[rtems commit] m68k: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC
Tue Sep 23 15:38:54 UTC 2014
The code is m68k and the comment is PowerPC.
Any guidance for the porting guide on what constitutes too expensive? There should be some general guidelines regarding when to pick a format bases on that.
Also.. This means that some ports will have 2038 issues at the score level. We have to address 64 bit time_t at some point.
On September 23, 2014 3:42:48 AM CDT, Sebastian Huber <sebh at rtems.org> wrote:
>Module:    rtems
>Branch:    master
>Commit:    5323247c3148a22baefb1590533972c401f7d745
>Changeset:
>http://git.rtems.org/rtems/commit/?id=5323247c3148a22baefb1590533972c401f7d745
>Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>Date:      Tue Sep 23 08:01:56 2014 +0200
>Converting 64-bit nanoseconds values into the common struct timeval or
>struct timespec formats requires a 64-bit division to get the seconds
>value.  Performance analysis of high network loads revealed that this
>is
>too costly on PowerPC.
> cpukit/score/cpu/m68k/rtems/score/cpu.h |    2 +-
> 1 files changed, 1 insertions(+), 1 deletions(-)
>diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h
>b/cpukit/score/cpu/m68k/rtems/score/cpu.h
>index d222465..7d164f3 100644
>--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
>+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
>@@ -102,7 +102,7 @@ extern "C" {
> #define CPU_STACK_GROWS_UP               FALSE
> #define CPU_STRUCTURE_ALIGNMENT          __attribute__ ((aligned (4)))
>-#define CPU_TIMESTAMP_USE_INT64_INLINE TRUE
>+#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE
>*  Define what is required to specify how the network to host
>conversion
>_______________________________________________
>vc mailing list
>vc at rtems.org
>http://lists.rtems.org/mailman/listinfo/vc
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140923/91bd2f71/attachment.html>
