RTEMS libbsd port: how to link the driver
ragu nath ragunath3252 at gmail.com
Tue Apr 7 08:46:15 UTC 2015
Thanks for your help. I added the driver in the nexus-devices.h and it
was working.  I was missing the header file default-network-init.h in
my application. Now I am able to link the driver to the application.
Regards,
Ragunath
On Tue, Apr 7, 2015 at 10:55 AM, Sebastian Huber
> Hello,
> do you refer to the new network stack (https://git.rtems.org/rtems-libbsd)?
> There is documentation in the file 'libbsd.txt', but I have to admit its
> poorly documented, mainly due to lack of time and budget.  For the driver
> registration see the file nexus-devices.h and the tests.
> On 06/04/15 21:12, ragu nath wrote:
>> Hi,
>> What is the procedure to link a network driver to the application in
>> rtems libbsd port? The drivers are compiled and available in the
>> libbsd archive. I dont know how to link the driver to the application.
>> I followed the RTEMS NETWORKING supplement document and tried defining
>> the following structures. But it did not work
>> static struct rtems_bsdnet_ifconfig netdriver_config = {
>> RTEMS_BSP_NETWORK_DRIVER_NAME,
>> RTEMS_BSP_NETWORK_DRIVER_ATTACH
>> struct rtems_bsdnet_config rtems_bsdnet_config = {
>> &netdriver_config,
>> rtems_bsdnet_do_bootp,
>> If there is any latest documentation available, pls let me know.
>> Thanks,
>> Ragunath
>> devel mailing list
>> devel at rtems.org
ragu
