TMS570 BSP: RTEMS license compatible TMS570LS3137 header files progress
Wed Apr 1 14:38:05 UTC 2015
On Wed, Apr 1, 2015 at 7:01 AM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
> Hello all,
> I would like to inform you that Premysl Houdek is near to finishing
> preparation of complete registers header files for TMS570LS3137.
> The register and fields definition are interactively retrieved
> with help of some macro from MCU PDF manual files.
This is a great effort
> We decided to store retrieved data in JSON format.
> The raw files are available in rtems-tms570-utils repository
> temporary branch
>   https://github.com/AoLaD/rtems-tms570-utils/tree/Headers/headers/raw_files
> There are examples of the final JSON files after check/review
> for completeness. I.e. for CRC module
>   https://github.com/AoLaD/rtems-tms570-utils/blob/Headers/headers/prepared_files/CRC.json
> Then there is a Python script which generates RTEMS style
> headerfiles. Example
>   https://github.com/AoLaD/rtems-tms570-utils/blob/Headers/headers/headers/CRC.h
For headers/code that is automatically generated, I'd like to see a
very permissive license applied to the tool output. Slapping an RTEMS
License on it is ok, but not ideal to me. I guess we should just
ensure the license on the Python script is suitable for use in
generating usably-licensed code. I don't know what licensing models
exist for this.
> The single bit fields are generated as
>   #define TMS570_CRC_CRC_INTR_CH2_TIMEOUTENR BSP_FLD32(12)
> The multibit fields should be generated as
>   #define TMS570_CRC_CRC_PCOUNT_REG1_CRC_PAT_COUNT1(val) BSP_FLD32(val,0, 19)
>   #define TMS570_CRC_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19)
>   #define TMS570_CRC_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
This seems a little verbose. I guess the automatic definitions may be
hard to generate, but CRC 3 times in the def name is a lot.
> There is now mistake that GET is used once instead of SET in this example.
> But that will be corrected.
> It would be great amount of work to prepare complete initialization
> sequence from scratch to not touch problematically licensed HalCoGen
> files. But when format of header files is agreed upon it is doable.
This is an interesting direction to go. The idea of generating init
code (and bootstrap!) from documentation is compelling.
> So generally, what is your opinion about the format?
> (may be that tools and approach can be reused for other chips as well)
> We plan to shake-up actual RTEMS TMS570 serial port and timers
> support to use proposed headers format. Then we start on HalCoGen-free
> boot-up process work. So I hope we can have complete self-contained
> RTEMS support mainlined one day.
Keep an eye out for development of RTEMS with micromonitor bootloader.
This may be a useful tool for generating code in it maybe.
> The first step is to finish headers and replace initial sparse
> ones in RTEMS mainline by new set. I expect that we include only
> header files in RTEMS and JSONs stay in utils repo. But we are open
> to other suggestions as well.
> To Martin Galvan: What is your opinion? Would you join the work in
> this direction?
> We have no contract for the work so I cannot promise any timing.
> Premysl Houdek should to finish main part of the work before
> his thesis submission. Which can be in two up to max eight months.
I think if you can get proof-of-concept for generating bootstrap code
from documentation, this could be compelling for some users out there
to give money to produce non-GPL bootloaders for other boards. Not
that I know of any off-hand.
> Best wishes,
>                 Pavel
> devel mailing list
> devel at rtems.org
