[PATCH 1/5] capture: Removal of capture task tracking.
    Jennifer Averett
    Jennifer.Averett at OARcorp.com
    Tue Sep 23 12:29:48 UTC 2014
I tried to limit how much functionality I removed from the capture engine with this
set of patches and limit it to what had to be removed in order to support removal of
capture tasks.   I have no problem with it moving to cpuuse, but I think it would need to
be modified to use a printk plugin and account for __RTEMS_USE_TICKS_FOR_STATISTICS__ .
jennifer
> -----Original Message-----
> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Chris Johns
> Sent: Monday, September 22, 2014 4:57 PM
> To: devel at rtems.org
> Subject: Re: [PATCH 1/5] capture: Removal of capture task tracking.
> On 23/09/2014 12:00 am, Jennifer Averett wrote:
> > This patch removes functionality for stack checking from
> > the capture engine and requiresi the use of existing rtems
> > functions for this information.  It modifies ctload to use
> > functionality similar to rtems cpuusage.  It removes the
> > capture task and stores a new capture task record the first
> > time the task is seen.  The per task data that was still
> > needed is scaled down and stored in the tcb.
> If the capture engine is not needed for ctload to work why not move that
> code out of here and into the cpuuse command ? It would appear more
> available to users.
> >   cpukit/libmisc/capture/capture-cli.c            | 383 ++++++++++++++----------
> >   cpukit/libmisc/capture/capture.c                | 367 ++++++-----------------
> >   cpukit/libmisc/capture/capture.h                | 295 ++++--------------
> >   cpukit/libmisc/capture/capture_user_extension.c | 219 +++-----------
> >   cpukit/libmisc/capture/captureimpl.h            |  53 +---
> >   5 files changed, 420 insertions(+), 897 deletions(-)
> > diff --git a/cpukit/libmisc/capture/capture-cli.c
> b/cpukit/libmisc/capture/capture-cli.c
> > index 2aa7c9c..6fe7e6c 100644
> > --- a/cpukit/libmisc/capture/capture-cli.c
> > +++ b/cpukit/libmisc/capture/capture-cli.c
> > @@ -35,12 +35,28 @@
> >   #include <rtems.h>
> >   #include <rtems/capture-cli.h>
> >   #include <rtems/monitor.h>
> > +#include <rtems/cpuuse.h>
> >   #define RC_UNUSED __attribute__((unused))
> >   #define RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS (20)
> > + * Counter used to count the number of active tasks.
> > +static int                   rtems_capture_cli_task_count = 0;
> > + * Array of tasks sorted by load.
> > +static rtems_tcb*
> rtems_capture_cli_load_tasks[RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS +
> 1];
> > + * The load for each tcb at the moment rtems_capture_cli_load_tasks was
> generated.
> > +static unsigned long long
> rtems_capture_cli_load[RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS + 1];
> >    * The user capture timestamper.
> >   static rtems_capture_timestamp capture_timestamp;
> > @@ -233,6 +249,104 @@ rtems_capture_cli_print_timestamp (uint64_t
> uptime)
> >     fprintf (stdout, "%5lu:%02lu:%02lu.%09lu", hours, minutes, seconds,
> nanosecs);
> > +static void
> > +rtems_capture_cli_print_task (rtems_tcb *tcb)
> > +  rtems_task_priority   ceiling = rtems_capture_watch_get_ceiling ();
> > +  rtems_task_priority   floor = rtems_capture_watch_get_floor ();
> > +  rtems_task_priority   priority;
> > +  int                   length;
> > +  priority = rtems_capture_task_real_priority (tcb);
> > +  fprintf (stdout, " ");
> > +  rtems_monitor_dump_id (rtems_capture_task_id (tcb));
> > +  rtems_monitor_dump_name (rtems_capture_task_id (tcb));
> > +  rtems_monitor_dump_priority (rtems_capture_task_start_priority
> (tcb));
> > +  rtems_monitor_dump_priority (rtems_capture_task_real_priority (tcb));
> > +  rtems_monitor_dump_priority (rtems_capture_task_curr_priority
> (tcb));
> > +  length = rtems_monitor_dump_state (rtems_capture_task_state (tcb));
> > +  fprintf (stdout, "%*c", 14 - length, ' ');
> > +  fprintf (stdout, " %c%c",
> > +           'a',
> > +           rtems_capture_task_flags (tcb) & RTEMS_CAPTURE_TRACED ? 't' : '-
> > +  if ((floor > ceiling) && (ceiling > priority))
> > +    fprintf (stdout, "--");
> > +  else
> > +    uint32_t flags = rtems_capture_task_control_flags (tcb);
> > +    fprintf (stdout, "%c%c",
> > +             rtems_capture_task_control (tcb) ?
> > +             (flags & RTEMS_CAPTURE_WATCH ? 'w' : '+') : '-',
> > +             rtems_capture_watch_global_on () ? 'g' : '-');
> > +  fprintf (stdout, "\n");
> > +static void
> > +rtems_caputure_cli_print_record_std(rtems_capture_record_t* rec,
> uint64_t diff)
> > +  uint32_t                     event;
> > +  int                          e;
> > +  event = rec->events >> RTEMS_CAPTURE_EVENT_START;
> > +  for (e = RTEMS_CAPTURE_EVENT_START; e <
> RTEMS_CAPTURE_EVENT_END; e++)
> > +    if (event & 1)
> > +      rtems_capture_cli_print_timestamp (rec->time);
> > +      fprintf (stdout, " %9" PRId64 " ", diff);
> > +      rtems_monitor_dump_id (rec->task_id);
> > +      fprintf(stdout, "      %3" PRId32 " %3" PRId32 " %s\n",
> > +             (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) & 0xff,
> > +             (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff,
> > +             rtems_capture_event_text (e));
> > +    event >>= 1;
> > +static void
> > +rtems_caputre_cli_print_record_task(rtems_capture_record_t* rec)
> > +  rtems_capture_task_record_t* task_rec =
> (rtems_capture_task_record_t*) rec;
> > +   fprintf (stdout, " %c%c%c%c",
> > +            (char) (task_rec->name >> 24) & 0xff,
> > +            (char) (task_rec->name >> 16) & 0xff,
> > +            (char) (task_rec->name >> 8) & 0xff,
> > +            (char) (task_rec->name >> 0) & 0xff);
> > +   fprintf (stdout, " %3" PRId32   " %3" PRId32 "\n",
> > +            task_rec->start_priority,
> > +            task_rec->stack_size);
> > + * rtems_capture_cli_count_tasks
> > + *  DESCRIPTION:
> > + * This function is called for each tcb and counts the
> > + * number of tasks.
> > +static void
> > +rtems_capture_cli_count_tasks (rtems_tcb *tcb)
> > +  rtems_capture_cli_task_count++;
> >    * rtems_capture_cli_task_list
> > @@ -248,71 +362,49 @@ rtems_capture_cli_task_list (int
> argc RC_UNUSED,
> >                                const rtems_monitor_command_arg_t* command_arg
> RC_UNUSED,
> >                                bool                               verbose RC_UNUSED)
> > -  rtems_task_priority   ceiling = rtems_capture_watch_get_ceiling ();
> > -  rtems_task_priority   floor = rtems_capture_watch_get_floor ();
> > -  rtems_capture_task_t* task = rtems_capture_get_task_list ();
> > -  int                   count = rtems_capture_task_count ();
> >     rtems_capture_time_t  uptime;
> >     rtems_capture_time (&uptime);
> > +  rtems_capture_cli_task_count = 0;
> > +  rtems_iterate_over_all_threads (rtems_capture_cli_count_tasks);
> >     fprintf (stdout, "uptime: ");
> >     rtems_capture_cli_print_timestamp (uptime);
> > -  fprintf (stdout, "\ntotal %i\n", count);
> > -  while (task)
> > -    rtems_task_priority priority;
> > -    int32_t             stack_used;
> > -    int32_t             time_used;
> > -    int                 length;
> > +  fprintf (stdout, "\ntotal %i\n", rtems_capture_cli_task_count);
> > +  rtems_iterate_over_all_threads (rtems_capture_cli_print_task);
> > -    stack_used = rtems_capture_task_stack_usage (task);
> > -    if (stack_used)
> > -      stack_used = (stack_used * 100) / rtems_capture_task_stack_size
> (task);
> > +static void
> > +rtems_capture_cli_task_sort (rtems_tcb* tcb)
> > +  int                   i;
> > +  int                   j;
> > -    if (stack_used > 100)
> > -      stack_used = 100;
> > +  if (tcb)
> > +    rtems_capture_time_t l = tcb->cpu_time_used;
> > -    time_used = (rtems_capture_task_time (task) * 100) / uptime;
> > -    if (time_used > 100)
> > -      time_used = 100;
> > +    for (i = 0; i < RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS; i++)
> > +      if (rtems_capture_cli_load_tasks[i])
> > +        if ((l == 0) || (l < rtems_capture_cli_load[i]))
> > +          continue;
> > -    priority = rtems_capture_task_real_priority (task);
> > +        for (j = (RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS - 1); j >= i; j--)
> > +          rtems_capture_cli_load_tasks[j + 1] =
> rtems_capture_cli_load_tasks[j];
> > +          rtems_capture_cli_load[j + 1]  = rtems_capture_cli_load[j];
> > -    fprintf (stdout, " ");
> > -    rtems_monitor_dump_id (rtems_capture_task_id (task));
> > -    rtems_monitor_dump_name (rtems_capture_task_id (task));
> > -    rtems_monitor_dump_priority (rtems_capture_task_start_priority
> (task));
> > -    rtems_monitor_dump_priority (rtems_capture_task_real_priority
> (task));
> > -    rtems_monitor_dump_priority (rtems_capture_task_curr_priority
> (task));
> > -    length = rtems_monitor_dump_state (rtems_capture_task_state
> (task));
> > -    fprintf (stdout, "%*c", 14 - length, ' ');
> > -    fprintf (stdout, " %c%c",
> > -             rtems_capture_task_valid (task) ? 'a' : 'd',
> > -             rtems_capture_task_flags (task) & RTEMS_CAPTURE_TRACED ? 't' :
> > -    if ((floor > ceiling) && (ceiling > priority))
> > -      fprintf (stdout, "--");
> > -    else
> > -      uint32_t flags = rtems_capture_task_control_flags (task);
> > -      fprintf (stdout, "%c%c",
> > -               rtems_capture_task_control (task) ?
> > -               (flags & RTEMS_CAPTURE_WATCH ? 'w' : '+') : '-',
> > -               rtems_capture_watch_global_on () ? 'g' : '-');
> > +      rtems_capture_cli_load_tasks[i] = tcb;
> > +      rtems_capture_cli_load[i]  = l;
> > +      break;
> > -    fprintf (stdout, " %3" PRId32 "%% %3" PRId32 "%% ", stack_used,
> time_used);
> > -    rtems_capture_cli_print_timestamp (rtems_capture_task_time (task));
> > -    fprintf (stdout, "\n");
> > -    task = rtems_capture_next_task (task);
> > @@ -328,26 +420,22 @@ rtems_capture_cli_task_list (int
> argc RC_UNUSED,
> >   static void
> >   rtems_capture_cli_task_load_thread (rtems_task_argument arg)
> > +  rtems_tcb*          tcb;
> >     int                 last_count = 0;
> >     FILE*               pstdout = (FILE*) arg;
> > +  int                 i;
> > +  int                 j;
> >     fileno(stdout);
> >     stdout = pstdout;
> >     while (true)
> tasks[RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS + 1];
> > -    unsigned long long    load[RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS +
> 1];
> > -    rtems_capture_task_t* task;
> > -    rtems_capture_time_t  uptime;
> > -    rtems_capture_time_t  total_time;
> > -    int                   count = 0;
> > -    int                   i;
> > -    int                   j;
> > -    rtems_capture_time (&uptime);
> > +    Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
> > +    uint32_t seconds, nanoseconds;
> > +    size_t                size;
> >       cli_load_thread_active = 1;
> > @@ -356,114 +444,98 @@ rtems_capture_cli_task_load_thread
> >        * into our local arrays. We only handle a limited number of
> >        * tasks.
> > +    size = sizeof (rtems_capture_cli_load_tasks);
> > +    memset (rtems_capture_cli_load_tasks, 0, size);
> > +    memset (rtems_capture_cli_load, 0, sizeof (rtems_capture_cli_load));
> > -    memset (tasks, 0, sizeof (tasks));
> > -    memset (load, 0, sizeof (load));
> > +    _Timestamp_Set_to_zero( &total );
> > +    uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
> > +    _TOD_Get_uptime( &uptime );
> > +    seconds = _Timestamp_Get_seconds( &uptime );
> > +    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
> > +                  TOD_NANOSECONDS_PER_MICROSECOND;
> > -    task = rtems_capture_get_task_list ();
> > -    total_time = 0;
> > -    while (task)
> > -      if (rtems_capture_task_valid (task))
> > -        rtems_capture_time_t l = rtems_capture_task_delta_time (task);
> > -        count++;
> > -        total_time += l;
> > -        for (i = 0; i < RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS; i++)
> > -          if (tasks[i])
> > -            if ((l == 0) || (l < load[i]))
> > -              continue;
> > -            for (j = (RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS - 1); j >= i; j--)
> > -              tasks[j + 1] = tasks[j];
> > -              load[j + 1]  = load[j];
> > -          tasks[i] = task;
> > -          load[i]  = l;
> > -          break;
> > +    rtems_iterate_over_all_threads (rtems_capture_cli_task_sort);
> >       fprintf (stdout, "\x1b[H\x1b[J Press ENTER to exit.\n\n");
> > -    rtems_capture_cli_print_timestamp (uptime);
> > +    fprintf (stdout, "%7" PRIu32 ".%06" PRIu32 "\n",  seconds,
> nanoseconds);
> >       fprintf (stdout,
> >                "\n\n"
> > -             "     PID NAME RPRI CPRI STATE          %%CPU     %%STK FLGS    EXEC
> TIME\n");
> > +             "     PID NAME RPRI CPRI STATE      EXEC TIME   %%CPU\n");
> > -    if (count > last_count)
> > -      j = count;
> > +    if (rtems_capture_cli_task_count > last_count)
> > +      j = rtems_capture_cli_task_count;
> >       else
> >         j = last_count;
> > -      int                 stack_used;
> > -      int                 task_load;
> > -      int                 k;
> > -      if (!tasks[i])
> > +      Timestamp_Control   last;
> > +      uint32_t            ival, fval;
> > +      if (!rtems_capture_cli_load_tasks[i])
> >           break;
> >         j--;
> > -      stack_used = rtems_capture_task_stack_usage (tasks[i]);
> > -      if (stack_used)
> (tasks[i]);
> > -        stack_used = 100;
> > -      task_load = (int) ((load[i] * 100000) / total_time);
> > -      priority = rtems_capture_task_real_priority (tasks[i]);
> > +       * If this is the currently executing thread, account for time
> > +       * since the last context switch.
> > +      tcb = rtems_capture_cli_load_tasks[i];
> > +      ran = rtems_capture_cli_load[i];
> > +      if ( _Thread_is_executing_on_a_core( tcb, &last ) ) {
> > +        Timestamp_Control used;
> > +        _Timestamp_Subtract( &last, &uptime, &used );
> > +        _Timestamp_Add_to( &ran, &used );
> > +      } else {
> > +      _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total );
> > +      _Timestamp_Divide( &ran, &total, &ival, &fval );
> > +      seconds = _Timestamp_Get_seconds( &ran );
> > +      nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
> >         fprintf (stdout, "\x1b[K");
> > -      rtems_monitor_dump_id (rtems_capture_task_id (tasks[i]));
> > -      rtems_monitor_dump_name (rtems_capture_task_id (tasks[i]));
> >         rtems_monitor_dump_priority (priority);
> (tasks[i]));
> (tcb));
> > -      k = rtems_monitor_dump_state (rtems_capture_task_state (tasks[i]));
> > -      fprintf (stdout, "%*c %3i.%03i%% ", 14 - k, ' ',
> > -               task_load / 1000, task_load % 1000);
> > -      fprintf (stdout, "%3i%% %c%c", stack_used,
> > -              rtems_capture_task_valid (tasks[i]) ? 'a' : 'd',
> > -              rtems_capture_task_flags (tasks[i]) & RTEMS_CAPTURE_TRACED ?
> 't' : '-');
> > +      rtems_monitor_dump_state (rtems_capture_task_state (tcb));
> > +      fprintf (stdout,
> > +            "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 ,
> > +            seconds, nanoseconds, ival, fval
> > +              'a',
> >         else
> > -                rtems_capture_task_control (tasks[i]) ?
> > -                (rtems_capture_task_control_flags (tasks[i]) &
> > +                (rtems_capture_task_control_flags (tcb) &
> (tasks[i]));
> > -    if (count < RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS)
> > +    if (rtems_capture_cli_task_count <
> > -      j = RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS - count;
> > +      j = RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS -
> >         while (j > 0)
> >           fprintf (stdout, "\x1b[K\n");
> > @@ -471,7 +543,7 @@ rtems_capture_cli_task_load_thread
> > -    last_count = count;
> > +    last_count = rtems_capture_cli_task_count;
> >       cli_load_thread_active = 0;
> > @@ -1415,42 +1487,23 @@ rtems_capture_cli_trace_records (int
> argc,
> >         rec = (rtems_capture_record_t*) ptr;
> >         if (csv)
> > -        fprintf (stdout, "%08" PRIxPTR ",%03" PRIu32
> > +        fprintf (stdout, "%08" PRIu32 ",%03" PRIu32
> >                      ",%03" PRIu32 ",%04" PRIx32 ",%" PRId64 "\n",
> > -                 (uintptr_t) rec->task,
> > +                 rec->task_id,
> 0xff,
> 0xff,
> >                    (rec->events >> RTEMS_CAPTURE_EVENT_START),
> >                    (uint64_t) rec->time);
> > -      else
> > -        uint64_t diff = 0;
> > -        uint32_t event;
> > -        int      e;
> > -        event = rec->events >> RTEMS_CAPTURE_EVENT_START;
> > -        for (e = RTEMS_CAPTURE_EVENT_START; e <
> > -          if (event & 1)
> > -            rtems_capture_cli_print_timestamp (rec->time);
> > -            if (last_t)
> > -              diff = rec->time - last_t;
> > -            last_t = rec->time;
> > -            fprintf (stdout, " %9" PRId64 " ", diff);
> > -            rtems_monitor_dump_id (rtems_capture_task_id (rec->task));
> > -            fprintf (stdout, " %c%c%c%c",
> > -                     (char) (rec->task->name >> 24) & 0xff,
> > -                     (char) (rec->task->name >> 16) & 0xff,
> > -                     (char) (rec->task->name >> 8) & 0xff,
> > -                     (char) (rec->task->name >> 0) & 0xff);
> > -            fprintf (stdout, " %3" PRId32 " %3" PRId32 " %s\n",
> > -                    (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) &
> 0xff,
> > -                    (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) &
> 0xff,
> > -                    rtems_capture_event_text (e));
> > -          event >>= 1;
> > +      else {
> > +        if ((rec->events >> RTEMS_CAPTURE_EVENT_START) == 0)
> > +          rtems_caputre_cli_print_record_task( rec );
> > +        else {
> > +          uint64_t diff = 0;
> > +          if (last_t)
> > +            diff = rec->time - last_t;
> > +          last_t = rec->time;
> > +          rtems_caputure_cli_print_record_std( rec, diff );
> >         ptr += rec->size;
> > diff --git a/cpukit/libmisc/capture/capture.c
> b/cpukit/libmisc/capture/capture.c
> > index 64d2699..6c839d9 100644
> > --- a/cpukit/libmisc/capture/capture.c
> > +++ b/cpukit/libmisc/capture/capture.c
> > @@ -27,7 +27,6 @@
> >   #include <stdlib.h>
> >   #include <string.h>
> > -#include <rtems/rtems/tasksimpl.h>
> >   #include "captureimpl.h"
> >   #include "capture_buffer.h"
> > @@ -64,10 +63,9 @@
> >    * RTEMS Capture Data.
> > -static rtems_capture_buffer_t         capture_records = {NULL, 0, 0, 0, 0, 0};
> > +static rtems_capture_buffer_t   capture_records = {NULL, 0, 0, 0, 0, 0};
> >   static uint32_t                 capture_count;
> >   static uint32_t                 capture_flags;
> > -static rtems_capture_task_t*    capture_tasks;
> >   static rtems_capture_control_t* capture_controls;
> >   static int                      capture_extension_index;
> > @@ -118,18 +116,6 @@ void rtems_capture_set_flags(uint32_t mask)
> >     capture_flags |= mask;
> > -rtems_capture_task_t* rtems_capture_find_capture_task( rtems_id
> ct_id )
> > -  rtems_capture_task_t* ct;
> > -  for (ct = capture_tasks; ct; ct = ct->forw) {
> > -    if (ct->id == ct_id)
> > -      break;
> > -  return ct;
> >    * This function returns the current time. If a handler is provided
> >    * by the user get the time from that.
> > @@ -207,7 +193,7 @@ rtems_capture_dup_name (rtems_name* dst,
> rtems_name src)
> >   static inline bool
> >   rtems_capture_by_in_to (uint32_t                 events,
> > -                        rtems_capture_task_t*    by,
> > +                        rtems_tcb*               by,
> >                           rtems_capture_control_t* to)
> >     uint32_t valid_mask = RTEMS_CAPTURE_CONTROL_FROM_MASK (0);
> > @@ -235,7 +221,8 @@ rtems_capture_by_in_to (uint32_t                 events,
> >          * not set.
> >         if (rtems_capture_match_name_id (to->by[i].name, to->by[i].id,
> > -                                       by->name, by->id))
> > +                                       rtems_capture_task_name( by ),
> > +                                       by->Object.id))
> >           return 1;
> > @@ -247,47 +234,6 @@ rtems_capture_by_in_to (uint32_t                 events,
> > - * This function raises the reference count.
> > -static inline void
> > -rtems_capture_refcount_up (rtems_capture_task_t* task)
> > -  task->refcount++;
> > - * This function lowers the reference count and if the count
> > - * reaches 0 the task control block is returned to the heap.
> > -static inline void
> > -rtems_capture_refcount_down (rtems_capture_task_t* task)
> > -  if (task->refcount)
> > -    task->refcount--;
> > - * This function setups a stack so its usage can be monitored.
> > -void
> > -rtems_capture_init_stack_usage (rtems_capture_task_t* task)
> > -  if (task->tcb)
> > -    uint32_t* s;
> > -    uint32_t  i;
> > -    task->stack_size  = task->tcb->Start.Initial_stack.size;
> > -    task->stack_clean = task->stack_size;
> > -    s = task->tcb->Start.Initial_stack.area;
> > -    for (i = 0; i < (task->stack_size - 128); i += 4)
> > -      *(s++) = 0xdeaddead;
> >    * This function searches for a trigger given a name.
> >   static inline rtems_capture_control_t*
> > @@ -302,6 +248,27 @@ rtems_capture_find_control (rtems_name name,
> rtems_id id)
> > + * This function checks if a new control structure matches
> > + * the given task and sets the control if it does.
> > +static void
> > +rtems_capture_initialize_control (rtems_tcb *tcb)
> > +  rtems_name                   name;
> > +  rtems_capture_control_t*     control;
> > +   * We need to scan the default control list to initialise
> > +   * this control.
> > +  rtems_object_get_classic_name( tcb->Object.id, &name );
> > +  control = capture_controls;
> > +  if (rtems_capture_match_name_id (control->name, control->id,
> > +                                   name, tcb->Object.id))
> > +    tcb->capture.control = control;
> >    * This function creates a capture control for the capture engine.
> > @@ -309,7 +276,6 @@ rtems_capture_create_control (rtems_name name,
> rtems_id id)
> >     rtems_interrupt_lock_context lock_context;
> >     if ((name == 0) && (id == 0))
> >       return NULL;
> > @@ -339,14 +305,7 @@ rtems_capture_create_control (rtems_name
> name, rtems_id id)
> >       control->next    = capture_controls;
> >       capture_controls = control;
> > -     * We need to scan the task list as set the control to the
> > -     * tasks.
> > -    for (task = capture_tasks; task != NULL; task = task->forw)
> > -      if (rtems_capture_match_name_id (name, id, task->name, task->id))
> > -        task->control = control;
> > +    rtems_iterate_over_all_threads (rtems_capture_initialize_control);
> >       rtems_interrupt_lock_release (&capture_lock, &lock_context);
> > @@ -354,130 +313,73 @@ rtems_capture_create_control (rtems_name
> name, rtems_id id)
> >     return control;
> > - * This function create the task control.
> > -rtems_capture_create_capture_task (rtems_tcb* new_task)
> > +void rtems_capture_record_task( rtems_tcb* tcb )
> > -  rtems_interrupt_lock_context lock_context;
> > -  rtems_capture_control_t*     control;
> > -  rtems_name                   name;
> > -  rtems_capture_time_t         time;
> > -  bool                         ok;
> > -  ok = rtems_workspace_allocate (sizeof (*task), (void **) &task);
> > -  if (!ok)
> > -    capture_flags |= RTEMS_CAPTURE_NO_MEMORY;
> > -    return NULL;
> > -   * Get the current time.
> > -  rtems_capture_get_time (&time);
> > +  rtems_capture_task_record_t rec;
> > +  void*                       ptr;
> > +  rtems_object_get_classic_name( tcb->Object.id, &rec.name );
> > -   * Check the type of name the object has.
> > +   * this control if it is a new task.
> > -  rtems_object_get_classic_name( new_task->Object.id, &name );
> > -  rtems_capture_dup_name (&task->name, name);
> > -  task->id               = new_task->Object.id;
> > -  task->flags            = 0;
> > -  task->in               = 0;
> > -  task->refcount         = 0;
> > -  task->out              = 0;
> > -  task->tcb              = new_task;
> > -  task->time             = 0;
> > -  task->time_in          = time;
> > -  task->control          = 0;
> > -  task->last_time        = 0;
> > -  task->tcb->extensions[capture_extension_index] = task;
> > -  task->start_priority = _RTEMS_tasks_Priority_from_Core(
> > -                           new_task->Start.initial_priority
> > -  task->stack_size     = new_task->Start.Initial_stack.size;
> > -  rtems_interrupt_lock_acquire (&capture_lock, &lock_context);
> > -  task->forw    = capture_tasks;
> > -  if (task->forw)
> > -    task->forw->back = task;
> > -  task->back    = NULL;
> > -  capture_tasks = task;
> > +  if (tcb->capture.control == NULL) {
> > +    for (control = capture_controls; control != NULL; control = control-
> >next)
> > +                                       rec.name, tcb->Object.id))
> > -  rtems_interrupt_lock_release (&capture_lock, &lock_context);
> > +  rec.stack_size = tcb->Start.Initial_stack.size;
> > +  rec.start_priority = _RTEMS_tasks_Priority_from_Core(
> > +    tcb->Start.initial_priority
> > +  tcb->capture.flags |= RTEMS_CAPTURE_RECORD_TASK;
> > -   * We need to scan the default control list to initialise
> > -   * this control.
> > +   *  Log the task information. The first time a task is
> > +   *  seen a record is logged.  This record can be identified
> > +   *  by a 0 in the event identifier.
> > -  for (control = capture_controls; control != NULL; control = control->next)
> > -    if (rtems_capture_match_name_id (control->name, control->id,
> > -                                     task->name, task->id))
> > -  return task;
> > - * This function destroy the task structure if the reference count
> > - * is 0 and the tcb has been cleared signalling the task has been
> > - * deleted.
> > -void
> > -rtems_capture_destroy_capture_task (rtems_capture_task_t* task)
> > -  if (task)
> > -    if (task->tcb || task->refcount)
> > -      task = 0;
> > -    if (task)
> > -      if (task->forw)
> > -        task->forw->back = task->back;
> > -      if (task->back)
> > -        task->back->forw = task->forw;
> > -      else
> > -        capture_tasks = task->forw;
> > -    rtems_workspace_free (task);
> > +  rtems_capture_begin_add_record (tcb, 0, sizeof(rec), &ptr);
> > +  ptr = rtems_capture_append_to_record(
> > +    ptr,
> > +    &rec.name,
> > +    sizeof( rec.name )
> > +    ptr,
> > +    &rec.start_priority,
> > +    sizeof( rec.start_priority)
> > +    ptr,
> > +    &rec.stack_size,
> > +    sizeof( rec.stack_size)
> > +  rtems_capture_end_add_record ( ptr );
> >    * This function indicates if data should be filtered from the
> >    * log.
> > -bool rtems_capture_filter( rtems_capture_task_t* task,
> > +bool rtems_capture_filter( rtems_tcb*            tcb,
> >                              uint32_t              events)
> > -  if (task &&
> > +  if (tcb &&
> >         ((capture_flags &
> >           (RTEMS_CAPTURE_TRIGGERED |
> RTEMS_CAPTURE_ONLY_MONITOR)) ==
> >          RTEMS_CAPTURE_TRIGGERED))
> > -    control = task->control;
> > +    control = tcb->capture.control;
> >        * Capture the record if we have an event that is always
> > @@ -485,8 +387,8 @@ bool rtems_capture_filter( rtems_capture_task_t*
> task,
> >        * watch ceiling, and the global watch or task watch is enabled.
> >       if ((events & RTEMS_CAPTURE_RECORD_EVENTS) ||
> > -        ((task->tcb->real_priority >= capture_ceiling) &&
> > -         (task->tcb->real_priority <= capture_floor) &&
> > +        ((tcb->real_priority >= capture_ceiling) &&
> > +         (tcb->real_priority <= capture_floor) &&
> >            ((capture_flags & RTEMS_CAPTURE_GLOBAL_WATCH) ||
> >             (control && (control->flags & RTEMS_CAPTURE_WATCH)))))
> > @@ -501,7 +403,7 @@ bool rtems_capture_filter( rtems_capture_task_t*
> task,
> >    * This function records a capture record into the capture buffer.
> >   void *
> > -rtems_capture_record_open (rtems_capture_task_t*         task,
> > +rtems_capture_record_open (rtems_tcb*                    tcb,
> >                              uint32_t                      events,
> >                              size_t                        size,
> >                              rtems_interrupt_lock_context* lock_context)
> > @@ -516,18 +418,17 @@ rtems_capture_record_open
> >     if ( capture_in )
> >       capture_count++;
> > -    capture_in->size   = size;
> > -    capture_in->task   = task;
> > -    capture_in->events = (events |
> > -                          (task->tcb->real_priority) |
> > -                          (task->tcb->current_priority << 8));
> > +    capture_in->size    = size;
> > +    capture_in->task_id = tcb->Object.id;
> > +    capture_in->events  = (events |
> > +                          (tcb->real_priority) |
> > +                          (tcb->current_priority << 8));
> >       if ((events & RTEMS_CAPTURE_RECORD_EVENTS) == 0)
> > -      task->flags |= RTEMS_CAPTURE_TRACED;
> > +      tcb->capture.flags |= RTEMS_CAPTURE_TRACED;
> >       rtems_capture_get_time (&capture_in->time);
> > -    rtems_capture_refcount_up (task);
> >       ptr = ptr + sizeof(*capture_in);
> >     else
> > @@ -546,10 +447,11 @@ void rtems_capture_record_close( void *rec,
> >    * cause of a trigger.
> >   bool
> > -rtems_capture_trigger (rtems_capture_task_t* ft,
> > -                       rtems_capture_task_t* tt,
> > -                       uint32_t              events)
> > +rtems_capture_trigger (rtems_tcb* ft,
> > +                       rtems_tcb* tt,
> > +                       uint32_t   events)
> >      * If we have not triggered then see if this is a trigger condition.
> > @@ -563,18 +465,18 @@ rtems_capture_trigger (rtems_capture_task_t*
> ft,
> >       if (ft)
> > -      fc = ft->control;
> > +      fc = ft->capture.control;
> >         if (fc)
> >           from_events = fc->from_triggers & events;
> >       if (tt)
> > -      tc = tt->control;
> > +      tc = tt->capture.control;
> >         if (tc)
> >           to_events = tc->to_triggers & events;
> > -        if (ft && tc->by_valid)
> > +        if (ft && tc->by_valid)
> >             from_to_events = tc->by_triggers & events;
> > @@ -633,7 +535,6 @@ rtems_capture_open (uint32_t   size,
> rtems_capture_timestamp timestamp __attribu
> >     capture_count   = 0;
> >     capture_flags   = 0;
> > -  capture_tasks   = NULL;
> >     capture_ceiling = 0;
> >     capture_floor   = 255;
> > @@ -659,7 +560,6 @@ rtems_status_code
> >   rtems_capture_close (void)
> >     rtems_status_code            sc;
> > @@ -685,17 +585,6 @@ rtems_capture_close (void)
> >     if (sc != RTEMS_SUCCESSFUL)
> >       return sc;
> > -  task = capture_tasks;
> > -  while (task)
> > -    rtems_capture_task_t* delete = task;
> > -    task = task->forw;
> > -    rtems_workspace_free (delete);
> >     while (control)
> > @@ -715,15 +604,6 @@ rtems_capture_close (void)
> >     return RTEMS_SUCCESSFUL;
> > - * This function allows control of tracing at a global level.
> > -static void
> > -rtems_capture_task_setup (Thread_Control *tcb)
> > -  rtems_capture_create_capture_task (tcb);
> >   rtems_status_code
> >   rtems_capture_control (bool enable)
> > @@ -742,8 +622,6 @@ rtems_capture_control (bool enable)
> >     else
> >       capture_flags &= ~RTEMS_CAPTURE_ON;
> > -  rtems_iterate_over_all_threads (rtems_capture_task_setup);
> > @@ -778,6 +656,16 @@ rtems_capture_monitor (bool enable)
> > + * This function clears the capture trace flag in the tcb.
> > +static void
> > +rtems_capture_flush_tcb (rtems_tcb *tcb)
> > +  tcb->capture.flags &= ~RTEMS_CAPTURE_TRACED;
> >    * This function flushes the capture buffer. The prime parameter allows
> the
> >    * capture engine to also be primed again.
> > @@ -785,15 +673,10 @@ rtems_status_code
> >   rtems_capture_flush (bool prime)
> > -    task->flags &= ~RTEMS_CAPTURE_TRACED;
> > +  rtems_iterate_over_all_threads (rtems_capture_flush_tcb);
> >     if (prime)
> >       capture_flags &= ~(RTEMS_CAPTURE_TRIGGERED |
> RTEMS_CAPTURE_OVERFLOW);
> > @@ -805,15 +688,6 @@ rtems_capture_flush (bool prime)
> > -  while (task)
> > -    rtems_capture_task_t* check = task;
> > -    rtems_capture_destroy_capture_task (check);
> > @@ -856,7 +730,6 @@ rtems_capture_watch_del (rtems_name name,
> rtems_id id)
> >     rtems_capture_control_t**    prev_control;
> >     bool                         found = false;
> > @@ -870,10 +743,6 @@ rtems_capture_watch_del (rtems_name name,
> rtems_id id)
> > -        if (task->control == control)
> >         *prev_control = control->next;
> > @@ -1373,8 +1242,6 @@ rtems_capture_release (uint32_t count)
> >       ptr_size += rec->size;
> > -    rtems_capture_refcount_down (rec->task);
> > -    rtems_capture_destroy_capture_task (rec->task);
> >       ptr += rec->size;
> > @@ -1416,48 +1283,6 @@ rtems_capture_event_text (int event)
> > - * This function returns the head of the list of tasks that the
> > - * capture engine has detected.
> > -rtems_capture_get_task_list (void)
> > -  return capture_tasks;
> > - * This function updates the stack usage. The task control block
> > - * is updated.
> > -uint32_t
> > -rtems_capture_task_stack_usage (rtems_capture_task_t* task)
> > -  if (task->tcb)
> > -    uint32_t* st;
> > -    uint32_t* s;
> > -     * @todo: Assumes all stacks move the same way.
> > -    st = task->tcb->Start.Initial_stack.area + task->stack_size;
> > -    while (s < st)
> > -      if (*s != 0xdeaddead)
> > -        break;
> > -      s++;
> > -      s - (uint32_t*) task->tcb->Start.Initial_stack.area;
> > -  return task->stack_clean;
> >    * This function returns the head of the list of control in the
> >    * capture engine.
> > diff --git a/cpukit/libmisc/capture/capture.h
> b/cpukit/libmisc/capture/capture.h
> > index 8bc2fc3..bd07922 100644
> > --- a/cpukit/libmisc/capture/capture.h
> > +++ b/cpukit/libmisc/capture/capture.h
> > @@ -46,6 +46,7 @@ extern "C" {
> >   #endif
> >   #include <rtems.h>
> > +#include <rtems/rtems/tasksimpl.h>
> >    * The number of tasks in a trigger group.
> > @@ -137,47 +138,10 @@ typedef struct rtems_capture_control_s
> >                                        RTEMS_CAPTURE_EXITTED)
> > - * @brief Catpure task control
> > - * RTEMS capture control provdes the information about a task, along
> > - * with its trigger state. The control is referenced by each
> > - * capture record. This is information neeed by the decoder. The
> > - * capture record cannot assume the task will exist when the record is
> > - * dumped via the target interface so task info needed for tracing is
> > - * copied and held here. Once the references in the trace buffer
> > - * have been removed and the task is deleted this structure is
> > - * released back to the heap.
> > - * The inline helper functions provide more details about the info
> > - * contained in this structure.
> > - * Note, the tracer code exploits the fact an rtems_name is a
> > - * 32bit value.
> > -typedef struct rtems_capture_task_s
> > -  rtems_name                   name;
> > -  rtems_id                     id;
> > -  uint32_t                     flags;
> > -  uint32_t                     refcount;
> > -  rtems_tcb*                   tcb;
> > -  uint32_t                     in;
> > -  uint32_t                     out;
> > -  rtems_task_priority          start_priority;
> > -  uint32_t                     stack_size;
> > -  uint32_t                     stack_clean;
> > -  rtems_capture_time_t         time_in;
> > -  rtems_capture_time_t         last_time;
> > -  struct rtems_capture_task_s* forw;
> > -  struct rtems_capture_task_s* back;
> > -} rtems_capture_task_t;
> >    * Task flags.
> > -#define RTEMS_CAPTURE_TRACED  (1U << 0)
> > +#define RTEMS_CAPTURE_TRACED      (1U << 0)
> > +#define RTEMS_CAPTURE_RECORD_TASK (1U << 1)
> >    * @brief Capture record.
> > @@ -188,12 +152,27 @@ typedef struct rtems_capture_task_s
> >   typedef struct rtems_capture_record_s
> >     uint32_t              events;
> >     size_t                size;
> > +  rtems_id              task_id;
> >   } rtems_capture_record_t;
> > + * @brief Capture task record.
> > + * This is a record that is written into
> > + * the buffer. The events includes the priority of the task
> > + * at the time of the context switch.
> > +typedef struct rtems_capture_task_record_s
> > +  rtems_capture_record_t rec;
> > +  rtems_name             name;
> > +  rtems_task_priority    start_priority;
> > +  uint32_t               stack_size;
> > +} rtems_capture_task_record_t;
> >    * The capture record event flags.
> > @@ -619,49 +598,24 @@ const char*
> >   rtems_capture_event_text (int event);
> > - * @brief Capture get task list.
> > - * @retval  This function returns the head of the list of tasks that
> > - *          the capture engine has detected.
> > -rtems_capture_get_task_list (void);
> > - * @brief Capture get next task in list.
> > - * This function returns the pointer to the next task in the list. The
> > - * pointer NULL terminates the list.
> > - * @param[in] task The capture task to get the next entry from.
> > + * @brief Capture record task.
> > - * @retval This function returns the pointer to the next task in the list. The
> > + * This function records a new capture task record.
> > + * @param[in] tcb is the task control block for the task
> > -static inline rtems_capture_task_t*
> > -rtems_capture_next_task (rtems_capture_task_t* task)
> > -  return task->forw;
> > +void rtems_capture_record_task( rtems_tcb* tcb );
> > - * @brief Capture is valid task control block
> > + * @brief Capture task recorded
> > - * This function returns true if the task control block points to
> > - * a valid task.
> > + * This function returns true if this task information has been
> > + * recorded.
> > - * @param[in] task The capture task.
> > - * @retval This function returns true if the task control block points to
> > - * a valid task. Otherwise, it returns false.
> > -static inline bool
> > -rtems_capture_task_valid (rtems_capture_task_t* task)
> > -  return task->tcb != NULL;
> > +static inline bool rtems_capture_task_recorded( rtems_tcb* tcb ) {
> > +  return ( (tcb->capture.flags & RTEMS_CAPTURE_RECORD_TASK) != 0 );
> > @@ -674,9 +628,9 @@ rtems_capture_task_valid (rtems_capture_task_t*
> task)
> >    * @retval This function returns the task id.
> >   static inline rtems_id
> > -rtems_capture_task_id (rtems_capture_task_t* task)
> > +rtems_capture_task_id (rtems_tcb* tcb)
> > -  return task->id;
> > +  return tcb->Object.id;
> > @@ -689,10 +643,10 @@ rtems_capture_task_id (rtems_capture_task_t*
> task)
> >    * @retval This function returns the task state.
> >   static inline States_Control
> > -rtems_capture_task_state (rtems_capture_task_t* task)
> > +rtems_capture_task_state (rtems_tcb* tcb)
> > -    return task->tcb->current_state;
> > +  if (tcb)
> > +    return tcb->current_state;
> >     return 0;
> > @@ -706,9 +660,11 @@ rtems_capture_task_state
> >    * @retval This function returns the task name.
> >   static inline rtems_name
> > -rtems_capture_task_name (rtems_capture_task_t* task)
> > +rtems_capture_task_name (rtems_tcb* tcb)
> > -  return task->name;
> > +  rtems_name  name;
> > +  return name;
> > @@ -721,9 +677,9 @@ rtems_capture_task_name
> >    * @retval This function returns the task flags.
> >   static inline uint32_t
> > -rtems_capture_task_flags (rtems_capture_task_t* task)
> > +rtems_capture_task_flags (rtems_tcb* tcb)
> > -  return task->flags;
> > +  return tcb->capture.flags;
> > @@ -736,9 +692,9 @@ rtems_capture_task_flags (rtems_capture_task_t*
> task)
> >    * @retval This function returns the task control if present.
> > -rtems_capture_task_control (rtems_capture_task_t* task)
> > +rtems_capture_task_control (rtems_tcb* tcb)
> > -  return task->control;
> > +  return tcb->capture.control;
> > @@ -751,45 +707,12 @@ rtems_capture_task_control
> >    * @retval This function returns the task control flags if a control is
> present.
> > -rtems_capture_task_control_flags (rtems_capture_task_t* task)
> > +rtems_capture_task_control_flags (rtems_tcb* tcb)
> > -  if (!task->control)
> > +  rtems_capture_control_t*  control = tcb->capture.control;
> > +  if (!control)
> >       return 0;
> > -  return task->control->flags;
> > - * @brief Capture get number of times task switched in.
> > - * This function returns the number of times the task has
> > - * been switched into context.
> > - * @retval This function returns the number of times the task has
> > -static inline uint32_t
> > -rtems_capture_task_switched_in (rtems_capture_task_t* task)
> > -  return task->in;
> > - * @brief Capture get number of times task switched out.
> > - * been switched out of context.
> > -rtems_capture_task_switched_out (rtems_capture_task_t* task)
> > -  return task->out;
> > +  return control->flags;
> > @@ -804,9 +727,11 @@ rtems_capture_task_switched_out
> >    * to track where the task's priority goes.
> >   static inline rtems_task_priority
> > -rtems_capture_task_start_priority (rtems_capture_task_t* task)
> > +rtems_capture_task_start_priority (rtems_tcb* tcb)
> > -  return task->start_priority;
> > +  return _RTEMS_tasks_Priority_from_Core(
> > @@ -819,11 +744,9 @@ rtems_capture_task_start_priority
> >    * @retval This function returns the tasks real priority.
> > -rtems_capture_task_real_priority (rtems_capture_task_t* task)
> > +rtems_capture_task_real_priority (rtems_tcb* tcb)
> > -    return task->tcb->real_priority;
> > -  return 0;
> > +  return tcb->real_priority;
> > @@ -836,113 +759,9 @@ rtems_capture_task_real_priority
> >    * @retval This function returns the tasks current priority.
> > -rtems_capture_task_curr_priority (rtems_capture_task_t* task)
> > +rtems_capture_task_curr_priority (rtems_tcb* tcb)
> > -    return task->tcb->current_priority;
> > -  return 0;
> > - * @brief Capture update stack usage.
> > - * is updated.
> > - * @retval This function updates the stack usage. The task control block
> > - * is updated.
> > -uint32_t
> > -rtems_capture_task_stack_usage (rtems_capture_task_t* task);
> > - * @brief Capture get stack size.
> > - * This function returns the task's stack size.
> > - * @retval This function returns the task's stack size.
> > -rtems_capture_task_stack_size (rtems_capture_task_t* task)
> > -  return task->stack_size;
> > - * @brief Capture get stack used.
> > - * This function returns the amount of stack used.
> > - * @retval This function returns the amount of stack used.
> > -rtems_capture_task_stack_used (rtems_capture_task_t* task)
> > -  return task->stack_size - task->stack_clean;
> > - * @brief Capture get task execution time.
> > - * This function returns the current execution time.
> > - * @retval This function returns the current execution time.
> > -static inline uint64_t
> > -rtems_capture_task_time (rtems_capture_task_t* task)
> > -  return task->time;
> > - * @brief Capture get delta in execution time.
> > - * This function returns the execution time as a different between the
> > - * last time the detla time was and now.
> > - * @retval This function returns the execution time as a different between
> the
> > -rtems_capture_task_delta_time (rtems_capture_task_t* task)
> > -  uint64_t t = task->time - task->last_time;
> > -  task->last_time = task->time;
> > -  return t;
> > - * @brief Capture get task count.
> > - * This function returns the number of tasks the capture
> > - * engine knows about.
> > - * @retval This function returns the number of tasks the capture
> > -rtems_capture_task_count (void)
> > -  uint32_t              count = 0;
> > -  while (task)
> > -    count++;
> > -  return count;
> > +  return tcb->current_priority;
> > @@ -1070,7 +889,7 @@ rtems_capture_control_all_by_triggers
> (rtems_capture_control_t* control)
> >    * This function returns the control valid BY flags.
> >    * @param[in] control The capture control.
> > - * @param[in] slot The XXX.
> > + * @param[in] slot The slot.
> >    * @retval This function returns the control valid BY flags.
> > @@ -1086,7 +905,7 @@ rtems_capture_control_by_valid
> (rtems_capture_control_t* control, int slot)
> >    * This function returns the control @a by task name.
> > - * @param[in] by The XXX.
> > + * @param[in] by The by index.
> >    * @retval This function returns the control @a by task name.
> > diff --git a/cpukit/libmisc/capture/capture_user_extension.c
> b/cpukit/libmisc/capture/capture_user_extension.c
> > index 4236d8c..4c7bc1d 100644
> > --- a/cpukit/libmisc/capture/capture_user_extension.c
> > +++ b/cpukit/libmisc/capture/capture_user_extension.c
> > @@ -84,20 +84,20 @@ static const rtems_extensions_table
> capture_extensions = {
> >     .thread_terminate = rtems_capture_terminated_task
> >   static inline void rtems_capture_record (
> > -  rtems_capture_task_t* task,
> > -  uint32_t              events
> > +  rtems_tcb*    tcb,
> > +  uint32_t      events
> >     rtems_capture_record_t*  rec;
> > +  void*                    ptr;
> > +  size_t                   size = sizeof(*rec);
> > -  if (rtems_capture_filter( task, events) )
> > +  if (rtems_capture_filter( tcb, events) )
> >       return;
> > -  rtems_capture_begin_add_record (task, events, sizeof(*rec), &rec);
> > -  rtems_capture_end_add_record ( rec );
> > +  rtems_capture_begin_add_record (tcb, events, size, &ptr);
> > @@ -133,27 +133,21 @@ rtems_status_code
> rtems_capture_user_extension_close(void)
> >    * This function is called when a task is created.
> >   static bool
> > -rtems_capture_create_task (rtems_tcb* current_task,
> > -                           rtems_tcb* new_task)
> > +rtems_capture_create_task (rtems_tcb* ct,
> > +                           rtems_tcb* nt)
> Any specific reason to shorten the names ?
> > -  rtems_capture_task_t* nt;
> > -  int                   index = rtems_capture_get_extension_index();
> > -  ct = current_task->extensions[index];
> >      * The task pointers may not be known as the task may have
> >      * been created before the capture engine was open. Add them.
> > -  if (ct == NULL)
> > -    ct = rtems_capture_create_capture_task (current_task);
> > +  if (!rtems_capture_task_recorded (ct))
> > +    rtems_capture_record_task (ct);
> >      * Create the new task's capture control block.
> > -  nt = rtems_capture_create_capture_task (new_task);
> > +  rtems_capture_record_task (nt);
> >     if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
> > @@ -168,147 +162,85 @@ rtems_capture_create_task (rtems_tcb*
> current_task,
> >    * This function is called when a task is started.
> >   static void
> > -rtems_capture_start_task (rtems_tcb* current_task,
> > -                          rtems_tcb* started_task)
> > +rtems_capture_start_task (rtems_tcb* ct,
> > +                          rtems_tcb* st)
> > -   * Get the capture task control block so we can trace this
> > -   * event.
> > -  rtems_capture_task_t* st;
> > -  st = started_task->extensions[index];
> > -  if (ct == NULL)
> >     if (st == NULL)
> > -    st = rtems_capture_create_capture_task (started_task);
> > +    rtems_capture_record_task (st);
> >     if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
> >       rtems_capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT);
> >       rtems_capture_record (st, RTEMS_CAPTURE_STARTED_EVENT);
> > -  rtems_capture_init_stack_usage (st);
> >    * This function is called when a task is restarted.
> >   static void
> > -rtems_capture_restart_task (rtems_tcb* current_task,
> > -                            rtems_tcb* restarted_task)
> > +rtems_capture_restart_task (rtems_tcb* ct,
> > +                            rtems_tcb* rt)
> > -   * event.
> > -  rtems_capture_task_t* rt;
> > -  rt = restarted_task->extensions[index];
> > -  if (ct == NULL)
> > -  if (rt == NULL)
> > -    rt = rtems_capture_create_capture_task (restarted_task);
> > +  if (!rtems_capture_task_recorded (rt))
> > +    rtems_capture_record_task (rt);
> >     if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
> >       rtems_capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT);
> >       rtems_capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT);
> > -  rtems_capture_task_stack_usage (rt);
> > -  rtems_capture_init_stack_usage (rt);
> >    * This function is called when a task is deleted.
> >   static void
> > -rtems_capture_delete_task (rtems_tcb* current_task,
> > -                           rtems_tcb* deleted_task)
> > +rtems_capture_delete_task (rtems_tcb* ct,
> > +                           rtems_tcb* dt)
> > -   * event.
> > -  rtems_capture_task_t* dt;
> > -   * The task pointers may not be known as the task may have
> > -   * been created before the capture engine was open. Add them.
> > -  dt = deleted_task->extensions[index];
> > -  if (ct == NULL)
> > -  if (dt == NULL)
> > -    dt = rtems_capture_create_capture_task (deleted_task);
> > +  if (!rtems_capture_task_recorded (dt))
> > +    rtems_capture_record_task (dt);
> >     if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
> >       rtems_capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT);
> >       rtems_capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT);
> > -  rtems_capture_task_stack_usage (dt);
> > -   * This task's tcb will be invalid. This signals the
> > -   * task has been deleted.
> > -  dt->tcb = 0;
> > -  rtems_capture_destroy_capture_task (dt);
> >    * This function is called when a task is begun.
> >   static void
> > -rtems_capture_begin_task (rtems_tcb* begin_task)
> > +rtems_capture_begin_task (rtems_tcb* bt)
> > -   * event.
> > -  rtems_capture_task_t* bt;
> > -  bt = begin_task->extensions[index];
> > -  if (bt == NULL)
> > -    bt = rtems_capture_create_capture_task (begin_task);
> > +  if (!rtems_capture_task_recorded (bt))
> > +    rtems_capture_record_task (bt);
> >     if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
> >       rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
> > @@ -319,69 +251,46 @@ rtems_capture_begin_task (rtems_tcb*
> begin_task)
> >    * returned rather than was deleted.
> >   static void
> > -rtems_capture_exitted_task (rtems_tcb* exitted_task)
> > +rtems_capture_exitted_task (rtems_tcb* et)
> > -   * event.
> > -  rtems_capture_task_t* et;
> > -  et = exitted_task->extensions[index];
> > -  if (et == NULL)
> > -    et = rtems_capture_create_capture_task (exitted_task);
> > +  if (!rtems_capture_task_recorded (et))
> > +    rtems_capture_record_task (et);
> >     if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
> >       rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
> > -  rtems_capture_task_stack_usage (et);
> >    * This function is called when a termination request is identified.
> >   static void
> > -rtems_capture_terminated_task (rtems_tcb* terminated_task)
> > +rtems_capture_terminated_task (rtems_tcb* tt)
> > -   * event.
> > -  rtems_capture_task_t* tt;
> > -  tt = terminated_task->extensions[index];
> > -  if (tt == NULL)
> > -    tt = rtems_capture_create_capture_task (terminated_task);
> > +  if (!rtems_capture_task_recorded (tt))
> > +    rtems_capture_record_task (tt);
> >     if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
> >       rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
> > -  rtems_capture_task_stack_usage (tt);
> >    * This function is called when a context is switched.
> >   static void
> > -rtems_capture_switch_task (rtems_tcb* current_task,
> > -                           rtems_tcb* heir_task)
> > +rtems_capture_switch_task (rtems_tcb* ct,
> > +                           rtems_tcb* ht)
> >     uint32_t flags = rtems_capture_get_flags();
> >      * Only perform context switch trace processing if tracing is
> > @@ -391,33 +300,11 @@ rtems_capture_switch_task (rtems_tcb*
> current_task,
> > -     * Get the cpature task control block so we can update the
> > -     * reference and perform any watch or trigger functions.
> > -    rtems_capture_task_t* ht;
> > -    if (_States_Is_dormant (current_task->current_state))
> > -      rtems_id ct_id = current_task->Object.id;
> > -      ct = rtems_capture_find_capture_task( ct_id );
> > -    else
> > -      if (ct == NULL)
> > -    ht = heir_task->extensions[index];
> > -    if (ht == NULL)
> > -      ht = rtems_capture_create_capture_task (heir_task);
> > +    if (!rtems_capture_task_recorded (ht))
> > +      rtems_capture_record_task (ht);
> >        * Update the execution time. Assume the time will not overflow
> > @@ -425,24 +312,6 @@ rtems_capture_switch_task (rtems_tcb*
> current_task,
> > -     * We could end up with null pointers for both the current task
> > -     * and the heir task.
> > -    if (ht)
> > -      ht->in++;
> > -      ht->time_in = time;
> > -    if (ct)
> > -      ct->out++;
> > -      if (ct->time_in)
> > -        ct->time += time - ct->time_in;
> >       if (rtems_capture_trigger (ct, ht, RTEMS_CAPTURE_SWITCH))
> RTEMS_CAPTURE_SWITCHED_OUT_EVENT);
> > diff --git a/cpukit/libmisc/capture/captureimpl.h
> b/cpukit/libmisc/capture/captureimpl.h
> > index fa36688..3c2f6c3 100644
> > --- a/cpukit/libmisc/capture/captureimpl.h
> > +++ b/cpukit/libmisc/capture/captureimpl.h
> > @@ -116,29 +116,6 @@ rtems_status_code
> rtems_capture_user_extension_open(void);
> >   rtems_status_code rtems_capture_user_extension_close(void);
> > - * @brief Capture find capture task.
> > - * This function finds the capture task control block
> > - * @param[in] ct_id specifies the task_id
> > - * @retval This method returns the capture task control block associated
> > - * with the given task id.
> ct_id );
> > - * @brief Capture create capture task control block.
> > - * This function create the capture task control block
> > - * @param[in] new_task specifies the rtems thread control block
> > - * @retval This method returns a capture task control block.
> > -rtems_capture_task_t* rtems_capture_create_capture_task (rtems_tcb*
> new_task);
> >    * @brief Capture trigger.
> >    * This function checks if we have triggered or if this event is a
> > @@ -151,9 +128,9 @@ rtems_capture_task_t*
> rtems_capture_create_capture_task (rtems_tcb* new_task);
> >    * @retval This method returns true if we have triggered or
> >    * if the event is a cause of a trigger.
> > -bool rtems_capture_trigger (rtems_capture_task_t* ft,
> > -                       uint32_t              events);
> > +bool rtems_capture_trigger (rtems_tcb* ft,
> > +                            rtems_tcb* tt,
> > +                            uint32_t   events);
> >    * @brief Capture append to record
> > @@ -188,7 +165,7 @@ static void
> *rtems_capture_append_to_record(void*  rec,
> >    * filtered from the log.  It returns false if this data
> >    * should be logged.
> > +bool rtems_capture_filter( rtems_tcb*            task,
> >                              uint32_t              events);
> >    * @brief Capture begin add record.
> > @@ -238,26 +215,6 @@ static inline void
> >     } while (0)
> > - * @brief Capture initialize stack usage
> > - * @param[in] task specifies the capture task block
> > -void rtems_capture_init_stack_usage (rtems_capture_task_t* task);
> > - * @brief Capture destroy task.
> > - * deleted.
> > -void rtems_capture_destroy_capture_task (rtems_capture_task_t* task);
> >    * @brief .
> > @@ -287,7 +244,7 @@ void rtems_capture_get_time
> (rtems_capture_time_t* time);
> >    * @retval This method returns a pointer to the next location in
> >    * the capture record to store data.
> > -void* rtems_capture_record_open (rtems_capture_task_t*         task,
> > +void* rtems_capture_record_open (rtems_tcb*                    task,
> >                                    uint32_t                      events,
> >                                    size_t                        size,
> >                                    rtems_interrupt_lock_context* lock_context);
> devel mailing list
> devel at rtems.org
