or1ksim: Updated results from RTEMS Tester
Hesham Moustafa
heshamelmatary at gmail.com
Sun Sep 21 00:00:00 UTC 2014
On Sun, Sep 21, 2014 at 1:15 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 21/09/2014 8:57 am, Hesham Moustafa wrote:
>> On Sat, Sep 20, 2014 at 7:53 AM, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>> On 20/09/2014 3:13 pm, Hesham Moustafa wrote:
>> I have 4 physical cores, and I usually run make with J8. My host
>> OS is
>> fedora 20.
>> Try with --jobs=4 and see if you get any time outs. Anything else
>> running at the same time may effect the result.
>> I did, but no big difference, the passed tests only raised to 446
>> although the system monitor was indicating an average processor
>> throughput of 75% during this run instance with --job=4.
> What does --jobs=none return as results ?
> Only "RTEMS Testing - Tester, v0.2.0" and no tests run.
> It also shows
>> that I have 8 CPUs (2 virtual ones per one physical core).
> I am not sure what effect hyper-threading gives us in this case.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140921/fec04f43/attachment.html>
