[PATCH] cpukit/libi2c allowed to probe on device init
Alexandru-Sever Horin
alex.sever.h at gmail.com
Thu Apr 2 07:45:46 UTC 2015
Hello Sebastian,
Thank you for the suggestion. The API compatible with Linux devices sounds
great.
However, the RTEMS version we are using is a few days before your patches,
and probably I will port a bt firther along the road.
I have one question, though, is there a plan to port other Linux driver
APIs like SPI ?
Thank you,
Alex H
On Thu, Apr 2, 2015 at 9:53 AM, Sebastian Huber <
> Hello Alexandru-Sever,
> in case you use the latest RTEMS version, then I would consider to use the
> new I2C support:
> https://docs.rtems.org/doxygen/cpukit/html/group__I2C.html
> For example see:
> https://git.rtems.org/rtems/tree/cpukit/dev/i2c
> https://git.rtems.org/rtems/tree/testsuites/libtests/i2c01
> On 02/04/15 08:48, Alexandru-Sever Horin wrote:
>> From: Alexandru-Sever Horin <alex.sever.h at gmail.com>
>> libi2c registration of a device fails if the device initialization fails
>> Benefits: allows for device probing on multiple addresses
>> cpukit/libi2c/libi2c.c | 27 ++++++++++++++++-----------
>> 1 file changed, 16 insertions(+), 11 deletions(-)
>> diff --git a/cpukit/libi2c/libi2c.c b/cpukit/libi2c/libi2c.c
>> index 233cb68..315a761 100644
>> --- a/cpukit/libi2c/libi2c.c
>> +++ b/cpukit/libi2c/libi2c.c
>> @@ -736,6 +736,16 @@ rtems_libi2c_register_drv (const char *name,
>> rtems_libi2c_drv_t * drvtbl,
>> /* found a free slot; encode slot + 1 ! */
>> minor = ((i + 1) << 13) | RTEMS_LIBI2C_MAKE_MINOR (busno,
>> i2caddr);
>> + /* before registering, try to initialize the device to check
>> it's there */
>> + if (drvtbl->ops->initialization_entry) {
>> + err = drvtbl->ops->initialization_entry (rtems_libi2c_major,
>> minor, 0);
>> + if (err) {
>> + LIBUNLOCK ();
>> + /* returned value must be negative on failure */
>> + return err < 0 ? err : -err;
>> if (name) {
>> size_t length = strlen (busses[busno].name) + strlen (name) + 2;
>> str = malloc (length);
>> @@ -751,9 +761,10 @@ rtems_libi2c_register_drv (const char *name,
>> /* note that 'umask' is applied to 'mode' */
>> if (mknod (str, mode, dev)) {
>> - safe_printf( DRVNM
>> - "Creating device node failed: %s; you can try to do
>> it manually...\n",
>> - strerror (errno));
>> + safe_printf ( DRVNM
>> + "Creating device node failed: %s;\n"
>> + "you can try to do it manually...\n",
>> + strerror (errno));
>> free (str);
>> @@ -761,17 +772,11 @@ rtems_libi2c_register_drv (const char *name,
>> drvs[i].drv = drvtbl;
>> - if (drvtbl->ops->initialization_entry)
>> - err =
>> - drvs[i].drv->ops->initialization_entry (rtems_libi2c_major,
>> minor,
>> - 0);
>> - else
>> - err = RTEMS_SUCCESSFUL;
>> LIBUNLOCK ();
>> - return err ? -err : minor;
>> + return minor;
>> LIBUNLOCK ();
>> return -RTEMS_TOO_MANY;
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150402/06063857/attachment-0001.html>
