or1ksim: Updated results from RTEMS Tester
Hesham Moustafa
heshamelmatary at gmail.com
Sat Sep 20 22:57:17 UTC 2014
On Sat, Sep 20, 2014 at 7:53 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 20/09/2014 3:13 pm, Hesham Moustafa wrote:
>> I have 4 physical cores, and I usually run make with J8. My host OS is
>> fedora 20.
> Try with --jobs=4 and see if you get any time outs. Anything else running
> at the same time may effect the result.
> I did, but no big difference, the passed tests only raised to 446 although
the system monitor was indicating an average processor throughput of 75%
during this run instance with --job=4. It also shows that I have 8 CPUs (2
virtual ones per one physical core).
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140921/85989f02/attachment-0001.html>
