGR_MCO2)
> +#define RCC_CFGR_MCO2_PLL       (3 << RCC_CFGR_MCO2)
>  #endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_RCC_H */
> diff --git a/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> b/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> index d337d3a..31823d1 100644
> --- a/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> +++ b/c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c
> @@ -17,9 +17,220 @@
>  #include <bsp/irq.h>
>  #include <bsp/bootcard.h>
>  #include <bsp/irq-generic.h>
> +#include <bsp/stm32f4.h>
> +#include <bsp/stm32f4xxxx_rcc.h>
> +static rtems_status_code set_system_clk(uint32_t sysclk, uint32_t hseclk,
> uint32_t hseflag);
> +static void init_main_osc(void)
> +  volatile stm32f4_rcc *rcc = STM32F4_RCC;
> +  /* Revert to reset values */
> +  rcc->cr   |= RCC_CR_HSION; /* turn on HSI */
> +  while (! (rcc->cr & RCC_CR_HSIRDY) );
> +  rcc->cfgr &= 0x00000300; /* all prescalers to 0, clock source to HSI */
> +  rcc->cr   &= 0xF0F0FFFD; /* turn off all clocks and PLL except HSI */
> +  set_system_clk(STM32F4_SYSCLK / 1000000L, STM32F4_HSE_OSCILLATOR /
> 1000000L, 1);
> + * Sets up clocks configuration to achieve desired system clock
> + * as close as possible with simple math
> uint32_t hseflag)
> +  volatile stm32f4_flash *flash = STM32F4_FLASH;
> +  rtems_interrupt_level level;
> +  long timeout = 0;
> +  const long timeoutset = 10000000L;
> +  int srcclk = 0;
> +  int pll_m = 0;
> +  int pll_n = 0;
> +  int pll_p = 0;
> +  int pll_q = 0;
> +  //int cr;
> +  int ahbpre = 0;
> +  int apbpre1 = 0;
> +  int apbpre2 = 0;
> +  if (sysclk == 16) {
> +    rcc->cr   |= 0x00000001; /* turn on HSI */
> +    while (! (rcc->cr & (1 << RCC_CR_HSIRDY)) );
> +    flash->acr = 0; /* slow clock so no cache, no prefetch, no latency */
> +    return RTEMS_SUCCESSFUL;
> +  if (hseclk == 0 || hseflag == 0) {
> +    srcclk = 16;
> +    hseflag = 0;
> +  else {
> +    srcclk = hseclk;
> +  if (sysclk > 180) {
> +    return RTEMS_INVALID_NUMBER;
> +  else if (sysclk > 96) {
> +    pll_n = sysclk; /* multpily by the desired speed in MHz */
> +    pll_p = 0; /* divide by 2 */
> +  else if (sysclk > 48) {
> +    pll_n = sysclk >> 1; /* multpily by 2x the desired speed in MHz */
> +    pll_p = 1; /* divide by 4 */
> +  else if (sysclk > 24) {
> +    pll_n = sysclk >> 2; /* multpily by 4x the desired speed in MHz */
> +    pll_p = 3; /* divide by 8 */
> +  else {
> +   * Lets use 1MHz input for PLL so we get higher VCO output
> +   * this way we get better value for the PLL_Q divader for the USB
> +   * Though you might want to use 2MHz as per CPU specification:
> +   * Caution:The software has to set these bits correctly to ensure
> +   * that the VCO input frequency ranges from 1 to 2 MHz.
> +   * It is recommended to select a frequency of 2 MHz to limit PLL jitter.
> +  pll_m = srcclk; /* divide by the oscilator speed in MHz */
> +  pll_n <<= 1; /* multiply by requested clock x2 */
> +  /* pll_q is a prescaler from VCO for the USB OTG FS, SDIO and RNG,
> +   * should result in the 48MHz for the USB
> +  pll_q = ((long)(srcclk * pll_n + srcclk * pll_n / 2)) / pll_m / 48;
> +  if (pll_q < 2)
> +    pll_q = 2;
> +  /* APB1 prescaler, APB1 clock must be < 42MHz */
> +  apbpre1 = (sysclk * 100) / 42;
> +  if (apbpre1 <= 100) {
> +    apbpre1 = RCC_CFGR_PPRE1_BY_1;
> +  else if (apbpre1 <= 200) {
> +    apbpre1 = RCC_CFGR_PPRE1_BY_2;
> +  else if (apbpre1 <= 400) {
> +    apbpre1 = RCC_CFGR_PPRE1_BY_4;
> +  else if (apbpre1 <= 800) {
> +    apbpre1 = RCC_CFGR_PPRE1_BY_8;
> +  else if (apbpre1) {
> +    apbpre1 = RCC_CFGR_PPRE1_BY_16;
> +  /* APB2 prescaler, APB2 clock must be < 84MHz */
> +  apbpre2 = (sysclk * 100) / 84;
> +  if (apbpre2 <= 100) {
> +    apbpre2 = RCC_CFGR_PPRE2_BY_1;
> +  else if (apbpre2 <= 200) {
> +    apbpre2 = RCC_CFGR_PPRE2_BY_2;
> +  else if (apbpre2 <= 400) {
> +    apbpre2 = RCC_CFGR_PPRE2_BY_4;
> +  else if (apbpre2 <= 800) {
> +    apbpre2 = RCC_CFGR_PPRE2_BY_8;
> +  else {
> +    apbpre2 = RCC_CFGR_PPRE2_BY_16;
> +  rtems_interrupt_disable(level);
> +  timeout = timeoutset;
> +  while ((! (rcc->cr & RCC_CR_HSIRDY) ) && timeout--);
> +  if (timeout == 0) while(1);
> +  /* all prescalers to 0, clock source to HSI */
> +  rcc->cfgr |= RCC_CFGR_SW_HSI;
> +  while ( ( (rcc->cfgr & RCC_CFGR_SWS_MASK) != RCC_CFGR_SWS_HSI ) &&
> --timeout );
> +  /* turn off PLL */
> +  rcc->cr   &= ~ (RCC_CR_PLLON | RCC_CR_PLLRDY);
> +  if (hseflag) {
> +    rcc->cr |= RCC_CR_HSEON;
> +    while ((! (rcc->cr & RCC_CR_HSERDY) ) && timeout--);
> +  rcc->pllcfgr &= 0xF0BC8000; /* clear PLL prescalers */
> +  /* set pll parameters */
> +  rcc->pllcfgr |=(pll_m << RCC_PLLCFGR_PLLM)  // input divider
> +               | (pll_n << RCC_PLLCFGR_PLLN)  // multiplier
> +               | (pll_p << RCC_PLLCFGR_PLLP)  // output divider from table
> +                                              // HSE v HSI
> +               | (hseflag ? RCC_PLLCFGR_PLLSRC_HSE :
> RCC_PLLCFGR_PLLSRC_HSI)
> +               | (pll_q << RCC_PLLCFGR_PLLQ); // PLLQ
> +  /* set prescalers for the internal busses */
> +  rcc->cfgr    |= apbpre1
> +               |  apbpre2
> +               |  ahbpre;
> +  /* set flash parameters, hard coded for now for fast system clocks */
> +  flash->acr  |= 5        // latency
> +              | (1 << 9)  // instruction cache
> +              | (1 << 10);// data cache
> +  /* turn on PLL */
> +  rcc->cr   |= RCC_CR_PLLON;
> +  while ( (! (rcc->cr & RCC_CR_PLLRDY) ) && --timeout );
> +  /* clock source to PLL */
> +  rcc->cfgr = (rcc->cfgr & ~RCC_CFGR_SW_MASK) | RCC_CFGR_SW_PLL;
> +  while ( ((rcc->cfgr & RCC_CFGR_SWS_MASK) != RCC_CFGR_SWS_PLL) &&
> --timeout );
> +  //if (timeout == 0) while(1);
> +  rtems_interrupt_enable(level);
>  void bsp_start(void)
> +  init_main_osc();
>    stm32f4_gpio_set_config_array(&stm32f4_start_config_gpio [0]);
>    bsp_interrupt_initialize();
> 2.1.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140920/828b5382/attachment-0001.html>
