[PATCH 3/4] timecounter: Use in RTEMS
Alexander Krutwig alexander.krutwig at embedded-brains.de
Wed Apr 8 12:44:15 UTC 2015
new rtems environment with the implementation of FreeBSD timecounters;
modifications of certain tests in the testsuite
New test: timecounter02
 cpukit/libnetworking/rtems/rtems_bsdnet_internal.h |   3 +-
 cpukit/libnetworking/rtems/rtems_glue.c            |   4 -
 cpukit/posix/src/clockgettime.c                    |   3 +-
 cpukit/posix/src/posixtimespecabsolutetimeout.c    |   2 +-
 cpukit/posix/src/timergettime.c                    |   2 +-
 cpukit/posix/src/timersettime.c                    |   4 +-
 cpukit/posix/src/timertsr.c                        |   2 +-
 cpukit/rtems/Makefile.am                           |   1 -
 cpukit/rtems/include/rtems/rtems/clock.h           |  25 --
 cpukit/rtems/src/clockgetuptimenanoseconds.c       |   9 +-
 cpukit/rtems/src/clockgetuptimeseconds.c           |   6 +-
 cpukit/rtems/src/clocksetnsecshandler.c            |  34 --
 cpukit/sapi/src/exinit.c                           |   1 +
 cpukit/score/Makefile.am                           |  16 +-
 cpukit/score/include/rtems/score/timestamp.h       | 267 ++++++++-------
 cpukit/score/include/rtems/score/timestamp64.h     | 379 ---------------------
 cpukit/score/include/rtems/score/tod.h             |   9 -
 cpukit/score/include/rtems/score/todimpl.h         | 119 +++----
 cpukit/score/preinstall.am                         |   4 -
 cpukit/score/src/coretod.c                         |  18 +-
 cpukit/score/src/coretodadjust.c                   |   9 +-
 cpukit/score/src/coretodget.c                      |  46 ---
 cpukit/score/src/coretodgetuptimetimespec.c        |  32 --
 cpukit/score/src/coretodsecondssinceepoch.c        |  32 --
 cpukit/score/src/coretodset.c                      |  10 +-
 cpukit/score/src/coretodtickle.c                   |  22 +-
 cpukit/score/src/tcgetscalerandmask.c              |  40 +++
 cpukit/score/src/ts64addto.c                       |  31 --
 cpukit/score/src/ts64divide.c                      |  51 ---
 cpukit/score/src/ts64equalto.c                     |  31 --
 cpukit/score/src/ts64getnanoseconds.c              |  30 --
 cpukit/score/src/ts64getseconds.c                  |  30 --
 cpukit/score/src/ts64lessthan.c                    |  31 --
 cpukit/score/src/ts64set.c                         |  33 --
 cpukit/score/src/ts64settozero.c                   |  31 --
 cpukit/score/src/ts64subtract.c                    |  31 --
 cpukit/score/src/ts64totimespec.c                  |  32 --
 cpukit/score/src/ts64totimeval.c                   |  37 --
 testsuites/sptests/Makefile.am                     |   2 +
 testsuites/sptests/configure.ac                    |   2 +
 testsuites/sptests/spclock_err01/init.c            |   8 -
 testsuites/sptests/spsize/size.c                   |   3 -
 testsuites/sptests/sptimecounter02/Makefile.am     |  19 ++
 testsuites/sptests/sptimecounter02/init.c          | 267 +++++++++++++++
 .../sptests/sptimecounter02/sptimecounter02.doc    |  12 +
 .../sptests/sptimecounter02/sptimecounter02.scn    |  13 +
 46 files changed, 586 insertions(+), 1207 deletions(-)
 delete mode 100644 cpukit/rtems/src/clocksetnsecshandler.c
 delete mode 100644 cpukit/score/include/rtems/score/timestamp64.h
 delete mode 100644 cpukit/score/src/coretodget.c
 delete mode 100644 cpukit/score/src/coretodgetuptimetimespec.c
 delete mode 100644 cpukit/score/src/coretodsecondssinceepoch.c
 create mode 100644 cpukit/score/src/tcgetscalerandmask.c
 delete mode 100644 cpukit/score/src/ts64addto.c
 delete mode 100644 cpukit/score/src/ts64divide.c
 delete mode 100644 cpukit/score/src/ts64equalto.c
 delete mode 100644 cpukit/score/src/ts64getnanoseconds.c
 delete mode 100644 cpukit/score/src/ts64getseconds.c
 delete mode 100644 cpukit/score/src/ts64lessthan.c
 delete mode 100644 cpukit/score/src/ts64set.c
 delete mode 100644 cpukit/score/src/ts64settozero.c
 delete mode 100644 cpukit/score/src/ts64subtract.c
 delete mode 100644 cpukit/score/src/ts64totimespec.c
 delete mode 100644 cpukit/score/src/ts64totimeval.c
 create mode 100644 testsuites/sptests/sptimecounter02/Makefile.am
 create mode 100644 testsuites/sptests/sptimecounter02/init.c
 create mode 100644 testsuites/sptests/sptimecounter02/sptimecounter02.doc
 create mode 100644 testsuites/sptests/sptimecounter02/sptimecounter02.scn
diff --git a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
index fc0370c..4de1b0b 100644
--- a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
+++ b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
@@ -12,6 +12,7 @@
 #include <rtems/fs.h>
+#include <rtems/bsd.h>
 #ifdef __cplusplus
 extern "C" {
@@ -61,7 +62,7 @@ void *memset(void *s, int c, size_t n);
 #define panic	rtems_panic
 #define suser(a,b)	0
-void microtime(struct timeval *tv);
+#define microtime(tv) rtems_bsd_microtime(tv)
 #define hz rtems_bsdnet_ticks_per_second
 #define tick rtems_bsdnet_microseconds_per_tick
diff --git a/cpukit/libnetworking/rtems/rtems_glue.c b/cpukit/libnetworking/rtems/rtems_glue.c
index f05530e..0a42f97 100644
--- a/cpukit/libnetworking/rtems/rtems_glue.c
+++ b/cpukit/libnetworking/rtems/rtems_glue.c
@@ -1344,7 +1344,3 @@ m_clalloc(int ncl, int nowait)
 	return 1;
-	rtems_clock_get_uptime_timeval(tv);
diff --git a/cpukit/posix/src/clockgettime.c b/cpukit/posix/src/clockgettime.c
index 2838ba6..06cafa5 100644
--- a/cpukit/posix/src/clockgettime.c
+++ b/cpukit/posix/src/clockgettime.c
@@ -37,7 +37,8 @@ int clock_gettime(
     rtems_set_errno_and_return_minus_one( EINVAL );
   if ( clock_id == CLOCK_REALTIME ) {
-    _TOD_Get(tp);
+    _TOD_Get_as_timespec(tp);
     return 0;
 #ifdef CLOCK_MONOTONIC
diff --git a/cpukit/posix/src/posixtimespecabsolutetimeout.c b/cpukit/posix/src/posixtimespecabsolutetimeout.c
index 32da45f..f302986 100644
--- a/cpukit/posix/src/posixtimespecabsolutetimeout.c
+++ b/cpukit/posix/src/posixtimespecabsolutetimeout.c
@@ -57,7 +57,7 @@ POSIX_Absolute_timeout_conversion_results_t _POSIX_Absolute_timeout_to_ticks(
    *  Is the absolute time in the past?
-  _TOD_Get( &current_time );
+  _TOD_Get_as_timespec( &current_time );
   if ( _Timespec_Less_than( abstime, &current_time ) )
     return POSIX_ABSOLUTE_TIMEOUT_IS_IN_PAST;
diff --git a/cpukit/posix/src/timergettime.c b/cpukit/posix/src/timergettime.c
index 2a810ef..f065cc9 100644
--- a/cpukit/posix/src/timergettime.c
+++ b/cpukit/posix/src/timergettime.c
@@ -49,7 +49,7 @@ int timer_gettime(
   /* Reads the current time */
   ptimer = _POSIX_Timer_Get( timerid, &location );
   switch ( location ) {
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index 6cc3780..4d2af5d 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -66,7 +66,7 @@ int timer_settime(
   /* Convert absolute to relative time */
   if (flags == TIMER_ABSTIME) {
     struct timespec now;
-    _TOD_Get( &now );
+    _TOD_Get_as_timespec( &now );
     /* Check for seconds in the past */
     if ( _Timespec_Greater_than( &now, &normalize.it_value ) )
@@ -125,7 +125,7 @@ int timer_settime(
        /* Indicate that the time is running */
        ptimer->state = POSIX_TIMER_STATE_CREATE_RUN;
-       _TOD_Get( &ptimer->time );
+       _TOD_Get_as_timespec( &ptimer->time );
       _Objects_Put( &ptimer->Object );
        return 0;
diff --git a/cpukit/posix/src/timertsr.c b/cpukit/posix/src/timertsr.c
index 8555463..512dd06 100644
--- a/cpukit/posix/src/timertsr.c
+++ b/cpukit/posix/src/timertsr.c
@@ -58,7 +58,7 @@ void _POSIX_Timer_TSR(
       return;
     /* Store the time when the timer was started again */
     /* The state really did not change but just to be safe */
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index 5e6f2ea..1af8536 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -158,7 +158,6 @@ librtems_a_SOURCES += src/clockgetuptimetimeval.c
 librtems_a_SOURCES += src/clockgetuptimeseconds.c
 librtems_a_SOURCES += src/clockgetuptimenanoseconds.c
 librtems_a_SOURCES += src/clockset.c
-librtems_a_SOURCES += src/clocksetnsecshandler.c
 librtems_a_SOURCES += src/clocktick.c
 librtems_a_SOURCES += src/clocktodtoseconds.c
 librtems_a_SOURCES += src/clocktodvalidate.c
diff --git a/cpukit/rtems/include/rtems/rtems/clock.h b/cpukit/rtems/include/rtems/rtems/clock.h
index 2a1c772..89750cf 100644
--- a/cpukit/rtems/include/rtems/rtems/clock.h
+++ b/cpukit/rtems/include/rtems/rtems/clock.h
@@ -14,7 +14,6 @@
  * - set the current date and time
  * - obtain the current date and time
- * - set the nanoseconds since last clock tick handler
  * - announce a clock tick
  * - obtain the system uptime
@@ -69,12 +68,6 @@ typedef enum {
 } rtems_clock_get_options;
- *  Type for the nanoseconds since last tick BSP extension.
-typedef TOD_Nanoseconds_since_last_tick_routine
-  rtems_nanoseconds_extension_routine;
  * @brief Obtain Current Time of Day
  * @deprecated rtems_clock_get() is deprecated. Use the more explicit
@@ -279,24 +272,6 @@ rtems_status_code rtems_clock_set(
 rtems_status_code rtems_clock_tick( void );
- * @brief Set the BSP specific Nanoseconds Extension
- * Clock Manager
- * This directive sets the BSP provided nanoseconds since last tick
- * extension.
- * @param[in] routine is a pointer to the extension routine
- * @return This method returns RTEMS_SUCCESSFUL if there was not an
- *         error. Otherwise, a status code is returned indicating the
- *         source of the error.
-rtems_status_code rtems_clock_set_nanoseconds_extension(
-  rtems_nanoseconds_extension_routine routine
  * @brief Obtain the System Uptime
  * This directive returns the system uptime.
diff --git a/cpukit/rtems/src/clockgetuptimenanoseconds.c b/cpukit/rtems/src/clockgetuptimenanoseconds.c
index 0310e59..d43f672 100644
--- a/cpukit/rtems/src/clockgetuptimenanoseconds.c
+++ b/cpukit/rtems/src/clockgetuptimenanoseconds.c
@@ -23,13 +23,8 @@
 uint64_t rtems_clock_get_uptime_nanoseconds( void )
   Timestamp_Control  snapshot_as_timestamp;
-  uint32_t           nanoseconds;
-  ISR_lock_Context   lock_context;
-  _TOD_Acquire( &_TOD, &lock_context );
-    snapshot_as_timestamp = _TOD.uptime;
-    nanoseconds = ( *_TOD.nanoseconds_since_last_tick )();
-  _TOD_Release( &_TOD, &lock_context );
+  _TOD_Get_uptime(&snapshot_as_timestamp);
-  return _Timestamp_Get_As_nanoseconds( &snapshot_as_timestamp, nanoseconds );
+  return _Timestamp_Get_nanoseconds(&snapshot_as_timestamp);
diff --git a/cpukit/rtems/src/clockgetuptimeseconds.c b/cpukit/rtems/src/clockgetuptimeseconds.c
index 0312921..5c6b57c 100644
--- a/cpukit/rtems/src/clockgetuptimeseconds.c
+++ b/cpukit/rtems/src/clockgetuptimeseconds.c
@@ -28,14 +28,10 @@
 time_t rtems_clock_get_uptime_seconds( void )
-  TOD_Control       *tod = &_TOD;
   struct timespec    snapshot_as_timespec;
-  _TOD_Acquire( tod, &lock_context );
-  snapshot_as_timestamp = tod->uptime;
-  _TOD_Release( tod, &lock_context );
   _Timestamp_To_timespec( &snapshot_as_timestamp, &snapshot_as_timespec );
diff --git a/cpukit/rtems/src/clocksetnsecshandler.c b/cpukit/rtems/src/clocksetnsecshandler.c
deleted file mode 100644
index ae08246..0000000
--- a/cpukit/rtems/src/clocksetnsecshandler.c
+++ /dev/null
@@ -1,34 +0,0 @@
- * @file
- * @ingroup ClassicClock Clocks
- *  COPYRIGHT (c) 1989-2006.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/rtems/clock.h>
-#include <rtems/score/todimpl.h>
-  if ( !routine )
-    return RTEMS_INVALID_ADDRESS;
-  _TOD_Set_nanoseconds_since_last_tick_handler( routine );
-  return RTEMS_SUCCESSFUL;
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 235ba77..af14846 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -44,6 +44,7 @@
 #include <rtems/score/priority.h>
 #include <rtems/score/smpimpl.h>
+#include <rtems/score/timecounter.h>
 #include <rtems/score/userextimpl.h>
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index d9aceef..596df68 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -94,7 +94,6 @@ include_rtems_score_HEADERS += include/rtems/score/threadqimpl.h
 include_rtems_score_HEADERS += include/rtems/score/threadsync.h
 include_rtems_score_HEADERS += include/rtems/score/timespec.h
 include_rtems_score_HEADERS += include/rtems/score/timestamp.h
-include_rtems_score_HEADERS += include/rtems/score/timestamp64.h
 include_rtems_score_HEADERS += include/rtems/score/timecounter.h
 include_rtems_score_HEADERS += include/rtems/score/timecounterimpl.h
 include_rtems_score_HEADERS += include/rtems/score/tls.h
@@ -319,18 +318,10 @@ libscore_a_SOURCES += src/timespecaddto.c src/timespecfromticks.c \
     src/timespecsubtract.c src/timespectoticks.c src/timespecdivide.c \
     src/timespecdividebyinteger.c src/timespecgetasnanoseconds.c
-## TIMESTAMP_INT64_C_FILES
-libscore_a_SOURCES += src/ts64addto.c \
-    src/ts64divide.c src/ts64equalto.c \
-    src/ts64getnanoseconds.c src/ts64getseconds.c \
-    src/ts64lessthan.c \
-    src/ts64set.c src/ts64settozero.c src/ts64subtract.c \
-    src/ts64totimespec.c src/ts64totimeval.c
 ## TOD_C_FILES
-libscore_a_SOURCES += src/coretod.c src/coretodset.c src/coretodget.c \
-    src/coretodgetuptimetimespec.c src/coretodtickle.c \
-    src/coretodsecondssinceepoch.c src/coretodtickspersec.c \
+libscore_a_SOURCES += src/coretod.c src/coretodset.c \
+    src/coretodtickle.c \
+    src/coretodtickspersec.c \
     src/coretodadjust.c
 ## WATCHDOG_C_FILES
@@ -355,6 +346,7 @@ libscore_a_SOURCES += src/once.c
 libscore_a_SOURCES += src/resourceiterate.c
 libscore_a_SOURCES += src/smpbarrierwait.c
 libscore_a_SOURCES += src/kern_tc.c
+libscore_a_SOURCES += src/tcgetscalerandmask.c
 EXTRA_DIST = src/Unlimited.txt
diff --git a/cpukit/score/include/rtems/score/timestamp.h b/cpukit/score/include/rtems/score/timestamp.h
index dbd0425..056976b 100644
--- a/cpukit/score/include/rtems/score/timestamp.h
+++ b/cpukit/score/include/rtems/score/timestamp.h
@@ -42,55 +42,45 @@
 #include <sys/time.h>
-#include <rtems/score/cpu.h>
-#include <rtems/score/timespec.h>
+#include <rtems/score/basedefs.h>
+#include "timespec.h"
 #ifdef __cplusplus
 extern "C" {
 #endif
-#if ! ( ( CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE \
-    && CPU_TIMESTAMP_USE_INT64 == FALSE \
-    && CPU_TIMESTAMP_USE_INT64_INLINE == FALSE ) \
-  || ( CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == FALSE \
-    && CPU_TIMESTAMP_USE_INT64 == TRUE \
-    && CPU_TIMESTAMP_USE_INT64_INLINE == TRUE ) )
-  #error "Invalid SuperCore Timestamp implementations selection."
-#endif
-#if CPU_TIMESTAMP_USE_INT64 == TRUE || CPU_TIMESTAMP_USE_INT64_INLINE == TRUE
-  #include <rtems/score/timestamp64.h>
-#endif
+#define MICROSECONDS_PER_SECOND 1000000
+#define NANOSECONDS_PER_SECOND 1000000000
  *   Define the Timestamp control type.
-#if CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE
-  typedef struct timespec Timestamp_Control;
-#else
-  typedef Timestamp64_Control Timestamp_Control;
-#endif
+typedef struct bintime Timestamp_Control;
  *  @brief Set timestamp to specified seconds and nanoseconds.
- *  This method sets the timestamp to the specified @a _seconds and @a _nanoseconds
- *  value.
+ *  This method sets the timestamp to the specified @a _seconds and
+ *  @a _nanoseconds value.
  *  @param[in] _time points to the timestamp instance to validate.
  *  @param[in] _seconds is the seconds portion of the timestamp
  *  @param[in] _nanoseconds is the nanoseconds portion of the timestamp
-  #define _Timestamp_Set( _time, _seconds, _nanoseconds ) \
-          _Timespec_Set( _time, _seconds, _nanoseconds )
-#else
-	  _Timestamp64_Set( _time, _seconds, _nanoseconds )
-#endif
+RTEMS_INLINE_ROUTINE void _Timestamp_Set(
+  Timestamp_Control *_time,
+  time_t _seconds,
+  long _nanoseconds
+  struct timespec _ts;
+  _ts.tv_sec = _seconds;
+  _ts.tv_nsec = _nanoseconds;
+  timespec2bintime(&_ts, _time);
  *  @brief Sets the timestamp to zero.
@@ -100,13 +90,14 @@ extern "C" {
  *  @param[in] _time points to the timestamp instance to zero.
-  #define _Timestamp_Set_to_zero( _time ) \
-          _Timespec_Set_to_zero( _time )
-#else
-	  _Timestamp64_Set_to_zero( _time )
-#endif
+RTEMS_INLINE_ROUTINE void _Timestamp_Set_to_zero(
+  _time->sec = 0;
+  _time->frac = 0;
  *  @brief Less than operator for timestamps.
@@ -119,13 +110,23 @@ extern "C" {
  *  @retval This method returns true if @a _lhs is less than the @a _rhs and
  *          false otherwise.
-  #define _Timestamp_Less_than( _lhs, _rhs ) \
-          _Timespec_Less_than( _lhs, _rhs )
-#else
-	  _Timestamp64_Less_than( _lhs, _rhs )
-#endif
+RTEMS_INLINE_ROUTINE bool _Timestamp_Less_than(
+  Timestamp_Control *_lhs, Timestamp_Control *_rhs
+  if ( _lhs->sec < _rhs->sec )
+    return true;
+  if ( _lhs->sec > _rhs->sec )
+    return false;
+  /* assert: lhs->tv_sec == rhs->tv_sec */
+  if ( _lhs->frac < _rhs->frac)
+    return true;
+  return false;
  *  @brief Greater than operator for timestamps.
@@ -138,8 +139,23 @@ extern "C" {
  *  @retval This method returns true if @a _lhs is greater than the @a _rhs and
  *          false otherwise.
-#define _Timestamp_Greater_than( _lhs, _rhs ) \
-  _Timestamp_Less_than( _rhs, _lhs )
+RTEMS_INLINE_ROUTINE bool _Timestamp_Greater_than(
+    return true;
+    return false;
+  if ( _lhs->frac > _rhs->frac)
+    return true;
+  return false;
  *  @brief Equal to than operator for timestamps.
@@ -152,13 +168,16 @@ extern "C" {
  *  @retval This method returns true if @a _lhs is equal to  @a _rhs and
  *          false otherwise.
-  #define _Timestamp_Equal_to( _lhs, _rhs ) \
-          _Timespec_Equal_to( _lhs, _rhs )
-#else
-	  _Timestamp64_Equal_to( _lhs, _rhs )
-#endif
+RTEMS_INLINE_ROUTINE bool _Timestamp_Equal_to(
+  if (( _lhs->sec < _rhs->sec) && (_lhs->frac == _rhs->frac))
+    return true;
+  return false;
  *  @brief Adds two timestamps.
@@ -171,13 +190,15 @@ extern "C" {
  *  @retval This method returns the number of seconds @a time increased by.
-  #define _Timestamp_Add_to( _time, _add ) \
-          _Timespec_Add_to( _time, _add )
-#else
-	  _Timestamp64_Add_to( _time, _add )
-#endif
+RTEMS_INLINE_ROUTINE time_t _Timestamp_Add_to(
+  const Timestamp_Control *_add
+  time_t seconds = _time->sec;
+  bintime_add(_time, _add);
+  return ((_time->sec) - seconds);
  *  @brief Subtracts two timestamps.
@@ -192,13 +213,17 @@ extern "C" {
  *  @retval This method fills in @a _result.
-  #define _Timestamp_Subtract( _start, _end, _result ) \
-          _Timespec_Subtract( _start, _end, _result )
-#else
-	  _Timestamp64_Subtract( _start, _end, _result )
-#endif
+RTEMS_INLINE_ROUTINE void _Timestamp_Subtract(
+  const Timestamp_Control *_start,
+  const Timestamp_Control *_end,
+  Timestamp_Control       *_result
+  _result->sec = _end->sec;
+  _result->frac = _end->frac;
+  bintime_sub(_result, _start);
  *  @brief Divides a timestamp by another timestamp.
@@ -213,13 +238,24 @@ extern "C" {
  *  @retval This method fills in @a result.
-  #define _Timestamp_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage ) \
-          _Timespec_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage )
-#else
-          _Timestamp64_Divide( _lhs, _rhs, _ival_percentage, _fval_percentage )
-#endif
+RTEMS_INLINE_ROUTINE void _Timestamp_Divide(
+  const Timestamp_Control *_lhs,
+  const Timestamp_Control *_rhs,
+  uint32_t              *_ival_percentage,
+  uint32_t              *_fval_percentage
+  struct timespec _time_left, _time_right;
+  bintime2timespec(_lhs, &_time_left);
+  bintime2timespec(_rhs, &_time_right);
+  _Timespec_Divide(&_time_left,
+		   &_time_right,
+		   _ival_percentage,
+		   _fval_percentage
  *  @brief Get seconds portion of timestamp.
@@ -230,13 +266,12 @@ extern "C" {
  *  @retval The seconds portion of @a _time.
-  #define _Timestamp_Get_seconds( _time ) \
-          _Timespec_Get_seconds( _time )
-#else
-	  _Timestamp64_Get_seconds( _time )
-#endif
+RTEMS_INLINE_ROUTINE time_t _Timestamp_Get_seconds(
+  const Timestamp_Control *_time
+  return _time->sec;
  *  @brief Get nanoseconds portion of timestamp.
@@ -247,13 +282,14 @@ extern "C" {
  *  @retval The nanoseconds portion of @a _time.
-  #define _Timestamp_Get_nanoseconds( _time ) \
-          _Timespec_Get_nanoseconds( _time )
-#else
-	  _Timestamp64_Get_nanoseconds( _time )
-#endif
+RTEMS_INLINE_ROUTINE uint32_t _Timestamp_Get_nanoseconds(
+  bintime2timespec(_time, &_ts);
+  return _ts.tv_nsec;
  *  @brief Get the timestamp as nanoseconds.
@@ -261,16 +297,23 @@ extern "C" {
  *  This method returns the timestamp as nanoseconds.
+ *  @param[in] _nanoseconds adds nanoseconds since last tick
  *  @retval The time in nanoseconds.
-  #define _Timestamp_Get_As_nanoseconds( _timestamp, _nanoseconds ) \
-          _Timespec_Get_As_nanoseconds( _timestamp, _nanoseconds )
-#else
-	  _Timestamp64_Get_As_nanoseconds( _timestamp, _nanoseconds )
-#endif
+RTEMS_INLINE_ROUTINE uint64_t _Timestamp_Get_As_nanoseconds(
+  const Timestamp_Control *_time,
+  const uint32_t _nanoseconds
+  struct timespec ts;
+  uint64_t overall_ns_val;
+  bintime2timespec(_time, &ts);
+  overall_ns_val = _Timespec_Get_As_nanoseconds(&ts, _nanoseconds);
+  return overall_ns_val;
  *  @brief Convert timestamp to struct timespec.
@@ -280,14 +323,13 @@ extern "C" {
  *  @param[in] _timestamp points to the timestamp
  *  @param[in] _timespec points to the timespec
-  /* in this case we know they are the same type so use simple assignment */
-  #define _Timestamp_To_timespec( _timestamp, _timespec  ) \
-          *(_timespec) = *(_timestamp)
-#else
-	  _Timestamp64_To_timespec( _timestamp, _timespec  )
-#endif
+RTEMS_INLINE_ROUTINE void _Timestamp_To_timespec(
+  const Timestamp_Control *_timestamp,
+  struct timespec *_timespec
+  bintime2timespec(_timestamp, _timespec);
  *  @brief Convert timestamp to struct timeval.
@@ -295,16 +337,13 @@ extern "C" {
  *  @param[in] _timeval points to the timeval
-  #define _Timestamp_To_timeval( _timestamp, _timeval  ) \
-    do { \
-      (_timeval)->tv_sec = (_timestamp)->tv_sec; \
-      (_timeval)->tv_usec = (_timestamp)->tv_nsec / 1000; \
-    } while (0)
-#else
-	  _Timestamp64_To_timeval( _timestamp, _timeval  )
-#endif
+RTEMS_INLINE_ROUTINE void _Timestamp_To_timeval(
+  struct timeval *_timeval
+  bintime2timeval(_timestamp, _timeval);
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/timestamp64.h b/cpukit/score/include/rtems/score/timestamp64.h
index 39b4965..0000000
--- a/cpukit/score/include/rtems/score/timestamp64.h
+++ /dev/null
@@ -1,379 +0,0 @@
- *  @file  rtems/score/timestamp64.h
- *  @brief Helpers for Manipulating 64-bit Integer Timestamps
- *  This include file contains helpers for manipulating
- *  64-bit integer timestamps.
- *  COPYRIGHT (c) 1989-2009.
-#ifndef _RTEMS_SCORE_TIMESTAMP64_H
-#define _RTEMS_SCORE_TIMESTAMP64_H
- *  @defgroup SuperCoreTimestamp64 SuperCore Sixty-Four Bit Timestamps
- *  @ingroup Score
- *  This handler encapsulates functionality related to manipulating
- *  the 64 bit integer implementation of SuperCore Timestamps.
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  This .h file is not for general use.  It is an alternative
- *  implementation of Timestamps and should only be used that way.
-#ifndef _RTEMS_SCORE_TIMESTAMP_H
-  #error "Should only be included by rtems/score/timestamp.h"
-#endif
- *  Verify something is defined.
-#if CPU_TIMESTAMP_USE_INT64 != TRUE && CPU_TIMESTAMP_USE_INT64_INLINE != TRUE
-  #error "SuperCore Timestamp64 implementation included but not defined."
-#endif
- *   Define the Timestamp control type.
-typedef int64_t Timestamp64_Control;
-static inline void _Timestamp64_implementation_Set(
-  Timestamp64_Control *_time,
-  Timestamp64_Control  _seconds,
-  Timestamp64_Control  _nanoseconds
-  *_time = _seconds * 1000000000L + _nanoseconds;
- *  @brief Set 64-bit timestamp to seconds nanosecond.
- *  This method sets the timestamp to the specified seconds and nanoseconds
- *  value.
- *  @param[in] _time points to the timestamp instance to validate.
- *  @param[in] _seconds is the seconds portion of the timestamp
- *  @param[in] _nanoseconds is the nanoseconds portion of the timestamp
-#if CPU_TIMESTAMP_USE_INT64_INLINE == TRUE
-  #define _Timestamp64_Set( _time, _seconds, _nanoseconds ) \
-    _Timestamp64_implementation_Set( _time, _seconds, _nanoseconds )
-#else
-  void _Timestamp64_Set(
-#endif
-static inline void _Timestamp64_implementation_Set_to_zero(
-  *_time = 0;
- *  @brief Sets the 64-bit timestamp to zero.
- *  This method sets the timestamp to zero value.
- *  @param[in] _time points to the timestamp instance to zero.
-  #define _Timestamp64_Set_to_zero( _time ) \
-    _Timestamp64_implementation_Set_to_zero( _time )
-#else
-  void _Timestamp64_Set_to_zero(
-#endif
-static inline bool _Timestamp64_implementation_Less_than(
-  const Timestamp64_Control *_lhs,
-  const Timestamp64_Control *_rhs
-  return *_lhs < *_rhs;
- *  @brief The "less than" operator for 64-bit timestamps.
- *  This method is the less than operator for timestamps.
- *  @param[in] _lhs points to the left hand side timestamp
- *  @param[in] _rhs points to the right hand side timestamp
- *  @retval This method returns true if @a _lhs is less than the @a _rhs and
- *          false otherwise.
-  #define _Timestamp64_Less_than( _lhs, _rhs ) \
-    _Timestamp64_implementation_Less_than( _lhs, _rhs )
-#else
-  bool _Timestamp64_Less_than(
-#endif
-static inline bool _Timestamp64_implementation_Equal_to(
-  return *_lhs == *_rhs;
-#define _Timestamp64_Greater_than( _lhs, _rhs ) \
-  _Timestamp64_Less_than( _rhs, _lhs )
- *  @brief The "equal to" operator for 64-bit timestamps.
- *  This method is the is equal to than operator for timestamps.
- *  @retval This method returns true if @a _lhs is equal to  @a _rhs and
-  #define _Timestamp64_Equal_to( _lhs, _rhs ) \
-    _Timestamp64_implementation_Equal_to( _lhs, _rhs )
-#else
-  bool _Timestamp64_Equal_to(
-#endif
-static inline void _Timestamp64_implementation_Add_to(
-  const Timestamp64_Control *_add
-  *_time += *_add;
- *  @brief Add two 64-bit timestamps.
- *  This routine adds two timestamps.  The second argument is added
- *  to the first.
- *  @param[in] _time points to the base time to be added to
- *  @param[in] _add points to the timestamp to add to the first argument
- *  @retval This method returns the number of seconds @a time increased by.
-  #define _Timestamp64_Add_to( _time, _add ) \
-    _Timestamp64_implementation_Add_to( _time, _add )
-#else
-  void _Timestamp64_Add_to(
-#endif
-static inline void _Timestamp64_implementation_Subtract(
-  const Timestamp64_Control *_start,
-  const Timestamp64_Control *_end,
-  Timestamp64_Control       *_result
-  *_result = *_end - *_start;
- *  @brief Subtract two 64-bit timestamps.
- *  This routine subtracts two timestamps.  @a result is set to
- *  @a end - @a start.
- *  @param[in] _start points to the starting time
- *  @param[in] _end points to the ending time
- *  @param[out] _result points to the difference between
- *             starting and ending time.
-  #define _Timestamp64_Subtract( _start, _end, _result ) \
-    _Timestamp64_implementation_Subtract( _start, _end, _result )
-#else
-  void _Timestamp64_Subtract(
-#endif
- *  @brief Divide 64-bit timestamp by another 64-bit timestamp.
- *  This routine divides a timestamp by another timestamp.  The
- *  intended use is for calculating percentages to three decimal points.
- *  @param[in] _lhs points to the left hand number
- *  @param[in] _rhs points to the right hand number
- *  @param[out] _ival_percentage points to the integer portion of the average
- *  @param[out] _fval_percentage points to the thousandths of percentage
-void _Timestamp64_Divide(
-  const Timestamp64_Control *_rhs,
-  uint32_t                  *_ival_percentage,
-  uint32_t                  *_fval_percentage
-static inline uint32_t _Timestamp64_implementation_Get_seconds(
-  const Timestamp64_Control *_time
-  return (uint32_t) (*_time / 1000000000L);
- *  @brief Get seconds portion of a 64-bit timestamp.
- *  This method returns the seconds portion of the specified timestamp
- *  @retval The seconds portion of @a _time.
-  #define _Timestamp64_Get_seconds( _time ) \
-    _Timestamp64_implementation_Get_seconds( _time )
-#else
-  uint32_t _Timestamp64_Get_seconds(
-#endif
-static inline uint32_t _Timestamp64_implementation_Get_nanoseconds(
-  return (uint32_t) (*_time % 1000000000L);
- *  @brief Get nanoseconds portion of a 64-bit timestamp.
- *  This method returns the nanoseconds portion of the specified timestamp
- *  @retval The nanoseconds portion of @a _time.
-  #define _Timestamp64_Get_nanoseconds( _time ) \
-    _Timestamp64_implementation_Get_nanoseconds( _time )
-#else
-  uint32_t _Timestamp64_Get_nanoseconds(
-#endif
-static inline uint64_t _Timestamp64_implementation_Get_As_nanoseconds(
-  const Timestamp64_Control *_time,
-  const uint32_t nanoseconds
-  return *_time + (uint64_t) nanoseconds;
- *  @brief Get the 64-bit timestamp as nanoseconds.
- *  This method returns the 64-bit timestamp as it is already in nanoseconds.
-#define _Timestamp64_Get_As_nanoseconds( _time, _nanoseconds ) \
-  _Timestamp64_implementation_Get_As_nanoseconds( _time, _nanoseconds )
-static inline void _Timestamp64_implementation_To_timespec(
-  const Timestamp64_Control *_timestamp,
-  struct timespec           *_timespec
-  _timespec->tv_sec = (time_t) (*_timestamp / 1000000000L);
-  _timespec->tv_nsec = (long) (*_timestamp % 1000000000L);
- *  @brief Convert 64-bit timestamp to struct timespec.
- *  @param[in] _timestamp points to the timestamp
- *  @param[out] _timespec points to the timespec
-  #define _Timestamp64_To_timespec( _timestamp, _timespec  ) \
-    _Timestamp64_implementation_To_timespec( _timestamp, _timespec )
-#else
-  void _Timestamp64_To_timespec(
-#endif
-static inline void _Timestamp64_implementation_To_timeval(
-  struct timeval            *_timeval
-  _timeval->tv_sec = (time_t) (*_timestamp / 1000000000U);
-  _timeval->tv_usec = (suseconds_t) ((*_timestamp % 1000000000U) / 1000U);
- *  @brief Convert 64-bit timestamp to struct timeval.
- *  @param[out] _timeval points to the timeval
-  #define _Timestamp64_To_timeval( _timestamp, _timeval  ) \
-    _Timestamp64_implementation_To_timeval( _timestamp, _timeval )
-#else
-  void _Timestamp64_To_timeval(
-#endif
-#ifdef __cplusplus
-#endif
-#endif
-/* end of include file */
diff --git a/cpukit/score/include/rtems/score/tod.h b/cpukit/score/include/rtems/score/tod.h
index 1972b0f..c0ab5e7 100644
--- a/cpukit/score/include/rtems/score/tod.h
+++ b/cpukit/score/include/rtems/score/tod.h
@@ -24,15 +24,6 @@
 extern "C" {
 #endif
- * @brief Returns the nanoseconds since the last clock tick.
- * @ingroup ScoreTOD
- * @return The nanoseconds since the last clock tick.
-typedef uint32_t ( *TOD_Nanoseconds_since_last_tick_routine )( void );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/include/rtems/score/todimpl.h b/cpukit/score/include/rtems/score/todimpl.h
index ad5ed39..cf12d30 100644
--- a/cpukit/score/include/rtems/score/todimpl.h
+++ b/cpukit/score/include/rtems/score/todimpl.h
@@ -19,8 +19,8 @@
 #define _RTEMS_SCORE_TODIMPL_H
 #include <rtems/score/tod.h>
-#include <rtems/score/isrlock.h>
 #include <rtems/score/timestamp.h>
+#include <rtems/score/timecounterimpl.h>
 #include <time.h>
@@ -131,25 +131,6 @@ extern "C" {
 typedef struct {
-   * @brief Current time of day value.
-   * This field is protected by the lock.
-  Timestamp_Control now;
-   * @brief System uptime.
-  Timestamp_Control uptime;
-   * @brief Lock to protect the now and uptime fields.
-  ISR_lock_Control lock;
    * @brief Time of day seconds trigger.
    * This value specifies the nanoseconds since the last time of day second.
@@ -159,13 +140,6 @@ typedef struct {
   uint32_t seconds_trigger;
-   * @brief The current nanoseconds since last tick handler.
-   * This field must not be NULL after initialization.
-  TOD_Nanoseconds_since_last_tick_routine nanoseconds_since_last_tick;
    *  @brief Indicates if the time of day is set.
    *  This is true if the application has set the current
@@ -176,12 +150,6 @@ typedef struct {
 SCORE_EXTERN TOD_Control _TOD;
-#define _TOD_Acquire( _tod, lock_context ) \
-  _ISR_lock_ISR_disable_and_acquire( &( _tod )->lock, lock_context )
-#define _TOD_Release( _tod, lock_context ) \
-  _ISR_lock_Release_and_ISR_enable( &( _tod )->lock, lock_context )
  *  @brief Initializes the time of day handler.
@@ -201,6 +169,18 @@ void _TOD_Set_with_timestamp(
   const Timestamp_Control *tod_as_timestamp
+ *  @brief Sets the time of day from timespec.
+ *  The @a tod_as_timestamp timestamp represents the time since UNIX epoch.
+ *  The watchdog seconds chain will be adjusted.
+ *  In the process the input given as timespec will be transformed to FreeBSD
+ *  bintime format to guarantee the right format for later setting it with a
+ *  timestamp.
+ *  @param[in] tod_as_timespec is the constant of the time of day as a timespec
 static inline void _TOD_Set(
   const struct timespec *tod_as_timespec
@@ -216,31 +196,27 @@ static inline void _TOD_Set(
- *  @brief Returns a snapshot of a clock.
- *  This function invokes the nanoseconds extension.
- *  @param[out] snapshot points to an area that will contain the current
- *              TOD plus the BSP nanoseconds since last tick adjustment
- *  @param[in] clock contains the current TOD
+ *  @brief Gets the current time in the bintime format.
- *  @retval @a snapshot
+ *  @param[out] time is the value gathered by the bintime request
-Timestamp_Control *_TOD_Get_with_nanoseconds(
-  Timestamp_Control *snapshot,
-  const Timestamp_Control *clock
 static inline void _TOD_Get(
-  struct timespec *tod_as_timespec
+  Timestamp_Control *time
-  Timestamp_Control  tod_as_timestamp;
-  Timestamp_Control *tod_as_timestamp_ptr;
+  _Timecounter_Bintime(time);
-  tod_as_timestamp_ptr =
-    _TOD_Get_with_nanoseconds( &tod_as_timestamp, &_TOD.now );
-  _Timestamp_To_timespec( tod_as_timestamp_ptr, tod_as_timespec );
+ *  @brief Gets the current time in the timespec format.
+ *  @param[out] time is the value gathered by the nanotime request
+static inline void _TOD_Get_as_timespec(
+  struct timespec *time
+  _Timecounter_Nanotime(time);
@@ -255,7 +231,8 @@ static inline void _TOD_Get_uptime(
-  _TOD_Get_with_nanoseconds( time, &_TOD.uptime );
+  _Timecounter_Binuptime(time);
+  time->sec --;
@@ -266,9 +243,13 @@ static inline void _TOD_Get_uptime(
  *  @param[in] time is a pointer to the uptime to be returned
-void _TOD_Get_uptime_as_timespec(
+static inline void _TOD_Get_uptime_as_timespec(
+  _Timecounter_Nanouptime(time);
+  time->tv_sec --;
  *  @brief Number of seconds Since RTEMS epoch.
@@ -276,7 +257,14 @@ void _TOD_Get_uptime_as_timespec(
  *  The following contains the number of seconds from 00:00:00
  *  January 1, TOD_BASE_YEAR until the current time of day.
-uint32_t _TOD_Seconds_since_epoch( void );
+static inline uint32_t _TOD_Seconds_since_epoch( void )
+  struct bintime bt;
+  _Timecounter_Bintime(&bt);
+  return bt.sec;
  *  @brief Increments time of day at each clock tick.
@@ -314,12 +302,7 @@ RTEMS_INLINE_ROUTINE void _TOD_Get_timeval(
   struct timeval *time
-  Timestamp_Control  snapshot_as_timestamp;
-  Timestamp_Control *snapshot_as_timestamp_ptr;
-  snapshot_as_timestamp_ptr =
-    _TOD_Get_with_nanoseconds( &snapshot_as_timestamp, &_TOD.now );
-  _Timestamp_To_timeval( snapshot_as_timestamp_ptr, time );
+  _Timecounter_Microtime(time);
@@ -335,18 +318,6 @@ void _TOD_Adjust(
- * @brief Install the BSP's nanoseconds since clock tick handler
- * @param[in] routine is the BSP's nanoseconds since clock tick method
-RTEMS_INLINE_ROUTINE void _TOD_Set_nanoseconds_since_last_tick_handler(
-  TOD_Nanoseconds_since_last_tick_routine routine
-  _TOD.nanoseconds_since_last_tick = routine;
  * @brief Check if the TOD is Set
  * @return TRUE is the time is set. FALSE otherwise.
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 9be9fcc..b74afb8 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -348,10 +348,6 @@ $(PROJECT_INCLUDE)/rtems/score/timestamp.h: include/rtems/score/timestamp.h $(PR
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timestamp.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timestamp.h
-$(PROJECT_INCLUDE)/rtems/score/timestamp64.h: include/rtems/score/timestamp64.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
 $(PROJECT_INCLUDE)/rtems/score/timecounter.h: include/rtems/score/timecounter.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timecounter.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timecounter.h
diff --git a/cpukit/score/src/coretod.c b/cpukit/score/src/coretod.c
index 2deeeba..67d5104 100644
--- a/cpukit/score/src/coretod.c
+++ b/cpukit/score/src/coretod.c
@@ -20,23 +20,15 @@
-static uint32_t _TOD_Nanoseconds_since_tick_default_handler( void )
-  return 0;
 void _TOD_Handler_initialization(void)
-  _ISR_lock_Initialize( &tod->lock, "TOD" );
-  _Timestamp_Set( &tod->now, TOD_SECONDS_1970_THROUGH_1988, 0 );
-  _Timestamp_Set_to_zero( &tod->uptime );
-  tod->nanoseconds_since_last_tick =
-    _TOD_Nanoseconds_since_tick_default_handler;
+  ts.tv_sec = TOD_SECONDS_1970_THROUGH_1988;
+  ts.tv_nsec = 0;
+  _Timecounter_Initialize();
+  _Timecounter_Set_clock(&ts);
   /* TOD has not been set */
   tod->is_set = false;
diff --git a/cpukit/score/src/coretodadjust.c b/cpukit/score/src/coretodadjust.c
index 09cf01a..6097e20 100644
--- a/cpukit/score/src/coretodadjust.c
+++ b/cpukit/score/src/coretodadjust.c
@@ -25,8 +25,7 @@ void _TOD_Adjust(
   const Timestamp_Control delta
-  Timestamp_Control  tod;
-  Timestamp_Control *tod_ptr;
+  Timestamp_Control tod;
    * Currently, RTEMS does the adjustment in one movement.
@@ -41,11 +40,11 @@ void _TOD_Adjust(
   _Thread_Disable_dispatch();
-    tod_ptr = _TOD_Get_with_nanoseconds( &tod, &_TOD.now );
+    _TOD_Get( &tod );
-    _Timestamp_Add_to( tod_ptr, &delta );
+    _Timestamp_Add_to( &tod, &delta );
-    _TOD_Set_with_timestamp( tod_ptr );
+    _TOD_Set_with_timestamp( &tod );
   _Thread_Enable_dispatch();
diff --git a/cpukit/score/src/coretodget.c b/cpukit/score/src/coretodget.c
index 70eb238..0000000
--- a/cpukit/score/src/coretodget.c
+++ /dev/null
@@ -1,46 +0,0 @@
- * @file
- * @brief Returns a Current TOD with Nanosecond Granularity
- *  COPYRIGHT (c) 1989-2014.
-#if HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <rtems/score/isrlevel.h>
-  Timestamp_Control offset;
-    nanoseconds = ( *tod->nanoseconds_since_last_tick )();
-    now = *clock;
-  _Timestamp_Set( &offset, 0, nanoseconds );
-  _Timestamp_Add_to( &now, &offset );
-  *snapshot = now;
-  return snapshot;
diff --git a/cpukit/score/src/coretodgetuptimetimespec.c b/cpukit/score/src/coretodgetuptimetimespec.c
index 5980b2f..0000000
--- a/cpukit/score/src/coretodgetuptimetimespec.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @brief Get Uptime as struct timespec
-#if HAVE_CONFIG_H
-#endif
-  struct timespec *uptime
-  Timestamp_Control uptime_ts;
-  /* assume time checked for NULL by caller */
-  _TOD_Get_uptime( &uptime_ts );
-  _Timestamp_To_timespec( &uptime_ts, uptime );
diff --git a/cpukit/score/src/coretodsecondssinceepoch.c b/cpukit/score/src/coretodsecondssinceepoch.c
index b7bd270..0000000
--- a/cpukit/score/src/coretodsecondssinceepoch.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
-#if HAVE_CONFIG_H
-#endif
-   now = tod->now;
-  return _Timestamp_Get_seconds( &now );
diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
index 6006e66..8cff81c 100644
--- a/cpukit/score/src/coretodset.c
+++ b/cpukit/score/src/coretodset.c
@@ -27,10 +27,14 @@ void _TOD_Set_with_timestamp(
   uint32_t nanoseconds = _Timestamp_Get_nanoseconds( tod_as_timestamp );
   Watchdog_Interval seconds_next = _Timestamp_Get_seconds( tod_as_timestamp );
   Watchdog_Interval seconds_now;
+  bintime2timespec(tod_as_timestamp, &ts);
+  nanoseconds = ts.tv_nsec;
+  seconds_next = ts.tv_sec;
@@ -41,9 +45,7 @@ void _TOD_Set_with_timestamp(
   else
     _Watchdog_Adjust_seconds( WATCHDOG_FORWARD, seconds_next - seconds_now );
-  tod->now = *tod_as_timestamp;
   tod->seconds_trigger = nanoseconds;
   tod->is_set = true;
diff --git a/cpukit/score/src/coretodtickle.c b/cpukit/score/src/coretodtickle.c
index 9116fc1..3d7c71e 100644
--- a/cpukit/score/src/coretodtickle.c
+++ b/cpukit/score/src/coretodtickle.c
@@ -24,30 +24,10 @@
 void _TOD_Tickle_ticks( void )
-  Timestamp_Control  tick;
-  uint32_t           nanoseconds_per_tick;
-  nanoseconds_per_tick = rtems_configuration_get_nanoseconds_per_tick();
-  /* Convert the tick quantum to a timestamp */
-  _Timestamp_Set( &tick, 0, nanoseconds_per_tick );
   /* Update the counter of ticks since boot */
   _Watchdog_Ticks_since_boot += 1;
-  /* Update the uptime */
-  _Timestamp_Add_to( &tod->uptime, &tick );
-  /* Update the current TOD */
-  _Timestamp_Add_to( &tod->now, &tick );
-  _TOD.seconds_trigger += nanoseconds_per_tick;
+  _TOD.seconds_trigger += rtems_configuration_get_nanoseconds_per_tick();
   if ( _TOD.seconds_trigger >= 1000000000UL ) {
     _TOD.seconds_trigger -= 1000000000UL;
     _Watchdog_Tickle_seconds();
diff --git a/cpukit/score/src/tcgetscalerandmask.c b/cpukit/score/src/tcgetscalerandmask.c
new file mode 100644
index 0000000..a2a2db4
--- /dev/null
+++ b/cpukit/score/src/tcgetscalerandmask.c
@@ -0,0 +1,40 @@
+ * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+void _Timecounter_Get_binary_scaler_and_mask(
+  uint32_t  counter_ticks_per_clock_tick,
+  uint64_t *scaler,
+  uint32_t *mask
+  uint32_t power_of_two = 1;
+  int i;
+  for ( i = 0; i < 32; ++i ) {
+    if ( power_of_two >= counter_ticks_per_clock_tick ) {
+      break;
+    power_of_two *= 2;
+  *mask = (2 * power_of_two) - 1;
+  *scaler = ((uint64_t) power_of_two << 32) / counter_ticks_per_clock_tick;
diff --git a/cpukit/score/src/ts64addto.c b/cpukit/score/src/ts64addto.c
index a0f4b3c..0000000
--- a/cpukit/score/src/ts64addto.c
+++ /dev/null
@@ -1,31 +0,0 @@
- * @file score/src/ts64addto.c
- * @brief Add to a Timestamp
- * @ingroup SuperCore
- *  COPYRIGHT (c) 1989-2008.
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/score/timestamp.h>
-void _Timestamp64_Add_to(
-  _Timestamp64_implementation_Add_to( _time, _add );
-#endif
diff --git a/cpukit/score/src/ts64divide.c b/cpukit/score/src/ts64divide.c
index d9a5099..0000000
--- a/cpukit/score/src/ts64divide.c
+++ /dev/null
@@ -1,51 +0,0 @@
- *  @file
- *  @brief Divide Timestamp
- *  COPYRIGHT (c) 1989-2007.
-#if HAVE_CONFIG_H
-#endif
-/* This method is never inlined. */
-  Timestamp64_Control answer;
-  if ( *_rhs == 0 ) {
-    *_ival_percentage = 0;
-    *_fval_percentage = 0;
-    return;
-   *  This looks odd but gives the results the proper precision.
-   *  TODO: Rounding on the last digit of the fval.
-  answer = (*_lhs * 100000) / *_rhs;
-  *_ival_percentage = answer / 1000;
-  *_fval_percentage = answer % 1000;
-#endif
diff --git a/cpukit/score/src/ts64equalto.c b/cpukit/score/src/ts64equalto.c
index fd07474..0000000
--- a/cpukit/score/src/ts64equalto.c
+++ /dev/null
@@ -1,31 +0,0 @@
- *  @file
- *  @brief Timestamp equal to Operator
-#if HAVE_CONFIG_H
-#endif
-bool _Timestamp64_Equal_to(
-  return _Timestamp64_implementation_Equal_to( _lhs, _rhs );
-#endif
diff --git a/cpukit/score/src/ts64getnanoseconds.c b/cpukit/score/src/ts64getnanoseconds.c
index a5da43b..0000000
--- a/cpukit/score/src/ts64getnanoseconds.c
+++ /dev/null
@@ -1,30 +0,0 @@
- *  @file  score/src/ts64toticks.c
- *  @brief Get Nanoseconds Portion of Timestamp
-#if HAVE_CONFIG_H
-#endif
-uint32_t _Timestamp64_Get_nanoseconds(
-  return _Timestamp64_implementation_Get_nanoseconds( _time );
-#endif
diff --git a/cpukit/score/src/ts64getseconds.c b/cpukit/score/src/ts64getseconds.c
index eca0536..0000000
--- a/cpukit/score/src/ts64getseconds.c
+++ /dev/null
@@ -1,30 +0,0 @@
- * @file
- * @brief Get Seconds Portion of Timestamp
-#if HAVE_CONFIG_H
-#endif
-uint32_t _Timestamp64_Get_seconds(
-  return _Timestamp64_implementation_Get_seconds( _time );
-#endif
diff --git a/cpukit/score/src/ts64lessthan.c b/cpukit/score/src/ts64lessthan.c
index d147814..0000000
--- a/cpukit/score/src/ts64lessthan.c
+++ /dev/null
@@ -1,31 +0,0 @@
- * @file
- * @brief Timestamp Less Than Operator
- * @ingroup SuperCore Timestamp64
-#if HAVE_CONFIG_H
-#endif
-bool _Timestamp64_Less_than(
-  return _Timestamp64_implementation_Less_than( _lhs, _rhs );
-#endif
diff --git a/cpukit/score/src/ts64set.c b/cpukit/score/src/ts64set.c
index 22771d6..0000000
--- a/cpukit/score/src/ts64set.c
+++ /dev/null
@@ -1,33 +0,0 @@
- * @file
- * @brief Set Timestamp to Specified Seconds and Nanoseconds
-#if HAVE_CONFIG_H
-#endif
-void _Timestamp64_Set(
-  _Timestamp64_implementation_Set( _time, _seconds, _nanoseconds );
-#endif
diff --git a/cpukit/score/src/ts64settozero.c b/cpukit/score/src/ts64settozero.c
index 7b319df..0000000
--- a/cpukit/score/src/ts64settozero.c
+++ /dev/null
@@ -1,31 +0,0 @@
- * @file
- * @brief Zero a Timestamp64 Instance
-#if HAVE_CONFIG_H
-#endif
-void _Timestamp64_Set_to_zero(
-  _Timestamp64_implementation_Set_to_zero( _time );
-#endif
diff --git a/cpukit/score/src/ts64subtract.c b/cpukit/score/src/ts64subtract.c
index 1ee917b..0000000
--- a/cpukit/score/src/ts64subtract.c
+++ /dev/null
@@ -1,31 +0,0 @@
- * @file
- * @brief Subtract Two Timestamps
- * @ingroup Timestamp
-#if HAVE_CONFIG_H
-#endif
-void _Timestamp64_Subtract(
-  _Timestamp64_implementation_Subtract( _start, _end, _result );
-#endif
diff --git a/cpukit/score/src/ts64totimespec.c b/cpukit/score/src/ts64totimespec.c
index 7e81da7..0000000
--- a/cpukit/score/src/ts64totimespec.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * @file
- * @brief Convert Timestamp to Struct Timespec
-#if HAVE_CONFIG_H
-#endif
-void _Timestamp64_To_timespec(
-  _Timestamp64_implementation_To_timespec( _timestamp, _timespec );
-#endif
diff --git a/cpukit/score/src/ts64totimeval.c b/cpukit/score/src/ts64totimeval.c
index 1ac765b..0000000
--- a/cpukit/score/src/ts64totimeval.c
+++ /dev/null
@@ -1,37 +0,0 @@
- * @file
- * @brief Convert 64-bit Timestamp to struct timeval
- * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
- *  Obere Lagerstr. 30
- *  82178 Puchheim
- *  Germany
-#if HAVE_CONFIG_H
-#endif
-void _Timestamp64_To_timeval(
-  _Timestamp64_implementation_To_timeval( _timestamp, _timeval );
-#endif
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 9025ff3..c3fc443 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -38,6 +38,8 @@ else
 _SUBDIRS += sp29
 endif
 _SUBDIRS += spintrcritical23
+_SUBDIRS += sptimecounter01
+_SUBDIRS += sptimecounter02
 _SUBDIRS += spatomic01
 _SUBDIRS += spintrcritical22
 _SUBDIRS += spsem03
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index ae3c763..dbdd30f 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -41,6 +41,8 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
 spintrcritical23/Makefile
+sptimecounter02/Makefile
+sptimecounter01/Makefile
 spatomic01/Makefile
 spglobalcon01/Makefile
 spintrcritical22/Makefile
diff --git a/testsuites/sptests/spclock_err01/init.c b/testsuites/sptests/spclock_err01/init.c
index ab5c00a..087c8d4 100644
--- a/testsuites/sptests/spclock_err01/init.c
+++ b/testsuites/sptests/spclock_err01/init.c
@@ -115,14 +115,6 @@ rtems_task Init(
     puts( "TA1 - rtems_clock_get_tod_timeval - RTEMS_NOT_DEFINED" );
-  puts( "TA1 - rtems_clock_set_nanoseconds_extension - RTEMS_INVALID_ADDRESS" );
-  status = rtems_clock_set_nanoseconds_extension( NULL );
-  fatal_directive_status(
-    status,
-    RTEMS_INVALID_ADDRESS,
-    "rtems_clock_set_nanoseconds_extension NULL param"
   /* NULL parameter */
   status = rtems_clock_set( NULL );
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index f427bd2..3e01466 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -390,9 +390,6 @@ uninitialized =
 /*timerimpl.h*/ (sizeof _Timer_Information)               +
-/*tod.h*/       (sizeof _TOD.now)                         +
-                (sizeof _TOD.uptime)                      +
 /*tqdata.h*/    0                                         +
 /*types.h*/     0                                         +
diff --git a/testsuites/sptests/sptimecounter02/Makefile.am b/testsuites/sptests/sptimecounter02/Makefile.am
index 0000000..498c24e
--- /dev/null
+++ b/testsuites/sptests/sptimecounter02/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = sptimecounter02
+sptimecounter02_SOURCES = init.c
+dist_rtems_tests_DATA = sptimecounter02.scn sptimecounter02.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(sptimecounter02_OBJECTS)
+LINK_LIBS = $(sptimecounter02_LDLIBS)
+sptimecounter02$(EXEEXT): $(sptimecounter02_OBJECTS) $(sptimecounter02_DEPENDENCIES)
+	@rm -f sptimecounter02$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/sptimecounter02/init.c b/testsuites/sptests/sptimecounter02/init.c
index 0000000..1d9b661
--- /dev/null
+++ b/testsuites/sptests/sptimecounter02/init.c
@@ -0,0 +1,267 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#ifdef HAVE_CONFIG_H
+#endif
+#define _KERNEL
+#include <sys/time.h>
+#include <sys/timetc.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <inttypes.h>
+#include <assert.h>
+#include <unistd.h>
+#include <rtems.h>
+#include <rtems/counter.h>
+#include <rtems/test.h>
+#include <rtems/timecounter.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SPTIMECOUNTER_2";
+#define MASTER_PRIORITY 1
+#define WORKER_PRIORITY 2
+#define CPU_COUNT 32
+#define DURATION_LENGTH 1
+typedef struct {
+  rtems_test_parallel_context base;
+  struct timecounter tc_soft;
+  struct timecounter tc_cpu_counter;
+  u_int tc_soft_counter;
+  uint32_t binuptime_per_job[CPU_COUNT];
+  uint32_t rtemsuptime_per_job[CPU_COUNT];
+} timecounter_context;
+typedef struct {
+  struct bintime start_bin;
+  struct bintime end_bin;
+  struct bintime diff;
+} test_variables;
+static timecounter_context test_instance;
+static test_variables test_values;
+static rtems_interval test_duration(void)
+  return DURATION_LENGTH * rtems_clock_get_ticks_per_second();
+static u_int test_get_timecount_null(struct timecounter *tc)
+	return 0;
+static u_int test_get_timecount_cpu(struct timecounter *tc)
+  return 0xffffffff - rtems_counter_read();
+static void register_hardware_tc_null(timecounter_context *ctx)
+  struct timecounter *tc_cpu = &ctx->tc_cpu_counter;
+  tc_cpu->tc_get_timecount = test_get_timecount_null;
+  tc_cpu->tc_counter_mask = 0xffffffff;
+  tc_cpu->tc_frequency = rtems_counter_nanoseconds_to_ticks(1000000000);
+  tc_cpu->tc_quality = 2000;
+  rtems_timecounter_install(tc_cpu);
+ * Start of Timers
+static rtems_interval test_bintime_init(
+  rtems_test_parallel_context *base,
+  void *arg,
+  size_t active_workers
+  return test_duration();
+static void test_bintime_body(
+  void *arg,
+  size_t active_workers,
+  size_t worker_index
+  timecounter_context *ctx = (timecounter_context *) base;
+  uint32_t counter = 0;
+  test_variables *values = &test_values;
+  while (!rtems_test_parallel_stop_job(&ctx->base)) {
+    ++counter;
+    rtems_bsd_binuptime(&bt);
+    if (counter == 1){
+      values->start_bin = bt;
+  values->end_bin = bt;
+  values->diff = bt;
+  bintime_sub(&values->diff, &values->start_bin);
+  printf("\n%" PRIu32 " %" PRIu64 "\n", values->start_bin.sec,
+    values->start_bin.frac);
+  printf("%" PRIu32 " %" PRIu64 "\n", values->end_bin.sec,
+    values->end_bin.frac);
+  assert((values->diff.sec == DURATION_LENGTH) ||
+   ((values->diff.sec == DURATION_LENGTH - 1) &&
+   (values->diff.frac > UINT64_C(18000000000000000000))) ||
+   ((values->diff.sec == DURATION_LENGTH + 1) &&
+   (values->end_bin.frac < UINT64_C(2000000000000000000)))
+  ctx->binuptime_per_job[worker_index] = counter;
+static void test_bintime_fini(
+  void *arg,
+  size_t i;
+  printf("  <BinuptimeTest activeWorker=\"%zu\">\n", active_workers);
+  for (i = 0; i < active_workers; ++i) {
+    printf(
+      "      <Counter worker=\"%zu\">%" PRIu32 "</Counter>\n",
+      (i+1), ctx->binuptime_per_job[i]);
+  printf("  </BinuptimeTest>\n");
+static rtems_interval test_bintime_null_init(
+  void *arg,
+  timecounter_context *ctx = &test_instance;
+  register_hardware_tc_null(ctx);
+static void test_bintime_null_body(
+  void *arg,
+    ++counter;
+static void test_bintime_null_fini(
+  void *arg,
+  size_t i;
+  printf("  <BinuptimenullTest activeWorker=\"%zu\">\n", active_workers);
+    printf(
+  printf("  </BinuptimenullTest>\n");
+static const rtems_test_parallel_job timecounter_jobs[] = {
+    .init = test_bintime_init,
+    .body = test_bintime_body,
+    .fini = test_bintime_fini,
+    .cascade = true
+    .init = test_bintime_null_init,
+    .body = test_bintime_null_body,
+    .fini = test_bintime_null_fini,
+    .cascade = true
+ * Start of Init
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  printf("<TEST>\n");
+  rtems_test_parallel(
+    &ctx->base,
+    NULL,
+    &timecounter_jobs[0],
+    RTEMS_ARRAY_SIZE(timecounter_jobs)
+  printf("</TEST>\n");
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS (2 + CPU_COUNT - 1)
+#define CONFIGURE_MAXIMUM_TIMERS 2
+#define CONFIGURE_MAXIMUM_PERIODS 1
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/sptimecounter02/sptimecounter02.doc b/testsuites/sptests/sptimecounter02/sptimecounter02.doc
index 0000000..9988ad0
--- /dev/null
+++ b/testsuites/sptests/sptimecounter02/sptimecounter02.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: sptimecounter02
+directives:
+  rtems_timecounter_install, rtems_bsd_binuptime.
+concepts:
+  measurement of performance tests: how often per timeframe can FreeBSD time
+  routines be called in comparison to original rtems timing routines.
diff --git a/testsuites/sptests/sptimecounter02/sptimecounter02.scn b/testsuites/sptests/sptimecounter02/sptimecounter02.scn
index 0000000..cb61e72
--- /dev/null
+++ b/testsuites/sptests/sptimecounter02/sptimecounter02.scn
@@ -0,0 +1,13 @@
+*** BEGIN OF TEST SPTIMECOUNTER_2 ***
+<TEST>
+1 75991292036483475
+2 255000544837680083
+  <BinuptimeTest activeWorker="1">
+      <Counter worker="1">35997</Counter>
+  </BinuptimeTest>
+  <BinuptimenullTest activeWorker="1">
+      <Counter worker="1">59416</Counter>
+  </BinuptimenullTest>
+</TEST>
+*** END OF TEST SPTIMECOUNTER_2 ***
1.8.4.5
