[PATCH] or1ksim: Console: implement uart_read_polled
Hesham Moustafa
heshamelmatary at gmail.com
Mon Sep 29 19:53:58 UTC 2014
Thanks for committing.
There are some other few pending patches. This one [1] adds
qemu-system-or32 script to sim-scripts, and this [2] adds a new RTEMS
tester script to test or1ksim BSP running on qemu.
[1] http://lists.rtems.org/pipermail/devel/2014-September/008064.html
[2] http://lists.rtems.org/pipermail/devel/2014-September/008047.html
On Mon, Sep 29, 2014 at 9:38 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> Sorry. This is now committed.
> Anything else besides the task stack initialization patch?
> --joel
> On 9/29/2014 12:57 AM, Hesham Moustafa wrote:
> Hi,
> This patch is needed for capture, pppd and any other tests that prompt
> users to input data interactively.
> Regards,
> Hesham
> On Fri, Sep 19, 2014 at 9:20 PM, Hesham ALMatary <heshamelmatary at gmail.com
> > wrote:
>> Implement uart_read_polled which is needed for any application that
>> reads input from users. It works fine with pppd, capture, and all
>> termios tests.
>> c/src/lib/libbsp/or1k/or1ksim/console/uart.c | 13 +++++++++++--
>> 1 file changed, 11 insertions(+), 2 deletions(-)
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>> b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>> index f1cfa09..c0ee618 100644
>> --- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>> @@ -86,9 +86,18 @@ static int uart_last_close(int major, int minor, void
>> *arg)
>> return 0;
>> -static int uart_read_polled(int minor)
>> +static char uart_read_polled(int minor)
>> - return -1;
>> + unsigned char lsr;
>> + char c;
>> + /* Get a character when avaiable */
>> + do {
>> + lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
>> + } while ((lsr & OR1KSIM_BSP_UART_REG_LINE_STATUS_DR)
>> + != OR1KSIM_BSP_UART_REG_LINE_STATUS_DR);
>> + return OR1KSIM_REG(OR1KSIM_BSP_UART_REG_RX);
>> static void uart_write_polled(int minor, char c)
>> 1.9.3
> Joel Sherrill, Ph.D. Director of Research & Developmentjoel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140929/2e0de0be/attachment.html>
