Propose to release 4.11 pending drvmgr/pci
Wed Apr 1 15:31:42 UTC 2015
On Wed, Apr 1, 2015 at 11:25 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On April 1, 2015 10:14:48 AM CDT, Daniel Hellstrom <daniel at gaisler.com> wrote:
>>On 04/01/2015 05:05 PM, Gedare Bloom wrote:
>>> Daniel,
>>> On Wed, Apr 1, 2015 at 11:02 AM, Daniel Hellstrom
>>>> On 04/01/2015 04:40 PM, Gedare Bloom wrote:
>>>>> I'd like to cut the 4.11 branch as soon as we get the drvmgr/pci
>>>>> patches merged. Please state if you have any other necessary
>>patches
>>>>> or blockers for release. The plan will be to create a 4.11 branch
>>and
>>>>> tag 4.11.0 and then only bug-fixes should go into 4.11 branch, and
>>>>> master becomes the next release branch.
>>>>> Gedare
>>>> I hope that this includes the drivers that depends on the
>>libpci/drvmgr too?
>>>> Otherwise I have no patches pending.
>>>> Danielh
>>> Yes, I'd like for you to push the patches you have posted, and if you
>>> have fixes yet to push those, otherwise we will post fixes to both
>>the
>>> 4.11 and new release series for drvmgr. We'll treat it as
>>> "sparc-specific" code for now despite that it is in cpukit, with the
>>> long-term goal to get a testing framework up and get it usable across
>>> architectures.
>>> Gedare
>>Ok. Then I will finish up the clean-up work I started and I will also
>>make the libdrvmgr sparc specific since the libpci already is. After
>>that I will push it to master. Then I will continue with the
>>clean-ups and submit them to the list and we will see how/when that is
>>included.
> Is there any user documentation at this point? I don't know what if any would eventually be part of the BSP Guide.
> Just adding it to the testing task.
There is I believe a new texinfo for pci and a separate docbook for drvmgr IIRC.
>>Danielh
>>_______________________________________________
>>devel mailing list
>>devel at rtems.org
>>http://lists.rtems.org/mailman/listinfo/devel
> --joel
