or1ksim: Updated results from RTEMS Tester
Hesham Moustafa
heshamelmatary at gmail.com
Sat Sep 20 05:13:32 UTC 2014
On Sep 20, 2014 6:44 AM, "Chris Johns" <chrisj at rtems.org> wrote:
> On 20/09/2014 12:56 am, Hesham Moustafa wrote:
>> However, when I tested failures and timeouts separately, most of them
>> work on QEMU, the others miss the trailing end-of-test line, which
>> exists when I run them on or1ksim simulator.
> How many cores do you have and what host OS ? I assume this is not on a
VM.
I have 4 physical cores, and I usually run make with J8. My host OS is
fedora 20.
> The tester attempts to have a single test running on each core but the
effect this can have may vary from host to host. The --jobs option is there
to help.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140920/066da825/attachment-0002.html>
