[PATCH 24/42] LIBPCI: new implementation private header file
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:32:51 UTC 2015
 - new implementation private header file
 - moved double implementation of pci_dev_create used by read & auto cfg
   libraries to common pci_dev_create.c
 - moved declaration of pci_bus_cnt to private header file so avoid extern
   in .c files
 cpukit/libpci/Makefile.am          |    1 +
 cpukit/libpci/pci_cfg_auto.c       |   22 ++--------------------
 cpukit/libpci/pci_cfg_peripheral.c |    3 +--
 cpukit/libpci/pci_cfg_read.c       |   22 ++--------------------
 cpukit/libpci/pci_cfg_static.c     |    5 ++---
 cpukit/libpci/pci_dev_create.c     |   34 ++++++++++++++++++++++++++++++++++
 cpukit/libpci/pci_internal.h       |   14 ++++++++++++++
 7 files changed, 56 insertions(+), 45 deletions(-)
 create mode 100644 cpukit/libpci/pci_dev_create.c
 create mode 100644 cpukit/libpci/pci_internal.h
diff --git a/cpukit/libpci/Makefile.am b/cpukit/libpci/Makefile.am
index cff25b3..cf336ed 100644
--- a/cpukit/libpci/Makefile.am
+++ b/cpukit/libpci/Makefile.am
@@ -28,6 +28,7 @@ libpci_a_SOURCES += pci_cfg_print_code.c
 libpci_a_SOURCES += pci_cfg_read.c
 libpci_a_SOURCES += pci_cfg_static.c
 libpci_a_SOURCES += pci_cfg_peripheral.c
+libpci_a_SOURCES += pci_dev_create.c
 libpci_a_SOURCES += pci_find.c
 libpci_a_SOURCES += pci_find_dev.c
 libpci_a_SOURCES += pci_for_each.c
diff --git a/cpukit/libpci/pci_cfg_auto.c b/cpukit/libpci/pci_cfg_auto.c
index b23c0bc..d591977 100644
--- a/cpukit/libpci/pci_cfg_auto.c
+++ b/cpukit/libpci/pci_cfg_auto.c
@@ -19,6 +19,8 @@
 #include <pci/access.h>
 #include <pci/cfg.h>
+#include "pci_internal.h"
 /* #define DEBUG */
 #ifdef DEBUG
@@ -38,9 +40,6 @@
 #define PCI_CFG_W16(dev, args...) pci_cfg_w16(dev, args)
 #define PCI_CFG_W32(dev, args...) pci_cfg_w32(dev, args)
-/* Number of PCI buses */
-extern int pci_bus_cnt;
 int pci_config_auto_initialized = 0;
 /* Configuration setup */
@@ -268,23 +267,6 @@ static void pci_dev_free(struct pci_dev *dev)
 #endif
-static struct pci_dev *pci_dev_create(int isbus)
-	void *ptr;
-	int size;
-	if (isbus)
-		size = sizeof(struct pci_bus);
-	else
-		size = sizeof(struct pci_dev);
-	ptr = malloc(size);
-	if (!ptr)
-		rtems_fatal_error_occurred(RTEMS_NO_MEMORY);
-	memset(ptr, 0, size);
-	return ptr;
 static void pci_find_devs(struct pci_bus *bus)
 	uint32_t id, tmp;
diff --git a/cpukit/libpci/pci_cfg_peripheral.c b/cpukit/libpci/pci_cfg_peripheral.c
index e6c69b6..c2ab7ec 100644
--- a/cpukit/libpci/pci_cfg_peripheral.c
+++ b/cpukit/libpci/pci_cfg_peripheral.c
@@ -18,8 +18,7 @@
-/* Number of buses */
 /* Assume that user has defined static setup array in pci_hb */
 int pci_config_peripheral(void)
diff --git a/cpukit/libpci/pci_cfg_read.c b/cpukit/libpci/pci_cfg_read.c
index a2154d2..b1ea070 100644
--- a/cpukit/libpci/pci_cfg_read.c
+++ b/cpukit/libpci/pci_cfg_read.c
@@ -14,6 +14,8 @@
 /* PCI Library
  * (For debugging it might be good to use other functions or the driver's
  *  directly)
@@ -31,29 +33,9 @@
 #define DBG(args...)
 #endif
 /* The Host Bridge bus is initialized here */
 extern struct pci_bus pci_hb;
-	void *ptr;
-	int size;
-	if (isbus)
-	else
-	if (!ptr)
-	return ptr;
 /* Check if address is accessible from host */
 static int pci_read_addressable(struct pci_dev *dev, struct pci_res *res)
diff --git a/cpukit/libpci/pci_cfg_static.c b/cpukit/libpci/pci_cfg_static.c
index 5ec2242..9974eb9 100644
--- a/cpukit/libpci/pci_cfg_static.c
+++ b/cpukit/libpci/pci_cfg_static.c
@@ -20,6 +20,8 @@
 #define PCI_CFG_R8(dev, args...) pci_cfg_r8(dev, args)
 #define PCI_CFG_R16(dev, args...) pci_cfg_r16(dev, args)
 #define PCI_CFG_R32(dev, args...) pci_cfg_r32(dev, args)
@@ -27,9 +29,6 @@
 /* Enumrate one bus if device is a bridge, and all it's subordinate buses */
 static int pci_init_dev(struct pci_dev *dev, void *unused)
diff --git a/cpukit/libpci/pci_dev_create.c b/cpukit/libpci/pci_dev_create.c
new file mode 100644
index 0000000..a79e429
--- /dev/null
+++ b/cpukit/libpci/pci_dev_create.c
@@ -0,0 +1,34 @@
+/*  Device allocator helper used by PCI Auto/Read Configuration Library
+ *  COPYRIGHT (c) 2010 Cobham Gaisler AB.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#include <rtems.h>
+#include <stdlib.h>
+#include <rtems/bspIo.h>
+#include <pci.h>
+#include <pci/cfg.h>
+struct pci_dev *pci_dev_create(int isbus)
+	void *ptr;
+	int size;
+	if (isbus)
+		size = sizeof(struct pci_bus);
+	else
+		size = sizeof(struct pci_dev);
+	ptr = malloc(size);
+	if (!ptr)
+		rtems_fatal_error_occurred(RTEMS_NO_MEMORY);
+	memset(ptr, 0, size);
+	return ptr;
diff --git a/cpukit/libpci/pci_internal.h b/cpukit/libpci/pci_internal.h
index 0000000..b45ef56
--- /dev/null
+++ b/cpukit/libpci/pci_internal.h
@@ -0,0 +1,14 @@
+/* Private libpci declarations
+ * COPYRIGHT (c) 2015 Cobham Gaisler AB.
+/* Number of buses */
+extern int pci_bus_cnt;
+/* Allocate a PCI device for a standard device or a bridge device */
+struct pci_dev *pci_dev_create(int isbus);
1.7.0.4
