[PATCH] or1ksim: Console: implement uart_read_polled
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Sep 29 19:38:38 UTC 2014
Sorry. This is now committed.
Anything else besides the task stack initialization patch?
--joel
On 9/29/2014 12:57 AM, Hesham Moustafa wrote:
> Hi,
> This patch is needed for capture, pppd and any other tests that prompt
> users to input data interactively.
> Regards,
> Hesham
> On Fri, Sep 19, 2014 at 9:20 PM, Hesham ALMatary
> <heshamelmatary at gmail.com <mailto:heshamelmatary at gmail.com>> wrote:
> Implement uart_read_polled which is needed for any application that
> reads input from users. It works fine with pppd, capture, and all
> termios tests.
> c/src/lib/libbsp/or1k/or1ksim/console/uart.c | 13 +++++++++++--
> 1 file changed, 11 insertions(+), 2 deletions(-)
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> index f1cfa09..c0ee618 100644
> --- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> @@ -86,9 +86,18 @@ static int uart_last_close(int major, int
> minor, void *arg)
> return 0;
> -static int uart_read_polled(int minor)
> +static char uart_read_polled(int minor)
> - return -1;
> + unsigned char lsr;
> + char c;
> + /* Get a character when avaiable */
> + do {
> + lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
> + } while ((lsr & OR1KSIM_BSP_UART_REG_LINE_STATUS_DR)
> + != OR1KSIM_BSP_UART_REG_LINE_STATUS_DR);
> + return OR1KSIM_REG(OR1KSIM_BSP_UART_REG_RX);
> static void uart_write_polled(int minor, char c)
> 1.9.3
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140929/19e1d2a8/attachment.html>
