[PATCH 10/42] LEON: converted PCI peripherals to BSD header
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:32:37 UTC 2015
 c/src/lib/libbsp/sparc/shared/pci/gr_701.c         |    6 +++---
 .../lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c  |    6 +++---
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c    |   14 +++++++-------
 .../libbsp/sparc/shared/pci/gr_rasta_spw_router.c  |    8 ++++----
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c  |   14 +++++++-------
 5 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_701.c b/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
index 815b850..011a594 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
@@ -269,9 +269,9 @@ static int gr701_hw_init(struct gr701_priv *priv)
 	priv->bus_maps_up[1].size = 0;
 	/* Enable I/O and Mem accesses */
-	pci_cfg_r32(pcidev, PCI_COMMAND, &com1);
-	com1 |= PCI_COMMAND_IO | PCI_COMMAND_MEMORY;
-	pci_cfg_w32(pcidev, PCI_COMMAND, com1);
+	pci_cfg_r32(pcidev, PCIR_COMMAND, &com1);
+	com1 |= PCIM_CMD_PORTEN | PCIM_CMD_MEMEN;
+	pci_cfg_w32(pcidev, PCIR_COMMAND, com1);
 	/* Start AMBA PnP scan at first AHB bus */
 	ambapp_scan(&priv->abus, devinfo->resources[1].address + 0x3f00000,
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
index 96225c8..bc80f95 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
@@ -240,14 +240,14 @@ static int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
 	*page0 = priv->version->amba_ioarea & 0xf0000000;
 	/* set parity error response */
-	pci_cfg_r32(priv->pcidev, PCI_COMMAND, &data);
-	pci_cfg_w32(priv->pcidev, PCI_COMMAND, (data|PCI_COMMAND_PARITY));
+	pci_cfg_r32(priv->pcidev, PCIR_COMMAND, &data);
+	pci_cfg_w32(priv->pcidev, PCIR_COMMAND, (data|PCIM_CMD_PERRESPEN));
 	/* Setup cache line size. Default cache line size will result in
 	 * poor performance (256 word fetches), 0xff will set it according
 	 * to the max size of the PCI FIFO.
-	pci_cfg_w8(priv->pcidev, PCI_CACHE_LINE_SIZE, 0xff);
+	pci_cfg_w8(priv->pcidev, PCIR_CACHELNSZ, 0xff);
 	/* Scan AMBA Plug&Play */
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
index 417056f..08b3c37 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
@@ -274,8 +274,8 @@ static int gr_rasta_io_hw_init(struct gr_rasta_io_priv *priv)
 		uint32_t data;
 #endif
@@ -283,7 +283,7 @@ static int gr_rasta_io_hw_init(struct gr_rasta_io_priv *priv)
@@ -401,7 +401,7 @@ static int gr_rasta_io2_hw_init(struct gr_rasta_io_priv *priv)
 	struct pci_dev_info *devinfo = priv->devinfo;
 	/* Check capabilities list bit */
-	pci_cfg_r8(pcidev, PCI_STATUS, &tmp2);
+	pci_cfg_r8(pcidev, PCIR_STATUS, &tmp2);
 	if (!((tmp2 >> 4) & 1)) {
 		/* Capabilities list not available which it should be in the
@@ -411,7 +411,7 @@ static int gr_rasta_io2_hw_init(struct gr_rasta_io_priv *priv)
 	/* Read capabilities pointer */
-	pci_cfg_r8(pcidev, PCI_CAP_PTR, &cap_ptr);
+	pci_cfg_r8(pcidev, PCIR_CAP_PTR, &cap_ptr);
 	/* Set AHB address mappings for target PCI bars
 	 * BAR0: 16MB  : Mapped to I/O at 0x80000000
@@ -430,8 +430,8 @@ static int gr_rasta_io2_hw_init(struct gr_rasta_io_priv *priv)
 #if 0
-	pci_cfg_r32(pcidev, PCI_COMMAND, &data);
-	pci_cfg_w32(pcidev, PCI_COMMAND, (data|PCI_COMMAND_PARITY));
+	pci_cfg_r32(pcidev, PCIR_COMMAND, &data);
+	pci_cfg_w32(pcidev, PCIR_COMMAND, (data|PCIM_CMD_PERRESPEN));
 #endif
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
index 986adcc..244a8aa 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
@@ -256,7 +256,7 @@ static int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
 		/* Capabilities list not available which it should be in the GRPCI2 */
@@ -264,7 +264,7 @@ static int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
 	/* Set AHB address mappings for target PCI bars */
 	pci_cfg_w32(pcidev, cap_ptr+GRPCI2_BAR0_TO_AHB_MAP, 0xffe00000);  /* APB bus, AHB I/O bus 2 MB */
@@ -276,8 +276,8 @@ static int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
 #if 0
 #endif
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
index 809919e..afd2142 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
@@ -340,8 +340,8 @@ static int gr_rasta_tmtc0_hw_init(struct gr_rasta_tmtc_priv *priv)
 		uint32_t data;
 #endif
@@ -349,7 +349,7 @@ static int gr_rasta_tmtc0_hw_init(struct gr_rasta_tmtc_priv *priv)
-	pci_cfg_w8(pcidev, PCI_CACHE_LINE_SIZE, 0xff);
+	pci_cfg_w8(pcidev, PCIR_CACHELNSZ, 0xff);
@@ -442,7 +442,7 @@ static int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
@@ -452,7 +452,7 @@ static int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
@@ -471,8 +471,8 @@ static int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
 #if 0
 #endif
1.7.0.4
