or1k not running hello with sim-scripts or rtems-tester
Hesham ALMatary heshamelmatary at gmail.com
Thu Apr 2 11:30:43 UTC 2015
Hi,
I checked it out again. For sim-scripts qemu-or1k is working fine.
or1ksim was waiting for GDB to connect, I submitted a patch to make it
running right away. For RTEMS Tester, every test would run until it
times out, because there is no way to force qemu to terminate from
RTEMS (unlike or1ksim simulator). sim-scripts/or1ksim is sending a
kill signal to qemu-system-or32 once it sees "END OF TEST" message,
can this be done for RTEMS Tester?
On Thu, Apr 2, 2015 at 10:53 AM, Hesham ALMatary
<heshamelmatary at gmail.com> wrote:
> Hi Dr. Joel,
> Do you have or1ksim simulator installed? Both depend on it. I ran
> hello world with sim-scripts now again and it's working fine.
> Regards,
> Hesham
> On Wed, Apr 1, 2015 at 9:09 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> Hesham.. I can't get hello world to run with either framework.
>> Can you take a look?
>> Thanks.
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
> Hesham
Hesham
