RTEMS libbsd port: how to link the driver
Tue Apr 7 14:08:09 UTC 2015
On Tue, Apr 7, 2015 at 4:46 AM, ragu nath <ragunath3252 at gmail.com> wrote:
> Thanks for your help. I added the driver in the nexus-devices.h and it
> was working.  I was missing the header file default-network-init.h in
> my application. Now I am able to link the driver to the application.
Documentation patches welcomed. :)
> Regards,
> Ragunath
> On Tue, Apr 7, 2015 at 10:55 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> do you refer to the new network stack (https://git.rtems.org/rtems-libbsd)?
>> There is documentation in the file 'libbsd.txt', but I have to admit its
>> poorly documented, mainly due to lack of time and budget.  For the driver
>> registration see the file nexus-devices.h and the tests.
>> On 06/04/15 21:12, ragu nath wrote:
>>> Hi,
>>> What is the procedure to link a network driver to the application in
>>> rtems libbsd port? The drivers are compiled and available in the
>>> libbsd archive. I dont know how to link the driver to the application.
>>> I followed the RTEMS NETWORKING supplement document and tried defining
>>> the following structures. But it did not work
>>> static struct rtems_bsdnet_ifconfig netdriver_config = {
>>> RTEMS_BSP_NETWORK_DRIVER_NAME,
>>> RTEMS_BSP_NETWORK_DRIVER_ATTACH
>>> struct rtems_bsdnet_config rtems_bsdnet_config = {
>>> &netdriver_config,
>>> rtems_bsdnet_do_bootp,
>>> If there is any latest documentation available, pls let me know.
>>> Thanks,
>>> Ragunath
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> ragu
> devel mailing list
> devel at rtems.org
