[PATCH 12/42] leon3: timer config updated to use proper naming
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:32:39 UTC 2015
To be merged with "leon3: make timer initialization configurable"
 c/src/lib/libbsp/sparc/leon3/amba/amba.c    |   10 +++++-----
 c/src/lib/libbsp/sparc/leon3/include/leon.h |    4 ++--
 2 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
index 8e6cef5..fe481f5 100644
--- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
+++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
@@ -71,8 +71,8 @@ rtems_interrupt_lock LEON3_IrqCtrl_Lock =
 /* Pointers to Interrupt Controller configuration registers */
 volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
-struct ambapp_dev *irqmp_dev;
-struct ambapp_dev *timer_dev;
+struct ambapp_dev *LEON3_IrqCtrl_Adev;
+struct ambapp_dev *LEON3_Timer_Adev;
  *  amba_initialize
@@ -109,7 +109,7 @@ void amba_initialize(void)
   LEON3_IrqCtrl_Regs = (volatile struct irqmp_regs *)DEV_TO_APB(adev)->start;
-  irqmp_dev = adev;
+  LEON3_IrqCtrl_Adev = adev;
   if ((LEON3_IrqCtrl_Regs->ampctrl >> 28) > 0) {
     /* IRQ Controller has support for multiple IRQ Controllers, each
      * CPU can be routed to different Controllers, we find out which
@@ -139,12 +139,12 @@ void amba_initialize(void)
                                  ambapp_find_by_idx, &leon3_timer_core_index);
   if (adev) {
     LEON3_Timer_Regs = (volatile struct gptimer_regs *)DEV_TO_APB(adev)->start;
-    timer_dev = adev;
+    LEON3_Timer_Adev = adev;
     /* Register AMBA Bus Frequency */
     ambapp_freq_init(
       &ambapp_plb,
-      timer_dev,
+      LEON3_Timer_Adev,
       (LEON3_Timer_Regs->scaler_reload + 1)
         * LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index 8d7a03a..8ad8a18 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -131,11 +131,11 @@ extern "C" {
 /* LEON3 Interrupt Controller */
 extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
-extern struct ambapp_dev *irqmp_dev;
+extern struct ambapp_dev *LEON3_IrqCtrl_Adev;
 /* LEON3 GP Timer */
 extern volatile struct gptimer_regs *LEON3_Timer_Regs;
-extern struct ambapp_dev *timer_dev;
+extern struct ambapp_dev *LEON3_Timer_Adev;
 /* LEON3 CPU Index of boot CPU */
 extern uint32_t LEON3_Cpu_Index;
1.7.0.4
