[PATCH] or1k: Send halt signal to or1k simulators when rtems terminates
Hesham ALMatary heshamelmatary at gmail.com
Thu Apr 2 13:15:15 UTC 2015
 cpukit/score/cpu/or1k/rtems/score/cpu.h          |  1 +
 cpukit/score/cpu/or1k/rtems/score/or1k-utility.h | 11 ++++++++++-
 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu.h b/cpukit/score/cpu/or1k/rtems/score/cpu.h
index 45aeb08..21cbb6d 100644
--- a/cpukit/score/cpu/or1k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/rtems/score/cpu.h
@@ -702,6 +702,7 @@ void _CPU_Context_Initialize(
 #define _CPU_Fatal_halt(_source, _error ) \
         printk("Fatal Error %d.%d Halted\n",_source, _error); \
+        _OR1KSIM_CPU_Halt(); \
         for(;;)
 /* end of Fatal Error manager macros */
diff --git a/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h b/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
index 6b238b1..fa8756a 100644
--- a/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
+++ b/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
@@ -362,7 +362,6 @@ static inline void _OR1K_mtspr(uint32_t reg, uint32_t value)
 #define _OR1K_CPU_Sleep() \
    _OR1K_mtspr(CPU_OR1K_SPR_PMR, CPU_OR1K_SPR_PMR_SME)
 #define _OR1K_CPU_Suspend() \
@@ -376,6 +375,16 @@ static inline void _OR1K_Sync_pipeline( void )
   asm volatile("l.psync");
+ * @brief or1ksim simulator can be sent a halt signal from RTEMS to tell
+ * the running or1ksim process on the host machine to exit. The following
+ * implementation has no effect on QEMU or hardware implementation and will
+ * be treated as normal l.nop.
+#define _OR1KSIM_CPU_Halt() \
+	asm volatile ("l.nop 0xc")
 #else /* ASM */
 #endif /* ASM */
2.1.0
