Cortex-M0 BPS creation
Pavel Pisa ppisa4lists at pikron.com
Mon Sep 22 11:25:48 UTC 2014
Hello Sebastian and Oleg,
On Monday 22 of September 2014 07:35:38 Sebastian Huber wrote:
> On 22/09/14 06:36, Мороз Олег wrote:
> >      Hello everyone. i'm new to  BSP development.  We have a project
> > which is uses some kind of cortex-m0 microcontroller. As i understand
> > it's armv6-m family. Is this CPU family is supported by rtems? I'm
> > reading the book called "BSP and device driver development guide"  and it
> > says look at
> > "cpukit/score/cpu/CPU". This directory contains only armv7-m and armv4
> > files. Is it correct?
> The armv7-m support will probably work also for a Cortex-M0.
I think that M3 context switch would be mostly OK.
Exception and interrupts model is the same as for M3,
but I have feeling that there exists option to
use some simplified one - but it can be for M1.
But you need to use M0 specific GCC options.
We use GCC for nRF51 Cortex-M0 with next options
  arm-none-eabi-gcc -mcpu=cortex-m0 -mthumb --std=gnu99 -Wall -mfloat-abi=soft
Else GCC can use Thumb2 instructions which are not supporeted
by ARMv6-m. For example Thumb instructions CBZ, CBNZ, IT
emitted by GCC for M3 are not supported by M0.
So toolchain rebuild is required for sure.
Best wishes,
             Pavel
