[PATCH] Adding "eth" linker script section for arm bsp.
Federico Casares
federico.casares at tallertechnologies.com
Tue Sep 2 13:07:37 UTC 2014
Hi Sebastian,
Are you suggesting to remove the
"lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg" and
"lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth.cfg" files?
The tcfg includes in its list two tests that should not be compiled for
this BSP configuration, due to BBS size required by those tests. This
differs from the other configurations available for the LPC176x.
Regards.
On Tue, Sep 2, 2014 at 9:01 AM, Sebastian Huber <
> Hello Federico,
> since this just adds a linker command file variant, I would prefer to just
> add the linker command file without the BSP name. You can then use
> "-qnolinkcmds -T linkcmds.lpc1768_mbed_ahb_ram_eth" to select this memory
> map.
> On 01/09/14 15:21, Federico Casares wrote:
>> Attached the new version of this add.
>> Regards
>> On Fri, Aug 29, 2014 at 2:30 PM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> Hello Federico,
>> you can do it like this:
>> http://git.rtems.org/rtems/__tree/c/src/lib/libbsp/arm/__
>> altera-cyclone-v/startup/__linkcmds.altcycv_devkit
>> <http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/
>> altera-cyclone-v/startup/linkcmds.altcycv_devkit>
>> You can also use the INCLUDE directive to reduce the copy and paste.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-__brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> http://www.tallertechnologies.com <http://www.tallertechnologies.com>
>> Casares, Federico
>> Sr. Software Engineer
>> Taller Technologies Argentina
>> San Lorenzo 47, 3rd Floor, Office 5
>> Córdoba, Argentina
[image: http://www.tallertechnologies.com]
Casares, Federico
Córdoba, Argentina
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140902/1b5e6328/attachment-0002.html>
