[PATCH 3/4] new rtems environment with the implementation of FreeBSD timecounters; modifications of certain tests in the testsuite New test: timecounter02
Wed Apr 1 16:08:10 UTC 2015
On Wed, Apr 1, 2015 at 11:58 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 4/1/2015 10:01 AM, Gedare Bloom wrote:
>> I didn't read much of this, but it needs doxygen, and probably part of
>> the previous patch should be merged in here, or some better
>> splitting/recombining of patches so I don't have to review code that
>> gets fixed. It's worth repeating, the "rtems_*time" functions are not
>> following the API conventions of rtems_package_method, it should be
>> rtems_timecounter_*time like rtems_timecounter_bintime.
>> Please use a short git-commit message for the first line, and longer
>> git commit message after a blank line. This will avoid really long
>> lines in git log, and long subjects in git-send-email. I guess this
>> advice is in the Git page
>> (https://devel.rtems.org/wiki/Developer/Git).
> It is already combined so I am not going to complain but I see a method
> renamed
> in here (_TOD_Get). Personally I like a series of small patches and that
> is an
> example of something that could have been done independently.  Remember
> smaller patches are easier for everyone to review. It is often hard to
> think that
> way as you are working and knees deep in it, but it is important.
> Add an _ after _Timecount_Get and rtems_get_ in various API methods. But the
> rtems_get methods are (as Gedare pointed out) named incorrectly per the
> RTEMS API naming patterns.
The _ after get may not be needed if there is a reason such as wanting
to be close to an upstream interface.
> rtems_ methods should not be in the score. By convention, they should be in
> the rtems_ directory.
> I think I see some tabs in the files particularly the test code. Check
> all code for
> tabs. They shouldn't be used in source files.
> Tests usually have a comment marking the beginning and end of the
> configuration
> section. Just check another test for the convention.
> I agree with Gedare that a lot of Doxygen is missing. File headers and
> group annotation
> appear to be largely missing in addition to methods not having any
> documentation.
>> Gedare
>> On Wed, Apr 1, 2015 at 10:37 AM, Alexander Krutwig
>> <alexander.krutwig at embedded-brains.de> wrote:
>>>  cpukit/libnetworking/rtems/rtems_bsdnet_internal.h |   3 +-
>>>  cpukit/libnetworking/rtems/rtems_glue.c            |   4 -
>>>  cpukit/posix/src/clockgettime.c                    |   3 +-
>>>  cpukit/posix/src/posixtimespecabsolutetimeout.c    |   2 +-
>>>  cpukit/posix/src/timergettime.c                    |   2 +-
>>>  cpukit/posix/src/timersettime.c                    |   4 +-
>>>  cpukit/posix/src/timertsr.c                        |   2 +-
>>>  cpukit/rtems/Makefile.am                           |   1 -
>>>  cpukit/rtems/include/rtems/rtems/clock.h           |  25 --
>>>  cpukit/rtems/src/clockgetuptimenanoseconds.c       |   9 +-
>>>  cpukit/rtems/src/clockgetuptimeseconds.c           |   6 +-
>>>  cpukit/rtems/src/clocksetnsecshandler.c            |  34 --
>>>  cpukit/sapi/Makefile.am                            |   1 +
>>>  cpukit/sapi/include/rtems/timecounter.h            |  89 +++++
>>>  cpukit/sapi/preinstall.am                          |   4 +
>>>  cpukit/sapi/src/exinit.c                           |   3 +
>>>  cpukit/score/Makefile.am                           |  18 +-
>>>  cpukit/score/include/rtems/score/timecounter.h     |  59 +++-
>>>  cpukit/score/include/rtems/score/timecounterimpl.h | 119 +++++++
>>>  cpukit/score/include/rtems/score/timestamp.h       | 267 ++++++++-------
>>>  cpukit/score/include/rtems/score/timestamp64.h     | 379 ---------------------
>>>  cpukit/score/include/rtems/score/tod.h             |   9 -
>>>  cpukit/score/include/rtems/score/todimpl.h         | 101 ++----
>>>  cpukit/score/preinstall.am                         |  10 +-
>>>  cpukit/score/src/coretod.c                         |  18 +-
>>>  cpukit/score/src/coretodadjust.c                   |   9 +-
>>>  cpukit/score/src/coretodget.c                      |  46 ---
>>>  cpukit/score/src/coretodgetuptimetimespec.c        |  32 --
>>>  cpukit/score/src/coretodsecondssinceepoch.c        |  32 --
>>>  cpukit/score/src/coretodset.c                      |  10 +-
>>>  cpukit/score/src/coretodtickle.c                   |  22 +-
>>>  cpukit/score/src/tcgetscalerandmask.c              |  40 +++
>>>  cpukit/score/src/ts64addto.c                       |  31 --
>>>  cpukit/score/src/ts64divide.c                      |  51 ---
>>>  cpukit/score/src/ts64equalto.c                     |  31 --
>>>  cpukit/score/src/ts64getnanoseconds.c              |  30 --
>>>  cpukit/score/src/ts64getseconds.c                  |  30 --
>>>  cpukit/score/src/ts64lessthan.c                    |  31 --
>>>  cpukit/score/src/ts64set.c                         |  33 --
>>>  cpukit/score/src/ts64settozero.c                   |  31 --
>>>  cpukit/score/src/ts64subtract.c                    |  31 --
>>>  cpukit/score/src/ts64totimespec.c                  |  32 --
>>>  cpukit/score/src/ts64totimeval.c                   |  37 --
>>>  testsuites/sptests/Makefile.am                     |   2 +
>>>  testsuites/sptests/configure.ac                    |   2 +
>>>  testsuites/sptests/spclock_err01/init.c            |   8 -
>>>  testsuites/sptests/spsize/size.c                   |   3 -
>>>  testsuites/sptests/sptimecounter02/Makefile.am     |  19 ++
>>>  testsuites/sptests/sptimecounter02/init.c          | 266 +++++++++++++++
>>>  .../sptests/sptimecounter02/sptimecounter02.doc    |  11 +
>>>  .../sptests/sptimecounter02/sptimecounter02.scn    |   0
>>>  51 files changed, 818 insertions(+), 1224 deletions(-)
>>>  delete mode 100644 cpukit/rtems/src/clocksetnsecshandler.c
>>>  create mode 100644 cpukit/sapi/include/rtems/timecounter.h
>>>  create mode 100644 cpukit/score/include/rtems/score/timecounterimpl.h
>>>  delete mode 100644 cpukit/score/include/rtems/score/timestamp64.h
>>>  delete mode 100644 cpukit/score/src/coretodget.c
>>>  delete mode 100644 cpukit/score/src/coretodgetuptimetimespec.c
>>>  delete mode 100644 cpukit/score/src/coretodsecondssinceepoch.c
>>>  create mode 100644 cpukit/score/src/tcgetscalerandmask.c
>>>  delete mode 100644 cpukit/score/src/ts64addto.c
>>>  delete mode 100644 cpukit/score/src/ts64divide.c
>>>  delete mode 100644 cpukit/score/src/ts64equalto.c
>>>  delete mode 100644 cpukit/score/src/ts64getnanoseconds.c
>>>  delete mode 100644 cpukit/score/src/ts64getseconds.c
>>>  delete mode 100644 cpukit/score/src/ts64lessthan.c
>>>  delete mode 100644 cpukit/score/src/ts64set.c
>>>  delete mode 100644 cpukit/score/src/ts64settozero.c
>>>  delete mode 100644 cpukit/score/src/ts64subtract.c
>>>  delete mode 100644 cpukit/score/src/ts64totimespec.c
>>>  delete mode 100644 cpukit/score/src/ts64totimeval.c
>>>  create mode 100644 testsuites/sptests/sptimecounter02/Makefile.am
>>>  create mode 100644 testsuites/sptests/sptimecounter02/init.c
>>>  create mode 100644 testsuites/sptests/sptimecounter02/sptimecounter02.doc
>>>  create mode 100644 testsuites/sptests/sptimecounter02/sptimecounter02.scn
>>> diff --git a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
>>> index fc0370c..01562b1 100644
>>> --- a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
>>> +++ b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
>>> @@ -12,6 +12,7 @@
>>>  #include <rtems.h>
>>>  #include <rtems/fs.h>
>>> +#include <rtems/timecounter.h>
>>>  #ifdef __cplusplus
>>>  extern "C" {
>>> @@ -61,7 +62,7 @@ void *memset(void *s, int c, size_t n);
>>>  #define panic  rtems_panic
>>>  #define suser(a,b)     0
>>> -void microtime(struct timeval *tv);
>>> +#define microtime(tv) rtems_microtime(tv)
>>>  #define hz rtems_bsdnet_ticks_per_second
>>>  #define tick rtems_bsdnet_microseconds_per_tick
>>> diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
>>> index f05530e..0a42f97 100644
>>> --- a/cpukit/libnetworking/rtems/rtems_glue.c
>>> +++ b/cpukit/libnetworking/rtems/rtems_glue.c
>>> @@ -1344,7 +1344,3 @@ m_clalloc(int ncl, int nowait)
>>>         return 1;
>>> -       rtems_clock_get_uptime_timeval(tv);
>>> diff --git a/cpukit/posix/src/clockgettime.c b/cpukit/posix/src/clockgettime.c
>>> index 2838ba6..06cafa5 100644
>>> --- a/cpukit/posix/src/clockgettime.c
>>> +++ b/cpukit/posix/src/clockgettime.c
>>> @@ -37,7 +37,8 @@ int clock_gettime(
>>>      rtems_set_errno_and_return_minus_one( EINVAL );
>>>    if ( clock_id == CLOCK_REALTIME ) {
>>> -    _TOD_Get(tp);
>>> +    _TOD_Get_as_timespec(tp);
>>>      return 0;
>>>  #ifdef CLOCK_MONOTONIC
>>> diff --git a/cpukit/posix/src/posixtimespecabsolutetimeout.c b/cpukit/posix/src/posixtimespecabsolutetimeout.c
>>> index 32da45f..f302986 100644
>>> --- a/cpukit/posix/src/posixtimespecabsolutetimeout.c
>>> +++ b/cpukit/posix/src/posixtimespecabsolutetimeout.c
>>> @@ -57,7 +57,7 @@ POSIX_Absolute_timeout_conversion_results_t _POSIX_Absolute_timeout_to_ticks(
>>>     *  Is the absolute time in the past?
>>> -  _TOD_Get( &current_time );
>>> +  _TOD_Get_as_timespec( &current_time );
>>>    if ( _Timespec_Less_than( abstime, &current_time ) )
>>>      return POSIX_ABSOLUTE_TIMEOUT_IS_IN_PAST;
>>> diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
>>> index 2a810ef..f065cc9 100644
>>> --- a/cpukit/posix/src/timergettime.c
>>> +++ b/cpukit/posix/src/timergettime.c
>>> @@ -49,7 +49,7 @@ int timer_gettime(
>>>    /* Reads the current time */
>>>    ptimer = _POSIX_Timer_Get( timerid, &location );
>>>    switch ( location ) {
>>> diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
>>> index 6cc3780..4d2af5d 100644
>>> --- a/cpukit/posix/src/timersettime.c
>>> +++ b/cpukit/posix/src/timersettime.c
>>> @@ -66,7 +66,7 @@ int timer_settime(
>>>    /* Convert absolute to relative time */
>>>    if (flags == TIMER_ABSTIME) {
>>>      struct timespec now;
>>> -    _TOD_Get( &now );
>>> +    _TOD_Get_as_timespec( &now );
>>>      /* Check for seconds in the past */
>>>      if ( _Timespec_Greater_than( &now, &normalize.it_value ) )
>>> @@ -125,7 +125,7 @@ int timer_settime(
>>>         /* Indicate that the time is running */
>>>         ptimer->state = POSIX_TIMER_STATE_CREATE_RUN;
>>> -       _TOD_Get( &ptimer->time );
>>> +       _TOD_Get_as_timespec( &ptimer->time );
>>>        _Objects_Put( &ptimer->Object );
>>>         return 0;
>>> diff --git a/cpukit/posix/src/timertsr.c b/cpukit/posix/src/timertsr.c
>>> index 8555463..512dd06 100644
>>> --- a/cpukit/posix/src/timertsr.c
>>> +++ b/cpukit/posix/src/timertsr.c
>>> @@ -58,7 +58,7 @@ void _POSIX_Timer_TSR(
>>>        return;
>>>      /* Store the time when the timer was started again */
>>>      /* The state really did not change but just to be safe */
>>> diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
>>> index 5e6f2ea..1af8536 100644
>>> --- a/cpukit/rtems/Makefile.am
>>> +++ b/cpukit/rtems/Makefile.am
>>> @@ -158,7 +158,6 @@ librtems_a_SOURCES += src/clockgetuptimetimeval.c
>>>  librtems_a_SOURCES += src/clockgetuptimeseconds.c
>>>  librtems_a_SOURCES += src/clockgetuptimenanoseconds.c
>>>  librtems_a_SOURCES += src/clockset.c
>>> -librtems_a_SOURCES += src/clocksetnsecshandler.c
>>>  librtems_a_SOURCES += src/clocktick.c
>>>  librtems_a_SOURCES += src/clocktodtoseconds.c
>>>  librtems_a_SOURCES += src/clocktodvalidate.c
>>> diff --git a/cpukit/rtems/include/rtems/rtems/clock.h b/cpukit/rtems/include/rtems/rtems/clock.h
>>> index 2a1c772..89750cf 100644
>>> --- a/cpukit/rtems/include/rtems/rtems/clock.h
>>> +++ b/cpukit/rtems/include/rtems/rtems/clock.h
>>> @@ -14,7 +14,6 @@
>>>   * - set the current date and time
>>>   * - obtain the current date and time
>>> - * - set the nanoseconds since last clock tick handler
>>>   * - announce a clock tick
>>>   * - obtain the system uptime
>>> @@ -69,12 +68,6 @@ typedef enum {
>>>  } rtems_clock_get_options;
>>> - *  Type for the nanoseconds since last tick BSP extension.
>>> -typedef TOD_Nanoseconds_since_last_tick_routine
>>> -  rtems_nanoseconds_extension_routine;
>>>   * @brief Obtain Current Time of Day
>>>   * @deprecated rtems_clock_get() is deprecated. Use the more explicit
>>> @@ -279,24 +272,6 @@ rtems_status_code rtems_clock_set(
>>>  rtems_status_code rtems_clock_tick( void );
>>> - * @brief Set the BSP specific Nanoseconds Extension
>>> - * Clock Manager
>>> - * This directive sets the BSP provided nanoseconds since last tick
>>> - * extension.
>>> - * @param[in] routine is a pointer to the extension routine
>>> - * @return This method returns RTEMS_SUCCESSFUL if there was not an
>>> - *         error. Otherwise, a status code is returned indicating the
>>> - *         source of the error.
>>> -rtems_status_code rtems_clock_set_nanoseconds_extension(
>>> -  rtems_nanoseconds_extension_routine routine
>>>   * @brief Obtain the System Uptime
>>>   * This directive returns the system uptime.
>>> diff --git a/cpukit/rtems/src/clockgetuptimenanoseconds.c b/cpukit/rtems/src/clockgetuptimenanoseconds.c
>>> index 0310e59..d43f672 100644
>>> --- a/cpukit/rtems/src/clockgetuptimenanoseconds.c
>>> +++ b/cpukit/rtems/src/clockgetuptimenanoseconds.c
>>> @@ -23,13 +23,8 @@
>>>  uint64_t rtems_clock_get_uptime_nanoseconds( void )
>>>    Timestamp_Control  snapshot_as_timestamp;
>>> -  uint32_t           nanoseconds;
>>> -  ISR_lock_Context   lock_context;
>>> -  _TOD_Acquire( &_TOD, &lock_context );
>>> -    snapshot_as_timestamp = _TOD.uptime;
>>> -    nanoseconds = ( *_TOD.nanoseconds_since_last_tick )();
>>> -  _TOD_Release( &_TOD, &lock_context );
>>> +  _TOD_Get_uptime(&snapshot_as_timestamp);
>>> -  return _Timestamp_Get_As_nanoseconds( &snapshot_as_timestamp, nanoseconds );
>>> +  return _Timestamp_Get_nanoseconds(&snapshot_as_timestamp);
>>> diff --git a/cpukit/rtems/src/clockgetuptimeseconds.c b/cpukit/rtems/src/clockgetuptimeseconds.c
>>> index 0312921..5c6b57c 100644
>>> --- a/cpukit/rtems/src/clockgetuptimeseconds.c
>>> +++ b/cpukit/rtems/src/clockgetuptimeseconds.c
>>> @@ -28,14 +28,10 @@
>>>  time_t rtems_clock_get_uptime_seconds( void )
>>> -  TOD_Control       *tod = &_TOD;
>>>    struct timespec    snapshot_as_timespec;
>>> -  _TOD_Acquire( tod, &lock_context );
>>> -  snapshot_as_timestamp = tod->uptime;
>>> -  _TOD_Release( tod, &lock_context );
>>>    _Timestamp_To_timespec( &snapshot_as_timestamp, &snapshot_as_timespec );
>>> diff --git a/cpukit/rtems/src/clocksetnsecshandler.c b/cpukit/rtems/src/clocksetnsecshandler.c
>>> deleted file mode 100644
>>> index ae08246..0000000
>>> --- a/cpukit/rtems/src/clocksetnsecshandler.c
>>> +++ /dev/null
>>> @@ -1,34 +0,0 @@
>>> - * @file
>>> - * @ingroup ClassicClock Clocks
>>> - *  COPYRIGHT (c) 1989-2006.
>>> - *  On-Line Applications Research Corporation (OAR).
>>> - *  The license and distribution terms for this file may be
>>> - *  found in the file LICENSE in this distribution or at
>>> - *  http://www.rtems.org/license/LICENSE.
>>> -#if HAVE_CONFIG_H
>>> -#include "config.h"
>>> -#endif
>>> -#include <rtems/rtems/clock.h>
>>> -#include <rtems/score/todimpl.h>
>>> -  if ( !routine )
>>> -    return RTEMS_INVALID_ADDRESS;
>>> -  _TOD_Set_nanoseconds_since_last_tick_handler( routine );
>>> -  return RTEMS_SUCCESSFUL;
>>> diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
>>> index 070800e..17f0e4f 100644
>>> --- a/cpukit/sapi/Makefile.am
>>> +++ b/cpukit/sapi/Makefile.am
>>> @@ -19,6 +19,7 @@ include_rtems_HEADERS += include/rtems/rbheap.h
>>>  include_rtems_HEADERS += include/rtems/rbtree.h
>>>  include_rtems_HEADERS += include/rtems/scheduler.h
>>>  include_rtems_HEADERS += include/rtems/sptables.h
>>> +include_rtems_HEADERS += include/rtems/timecounter.h
>>>  include_rtems_HEADERS += include/rtems/timespec.h
>>>  EXTRA_DIST = include/rtems/README
>>> diff --git a/cpukit/sapi/include/rtems/timecounter.h b/cpukit/sapi/include/rtems/timecounter.h
>>> new file mode 100644
>>> index 0000000..a496e64
>>> --- /dev/null
>>> +++ b/cpukit/sapi/include/rtems/timecounter.h
>>> @@ -0,0 +1,89 @@
>>> + * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
>>> + *  embedded brains GmbH
>>> + *  Dornierstr. 4
>>> + *  82178 Puchheim
>>> + *  Germany
>>> + *  <rtems at embedded-brains.de>
>>> + * The license and distribution terms for this file may be
>>> + * found in the file LICENSE in this distribution or at
>>> + * http://www.rtems.org/license/LICENSE.
>>> +#ifndef _RTEMS_TIMECOUNTER_H
>>> +#define _RTEMS_TIMECOUNTER_H
>>> +#include <rtems/score/timecounter.h>
>>> +#include <rtems/score/basedefs.h>
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif /* __cplusplus */
>>> +RTEMS_INLINE_ROUTINE void rtems_bintime( struct bintime *bt )
>>> +  _Timecounter_Bintime( bt );
>>> +RTEMS_INLINE_ROUTINE void rtems_nanotime( struct timespec *ts )
>>> +  _Timecounter_Nanotime( ts );
>>> +RTEMS_INLINE_ROUTINE void rtems_microtime( struct timeval *tv )
>>> +  _Timecounter_Microtime( tv );
>>> +RTEMS_INLINE_ROUTINE void rtems_binuptime( struct bintime *bt )
>>> +  _Timecounter_Binuptime( bt );
>>> +RTEMS_INLINE_ROUTINE void rtems_nanouptime( struct timespec *ts )
>>> +  _Timecounter_Nanouptime( ts );
>>> +RTEMS_INLINE_ROUTINE void rtems_microuptime( struct timeval *tv )
>>> +  _Timecounter_Microuptime( tv );
>>> +RTEMS_INLINE_ROUTINE void rtems_getbintime( struct bintime *bt )
>>> +  _Timecounter_Getbintime( bt );
>>> +RTEMS_INLINE_ROUTINE void rtems_getnanotime( struct timespec *ts )
>>> +  _Timecounter_Getnanotime( ts );
>>> +RTEMS_INLINE_ROUTINE void rtems_getmicrotime( struct timeval *tv )
>>> +  _Timecounter_Getmicrotime( tv );
>>> +RTEMS_INLINE_ROUTINE void rtems_getbinuptime( struct bintime *bt )
>>> +  _Timecounter_Getbinuptime( bt );
>>> +RTEMS_INLINE_ROUTINE void rtems_getnanouptime( struct timespec *ts )
>>> +  _Timecounter_Getnanouptime( ts );
>>> +RTEMS_INLINE_ROUTINE void rtems_getmicrouptime( struct timeval *tv )
>>> +  _Timecounter_Getmicrouptime( tv );
>>> +#ifdef __cplusplus
>>> +#endif /* _RTEMS_TIMECOUNTER_H */
>>> diff --git a/cpukit/sapi/preinstall.am b/cpukit/sapi/preinstall.am
>>> index 3f864bb..4509842 100644
>>> --- a/cpukit/sapi/preinstall.am
>>> +++ b/cpukit/sapi/preinstall.am
>>> @@ -82,6 +82,10 @@ $(PROJECT_INCLUDE)/rtems/sptables.h: include/rtems/sptables.h $(PROJECT_INCLUDE)
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/sptables.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/sptables.h
>>> +$(PROJECT_INCLUDE)/rtems/timecounter.h: include/rtems/timecounter.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/timecounter.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/timecounter.h
>>>  $(PROJECT_INCLUDE)/rtems/timespec.h: include/rtems/timespec.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/timespec.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/timespec.h
>>> diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
>>> index 235ba77..5c265a6 100644
>>> --- a/cpukit/sapi/src/exinit.c
>>> +++ b/cpukit/sapi/src/exinit.c
>>> @@ -44,6 +44,7 @@
>>>  #include <rtems/score/priority.h>
>>>  #include <rtems/score/schedulerimpl.h>
>>>  #include <rtems/score/smpimpl.h>
>>>  #include <rtems/score/threadimpl.h>
>>>  #include <rtems/score/userextimpl.h>
>>> @@ -69,6 +70,8 @@ void rtems_initialize_data_structures(void)
>>>     *           are disabled by boot_card().
>>> +    _Timecounter_Initialize();
>>>    #if defined(RTEMS_MULTIPROCESSING)
>>>       *  Initialize the system state based on whether this is an MP system.
>>> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
>>> index 55fdc99..596df68 100644
>>> --- a/cpukit/score/Makefile.am
>>> +++ b/cpukit/score/Makefile.am
>>> @@ -94,7 +94,8 @@ include_rtems_score_HEADERS += include/rtems/score/threadqimpl.h
>>>  include_rtems_score_HEADERS += include/rtems/score/threadsync.h
>>>  include_rtems_score_HEADERS += include/rtems/score/timespec.h
>>>  include_rtems_score_HEADERS += include/rtems/score/timestamp.h
>>> -include_rtems_score_HEADERS += include/rtems/score/timestamp64.h
>>> +include_rtems_score_HEADERS += include/rtems/score/timecounter.h
>>> +include_rtems_score_HEADERS += include/rtems/score/timecounterimpl.h
>>>  include_rtems_score_HEADERS += include/rtems/score/tls.h
>>>  include_rtems_score_HEADERS += include/rtems/score/tod.h
>>>  include_rtems_score_HEADERS += include/rtems/score/todimpl.h
>>> @@ -317,18 +318,10 @@ libscore_a_SOURCES += src/timespecaddto.c src/timespecfromticks.c \
>>>      src/timespecsubtract.c src/timespectoticks.c src/timespecdivide.c \
>>>      src/timespecdividebyinteger.c src/timespecgetasnanoseconds.c
>>> -## TIMESTAMP_INT64_C_FILES
>>> -libscore_a_SOURCES += src/ts64addto.c \
>>> -    src/ts64divide.c src/ts64equalto.c \
>>> -    src/ts64getnanoseconds.c src/ts64getseconds.c \
>>> -    src/ts64lessthan.c \
>>> -    src/ts64set.c src/ts64settozero.c src/ts64subtract.c \
>>> -    src/ts64totimespec.c src/ts64totimeval.c
>>>  ## TOD_C_FILES
>>> -libscore_a_SOURCES += src/coretod.c src/coretodset.c src/coretodget.c \
>>> -    src/coretodgetuptimetimespec.c src/coretodtickle.c \
>>> -    src/coretodsecondssinceepoch.c src/coretodtickspersec.c \
>>> +libscore_a_SOURCES += src/coretod.c src/coretodset.c \
>>> +    src/coretodtickle.c \
>>> +    src/coretodtickspersec.c \
>>>      src/coretodadjust.c
>>>  ## WATCHDOG_C_FILES
>>> @@ -353,6 +346,7 @@ libscore_a_SOURCES += src/once.c
>>>  libscore_a_SOURCES += src/resourceiterate.c
>>>  libscore_a_SOURCES += src/smpbarrierwait.c
>>>  libscore_a_SOURCES += src/kern_tc.c
>>> +libscore_a_SOURCES += src/tcgetscalerandmask.c
>>>  EXTRA_DIST = src/Unlimited.txt
>>> diff --git a/cpukit/score/include/rtems/score/timecounter.h b/cpukit/score/include/rtems/score/timecounter.h
>>> index 3744a76..bae5851 100644
>>> --- a/cpukit/score/include/rtems/score/timecounter.h
>>> +++ b/cpukit/score/include/rtems/score/timecounter.h
>>> @@ -1,23 +1,52 @@
>>> + *  Dornierstr. 4
>>> + *  82178 Puchheim
>>> + *  Germany
>>> +#ifndef _RTEMS_SCORE_TIMECOUNTER_H
>>> +#define _RTEMS_SCORE_TIMECOUNTER_H
>>>  #include <sys/time.h>
>>> -void _Timecounter_Initialize(void);
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +void _Timecounter_Bintime( struct bintime *bt );
>>> +void _Timecounter_Nanotime( struct timespec *ts );
>>> +void _Timecounter_Microtime( struct timeval *tv );
>>> +void _Timecounter_Binuptime( struct bintime *bt );
>>> +void _Timecounter_Nanouptime( struct timespec *ts );
>>> +void _Timecounter_Microuptime( struct timeval *tv );
>>> +void _Timecounter_Getbintime( struct bintime *bt );
>>> +void _Timecounter_Getnanotime( struct timespec *ts );
>>> +void _Timecounter_Getmicrotime( struct timeval *tv );
>>> -void _Timecounter_Set_clock(const struct timespec *ts);
>>> +void _Timecounter_Getbinuptime( struct bintime *bt );
>>> -void _Timecounter_Ticktock(int cnt);
>>> +void _Timecounter_Getnanouptime( struct timespec *ts );
>>> -void rtems_bintime(struct bintime *bt);
>>> -void rtems_nanotime(struct timespec *tsp);
>>> -void rtems_microtime(struct timeval *tvp);
>>> -void rtems_binuptime(struct bintime *bt);
>>> -void rtems_nanouptime(struct timespec *tsp);
>>> -void rtems_microuptime(struct timeval *tvp);
>>> -void rtems_getbintime(struct bintime *bt);
>>> -void rtems_getnanotime(struct timespec *tsp);
>>> -void rtems_getmicrotime(struct timeval *tvp);
>>> -void rtems_getbinuptime(struct bintime *bt);
>>> -void rtems_getnanouptime(struct timespec *tsp);
>>> -void rtems_getmicrouptime(struct timeval *tvp);
>>> +void _Timecounter_Getmicrouptime( struct timeval *tv );
>>> +#ifdef __cplusplus
>>> +#endif /* _RTEMS_SCORE_TIMECOUNTER_H */
>>> diff --git a/cpukit/score/include/rtems/score/timecounterimpl.h b/cpukit/score/include/rtems/score/timecounterimpl.h
>>> index 0000000..5987672
>>> --- /dev/null
>>> +++ b/cpukit/score/include/rtems/score/timecounterimpl.h
>>> @@ -0,0 +1,119 @@
>>> + *  Dornierstr. 4
>>> + *  82178 Puchheim
>>> + *  Germany
>>> +#ifndef _RTEMS_SCORE_TIMECOUNTERIMPL_H
>>> +#define _RTEMS_SCORE_TIMECOUNTERIMPL_H
>>> +#include <sys/timetc.h>
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#define TIMECOUNTER_DEFAULT_DRIVER_QUALITY 100
>>> + *  @brief Starts the initialization of the timecounter.
>>> + *  This routine sets hardclock ticks per milliseconds and assigns to the
>>> + *  timecounters where to get the timecount information for each windup() call.
>>> +void _Timecounter_Initialize(void);
>>> + *  @brief Sets the clock of the timecounter.
>>> + *  This routine converts an input timespec into a bintime which is then set in
>>> + *  the timecounter.
>>> + *  @param[in] ts is a timespec for conversion.
>>> +void _Timecounter_Set_clock(const struct timespec *ts);
>>> + *  @brief Sets up the ring of timecounters.
>>> + *  This routine installs a "ring" of minimum one timecounter in the format of
>>> + *  the input and calls the windup function afterwards.
>>> + *  @param[in] tc is the timecounter instance of which the ring should be
>>> + *  created.
>>> + *  @code tc->tc_next = timecounters;
>>> + *        timecounters = tc;
>>> + *        (void)tc->tc_get_timecount(tc);
>>> + *        tc_windup();
>>> + *  @endcode
>>> +void _Timecounter_Install(struct timecounter *tc);
>>> + *  @brief Interrupt Routine that triggers a windup call.
>>> + *  Usage for timecount registers that run on binary basis.
>>> +void _Timecounter_Tick(void);
>>> + *  @brief Interrupt Routine that cannot trigger a windup call.
>>> + *  This routine is needed for a get_timecounter request where the information
>>> + *  is received from a real time clock register that does not offer a binary
>>> + *  basis. Here the bintime offset is generated by giving the delta and offset
>>> + *  parameters as inputs.
>>> + *  @param[in] delta is one timecounter interval + time from the start of the
>>> + *  new interval.
>>> + *  @param[in] offset is the time from the start of the new interval.
>>> + *  @code
>>> + *  th = timehands;
>>> + *  ogen = th->th_generation;
>>> + *  th->th_offset_count = offset;
>>> + *  bintime_addx(&th->th_offset, th->th_scale * delta);
>>> + *  @endcode
>>> +void _Timecounter_Tick_simple(u_int delta, u_int offset);
>>> + *  @brief creates scaler and mask for _Timecounter_Tick_simple.
>>> + *  Calculates the scaler and mask of the next upcoming power of 2. The scaler
>>> + *  is the next power of 2 divided by the counter_ticks_per_clock_ticks. The
>>> + *  mask is double the next power of 2 minus 1, as the timecounter can return a
>>> + *  maximum value of the length of two intervals.
>>> + *  @param[in] counter_ticks_per_clock_tick
>>> + *  @param[out] scaler is the value of the scaling factor which has to imposed
>>> + *  on the values returned by the get_timecount information
>>> + *  @param[out] mask is the value of double the next power of 2 minus 1
>>> +void _Timecounter_Get_binary_scaler_and_mask(
>>> +  uint32_t  counter_ticks_per_clock_tick,
>>> +  uint64_t *scaler,
>>> +  uint32_t *mask
>>> +#ifdef __cplusplus
>>> +#endif /* _RTEMS_SCORE_TIMECOUNTERIMPL_H */
>>> diff --git a/cpukit/score/include/rtems/score/timestamp.h b/cpukit/score/include/rtems/score/timestamp.h
>>> index dbd0425..056976b 100644
>>> --- a/cpukit/score/include/rtems/score/timestamp.h
>>> +++ b/cpukit/score/include/rtems/score/timestamp.h
>>> @@ -42,55 +42,45 @@
>>> -#include <rtems/score/cpu.h>
>>> -#include <rtems/score/timespec.h>
>>> +#include "timespec.h"
>>>  #ifdef __cplusplus
>>>  extern "C" {
>>>  #endif
>>> -#if ! ( ( CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE \
>>> -    && CPU_TIMESTAMP_USE_INT64 == FALSE \
>>> -    && CPU_TIMESTAMP_USE_INT64_INLINE == FALSE ) \
>>> -  || ( CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == FALSE \
>>> -    && CPU_TIMESTAMP_USE_INT64 == TRUE \
>>> -    && CPU_TIMESTAMP_USE_INT64_INLINE == TRUE ) )
>>> -  #error "Invalid SuperCore Timestamp implementations selection."
>>> -#endif
>>> -#if CPU_TIMESTAMP_USE_INT64 == TRUE || CPU_TIMESTAMP_USE_INT64_INLINE == TRUE
>>> -  #include <rtems/score/timestamp64.h>
>>> -#endif
>>> +#define MICROSECONDS_PER_SECOND 1000000
>>> +#define NANOSECONDS_PER_SECOND 1000000000
>>>   *   Define the Timestamp control type.
>>> -#if CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE
>>> -  typedef struct timespec Timestamp_Control;
>>> -#else
>>> -  typedef Timestamp64_Control Timestamp_Control;
>>> -#endif
>>> +typedef struct bintime Timestamp_Control;
>>>   *  @brief Set timestamp to specified seconds and nanoseconds.
>>> - *  This method sets the timestamp to the specified @a _seconds and @a _nanoseconds
>>> - *  value.
>>> + *  This method sets the timestamp to the specified @a _seconds and
>>> + *  @a _nanoseconds value.
>>>   *  @param[in] _time points to the timestamp instance to validate.
>>>   *  @param[in] _seconds is the seconds portion of the timestamp
>>>   *  @param[in] _nanoseconds is the nanoseconds portion of the timestamp
>>> -  #define _Timestamp_Set( _time, _seconds, _nanoseconds ) \
>>> -          _Timespec_Set( _time, _seconds, _nanoseconds )
>>> -#else
>>> -         _Timestamp64_Set( _time, _seconds, _nanoseconds )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE void _Timestamp_Set(
>>> +  Timestamp_Control *_time,
>>> +  time_t _seconds,
>>> +  long _nanoseconds
>>> +  struct timespec _ts;
>>> +  _ts.tv_sec = _seconds;
>>> +  _ts.tv_nsec = _nanoseconds;
>>> +  timespec2bintime(&_ts, _time);
>>>   *  @brief Sets the timestamp to zero.
>>> @@ -100,13 +90,14 @@ extern "C" {
>>>   *  @param[in] _time points to the timestamp instance to zero.
>>> -  #define _Timestamp_Set_to_zero( _time ) \
>>> -          _Timespec_Set_to_zero( _time )
>>> -#else
>>> -         _Timestamp64_Set_to_zero( _time )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE void _Timestamp_Set_to_zero(
>>> +  _time->sec = 0;
>>> +  _time->frac = 0;
>>>   *  @brief Less than operator for timestamps.
>>> @@ -119,13 +110,23 @@ extern "C" {
>>>   *  @retval This method returns true if @a _lhs is less than the @a _rhs and
>>>   *          false otherwise.
>>> -  #define _Timestamp_Less_than( _lhs, _rhs ) \
>>> -          _Timespec_Less_than( _lhs, _rhs )
>>> -#else
>>> -         _Timestamp64_Less_than( _lhs, _rhs )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE bool _Timestamp_Less_than(
>>> +  Timestamp_Control *_lhs, Timestamp_Control *_rhs
>>> +  if ( _lhs->sec < _rhs->sec )
>>> +    return true;
>>> +  if ( _lhs->sec > _rhs->sec )
>>> +    return false;
>>> +  /* assert: lhs->tv_sec == rhs->tv_sec */
>>> +  if ( _lhs->frac < _rhs->frac)
>>> +    return true;
>>> +  return false;
>>>   *  @brief Greater than operator for timestamps.
>>> @@ -138,8 +139,23 @@ extern "C" {
>>>   *  @retval This method returns true if @a _lhs is greater than the @a _rhs and
>>>   *          false otherwise.
>>> -#define _Timestamp_Greater_than( _lhs, _rhs ) \
>>> -  _Timestamp_Less_than( _rhs, _lhs )
>>> +RTEMS_INLINE_ROUTINE bool _Timestamp_Greater_than(
>>> +    return true;
>>> +    return false;
>>> +  if ( _lhs->frac > _rhs->frac)
>>> +    return true;
>>> +  return false;
>>>   *  @brief Equal to than operator for timestamps.
>>> @@ -152,13 +168,16 @@ extern "C" {
>>>   *  @retval This method returns true if @a _lhs is equal to  @a _rhs and
>>>   *          false otherwise.
>>> -  #define _Timestamp_Equal_to( _lhs, _rhs ) \
>>> -          _Timespec_Equal_to( _lhs, _rhs )
>>> -#else
>>> -         _Timestamp64_Equal_to( _lhs, _rhs )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE bool _Timestamp_Equal_to(
>>> +  if (( _lhs->sec < _rhs->sec) && (_lhs->frac == _rhs->frac))
>>> +    return true;
>>> +  return false;
>>>   *  @brief Adds two timestamps.
>>> @@ -171,13 +190,15 @@ extern "C" {
>>>   *  @retval This method returns the number of seconds @a time increased by.
>>> -  #define _Timestamp_Add_to( _time, _add ) \
>>> -          _Timespec_Add_to( _time, _add )
>>> -#else
>>> -         _Timestamp64_Add_to( _time, _add )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE time_t _Timestamp_Add_to(
>>> +  const Timestamp_Control *_add
>>> +  time_t seconds = _time->sec;
>>> +  bintime_add(_time, _add);
>>> +  return ((_time->sec) - seconds);
>>>   *  @brief Subtracts two timestamps.
>>> @@ -192,13 +213,17 @@ extern "C" {
>>>   *  @retval This method fills in @a _result.
>>> -  #define _Timestamp_Subtract( _start, _end, _result ) \
>>> -          _Timespec_Subtract( _start, _end, _result )
>>> -#else
>>> -         _Timestamp64_Subtract( _start, _end, _result )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE void _Timestamp_Subtract(
>>> +  const Timestamp_Control *_start,
>>> +  const Timestamp_Control *_end,
>>> +  Timestamp_Control       *_result
>>> +  _result->sec = _end->sec;
>>> +  _result->frac = _end->frac;
>>> +  bintime_sub(_result, _start);
>>>   *  @brief Divides a timestamp by another timestamp.
>>> @@ -213,13 +238,24 @@ extern "C" {
>>>   *  @retval This method fills in @a result.
>>> -  #define _Timestamp_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage ) \
>>> -          _Timespec_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage )
>>> -#else
>>> -          _Timestamp64_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE void _Timestamp_Divide(
>>> +  const Timestamp_Control *_lhs,
>>> +  const Timestamp_Control *_rhs,
>>> +  uint32_t              *_ival_percentage,
>>> +  uint32_t              *_fval_percentage
>>> +  struct timespec _time_left, _time_right;
>>> +  bintime2timespec(_lhs, &_time_left);
>>> +  bintime2timespec(_rhs, &_time_right);
>>> +  _Timespec_Divide(&_time_left,
>>> +                  &_time_right,
>>> +                  _ival_percentage,
>>> +                  _fval_percentage
>>>   *  @brief Get seconds portion of timestamp.
>>> @@ -230,13 +266,12 @@ extern "C" {
>>>   *  @retval The seconds portion of @a _time.
>>> -  #define _Timestamp_Get_seconds( _time ) \
>>> -          _Timespec_Get_seconds( _time )
>>> -#else
>>> -         _Timestamp64_Get_seconds( _time )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE time_t _Timestamp_Get_seconds(
>>> +  const Timestamp_Control *_time
>>> +  return _time->sec;
>>>   *  @brief Get nanoseconds portion of timestamp.
>>> @@ -247,13 +282,14 @@ extern "C" {
>>>   *  @retval The nanoseconds portion of @a _time.
>>> -  #define _Timestamp_Get_nanoseconds( _time ) \
>>> -          _Timespec_Get_nanoseconds( _time )
>>> -#else
>>> -         _Timestamp64_Get_nanoseconds( _time )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE uint32_t _Timestamp_Get_nanoseconds(
>>> +  bintime2timespec(_time, &_ts);
>>> +  return _ts.tv_nsec;
>>>   *  @brief Get the timestamp as nanoseconds.
>>> @@ -261,16 +297,23 @@ extern "C" {
>>>   *  This method returns the timestamp as nanoseconds.
>>> + *  @param[in] _nanoseconds adds nanoseconds since last tick
>>>   *  @retval The time in nanoseconds.
>>> -  #define _Timestamp_Get_As_nanoseconds( _timestamp, _nanoseconds ) \
>>> -          _Timespec_Get_As_nanoseconds( _timestamp, _nanoseconds )
>>> -#else
>>> -         _Timestamp64_Get_As_nanoseconds( _timestamp, _nanoseconds )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE uint64_t _Timestamp_Get_As_nanoseconds(
>>> +  const Timestamp_Control *_time,
>>> +  const uint32_t _nanoseconds
>>> +  struct timespec ts;
>>> +  uint64_t overall_ns_val;
>>> +  bintime2timespec(_time, &ts);
>>> +  overall_ns_val = _Timespec_Get_As_nanoseconds(&ts, _nanoseconds);
>>> +  return overall_ns_val;
>>>   *  @brief Convert timestamp to struct timespec.
>>> @@ -280,14 +323,13 @@ extern "C" {
>>>   *  @param[in] _timestamp points to the timestamp
>>>   *  @param[in] _timespec points to the timespec
>>> -  /* in this case we know they are the same type so use simple assignment */
>>> -  #define _Timestamp_To_timespec( _timestamp, _timespec  ) \
>>> -          *(_timespec) = *(_timestamp)
>>> -#else
>>> -         _Timestamp64_To_timespec( _timestamp, _timespec  )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE void _Timestamp_To_timespec(
>>> +  const Timestamp_Control *_timestamp,
>>> +  struct timespec *_timespec
>>> +  bintime2timespec(_timestamp, _timespec);
>>>   *  @brief Convert timestamp to struct timeval.
>>> @@ -295,16 +337,13 @@ extern "C" {
>>>   *  @param[in] _timeval points to the timeval
>>> -  #define _Timestamp_To_timeval( _timestamp, _timeval  ) \
>>> -    do { \
>>> -      (_timeval)->tv_sec = (_timestamp)->tv_sec; \
>>> -      (_timeval)->tv_usec = (_timestamp)->tv_nsec / 1000; \
>>> -    } while (0)
>>> -#else
>>> -         _Timestamp64_To_timeval( _timestamp, _timeval  )
>>> -#endif
>>> +RTEMS_INLINE_ROUTINE void _Timestamp_To_timeval(
>>> +  struct timeval *_timeval
>>> +  bintime2timeval(_timestamp, _timeval);
>>>  #ifdef __cplusplus
>>> diff --git a/cpukit/score/include/rtems/score/timestamp64.h b/cpukit/score/include/rtems/score/timestamp64.h
>>> index 39b4965..0000000
>>> --- a/cpukit/score/include/rtems/score/timestamp64.h
>>> +++ /dev/null
>>> @@ -1,379 +0,0 @@
>>> - *  @file  rtems/score/timestamp64.h
>>> - *  @brief Helpers for Manipulating 64-bit Integer Timestamps
>>> - *  This include file contains helpers for manipulating
>>> - *  64-bit integer timestamps.
>>> - *  COPYRIGHT (c) 1989-2009.
>>> -#ifndef _RTEMS_SCORE_TIMESTAMP64_H
>>> -#define _RTEMS_SCORE_TIMESTAMP64_H
>>> - *  @defgroup SuperCoreTimestamp64 SuperCore Sixty-Four Bit Timestamps
>>> - *  @ingroup Score
>>> - *  This handler encapsulates functionality related to manipulating
>>> - *  the 64 bit integer implementation of SuperCore Timestamps.
>>> -#ifdef __cplusplus
>>> -extern "C" {
>>> -#endif
>>> - *  This .h file is not for general use.  It is an alternative
>>> - *  implementation of Timestamps and should only be used that way.
>>> -#ifndef _RTEMS_SCORE_TIMESTAMP_H
>>> -  #error "Should only be included by rtems/score/timestamp.h"
>>> -#endif
>>> - *  Verify something is defined.
>>> -#if CPU_TIMESTAMP_USE_INT64 != TRUE && CPU_TIMESTAMP_USE_INT64_INLINE != TRUE
>>> -  #error "SuperCore Timestamp64 implementation included but not defined."
>>> -#endif
>>> - *   Define the Timestamp control type.
>>> -typedef int64_t Timestamp64_Control;
>>> -static inline void _Timestamp64_implementation_Set(
>>> -  Timestamp64_Control *_time,
>>> -  Timestamp64_Control  _seconds,
>>> -  Timestamp64_Control  _nanoseconds
>>> -  *_time = _seconds * 1000000000L + _nanoseconds;
>>> - *  @brief Set 64-bit timestamp to seconds nanosecond.
>>> - *  This method sets the timestamp to the specified seconds and nanoseconds
>>> - *  value.
>>> - *  @param[in] _time points to the timestamp instance to validate.
>>> - *  @param[in] _seconds is the seconds portion of the timestamp
>>> - *  @param[in] _nanoseconds is the nanoseconds portion of the timestamp
>>> -#if CPU_TIMESTAMP_USE_INT64_INLINE == TRUE
>>> -  #define _Timestamp64_Set( _time, _seconds, _nanoseconds ) \
>>> -    _Timestamp64_implementation_Set( _time, _seconds, _nanoseconds )
>>> -#else
>>> -  void _Timestamp64_Set(
>>> -#endif
>>> -static inline void _Timestamp64_implementation_Set_to_zero(
>>> -  *_time = 0;
>>> - *  @brief Sets the 64-bit timestamp to zero.
>>> - *  This method sets the timestamp to zero value.
>>> - *  @param[in] _time points to the timestamp instance to zero.
>>> -  #define _Timestamp64_Set_to_zero( _time ) \
>>> -    _Timestamp64_implementation_Set_to_zero( _time )
>>> -#else
>>> -  void _Timestamp64_Set_to_zero(
>>> -#endif
>>> -static inline bool _Timestamp64_implementation_Less_than(
>>> -  const Timestamp64_Control *_lhs,
>>> -  const Timestamp64_Control *_rhs
>>> -  return *_lhs < *_rhs;
>>> - *  @brief The "less than" operator for 64-bit timestamps.
>>> - *  This method is the less than operator for timestamps.
>>> - *  @param[in] _lhs points to the left hand side timestamp
>>> - *  @param[in] _rhs points to the right hand side timestamp
>>> - *  @retval This method returns true if @a _lhs is less than the @a _rhs and
>>> - *          false otherwise.
>>> -  #define _Timestamp64_Less_than( _lhs, _rhs ) \
>>> -    _Timestamp64_implementation_Less_than( _lhs, _rhs )
>>> -#else
>>> -  bool _Timestamp64_Less_than(
>>> -#endif
>>> -static inline bool _Timestamp64_implementation_Equal_to(
>>> -  return *_lhs == *_rhs;
>>> -#define _Timestamp64_Greater_than( _lhs, _rhs ) \
>>> -  _Timestamp64_Less_than( _rhs, _lhs )
>>> - *  @brief The "equal to" operator for 64-bit timestamps.
>>> - *  This method is the is equal to than operator for timestamps.
>>> - *  @retval This method returns true if @a _lhs is equal to  @a _rhs and
>>> -  #define _Timestamp64_Equal_to( _lhs, _rhs ) \
>>> -    _Timestamp64_implementation_Equal_to( _lhs, _rhs )
>>> -#else
>>> -  bool _Timestamp64_Equal_to(
>>> -#endif
>>> -static inline void _Timestamp64_implementation_Add_to(
>>> -  const Timestamp64_Control *_add
>>> -  *_time += *_add;
>>> - *  @brief Add two 64-bit timestamps.
>>> - *  This routine adds two timestamps.  The second argument is added
>>> - *  to the first.
>>> - *  @param[in] _time points to the base time to be added to
>>> - *  @param[in] _add points to the timestamp to add to the first argument
>>> - *  @retval This method returns the number of seconds @a time increased by.
>>> -  #define _Timestamp64_Add_to( _time, _add ) \
>>> -    _Timestamp64_implementation_Add_to( _time, _add )
>>> -#else
>>> -  void _Timestamp64_Add_to(
>>> -#endif
>>> -static inline void _Timestamp64_implementation_Subtract(
>>> -  const Timestamp64_Control *_start,
>>> -  const Timestamp64_Control *_end,
>>> -  Timestamp64_Control       *_result
>>> -  *_result = *_end - *_start;
>>> - *  @brief Subtract two 64-bit timestamps.
>>> - *  This routine subtracts two timestamps.  @a result is set to
>>> - *  @a end - @a start.
>>> - *  @param[in] _start points to the starting time
>>> - *  @param[in] _end points to the ending time
>>> - *  @param[out] _result points to the difference between
>>> - *             starting and ending time.
>>> -  #define _Timestamp64_Subtract( _start, _end, _result ) \
>>> -    _Timestamp64_implementation_Subtract( _start, _end, _result )
>>> -#else
>>> -  void _Timestamp64_Subtract(
>>> -#endif
>>> - *  @brief Divide 64-bit timestamp by another 64-bit timestamp.
>>> - *  This routine divides a timestamp by another timestamp.  The
>>> - *  intended use is for calculating percentages to three decimal points.
>>> - *  @param[in] _lhs points to the left hand number
>>> - *  @param[in] _rhs points to the right hand number
>>> - *  @param[out] _ival_percentage points to the integer portion of the average
>>> - *  @param[out] _fval_percentage points to the thousandths of percentage
>>> -void _Timestamp64_Divide(
>>> -  const Timestamp64_Control *_rhs,
>>> -  uint32_t                  *_ival_percentage,
>>> -  uint32_t                  *_fval_percentage
>>> -static inline uint32_t _Timestamp64_implementation_Get_seconds(
>>> -  const Timestamp64_Control *_time
>>> -  return (uint32_t) (*_time / 1000000000L);
>>> - *  @brief Get seconds portion of a 64-bit timestamp.
>>> - *  This method returns the seconds portion of the specified timestamp
>>> - *  @retval The seconds portion of @a _time.
>>> -  #define _Timestamp64_Get_seconds( _time ) \
>>> -    _Timestamp64_implementation_Get_seconds( _time )
>>> -#else
>>> -  uint32_t _Timestamp64_Get_seconds(
>>> -#endif
>>> -static inline uint32_t _Timestamp64_implementation_Get_nanoseconds(
>>> -  return (uint32_t) (*_time % 1000000000L);
>>> - *  @brief Get nanoseconds portion of a 64-bit timestamp.
>>> - *  This method returns the nanoseconds portion of the specified timestamp
>>> - *  @retval The nanoseconds portion of @a _time.
>>> -  #define _Timestamp64_Get_nanoseconds( _time ) \
>>> -    _Timestamp64_implementation_Get_nanoseconds( _time )
>>> -#else
>>> -  uint32_t _Timestamp64_Get_nanoseconds(
>>> -#endif
>>> -static inline uint64_t _Timestamp64_implementation_Get_As_nanoseconds(
>>> -  const Timestamp64_Control *_time,
>>> -  const uint32_t nanoseconds
>>> -  return *_time + (uint64_t) nanoseconds;
>>> - *  @brief Get the 64-bit timestamp as nanoseconds.
>>> - *  This method returns the 64-bit timestamp as it is already in nanoseconds.
>>> -#define _Timestamp64_Get_As_nanoseconds( _time, _nanoseconds ) \
>>> -  _Timestamp64_implementation_Get_As_nanoseconds( _time, _nanoseconds )
>>> -static inline void _Timestamp64_implementation_To_timespec(
>>> -  const Timestamp64_Control *_timestamp,
>>> -  struct timespec           *_timespec
>>> -  _timespec->tv_sec = (time_t) (*_timestamp / 1000000000L);
>>> -  _timespec->tv_nsec = (long) (*_timestamp % 1000000000L);
>>> - *  @brief Convert 64-bit timestamp to struct timespec.
>>> - *  @param[in] _timestamp points to the timestamp
>>> - *  @param[out] _timespec points to the timespec
>>> -  #define _Timestamp64_To_timespec( _timestamp, _timespec  ) \
>>> -    _Timestamp64_implementation_To_timespec( _timestamp, _timespec )
>>> -#else
>>> -  void _Timestamp64_To_timespec(
>>> -#endif
>>> -static inline void _Timestamp64_implementation_To_timeval(
>>> -  struct timeval            *_timeval
>>> -  _timeval->tv_sec = (time_t) (*_timestamp / 1000000000U);
>>> -  _timeval->tv_usec = (suseconds_t) ((*_timestamp % 1000000000U) / 1000U);
>>> - *  @brief Convert 64-bit timestamp to struct timeval.
>>> - *  @param[out] _timeval points to the timeval
>>> -  #define _Timestamp64_To_timeval( _timestamp, _timeval  ) \
>>> -    _Timestamp64_implementation_To_timeval( _timestamp, _timeval )
>>> -#else
>>> -  void _Timestamp64_To_timeval(
>>> -#endif
>>> -#ifdef __cplusplus
>>> -#endif
>>> -#endif
>>> -/* end of include file */
>>> diff --git a/cpukit/score/include/rtems/score/tod.h b/cpukit/score/include/rtems/score/tod.h
>>> index 1972b0f..c0ab5e7 100644
>>> --- a/cpukit/score/include/rtems/score/tod.h
>>> +++ b/cpukit/score/include/rtems/score/tod.h
>>> @@ -24,15 +24,6 @@
>>>  extern "C" {
>>>  #endif
>>> - * @brief Returns the nanoseconds since the last clock tick.
>>> - * @ingroup ScoreTOD
>>> - * @return The nanoseconds since the last clock tick.
>>> -typedef uint32_t ( *TOD_Nanoseconds_since_last_tick_routine )( void );
>>>  #ifdef __cplusplus
>>>  #endif
>>> diff --git a/cpukit/score/include/rtems/score/todimpl.h b/cpukit/score/include/rtems/score/todimpl.h
>>> index ad5ed39..4fe85d4 100644
>>> --- a/cpukit/score/include/rtems/score/todimpl.h
>>> +++ b/cpukit/score/include/rtems/score/todimpl.h
>>> @@ -19,8 +19,8 @@
>>>  #define _RTEMS_SCORE_TODIMPL_H
>>>  #include <rtems/score/tod.h>
>>> -#include <rtems/score/isrlock.h>
>>>  #include <rtems/score/timestamp.h>
>>> +#include <rtems/score/timecounterimpl.h>
>>>  #include <time.h>
>>> @@ -131,25 +131,6 @@ extern "C" {
>>>  typedef struct {
>>> -   * @brief Current time of day value.
>>> -   * This field is protected by the lock.
>>> -  Timestamp_Control now;
>>> -   * @brief System uptime.
>>> -  Timestamp_Control uptime;
>>> -   * @brief Lock to protect the now and uptime fields.
>>> -  ISR_lock_Control lock;
>>>     * @brief Time of day seconds trigger.
>>>     * This value specifies the nanoseconds since the last time of day second.
>>> @@ -159,13 +140,6 @@ typedef struct {
>>>    uint32_t seconds_trigger;
>>> -   * @brief The current nanoseconds since last tick handler.
>>> -   * This field must not be NULL after initialization.
>>> -  TOD_Nanoseconds_since_last_tick_routine nanoseconds_since_last_tick;
>>>     *  @brief Indicates if the time of day is set.
>>>     *  This is true if the application has set the current
>>> @@ -176,12 +150,6 @@ typedef struct {
>>>  SCORE_EXTERN TOD_Control _TOD;
>>> -#define _TOD_Acquire( _tod, lock_context ) \
>>> -  _ISR_lock_ISR_disable_and_acquire( &( _tod )->lock, lock_context )
>>> -#define _TOD_Release( _tod, lock_context ) \
>>> -  _ISR_lock_Release_and_ISR_enable( &( _tod )->lock, lock_context )
>>>   *  @brief Initializes the time of day handler.
>>> @@ -215,32 +183,18 @@ static inline void _TOD_Set(
>>>    _TOD_Set_with_timestamp( &tod_as_timestamp );
>>> - *  @brief Returns a snapshot of a clock.
>>> - *  This function invokes the nanoseconds extension.
>>> - *  @param[out] snapshot points to an area that will contain the current
>>> - *              TOD plus the BSP nanoseconds since last tick adjustment
>>> - *  @param[in] clock contains the current TOD
>>> - *  @retval @a snapshot
>>> -Timestamp_Control *_TOD_Get_with_nanoseconds(
>>> -  Timestamp_Control *snapshot,
>>> -  const Timestamp_Control *clock
>>>  static inline void _TOD_Get(
>>> -  struct timespec *tod_as_timespec
>>> +  Timestamp_Control *time
>>> -  Timestamp_Control  tod_as_timestamp;
>>> -  Timestamp_Control *tod_as_timestamp_ptr;
>>> +  _Timecounter_Bintime(time);
>>> -  tod_as_timestamp_ptr =
>>> -    _TOD_Get_with_nanoseconds( &tod_as_timestamp, &_TOD.now );
>>> -  _Timestamp_To_timespec( tod_as_timestamp_ptr, tod_as_timespec );
>>> +static inline void _TOD_Get_as_timespec(
>>> +  struct timespec *time
>>> +  _Timecounter_Nanotime(time);
>>> @@ -255,7 +209,7 @@ static inline void _TOD_Get_uptime(
>>> -  _TOD_Get_with_nanoseconds( time, &_TOD.uptime );
>>> +  _Timecounter_Binuptime(time);
>>> @@ -266,9 +220,12 @@ static inline void _TOD_Get_uptime(
>>>   *  @param[in] time is a pointer to the uptime to be returned
>>> -void _TOD_Get_uptime_as_timespec(
>>> +static inline void _TOD_Get_uptime_as_timespec(
>>> +  _Timecounter_Nanouptime(time);
>>>   *  @brief Number of seconds Since RTEMS epoch.
>>> @@ -276,7 +233,14 @@ void _TOD_Get_uptime_as_timespec(
>>>   *  The following contains the number of seconds from 00:00:00
>>>   *  January 1, TOD_BASE_YEAR until the current time of day.
>>> -uint32_t _TOD_Seconds_since_epoch( void );
>>> +static inline uint32_t _TOD_Seconds_since_epoch( void )
>>> +  struct bintime bt;
>>> +  _Timecounter_Bintime(&bt);
>>> +  return bt.sec;
>>>   *  @brief Increments time of day at each clock tick.
>>> @@ -314,12 +278,7 @@ RTEMS_INLINE_ROUTINE void _TOD_Get_timeval(
>>>    struct timeval *time
>>> -  Timestamp_Control  snapshot_as_timestamp;
>>> -  Timestamp_Control *snapshot_as_timestamp_ptr;
>>> -  snapshot_as_timestamp_ptr =
>>> -    _TOD_Get_with_nanoseconds( &snapshot_as_timestamp, &_TOD.now );
>>> -  _Timestamp_To_timeval( snapshot_as_timestamp_ptr, time );
>>> +  _Timecounter_Microtime(time);
>>> @@ -335,18 +294,6 @@ void _TOD_Adjust(
>>> - * @brief Install the BSP's nanoseconds since clock tick handler
>>> - * @param[in] routine is the BSP's nanoseconds since clock tick method
>>> -RTEMS_INLINE_ROUTINE void _TOD_Set_nanoseconds_since_last_tick_handler(
>>> -  TOD_Nanoseconds_since_last_tick_routine routine
>>> -  _TOD.nanoseconds_since_last_tick = routine;
>>>   * @brief Check if the TOD is Set
>>>   * @return TRUE is the time is set. FALSE otherwise.
>>> diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
>>> index 75c8be6..b74afb8 100644
>>> --- a/cpukit/score/preinstall.am
>>> +++ b/cpukit/score/preinstall.am
>>> @@ -348,9 +348,13 @@ $(PROJECT_INCLUDE)/rtems/score/timestamp.h: include/rtems/score/timestamp.h $(PR
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timestamp.h
>>>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timestamp.h
>>> -$(PROJECT_INCLUDE)/rtems/score/timestamp64.h: include/rtems/score/timestamp64.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>>> -       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
>>> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
>>> +$(PROJECT_INCLUDE)/rtems/score/timecounter.h: include/rtems/score/timecounter.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timecounter.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timecounter.h
>>> +$(PROJECT_INCLUDE)/rtems/score/timecounterimpl.h: include/rtems/score/timecounterimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timecounterimpl.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timecounterimpl.h
>>>  $(PROJECT_INCLUDE)/rtems/score/tls.h: include/rtems/score/tls.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
>>>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/tls.h
>>> diff --git a/cpukit/score/src/coretod.c b/cpukit/score/src/coretod.c
>>> index 2deeeba..67d5104 100644
>>> --- a/cpukit/score/src/coretod.c
>>> +++ b/cpukit/score/src/coretod.c
>>> @@ -20,23 +20,15 @@
>>> -static uint32_t _TOD_Nanoseconds_since_tick_default_handler( void )
>>> -  return 0;
>>>  void _TOD_Handler_initialization(void)
>>> -  _ISR_lock_Initialize( &tod->lock, "TOD" );
>>> -  _Timestamp_Set( &tod->now, TOD_SECONDS_1970_THROUGH_1988, 0 );
>>> -  _Timestamp_Set_to_zero( &tod->uptime );
>>> -  tod->nanoseconds_since_last_tick =
>>> -    _TOD_Nanoseconds_since_tick_default_handler;
>>> +  ts.tv_sec = TOD_SECONDS_1970_THROUGH_1988;
>>> +  ts.tv_nsec = 0;
>>> +  _Timecounter_Set_clock(&ts);
>>>    /* TOD has not been set */
>>>    tod->is_set = false;
>>> diff --git a/cpukit/score/src/coretodadjust.c b/cpukit/score/src/coretodadjust.c
>>> index 09cf01a..6097e20 100644
>>> --- a/cpukit/score/src/coretodadjust.c
>>> +++ b/cpukit/score/src/coretodadjust.c
>>> @@ -25,8 +25,7 @@ void _TOD_Adjust(
>>>    const Timestamp_Control delta
>>> -  Timestamp_Control  tod;
>>> -  Timestamp_Control *tod_ptr;
>>> +  Timestamp_Control tod;
>>>     * Currently, RTEMS does the adjustment in one movement.
>>> @@ -41,11 +40,11 @@ void _TOD_Adjust(
>>>    _Thread_Disable_dispatch();
>>> -    tod_ptr = _TOD_Get_with_nanoseconds( &tod, &_TOD.now );
>>> +    _TOD_Get( &tod );
>>> -    _Timestamp_Add_to( tod_ptr, &delta );
>>> +    _Timestamp_Add_to( &tod, &delta );
>>> -    _TOD_Set_with_timestamp( tod_ptr );
>>> +    _TOD_Set_with_timestamp( &tod );
>>>    _Thread_Enable_dispatch();
>>> diff --git a/cpukit/score/src/coretodget.c b/cpukit/score/src/coretodget.c
>>> index 70eb238..0000000
>>> --- a/cpukit/score/src/coretodget.c
>>> +++ /dev/null
>>> @@ -1,46 +0,0 @@
>>> - * @file
>>> - * @brief Returns a Current TOD with Nanosecond Granularity
>>> - *  COPYRIGHT (c) 1989-2014.
>>> -#if HAVE_CONFIG_H
>>> -  #include "config.h"
>>> -#endif
>>> -#include <rtems/score/isrlevel.h>
>>> -  Timestamp_Control offset;
>>> -    nanoseconds = ( *tod->nanoseconds_since_last_tick )();
>>> -    now = *clock;
>>> -  _Timestamp_Set( &offset, 0, nanoseconds );
>>> -  _Timestamp_Add_to( &now, &offset );
>>> -  *snapshot = now;
>>> -  return snapshot;
>>> diff --git a/cpukit/score/src/coretodgetuptimetimespec.c b/cpukit/score/src/coretodgetuptimetimespec.c
>>> index 5980b2f..0000000
>>> --- a/cpukit/score/src/coretodgetuptimetimespec.c
>>> +++ /dev/null
>>> @@ -1,32 +0,0 @@
>>> - * @file
>>> - * @brief Get Uptime as struct timespec
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -  struct timespec *uptime
>>> -  Timestamp_Control uptime_ts;
>>> -  /* assume time checked for NULL by caller */
>>> -  _TOD_Get_uptime( &uptime_ts );
>>> -  _Timestamp_To_timespec( &uptime_ts, uptime );
>>> diff --git a/cpukit/score/src/coretodsecondssinceepoch.c b/cpukit/score/src/coretodsecondssinceepoch.c
>>> index b7bd270..0000000
>>> --- a/cpukit/score/src/coretodsecondssinceepoch.c
>>> +++ /dev/null
>>> @@ -1,32 +0,0 @@
>>> - * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
>>> - *  embedded brains GmbH
>>> - *  Dornierstr. 4
>>> - *  82178 Puchheim
>>> - *  Germany
>>> - *  <rtems at embedded-brains.de>
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -   now = tod->now;
>>> -  return _Timestamp_Get_seconds( &now );
>>> diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
>>> index 6006e66..8cff81c 100644
>>> --- a/cpukit/score/src/coretodset.c
>>> +++ b/cpukit/score/src/coretodset.c
>>> @@ -27,10 +27,14 @@ void _TOD_Set_with_timestamp(
>>>    uint32_t nanoseconds = _Timestamp_Get_nanoseconds( tod_as_timestamp );
>>>    Watchdog_Interval seconds_next = _Timestamp_Get_seconds( tod_as_timestamp );
>>>    Watchdog_Interval seconds_now;
>>> +  bintime2timespec(tod_as_timestamp, &ts);
>>> +  nanoseconds = ts.tv_nsec;
>>> +  seconds_next = ts.tv_sec;
>>> @@ -41,9 +45,7 @@ void _TOD_Set_with_timestamp(
>>>    else
>>>      _Watchdog_Adjust_seconds( WATCHDOG_FORWARD, seconds_next - seconds_now );
>>> -  tod->now = *tod_as_timestamp;
>>>    tod->seconds_trigger = nanoseconds;
>>>    tod->is_set = true;
>>> diff --git a/cpukit/score/src/coretodtickle.c b/cpukit/score/src/coretodtickle.c
>>> index 9116fc1..3d7c71e 100644
>>> --- a/cpukit/score/src/coretodtickle.c
>>> +++ b/cpukit/score/src/coretodtickle.c
>>> @@ -24,30 +24,10 @@
>>>  void _TOD_Tickle_ticks( void )
>>> -  Timestamp_Control  tick;
>>> -  uint32_t           nanoseconds_per_tick;
>>> -  nanoseconds_per_tick = rtems_configuration_get_nanoseconds_per_tick();
>>> -  /* Convert the tick quantum to a timestamp */
>>> -  _Timestamp_Set( &tick, 0, nanoseconds_per_tick );
>>>    /* Update the counter of ticks since boot */
>>>    _Watchdog_Ticks_since_boot += 1;
>>> -  /* Update the uptime */
>>> -  _Timestamp_Add_to( &tod->uptime, &tick );
>>> -  /* Update the current TOD */
>>> -  _Timestamp_Add_to( &tod->now, &tick );
>>> -  _TOD.seconds_trigger += nanoseconds_per_tick;
>>> +  _TOD.seconds_trigger += rtems_configuration_get_nanoseconds_per_tick();
>>>    if ( _TOD.seconds_trigger >= 1000000000UL ) {
>>>      _TOD.seconds_trigger -= 1000000000UL;
>>>      _Watchdog_Tickle_seconds();
>>> diff --git a/cpukit/score/src/tcgetscalerandmask.c b/cpukit/score/src/tcgetscalerandmask.c
>>> index 0000000..a2a2db4
>>> --- /dev/null
>>> +++ b/cpukit/score/src/tcgetscalerandmask.c
>>> @@ -0,0 +1,40 @@
>>> + *  Dornierstr. 4
>>> + *  82178 Puchheim
>>> + *  Germany
>>> +#if HAVE_CONFIG_H
>>> +  #include "config.h"
>>> +#endif
>>> +  uint64_t *scaler,
>>> +  uint32_t *mask
>>> +  uint32_t power_of_two = 1;
>>> +  int i;
>>> +  for ( i = 0; i < 32; ++i ) {
>>> +    if ( power_of_two >= counter_ticks_per_clock_tick ) {
>>> +      break;
>>> +    power_of_two *= 2;
>>> +  *mask = (2 * power_of_two) - 1;
>>> +  *scaler = ((uint64_t) power_of_two << 32) / counter_ticks_per_clock_tick;
>>> diff --git a/cpukit/score/src/ts64addto.c b/cpukit/score/src/ts64addto.c
>>> index a0f4b3c..0000000
>>> --- a/cpukit/score/src/ts64addto.c
>>> +++ /dev/null
>>> @@ -1,31 +0,0 @@
>>> - * @file score/src/ts64addto.c
>>> - * @brief Add to a Timestamp
>>> - * @ingroup SuperCore
>>> - *  COPYRIGHT (c) 1989-2008.
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -#include <rtems/score/timestamp.h>
>>> -void _Timestamp64_Add_to(
>>> -  _Timestamp64_implementation_Add_to( _time, _add );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64divide.c b/cpukit/score/src/ts64divide.c
>>> index d9a5099..0000000
>>> --- a/cpukit/score/src/ts64divide.c
>>> +++ /dev/null
>>> @@ -1,51 +0,0 @@
>>> - *  @file
>>> - *  @brief Divide Timestamp
>>> - *  COPYRIGHT (c) 1989-2007.
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -/* This method is never inlined. */
>>> -  Timestamp64_Control answer;
>>> -  if ( *_rhs == 0 ) {
>>> -    *_ival_percentage = 0;
>>> -    *_fval_percentage = 0;
>>> -    return;
>>> -   *  This looks odd but gives the results the proper precision.
>>> -   *  TODO: Rounding on the last digit of the fval.
>>> -  answer = (*_lhs * 100000) / *_rhs;
>>> -  *_ival_percentage = answer / 1000;
>>> -  *_fval_percentage = answer % 1000;
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64equalto.c b/cpukit/score/src/ts64equalto.c
>>> index fd07474..0000000
>>> --- a/cpukit/score/src/ts64equalto.c
>>> +++ /dev/null
>>> @@ -1,31 +0,0 @@
>>> - *  @file
>>> - *  @brief Timestamp equal to Operator
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -bool _Timestamp64_Equal_to(
>>> -  return _Timestamp64_implementation_Equal_to( _lhs, _rhs );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64getnanoseconds.c b/cpukit/score/src/ts64getnanoseconds.c
>>> index a5da43b..0000000
>>> --- a/cpukit/score/src/ts64getnanoseconds.c
>>> +++ /dev/null
>>> @@ -1,30 +0,0 @@
>>> - *  @file  score/src/ts64toticks.c
>>> - *  @brief Get Nanoseconds Portion of Timestamp
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -uint32_t _Timestamp64_Get_nanoseconds(
>>> -  return _Timestamp64_implementation_Get_nanoseconds( _time );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64getseconds.c b/cpukit/score/src/ts64getseconds.c
>>> index eca0536..0000000
>>> --- a/cpukit/score/src/ts64getseconds.c
>>> +++ /dev/null
>>> @@ -1,30 +0,0 @@
>>> - * @file
>>> - * @brief Get Seconds Portion of Timestamp
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -uint32_t _Timestamp64_Get_seconds(
>>> -  return _Timestamp64_implementation_Get_seconds( _time );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64lessthan.c b/cpukit/score/src/ts64lessthan.c
>>> index d147814..0000000
>>> --- a/cpukit/score/src/ts64lessthan.c
>>> +++ /dev/null
>>> @@ -1,31 +0,0 @@
>>> - * @file
>>> - * @brief Timestamp Less Than Operator
>>> - * @ingroup SuperCore Timestamp64
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -bool _Timestamp64_Less_than(
>>> -  return _Timestamp64_implementation_Less_than( _lhs, _rhs );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64set.c b/cpukit/score/src/ts64set.c
>>> index 22771d6..0000000
>>> --- a/cpukit/score/src/ts64set.c
>>> +++ /dev/null
>>> @@ -1,33 +0,0 @@
>>> - * @file
>>> - * @brief Set Timestamp to Specified Seconds and Nanoseconds
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -void _Timestamp64_Set(
>>> -  _Timestamp64_implementation_Set( _time, _seconds, _nanoseconds );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64settozero.c b/cpukit/score/src/ts64settozero.c
>>> index 7b319df..0000000
>>> --- a/cpukit/score/src/ts64settozero.c
>>> +++ /dev/null
>>> @@ -1,31 +0,0 @@
>>> - * @file
>>> - * @brief Zero a Timestamp64 Instance
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -void _Timestamp64_Set_to_zero(
>>> -  _Timestamp64_implementation_Set_to_zero( _time );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64subtract.c b/cpukit/score/src/ts64subtract.c
>>> index 1ee917b..0000000
>>> --- a/cpukit/score/src/ts64subtract.c
>>> +++ /dev/null
>>> @@ -1,31 +0,0 @@
>>> - * @file
>>> - * @brief Subtract Two Timestamps
>>> - * @ingroup Timestamp
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -void _Timestamp64_Subtract(
>>> -  _Timestamp64_implementation_Subtract( _start, _end, _result );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64totimespec.c b/cpukit/score/src/ts64totimespec.c
>>> index 7e81da7..0000000
>>> --- a/cpukit/score/src/ts64totimespec.c
>>> +++ /dev/null
>>> @@ -1,32 +0,0 @@
>>> - * @file
>>> - * @brief Convert Timestamp to Struct Timespec
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -void _Timestamp64_To_timespec(
>>> -  _Timestamp64_implementation_To_timespec( _timestamp, _timespec );
>>> -#endif
>>> diff --git a/cpukit/score/src/ts64totimeval.c b/cpukit/score/src/ts64totimeval.c
>>> index 1ac765b..0000000
>>> --- a/cpukit/score/src/ts64totimeval.c
>>> +++ /dev/null
>>> @@ -1,37 +0,0 @@
>>> - * @file
>>> - * @brief Convert 64-bit Timestamp to struct timeval
>>> - * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
>>> - *  Obere Lagerstr. 30
>>> - *  82178 Puchheim
>>> - *  Germany
>>> -#if HAVE_CONFIG_H
>>> -#endif
>>> -void _Timestamp64_To_timeval(
>>> -  _Timestamp64_implementation_To_timeval( _timestamp, _timeval );
>>> -#endif
>>> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
>>> index 9025ff3..c3fc443 100644
>>> --- a/testsuites/sptests/Makefile.am
>>> +++ b/testsuites/sptests/Makefile.am
>>> @@ -38,6 +38,8 @@ else
>>>  _SUBDIRS += sp29
>>>  endif
>>>  _SUBDIRS += spintrcritical23
>>> +_SUBDIRS += sptimecounter01
>>> +_SUBDIRS += sptimecounter02
>>>  _SUBDIRS += spatomic01
>>>  _SUBDIRS += spintrcritical22
>>>  _SUBDIRS += spsem03
>>> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
>>> index ae3c763..dbdd30f 100644
>>> --- a/testsuites/sptests/configure.ac
>>> +++ b/testsuites/sptests/configure.ac
>>> @@ -41,6 +41,8 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
>>>  # Explicitly list all Makefiles here
>>>  AC_CONFIG_FILES([Makefile
>>>  spintrcritical23/Makefile
>>> +sptimecounter02/Makefile
>>> +sptimecounter01/Makefile
>>>  spatomic01/Makefile
>>>  spglobalcon01/Makefile
>>>  spintrcritical22/Makefile
>>> diff --git a/testsuites/sptests/spclock_err01/init.c b/testsuites/sptests/spclock_err01/init.c
>>> index ab5c00a..087c8d4 100644
>>> --- a/testsuites/sptests/spclock_err01/init.c
>>> +++ b/testsuites/sptests/spclock_err01/init.c
>>> @@ -115,14 +115,6 @@ rtems_task Init(
>>>      puts( "TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED" );
>>> -  puts( "TA1 - rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS" );
>>> -  status = rtems_clock_set_nanoseconds_extension( NULL );
>>> -  fatal_directive_status(
>>> -    status,
>>> -    RTEMS_INVALID_ADDRESS,
>>> -    "rtems_clock_set_nanoseconds_extension NULL param"
>>>    /* NULL parameter */
>>>    status = rtems_clock_set( NULL );
>>> diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
>>> index f427bd2..3e01466 100644
>>> --- a/testsuites/sptests/spsize/size.c
>>> +++ b/testsuites/sptests/spsize/size.c
>>> @@ -390,9 +390,6 @@ uninitialized =
>>>  /*timerimpl.h*/ (sizeof _Timer_Information)               +
>>> -/*tod.h*/       (sizeof _TOD.now)                         +
>>> -                (sizeof _TOD.uptime)                      +
>>>  /*tqdata.h*/    0                                         +
>>>  /*types.h*/     0                                         +
>>> diff --git a/testsuites/sptests/sptimecounter02/Makefile.am b/testsuites/sptests/sptimecounter02/Makefile.am
>>> index 0000000..498c24e
>>> --- /dev/null
>>> +++ b/testsuites/sptests/sptimecounter02/Makefile.am
>>> @@ -0,0 +1,19 @@
>>> +rtems_tests_PROGRAMS = sptimecounter02
>>> +sptimecounter02_SOURCES = init.c
>>> +dist_rtems_tests_DATA = sptimecounter02.scn sptimecounter02.doc
>>> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
>>> +include $(top_srcdir)/../automake/compile.am
>>> +include $(top_srcdir)/../automake/leaf.am
>>> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
>>> +LINK_OBJS = $(sptimecounter02_OBJECTS)
>>> +LINK_LIBS = $(sptimecounter02_LDLIBS)
>>> +sptimecounter02$(EXEEXT): $(sptimecounter02_OBJECTS) $(sptimecounter02_DEPENDENCIES)
>>> +       @rm -f sptimecounter02$(EXEEXT)
>>> +       $(make-exe)
>>> +include $(top_srcdir)/../automake/local.am
>>> diff --git a/testsuites/sptests/sptimecounter02/init.c b/testsuites/sptests/sptimecounter02/init.c
>>> index 0000000..781401f
>>> --- /dev/null
>>> +++ b/testsuites/sptests/sptimecounter02/init.c
>>> @@ -0,0 +1,266 @@
>>> + *  Dornierstr. 4
>>> + *  82178 Puchheim
>>> + *  Germany
>>> +#ifdef HAVE_CONFIG_H
>>> +#endif
>>> +#define _KERNEL
>>> +#include <sys/time.h>
>>> +#include <stdlib.h>
>>> +#include <stdio.h>
>>> +#include <inttypes.h>
>>> +#include <assert.h>
>>> +#include <unistd.h>
>>> +#include <rtems.h>
>>> +#include <rtems/counter.h>
>>> +#include <rtems/test.h>
>>> +#include "tmacros.h"
>>> +const char rtems_test_name[] = "SPTIMECOUNTER_2";
>>> +#define MASTER_PRIORITY 1
>>> +#define WORKER_PRIORITY 2
>>> +#define CPU_COUNT 32
>>> +#define DURATION_LENGTH 2
>>> +typedef struct {
>>> +  rtems_test_parallel_context base;
>>> +  struct timecounter tc_soft;
>>> +  struct timecounter tc_cpu_counter;
>>> +  u_int tc_soft_counter;
>>> +  uint32_t binuptime_per_job[CPU_COUNT];
>>> +  uint32_t rtemsuptime_per_job[CPU_COUNT];
>>> +} timecounter_context;
>>> +typedef struct {
>>> +  struct bintime start_bin;
>>> +  struct bintime end_bin;
>>> +  struct bintime diff;
>>> +} test_variables;
>>> +static timecounter_context test_instance;
>>> +static test_variables test_values;
>>> +static rtems_interval test_duration(void)
>>> +  return DURATION_LENGTH * rtems_clock_get_ticks_per_second();
>>> +static u_int test_get_timecount_null(struct timecounter *tc)
>>> +       return 0;
>>> +static u_int test_get_timecount_cpu(struct timecounter *tc)
>>> +  return 0xffffffff - rtems_counter_read();
>>> +static void register_hardware_tc_null(timecounter_context *ctx)
>>> +  struct timecounter *tc_cpu = &ctx->tc_cpu_counter;
>>> +  tc_cpu->tc_get_timecount = test_get_timecount_null;
>>> +  tc_cpu->tc_counter_mask = 0xffffffff;
>>> +  tc_cpu->tc_frequency = rtems_counter_nanoseconds_to_ticks(1000000000);
>>> +  tc_cpu->tc_quality = 2000;
>>> +  _Timecounter_Install(tc_cpu);
>>> + * Start of Timers
>>> +static rtems_interval test_bintime_init(
>>> +  rtems_test_parallel_context *base,
>>> +  void *arg,
>>> +  size_t active_workers
>>> +  return test_duration();
>>> +static void test_bintime_body(
>>> +  void *arg,
>>> +  size_t active_workers,
>>> +  size_t worker_index
>>> +  timecounter_context *ctx = (timecounter_context *) base;
>>> +  uint32_t counter = 0;
>>> +  test_variables *values = &test_values;
>>> +  while (!rtems_test_parallel_stop_job(&ctx->base)) {
>>> +    ++counter;
>>> +    rtems_binuptime(&bt);
>>> +    if (counter == 1){
>>> +      values->start_bin = bt;
>>> +  values->end_bin = bt;
>>> +  values->diff = bt;
>>> +  bintime_sub(&values->diff, &values->start_bin);
>>> +  printf("\n%" PRIu32 " %" PRIu64 "\n", values->start_bin.sec,
>>> +    values->start_bin.frac);
>>> +  printf("%" PRIu32 " %" PRIu64 "\n", values->end_bin.sec,
>>> +    values->end_bin.frac);
>>> +  assert((values->diff.sec == DURATION_LENGTH) ||
>>> +   ((values->diff.sec == DURATION_LENGTH - 1) &&
>>> +   (values->diff.frac > UINT64_C(18000000000000000000))) ||
>>> +   ((values->diff.sec == DURATION_LENGTH + 1) &&
>>> +   (values->end_bin.frac < UINT64_C(2000000000000000000)))
>>> +  ctx->binuptime_per_job[worker_index] = counter;
>>> +static void test_bintime_fini(
>>> +  void *arg,
>>> +  size_t i;
>>> +  printf("  <BinuptimeTest activeWorker=\"%zu\">\n", active_workers);
>>> +  for (i = 0; i < active_workers; ++i) {
>>> +    printf(
>>> +      "      <Counter worker=\"%zu\">%" PRIu32 "</Counter>\n",
>>> +      (i+1), ctx->binuptime_per_job[i]);
>>> +  printf("  </BinuptimeTest>\n");
>>> +static rtems_interval test_bintime_null_init(
>>> +  void *arg,
>>> +  timecounter_context *ctx = &test_instance;
>>> +  register_hardware_tc_null(ctx);
>>> +static void test_bintime_null_body(
>>> +  void *arg,
>>> +    ++counter;
>>> +static void test_bintime_null_fini(
>>> +  void *arg,
>>> +  size_t i;
>>> +  printf("  <BinuptimenullTest activeWorker=\"%zu\">\n", active_workers);
>>> +    printf(
>>> +  printf("  </BinuptimenullTest>\n");
>>> +static const rtems_test_parallel_job timecounter_jobs[] = {
>>> +    .init = test_bintime_init,
>>> +    .body = test_bintime_body,
>>> +    .fini = test_bintime_fini,
>>> +    .cascade = true
>>> +    .init = test_bintime_null_init,
>>> +    .body = test_bintime_null_body,
>>> +    .fini = test_bintime_null_fini,
>>> +    .cascade = true
>>> + * Start of Init
>>> +static void Init(rtems_task_argument arg)
>>> +  TEST_BEGIN();
>>> +  printf("<TEST>\n");
>>> +  rtems_test_parallel(
>>> +    &ctx->base,
>>> +    NULL,
>>> +    &timecounter_jobs[0],
>>> +    RTEMS_ARRAY_SIZE(timecounter_jobs)
>>> +  printf("</TEST>\n");
>>> +  TEST_END();
>>> +  rtems_test_exit(0);
>>> +#define CONFIGURE_MICROSECONDS_PER_TICK 1000
>>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>> +#define CONFIGURE_MAXIMUM_TASKS (2 + CPU_COUNT - 1)
>>> +#define CONFIGURE_MAXIMUM_TIMERS 2
>>> +#define CONFIGURE_MAXIMUM_PERIODS 1
>>> +#define CONFIGURE_SMP_APPLICATION
>>> +#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>> +#include <rtems/confdefs.h>
>>> diff --git a/testsuites/sptests/sptimecounter02/sptimecounter02.doc b/testsuites/sptests/sptimecounter02/sptimecounter02.doc
>>> index 0000000..56e8bb6
>>> --- /dev/null
>>> +++ b/testsuites/sptests/sptimecounter02/sptimecounter02.doc
>>> @@ -0,0 +1,11 @@
>>> +This file describes the directives and concepts tested by this test set.
>>> +test set name: sptimecounter02
>>> +directives:
>>> +  TBD
>>> +concepts:
>>> +  TBD
>>> diff --git a/testsuites/sptests/sptimecounter02/sptimecounter02.scn b/testsuites/sptests/sptimecounter02/sptimecounter02.scn
>>> index 0000000..e69de29
>>> 1.8.4.5
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
