[PATCH 38/42] DRVMGR: remove struct driver registration func
Daniel Hellstrom daniel at gaisler.com
Tue Apr 14 11:33:05 UTC 2015
 .../lib/libbsp/sparc/leon2/startup/bsppredriver.c  |    4 +-
 c/src/lib/libbsp/sparc/leon3/amba/amba.c           |    8 +-
 cpukit/libdrvmgr/drvmgr.c                          |    6 +-
 cpukit/libdrvmgr/drvmgr.h                          |    4 +-
 cpukit/libdrvmgr/drvmgr_confdefs.h                 |  151 +++++--------------
 5 files changed, 50 insertions(+), 123 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
index 2e41b72..ad3694d 100644
--- a/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
+++ b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
@@ -31,9 +31,9 @@
  * the devmgr_confdefs.h. No specifc drivers needed by BSP since IRQ/TIMER/UART
  * is not drvmgr drivers.
-struct drvmgr_drv_reg_func drvmgr_drivers[] __attribute__((weak)) =
+drvmgr_drv_reg_func drvmgr_drivers[] __attribute__((weak)) =
-  {NULL} /* End array with NULL */
+  NULL /* End array with NULL */
 /* Defines what cores are avilable on the bus in addition to the standard
diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
index 87dcf22..60a236c 100644
--- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
+++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
@@ -38,11 +38,11 @@ extern void apbuart_cons_register_drv(void);
 /* All drivers included by BSP, this is overridden by the user by including
  * the drvmgr_confdefs.h. By default the Timer and UART driver are included.
-  {gptimer_register_drv},
-  {apbuart_cons_register_drv},
+  gptimer_register_drv,
+  apbuart_cons_register_drv,
 /* Driver resources configuration for AMBA root bus. It is declared weak
diff --git a/cpukit/libdrvmgr/drvmgr.c b/cpukit/libdrvmgr/drvmgr.c
index 7e669b4..7c37afd 100644
--- a/cpukit/libdrvmgr/drvmgr.c
+++ b/cpukit/libdrvmgr/drvmgr.c
@@ -83,7 +83,7 @@ void _DRV_Manager_init_level(int level)
 void _DRV_Manager_initialization(void)
-	struct drvmgr_drv_reg_func *drvreg;
+	drvmgr_drv_reg_func *drvreg;
 	/* drvmgr is already initialized statically by compiler except
 	 * the lock
@@ -92,9 +92,9 @@ void _DRV_Manager_initialization(void)
 	/* Call driver register functions. */
 	drvreg = &drvmgr_drivers[0];
-	while (drvreg->drv_reg) {
+	while (*drvreg) {
 		/* Make driver register */
-		drvreg->drv_reg();
+		(*drvreg)();
 		drvreg++;
diff --git a/cpukit/libdrvmgr/drvmgr.h b/cpukit/libdrvmgr/drvmgr.h
index ca52b3b..194de66 100644
--- a/cpukit/libdrvmgr/drvmgr.h
+++ b/cpukit/libdrvmgr/drvmgr.h
@@ -315,9 +315,7 @@ struct drvmgr_drv {
  *  for drivers to register themselfs. Used to select drivers available to the
  *  driver manager.
-struct drvmgr_drv_reg_func {
-	void (*drv_reg)(void);
+typedef void (*drvmgr_drv_reg_func)(void);
 /*** DRIVER | DEVICE | BUS FUNCTIONS ***/
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index 65f89e6..89d50e7 100644
--- a/cpukit/libdrvmgr/drvmgr_confdefs.h
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -24,244 +24,173 @@
 extern "C" {
 #endif
-extern struct drvmgr_drv_reg_func drvmgr_drivers[];
+extern drvmgr_drv_reg_func drvmgr_drivers[];
 #ifdef CONFIGURE_INIT
 /*** AMBA Plug & Play Drivers ***/
-#define DRIVER_AMBAPP_GAISLER_GPTIMER_REG {gptimer_register_drv}
 extern void gptimer_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_APBUART_REG {apbuart_cons_register_drv}
-#define DRIVER_AMBAPP_GAISLER_GRETH_REG {greth_register_drv}
 extern void greth_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRSPW_REG {grspw_register_drv}
 extern void grspw_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRSPW2_REG {grspw2_register_drv}
 extern void grspw2_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRCAN_REG {grcan_register_drv}
 extern void grcan_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_OCCAN_REG {occan_register_drv}
 extern void occan_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GR1553B_REG {gr1553_register}
 extern void gr1553_register(void);
-#define DRIVER_AMBAPP_GAISLER_GR1553BC_REG {gr1553bc_register}
 extern void gr1553bc_register(void);
-#define DRIVER_AMBAPP_GAISLER_GR1553BM_REG {gr1553bm_register}
 extern void gr1553bm_register(void);
-#define DRIVER_AMBAPP_GAISLER_GR1553RT_REG {gr1553rt_register}
 extern void gr1553rt_register(void);
-#define DRIVER_AMBAPP_GAISLER_B1553BRM_REG {b1553brm_register_drv}
 extern void b1553brm_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_B1553RT_REG {b1553rt_register_drv}
 extern void b1553rt_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRTM_REG {grtm_register_drv}
 extern void grtm_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRTC_REG {grtc_register_drv}
 extern void grtc_register_drv(void);
-#define DRIVER_AMBAPP_MCTRL_REG {mctrl_register_drv}
-extern void mctrl_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_PCIF_REG {pcif_register_drv}
 extern void pcif_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRPCI_REG {grpci_register_drv}
 extern void grpci_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRPCI2_REG {grpci2_register_drv}
+extern void mctrl_register_drv(void);
 extern void grpci2_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_SPICTRL_REG {spictrl_register_drv}
 extern void spictrl_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_I2CMST_REG {i2cmst_register_drv}
 extern void i2cmst_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRGPIO_REG {grgpio_register_drv}
 extern void grgpio_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRPWM_REG {grpwm_register_drv}
 extern void grpwm_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_GRADCDAC_REG {gradcdac_register_drv}
 extern void gradcdac_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_SPWCUC_REG {spwcuc_register}
 extern void spwcuc_register(void);
-#define DRIVER_AMBAPP_GAISLER_GRCTM_REG {grctm_register}
 extern void grctm_register(void);
-#define DRIVER_AMBAPP_GAISLER_SPW_ROUTER_REG {router_register_drv}
 extern void router_register_drv(void);
-#define DRIVER_AMBAPP_GAISLER_AHBSTAT_REG {ahbstat_register_drv}
 extern void ahbstat_register_drv(void);
 /*** LEON2 AMBA Hard coded bus Drivers ***/
-#define DRIVER_LEON2_AT697PCI_REG {at697pci_register_drv}
 extern void at697pci_register_drv(void);
-#define DRIVER_LEON2_AMBAPP_REG {ambapp_leon2_register}
 extern void ambapp_leon2_register(void);
 /*** PCI Bus Drivers (PCI Target drivers) ***/
-#define DRIVER_PCI_GR_RASTA_ADCDAC {gr_rasta_adcdac_register_drv}
 extern void gr_rasta_adcdac_register_drv(void);
-#define DRIVER_PCI_GR_RASTA_IO {gr_rasta_io_register_drv}
 extern void gr_rasta_io_register_drv(void);
-#define DRIVER_PCI_GR_RASTA_TMTC {gr_rasta_tmtc_register_drv}
 extern void gr_rasta_tmtc_register_drv(void);
-#define DRIVER_PCI_GR_701 {gr701_register_drv}
 extern void gr701_register_drv(void);
-#define DRIVER_PCI_GR_TMTC_1553 {gr_tmtc_1553_register_drv}
 extern void gr_tmtc_1553_register_drv(void);
-#define DRIVER_PCI_GR_RASTA_SPW_ROUTER {gr_rasta_spw_router_register_drv}
 extern void gr_rasta_spw_router_register_drv(void);
-#define DRIVER_PCI_GR_LEON4_N2X {gr_cpci_leon4_n2x_register_drv}
 extern void gr_cpci_leon4_n2x_register_drv(void);
 /* CONFIGURE DRIVER MANAGER */
-struct drvmgr_drv_reg_func drvmgr_drivers[] = {
+drvmgr_drv_reg_func drvmgr_drivers[] = {
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GPTIMER
-	DRIVER_AMBAPP_GAISLER_GPTIMER_REG,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_APBUART
-	DRIVER_AMBAPP_GAISLER_APBUART_REG,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRETH
-	DRIVER_AMBAPP_GAISLER_GRETH_REG,
+	greth_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRSPW
-	DRIVER_AMBAPP_GAISLER_GRSPW_REG,
+	grspw_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRSPW2
-	DRIVER_AMBAPP_GAISLER_GRSPW2_REG,
+	grspw2_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRCAN
-	DRIVER_AMBAPP_GAISLER_GRCAN_REG,
+	grcan_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_OCCAN
-	DRIVER_AMBAPP_GAISLER_OCCAN_REG,
+	occan_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553B
-	DRIVER_AMBAPP_GAISLER_GR1553B_REG,
+	gr1553_register,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553BC
-	DRIVER_AMBAPP_GAISLER_GR1553BC_REG,
+	gr1553bc_register,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553BM
-	DRIVER_AMBAPP_GAISLER_GR1553BM_REG,
+	gr1553bm_register,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GR1553RT
-	DRIVER_AMBAPP_GAISLER_GR1553RT_REG,
+	gr1553rt_register,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_B1553BRM
-	DRIVER_AMBAPP_GAISLER_B1553BRM_REG,
+	b1553brm_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_B1553RT
-	DRIVER_AMBAPP_GAISLER_B1553RT_REG,
+	b1553rt_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRTM
-	DRIVER_AMBAPP_GAISLER_GRTM_REG,
+	grtm_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRTC
-	DRIVER_AMBAPP_GAISLER_GRTC_REG,
+	grtc_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_PCIF
-	DRIVER_AMBAPP_GAISLER_PCIF_REG,
+	pcif_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPCI
-	DRIVER_AMBAPP_GAISLER_GRPCI_REG,
+	grpci_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPCI2
-	DRIVER_AMBAPP_GAISLER_GRPCI2_REG,
+	grpci2_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_MCTRL
-	DRIVER_AMBAPP_MCTRL_REG,
+	mctrl_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPICTRL
-	DRIVER_AMBAPP_GAISLER_SPICTRL_REG,
+	spictrl_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_I2CMST
-	DRIVER_AMBAPP_GAISLER_I2CMST_REG,
+	i2cmst_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRGPIO
-	DRIVER_AMBAPP_GAISLER_GRGPIO_REG,
+	grgpio_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRPWM
-	DRIVER_AMBAPP_GAISLER_GRPWM_REG,
+	grpwm_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRADCDAC
-	DRIVER_AMBAPP_GAISLER_GRADCDAC_REG,
+	gradcdac_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPWCUC
-	DRIVER_AMBAPP_GAISLER_SPWCUC_REG,
+	spwcuc_register,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRCTM
-	DRIVER_AMBAPP_GAISLER_GRCTM_REG,
+	grctm_register,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_SPW_ROUTER
-	DRIVER_AMBAPP_GAISLER_SPW_ROUTER_REG,
+	router_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_AHBSTAT
-	DRIVER_AMBAPP_GAISLER_AHBSTAT_REG,
+	ahbstat_register_drv,
 #endif
 	/*** LEON2 AMBA Drivers ***/
 #ifdef CONFIGURE_DRIVER_LEON2_AT697PCI
-	DRIVER_LEON2_AT697PCI_REG,
+	at697pci_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_LEON2_AMBAPP
-	DRIVER_LEON2_AMBAPP_REG,
+	ambapp_leon2_register,
 #endif
 	/*** PCI Target Drivers ***/
 #ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_ADCDAC
-	DRIVER_PCI_GR_RASTA_ADCDAC,
+	gr_rasta_adcdac_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_IO
-	DRIVER_PCI_GR_RASTA_IO,
+	gr_rasta_io_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_TMTC
-	DRIVER_PCI_GR_RASTA_TMTC,
+	gr_rasta_tmtc_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_PCI_GR_701
-	DRIVER_PCI_GR_701,
+	gr701_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_PCI_GR_TMTC_1553
-	DRIVER_PCI_GR_TMTC_1553,
+	gr_tmtc_1553_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_PCI_GR_RASTA_SPW_ROUTER
-	DRIVER_PCI_GR_RASTA_SPW_ROUTER,
+	gr_rasta_spw_router_register_drv,
 #endif
 #ifdef CONFIGURE_DRIVER_PCI_GR_LEON4_N2X
-	DRIVER_PCI_GR_LEON4_N2X,
+	gr_cpci_leon4_n2x_register_drv,
 #endif
1.7.0.4
