FATFS on target without iconv
Mon Apr 6 14:07:26 UTC 2015
On April 6, 2015 9:51:53 AM EDT, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>----- Joel Sherrill <joel.sherrill at oarcorp.com> schrieb:
>> Hi
>> Can the FAT filesystem be used on a target without iconv
>> support? Or should it be disabled?
>The iconv support is an application link-time configuration option.
Iconv is not available on all targets. It is disabled in the tool build. So not an application issue as much as ours.
Is fatfs supported on those targets? Can the use of the iconv library be disabled?
--joel
