[PATCH 19/42] PCI BUS: moved comment out of license header
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:32:46 UTC 2015
 cpukit/libpci/pci_bus.c |   25 +++++++++++--------------
 cpukit/libpci/pci_bus.h |   21 +++++++++++----------
 2 files changed, 22 insertions(+), 24 deletions(-)
diff --git a/cpukit/libpci/pci_bus.c b/cpukit/libpci/pci_bus.c
index 654d311..ef0a068 100644
--- a/cpukit/libpci/pci_bus.c
+++ b/cpukit/libpci/pci_bus.c
@@ -2,23 +2,20 @@
  *  COPYRIGHT (c) 2008 Cobham Gaisler AB.
- *  General part of PCI Bus driver. The driver is typically
- *  initialized from the PCI host driver separating the host
- *  driver from the common parts in PCI drivers.
- *  The PCI library must be initialized before starting the
- *  PCI bus driver. The PCI library have set up BARs and
- *  assigned system IRQs for targets.
- *  This PCI bus driver rely on the PCI library (pci.c) for
- *  interrupt registeration (pci_interrupt_register) and PCI
- *  target set up.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.com/license/LICENSE.
- *  2008-12-03, Daniel Hellstrom <daniel at gaisler.com>
- *    Created
+/* General part of PCI Bus driver. The driver is typically
+ * initialized from the PCI host driver separating the host
+ * driver from the common parts in PCI drivers.
+ * The PCI library must be initialized before starting the
+ * PCI bus driver. The PCI library have set up BARs and
+ * assigned system IRQs for targets.
+ * This PCI bus driver rely on the PCI library (pci.c) for
+ * interrupt registeration (pci_interrupt_register) and PCI
+ * target set up.
 /* Use PCI Configuration libarary pci_hb RAM device structure to find devices,
diff --git a/cpukit/libpci/pci_bus.h b/cpukit/libpci/pci_bus.h
index 359a55a..8e3912b 100644
--- a/cpukit/libpci/pci_bus.h
+++ b/cpukit/libpci/pci_bus.h
@@ -2,22 +2,23 @@
- *  target set up.
+/* General part of drvmgr PCI Bus driver. The driver is typically
+ * target set up.
 #ifndef __PCI_BUS_H__
 #define __PCI_BUS_H__
1.7.0.4
