[PATCH] or1k: New cache manager.
    Hesham Moustafa
    heshamelmatary at gmail.com
    Tue Sep 16 18:34:09 UTC 2014
On Tue, Sep 16, 2014 at 8:15 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 9/16/2014 12:54 PM, Hesham Moustafa wrote:
>> Hi
>> On Tue, Sep 16, 2014 at 7:47 PM, Joel Sherrill
>>> I don't understand this but I got it applied.
>>> I manually edited the saved email to delete the preinstall.am
>>> changes.  I committed the rest. Then I ran bootstrap -p myself
>>> and folded that into the rest of your patch.
>>> It should all be committed now.
>> Thanks for doing this, me too do not know what's wrong. BTW, commits
>> are not mirrored on github since 4 days ago.
>>> How about some new test results. :)
>> I did run one last night, no big progress since previous results :( Is
>> there any tool, script, utility program or whatever that I can use to
>> detect wrong memory access (i.e, stack overwrite, heap corruption,
>> access to another task context)? I tried to add -fstack-protector-all
>> to gcc, but QEMU did not get anything or core-dump, ticker just hangs.
> I haven't checked into how gcc does its stack overwrite protection.
> The tests by themselves don't have these problems. The first
> possible source is incorrect layout of sections to memory by
> the linker script. There is some debug code in boot
> There used to be debug printk's in bspgetworkarea.c so you
> could check if areas overlapped. That usually causes bad issues
> though. Let's go through some basics:
> + Does hello world run and exit cleanly?
The output of Hello World is:
*** BEGIN OF TEST HELLO WORLD ***
Hello World
*** END OF TEST HELLO WORLD ***
Fatal Error 5.0 Halted
>From GDB:
Breakpoint 1, _Terminate (
    the_source=RTEMS_FATAL_SOURCE_EXIT, is_internal=false, the_error=0)
    at ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:39
39  _ISR_Disable_without_giant( level );
(gdb) bt
#0  _Terminate (
#1  0x0003b5f8 in rtems_shutdown_executive (result=0)
    at ../../../../../../rtems/c/src/../../cpukit/sapi/src/exshutdown.c:21
#2  0x0003b350 in _exit (status=0)
    at ../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:47
#3  0x0002cc30 in exit (code=0)
    at ../../../../../gcc-4.8.3/newlib/libc/stdlib/exit.c:70
#4  0x00002184 in Init (ignored=253816)
    at ../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c:33
---Type <return> to continue, or q <return> to quit---
#5  0x0002c5b8 in _Thread_Handler ()
    at ../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:192
#6  0x0002c540 in _User_extensions_Thread_exitted (executing=0x40080)
    at ../../cpukit/../../../or1ksim/lib/include/rtems/score/userextimpl.h:243
> + How far does ticker get?
Ticker goes to the end:
*** BEGIN OF TEST CLOCK TICK ***
TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:05   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:10   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:10   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:15   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:15   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:20   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:20   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:25   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:30   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:30   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:30   12/31/1988
*** END OF TEST CLOCK TICK ***
Fatal Error 9.276564 Halted
>From GDB:
(gdb) break _Terminate
Breakpoint 1 at 0x19a68: file
../../../../../../rtems/c/src/../../cpukit/score/src/interr.c, line
39.
(gdb) break _OR1K_Exception_default
Breakpoint 2 at 0x2686c: file
../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c,
line 22.
(gdb) c
The program is not being run.
(gdb) target remote :50001
Remote debugging using :50001
0x00000100 in _reset ()
(gdb) c
Continuing.
Breakpoint 2, _OR1K_Exception_default (vector=6, frame=0x43854) at
../../../../../../../../rtems/c/src/../../cpukit/score/cpu/or1k/or1k-exception-default.c:22
22  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
(gdb) bt
#0  _OR1K_Exception_default (vector=6, frame=0x43854) at
#1  0x00026980 in jump_to_c_handler ()
Backtrace stopped: frame did not save the PC
vector 6 is _unalign exception.
> + Have you tried the trick I suggested earlier to disable the
> real clock tick driver, use the simulator idle tick code, and
> disable all the tests that are known to fail that way. This
> will eliminate the ISR code as an issue because you won't
> have any (if console output if polled).  See h8sim for
> an example. Should be a Makefile.am change, adding
> an include to the testsuite configuration file, building
> and running.
>>> --joel
>>> On 9/16/2014 12:30 PM, Hesham ALMatary wrote:
>>>> Implement new cache functions for or1k and create new bspstart function
>>>> for or1ksim to initialize instruction and data caches. Also, sim.cfg
>>>> is modified to enable/confiure cache units.
>>>>  c/src/lib/libbsp/or1k/or1ksim/Makefile.am        |   9 +-
>>>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am      |   4 +
>>>>  c/src/lib/libbsp/or1k/or1ksim/sim.cfg            |  21 +-
>>>>  c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c |  25 +++
>>>>  c/src/lib/libbsp/or1k/shared/include/cache_.h    |  43 ++++
>>>>  c/src/lib/libcpu/or1k/Makefile.am                |   3 +-
>>>>  c/src/lib/libcpu/or1k/preinstall.am              |   4 +
>>>>  c/src/lib/libcpu/or1k/shared/cache/cache.c       | 241 +++++++++++++++++++++++
>>>>  c/src/lib/libcpu/or1k/shared/cache/cache_.h      |   2 +-
>>>>  9 files changed, 334 insertions(+), 18 deletions(-)
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>>  create mode 100644 c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>>  create mode 100644 c/src/lib/libcpu/or1k/shared/cache/cache.c
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>> index 7af4fd0..7e1c10b 100644
>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>> @@ -30,6 +30,7 @@ include_bsp_HEADERS += ../../shared/include/irq-info.h
>>>>  include_bsp_HEADERS += ../../shared/include/stackalloc.h
>>>>  include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>>>>  include_bsp_HEADERS += ../../shared/tod.h
>>>> +include_bsp_HEADERS += ../shared/include/cache_.h
>>>>  include_bsp_HEADERS += include/irq.h
>>>>  include_bsp_HEADERS += include/uart.h
>>>>  include_bsp_HEADERS += include/or1ksim.h
>>>> @@ -61,8 +62,8 @@ libbsp_a_CPPFLAGS =
>>>>  libbsp_a_LIBADD =
>>>>  # Startup
>>>> -libbsp_a_SOURCES += ../../shared/bspstart.c
>>>>  libbsp_a_SOURCES += ../../shared/bspreset.c
>>>> +libbsp_a_SOURCES += startup/bspstart.c
>>>>  # Shared
>>>>  libbsp_a_SOURCES += ../../shared/bootcard.c
>>>> @@ -72,8 +73,6 @@ libbsp_a_SOURCES += ../../shared/bsplibc.c
>>>>  libbsp_a_SOURCES += ../../shared/bsppost.c
>>>>  libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
>>>>  libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>>>> -libbsp_a_SOURCES += ../../shared/cpucounterread.c
>>>> -libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
>>>>  libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>>>>  libbsp_a_SOURCES += ../../shared/sbrk.c
>>>>  libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>>>> @@ -100,9 +99,7 @@ libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>>>  libbsp_a_SOURCES += irq/irq.c
>>>>  # Cache
>>>> -libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>>>> -libbsp_a_SOURCES += ../../shared/include/cache_.h
>>>> -libbsp_a_CPPFLAGS += -I$(srcdir)/../../shared/include
>>>> +libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
>>>>  #                  Special Rules                                              #
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> index 1561b18..c0fa6b8 100644
>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> @@ -86,6 +86,10 @@ $(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h $(PROJECT_INCLUDE)/bsp/$(dirsta
>>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
>>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
>>>> +$(PROJECT_INCLUDE)/bsp/cache_.h: ../shared/include/cache_.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/cache_.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/cache_.h
>>>>  $(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>>> index 061f61a..ec73e3d 100644
>>>> --- a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
>>>> @@ -35,23 +35,23 @@ section mc
>>>>  end
>>>>  section ic
>>>> -  enabled   =   0
>>>> +  enabled   =   1
>>>>    nsets     = 256
>>>>    nways     =   1
>>>> -  blocksize =  16
>>>> +  blocksize =  32
>>>>    hitdelay  =  20
>>>> -  missdelay =  20
>>>> +  missdelay =  60
>>>>  end
>>>>  section dc
>>>> -  enabled = 0
>>>> -  nsets = 256
>>>> +  enabled = 1
>>>> +  nsets = 256
>>>>    nways = 1
>>>> -  blocksize = 16
>>>> -  load_hitdelay = 0
>>>> -  load_missdelay = 0
>>>> -  store_hitdelay = 0
>>>> -  store_missdelay = 0
>>>> +  blocksize = 32
>>>> +  load_hitdelay = 40
>>>> +  load_missdelay = 120
>>>> +  store_hitdelay = 40
>>>> +  store_missdelay = 120
>>>>  end
>>>>  section pic
>>>> @@ -78,6 +78,7 @@ section cpu
>>>>    ver = 0x12
>>>>    cfg = 0x00
>>>>    rev = 0x0001
>>>> +  upr = 0x0000075f
>>>>    superscalar = 0
>>>>    hazards = 0
>>>>    dependstats = 0
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>> new file mode 100644
>>>> index 0000000..d9fb7a7
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c
>>>> @@ -0,0 +1,25 @@
>>>> + * @file
>>>> + * @ingroup or1ksim
>>>> + * @brief Benchmark timer support.
>>>> + * Copyright (c) 2014 by Hesham ALMatary
>>>> + *  The license and distribution terms for this file may be
>>>> + *  found in the file LICENSE in this distribution or at
>>>> + *  http://www.rtems.org/license/LICENSE
>>>> +#include <bsp.h>
>>>> +#include <bsp/bootcard.h>
>>>> +#include <libcpu/cache.h>
>>>> +void bsp_start( void )
>>>> +  _CPU_cache_enable_instruction();
>>>> +  _CPU_cache_enable_data();
>>>> diff --git a/c/src/lib/libbsp/or1k/shared/include/cache_.h b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>> index 0000000..ee54227
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/shared/include/cache_.h
>>>> @@ -0,0 +1,43 @@
>>>> + * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>>>> + * http://www.rtems.org/license/LICENSE.
>>>> +#ifndef LIBBSP_OR1K_SHARED_CACHE_H
>>>> +#define LIBBSP_OR1K_SHARED_CACHE_H
>>>> +#include <assert.h>
>>>> +#include <bsp.h>
>>>> +#include <rtems/rtems/intr.h>
>>>> +#ifdef __cplusplus
>>>> +extern "C" {
>>>> +#endif /* __cplusplus */
>>>> +/* These two defines also ensure that the rtems_cache_* functions have bodies */
>>>> +#define CPU_DATA_CACHE_ALIGNMENT        32
>>>> +#define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
>>>> +#define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS 1
>>>> +static inline size_t
>>>> +_CPU_cache_get_data_cache_size( const uint32_t level )
>>>> +  return (level == 0 || level == 1)? 8192 : 0;
>>>> +_CPU_cache_get_instruction_cache_size( const uint32_t level )
>>>> +#ifdef __cplusplus
>>>> +#endif /* LIBBSP_OR1K_SHARED_CACHE_H */
>>>> diff --git a/c/src/lib/libcpu/or1k/Makefile.am b/c/src/lib/libcpu/or1k/Makefile.am
>>>> index f4a6372..0148548 100644
>>>> --- a/c/src/lib/libcpu/or1k/Makefile.am
>>>> +++ b/c/src/lib/libcpu/or1k/Makefile.am
>>>> @@ -10,8 +10,9 @@ include_libcpudir = $(includedir)/libcpu
>>>>  ## shared/cache
>>>>  include_libcpu_HEADERS = ../shared/include/cache.h
>>>> +include_libcpu_HEADERS += shared/cache/cache_.h
>>>>  noinst_PROGRAMS += shared/cache.rel
>>>> -shared_cache_rel_SOURCES = ../shared/src/no_cache.c shared/cache/cache_.h
>>>> +shared_cache_rel_SOURCES = shared/cache/cache.c ../shared/src/cache_manager.c
>>>>  shared_cache_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/cache
>>>>  shared_cache_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>> diff --git a/c/src/lib/libcpu/or1k/preinstall.am b/c/src/lib/libcpu/or1k/preinstall.am
>>>> index ee9d0da..84864cb 100644
>>>> --- a/c/src/lib/libcpu/or1k/preinstall.am
>>>> +++ b/c/src/lib/libcpu/or1k/preinstall.am
>>>> @@ -22,3 +22,7 @@ $(PROJECT_INCLUDE)/libcpu/cache.h: ../shared/include/cache.h $(PROJECT_INCLUDE)/
>>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache.h
>>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache.h
>>>> +$(PROJECT_INCLUDE)/libcpu/cache_.h: shared/cache/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
>>>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>>>> index 0000000..fdc67ce
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>>>> @@ -0,0 +1,241 @@
>>>> + * COPYRIGHT (c) 1989-2006
>>>> + * On-Line Applications Research Corporation (OAR).
>>>> +#include <rtems/score/cpu.h>
>>>> +#include <rtems/score/interr.h>
>>>> +#include <rtems/score/or1k-utility.h>
>>>> +static inline void _CPU_OR1K_Cache_enable_data(void)
>>>> +  uint32_t sr;
>>>> +   ISR_Level level;
>>>> +  _ISR_Disable (level);
>>>> +  sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_DCE);
>>>> +  _ISR_Enable(level);
>>>> +static inline void _CPU_OR1K_Cache_disable_data(void)
>>>> +  uint32_t sr;
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_DCE));
>>>> +static inline void _CPU_OR1K_Cache_enable_instruction(void)
>>>> +  uint32_t sr;
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr | CPU_OR1K_SPR_SR_ICE);
>>>> +static inline void _CPU_OR1K_Cache_disable_instruction(void)
>>>> +  uint32_t sr;
>>>> +  ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & ~CPU_OR1K_SPR_SR_ICE));
>>>> +static inline void _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
>>>> +  ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
>>>> +static inline void _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
>>>> +static inline void _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
>>>> +static inline void _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
>>>> +static inline void _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
>>>> +static inline void _CPU_OR1K_Cache_instruction_block_prefetch
>>>> +(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
>>>> +static inline void _CPU_OR1K_Cache_instruction_block_invalidate
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
>>>> +static inline void _CPU_OR1K_Cache_instruction_block_lock
>>>> +   ISR_Level level;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
>>>> +/* Implement RTEMS cache manager functions */
>>>> +void _CPU_cache_flush_1_data_line(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _CPU_OR1K_Cache_data_block_flush(d_addr);
>>>> +  //asm volatile("l.csync");
>>>> +void _CPU_cache_invalidate_1_data_line(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _CPU_OR1K_Cache_data_block_invalidate(d_addr);
>>>> +void _CPU_cache_freeze_data(void)
>>>> +  /* Do nothing */
>>>> +void _CPU_cache_unfreeze_data(void)
>>>> +  /* Do nothing */
>>>> +void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
>>>> +   ISR_Level level;
>>>> +  _CPU_OR1K_Cache_instruction_block_invalidate(d_addr);
>>>> +void _CPU_cache_freeze_instruction(void)
>>>> +  /* Do nothing */
>>>> +void _CPU_cache_unfreeze_instruction(void)
>>>> +  /* Do nothing */
>>>> +void _CPU_cache_flush_entire_data(void)
>>>> +void _CPU_cache_invalidate_entire_data(void)
>>>> +void _CPU_cache_invalidate_entire_instruction(void)
>>>> +void _CPU_cache_enable_data(void)
>>>> +  _CPU_OR1K_Cache_enable_data();
>>>> +void _CPU_cache_disable_data(void)
>>>> +  _CPU_OR1K_Cache_disable_data();
>>>> +void _CPU_cache_enable_instruction(void)
>>>> +  _CPU_OR1K_Cache_enable_instruction();
>>>> +void _CPU_cache_disable_instruction(void)
>>>> +  _CPU_OR1K_Cache_disable_instruction();
>>>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>>> index 08d9ecc..5f08410 100644
>>>> --- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>>>> @@ -5,7 +5,7 @@
>>>>  #ifndef __OR1K_CACHE_H
>>>>  #define __OR1K_CACHE_H
>>>> -#include <libcpu/cache.h>
>>>> +#include <bsp/cache_.h>
>>>>  #endif
>>>>  /* end of include file */
>>>> 1.9.3
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
