[PATCH 05/42] LIBPCI: moved copyright into a single line
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:32:32 UTC 2015
 cpukit/libpci/pci/access.h         |    3 +--
 cpukit/libpci/pci/cfg.h            |    3 +--
 cpukit/libpci/pci/cfg_auto.h       |    3 +--
 cpukit/libpci/pci/cfg_peripheral.h |    3 +--
 cpukit/libpci/pci/cfg_read.h       |    3 +--
 cpukit/libpci/pci/cfg_static.h     |    3 +--
 cpukit/libpci/pci/irq.h            |    3 +--
 cpukit/libpci/pci_access.c         |    3 +--
 cpukit/libpci/pci_access_func.c    |    3 +--
 cpukit/libpci/pci_access_io.c      |    3 +--
 cpukit/libpci/pci_access_mem.c     |    3 +--
 cpukit/libpci/pci_access_mem_be.c  |    3 +--
 cpukit/libpci/pci_access_mem_le.c  |    3 +--
 cpukit/libpci/pci_cfg.c            |    3 +--
 cpukit/libpci/pci_cfg_auto.c       |    3 +--
 cpukit/libpci/pci_cfg_peripheral.c |    3 +--
 cpukit/libpci/pci_cfg_print_code.c |    3 +--
 cpukit/libpci/pci_cfg_read.c       |    3 +--
 cpukit/libpci/pci_cfg_static.c     |    3 +--
 cpukit/libpci/pci_find.c           |    3 +--
 cpukit/libpci/pci_find_dev.c       |    3 +--
 cpukit/libpci/pci_for_each.c       |    3 +--
 cpukit/libpci/pci_for_each_child.c |    3 +--
 cpukit/libpci/pci_for_each_dev.c   |    3 +--
 cpukit/libpci/pci_get_dev.c        |    3 +--
 cpukit/libpci/pci_irq.c            |    3 +--
 cpukit/libpci/pci_print.c          |    3 +--
 27 files changed, 27 insertions(+), 54 deletions(-)
diff --git a/cpukit/libpci/pci/access.h b/cpukit/libpci/pci/access.h
index f8365db..990aaae 100644
--- a/cpukit/libpci/pci/access.h
+++ b/cpukit/libpci/pci/access.h
@@ -1,8 +1,7 @@
 /* Routines to access PCI memory/configuration space and other PCI related
  * functions the PCI Library provides.
- * COPYRIGHT (c) 2010.
- * Cobham Gaisler AB.
+ * COPYRIGHT (c) 2010 Cobham Gaisler AB.
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
diff --git a/cpukit/libpci/pci/cfg.h b/cpukit/libpci/pci/cfg.h
index 8869a51..592f364 100644
--- a/cpukit/libpci/pci/cfg.h
+++ b/cpukit/libpci/pci/cfg.h
@@ -3,8 +3,7 @@
  *  - static configuration (user defined config)
  * both versions are defined here.
diff --git a/cpukit/libpci/pci/cfg_auto.h b/cpukit/libpci/pci/cfg_auto.h
index 25e7336..71626c7 100644
--- a/cpukit/libpci/pci/cfg_auto.h
+++ b/cpukit/libpci/pci/cfg_auto.h
@@ -1,7 +1,6 @@
 /* PCI Auto Configuration Library
diff --git a/cpukit/libpci/pci/cfg_peripheral.h b/cpukit/libpci/pci/cfg_peripheral.h
index 68f2e24..bbeaf6e 100644
--- a/cpukit/libpci/pci/cfg_peripheral.h
+++ b/cpukit/libpci/pci/cfg_peripheral.h
@@ -1,7 +1,6 @@
 /* PCI Peripheral Configuration Library
diff --git a/cpukit/libpci/pci/cfg_read.h b/cpukit/libpci/pci/cfg_read.h
index af60a4e..31a600a 100644
--- a/cpukit/libpci/pci/cfg_read.h
+++ b/cpukit/libpci/pci/cfg_read.h
@@ -1,8 +1,7 @@
 /* PCI Read Configuration Library. Read current config that bootloader/BIOS
  * has setup.
diff --git a/cpukit/libpci/pci/cfg_static.h b/cpukit/libpci/pci/cfg_static.h
index 5633dfc..ff00300 100644
--- a/cpukit/libpci/pci/cfg_static.h
+++ b/cpukit/libpci/pci/cfg_static.h
@@ -1,7 +1,6 @@
 /* Static PCI Auto Configuration Library
diff --git a/cpukit/libpci/pci/irq.h b/cpukit/libpci/pci/irq.h
index 2dacadf..3a7dfe4 100644
--- a/cpukit/libpci/pci/irq.h
+++ b/cpukit/libpci/pci/irq.h
@@ -3,8 +3,7 @@
  * IRQ handling does not have so much with PCI to do, this library depends
  * on the BSP to implement shared interrupts.
diff --git a/cpukit/libpci/pci_access.c b/cpukit/libpci/pci_access.c
index 371c5ef..8fdf7ca 100644
--- a/cpukit/libpci/pci_access.c
+++ b/cpukit/libpci/pci_access.c
@@ -1,7 +1,6 @@
 /*  PCI Access Library
diff --git a/cpukit/libpci/pci_access_func.c b/cpukit/libpci/pci_access_func.c
index d86ccab..cf4f86b 100644
--- a/cpukit/libpci/pci_access_func.c
+++ b/cpukit/libpci/pci_access_func.c
@@ -1,7 +1,6 @@
diff --git a/cpukit/libpci/pci_access_io.c b/cpukit/libpci/pci_access_io.c
index 12e6699..c92870a 100644
--- a/cpukit/libpci/pci_access_io.c
+++ b/cpukit/libpci/pci_access_io.c
@@ -1,7 +1,6 @@
diff --git a/cpukit/libpci/pci_access_mem.c b/cpukit/libpci/pci_access_mem.c
index 216f83f..edc7409 100644
--- a/cpukit/libpci/pci_access_mem.c
+++ b/cpukit/libpci/pci_access_mem.c
@@ -1,8 +1,7 @@
  *  Registers-over-Memory Space - Generic Big/Little endian PCI bus definitions
diff --git a/cpukit/libpci/pci_access_mem_be.c b/cpukit/libpci/pci_access_mem_be.c
index f05b547..a493f92 100644
--- a/cpukit/libpci/pci_access_mem_be.c
+++ b/cpukit/libpci/pci_access_mem_be.c
@@ -1,8 +1,7 @@
  *  Registers-over-Memory Space - Generic Big endian PCI bus definitions
diff --git a/cpukit/libpci/pci_access_mem_le.c b/cpukit/libpci/pci_access_mem_le.c
index 2746f24..708f738 100644
--- a/cpukit/libpci/pci_access_mem_le.c
+++ b/cpukit/libpci/pci_access_mem_le.c
@@ -1,8 +1,7 @@
  *  Registers-over-Memory Space - Generic Little endian PCI bus definitions
diff --git a/cpukit/libpci/pci_cfg.c b/cpukit/libpci/pci_cfg.c
index 78a1229..e27d845 100644
--- a/cpukit/libpci/pci_cfg.c
+++ b/cpukit/libpci/pci_cfg.c
@@ -1,7 +1,6 @@
 /*  PCI Configuration Library
diff --git a/cpukit/libpci/pci_cfg_auto.c b/cpukit/libpci/pci_cfg_auto.c
index 548dd90..3f9c75f 100644
--- a/cpukit/libpci/pci_cfg_auto.c
+++ b/cpukit/libpci/pci_cfg_auto.c
@@ -1,7 +1,6 @@
 /*  PCI (Auto) configuration Library. Setup PCI configuration space and IRQ.
diff --git a/cpukit/libpci/pci_cfg_peripheral.c b/cpukit/libpci/pci_cfg_peripheral.c
index d1ba4c9..e6c69b6 100644
--- a/cpukit/libpci/pci_cfg_peripheral.c
+++ b/cpukit/libpci/pci_cfg_peripheral.c
@@ -1,7 +1,6 @@
 /*  PCI (Peripheral) Configuration Library
- *  COPYRIGHT (c) 2011.
+ *  COPYRIGHT (c) 2011 Cobham Gaisler AB.
diff --git a/cpukit/libpci/pci_cfg_print_code.c b/cpukit/libpci/pci_cfg_print_code.c
index 8770c8a..edd017d 100644
--- a/cpukit/libpci/pci_cfg_print_code.c
+++ b/cpukit/libpci/pci_cfg_print_code.c
@@ -1,8 +1,7 @@
 /* PCI (Static) Configuration Library. PCI Configuration C code console
  * printout routines that can be used to build a static PCI configuration.
diff --git a/cpukit/libpci/pci_cfg_read.c b/cpukit/libpci/pci_cfg_read.c
index 2db465d..b68eb47 100644
--- a/cpukit/libpci/pci_cfg_read.c
+++ b/cpukit/libpci/pci_cfg_read.c
@@ -1,8 +1,7 @@
 /*  Read current PCI configuration that bootloader or BIOS has already setup
  *  and initialize the PCI structures.
diff --git a/cpukit/libpci/pci_cfg_static.c b/cpukit/libpci/pci_cfg_static.c
index d7d4321..ad3182e 100644
--- a/cpukit/libpci/pci_cfg_static.c
+++ b/cpukit/libpci/pci_cfg_static.c
@@ -1,7 +1,6 @@
diff --git a/cpukit/libpci/pci_find.c b/cpukit/libpci/pci_find.c
index 945cb56..a2575b7 100644
--- a/cpukit/libpci/pci_find.c
+++ b/cpukit/libpci/pci_find.c
@@ -1,7 +1,6 @@
 /*  PCI Help function, Find a PCI device by VENDOR/DEVICE ID
diff --git a/cpukit/libpci/pci_find_dev.c b/cpukit/libpci/pci_find_dev.c
index 184d05c..3339c42 100644
--- a/cpukit/libpci/pci_find_dev.c
+++ b/cpukit/libpci/pci_find_dev.c
@@ -1,7 +1,6 @@
diff --git a/cpukit/libpci/pci_for_each.c b/cpukit/libpci/pci_for_each.c
index dc0a9a1..88e4ac3 100644
--- a/cpukit/libpci/pci_for_each.c
+++ b/cpukit/libpci/pci_for_each.c
@@ -1,7 +1,6 @@
 /*  PCI Help Function, iterate over all PCI devices. Find devices by cfg access.
diff --git a/cpukit/libpci/pci_for_each_child.c b/cpukit/libpci/pci_for_each_child.c
index 9d08b77..a4fef97 100644
--- a/cpukit/libpci/pci_for_each_child.c
+++ b/cpukit/libpci/pci_for_each_child.c
@@ -1,7 +1,6 @@
 /*  PCI Help function, iterate all PCI device children of PCI bus.
diff --git a/cpukit/libpci/pci_for_each_dev.c b/cpukit/libpci/pci_for_each_dev.c
index c2b3934..b090f1c 100644
--- a/cpukit/libpci/pci_for_each_dev.c
+++ b/cpukit/libpci/pci_for_each_dev.c
@@ -1,7 +1,6 @@
 /*  PCI Help function, iterate all PCI devices.
diff --git a/cpukit/libpci/pci_get_dev.c b/cpukit/libpci/pci_get_dev.c
index 5e07653..c415a80 100644
--- a/cpukit/libpci/pci_get_dev.c
+++ b/cpukit/libpci/pci_get_dev.c
@@ -1,7 +1,6 @@
 /*  PCI Help function, Find a PCI device by BUS|SLOT|FUNCTION
diff --git a/cpukit/libpci/pci_irq.c b/cpukit/libpci/pci_irq.c
index e379852..2f4d332 100644
--- a/cpukit/libpci/pci_irq.c
+++ b/cpukit/libpci/pci_irq.c
@@ -1,7 +1,6 @@
 /*  PCI IRQ Library
diff --git a/cpukit/libpci/pci_print.c b/cpukit/libpci/pci_print.c
index 9c40f1e..82baba9 100644
--- a/cpukit/libpci/pci_print.c
+++ b/cpukit/libpci/pci_print.c
@@ -1,7 +1,6 @@
 /*  PCI Print Current Configuration To Terminal
1.7.0.4
