[PATCH] or1ksim: Fix bug at UART driver.
Hesham ALMatary
heshamelmatary at gmail.com
Tue Apr 14 13:11:19 UTC 2015
Fix some UART register addresses and implementation bugs that
were causing malfunction of console driver on real hardware.
hello and ticker samples are tested and working fine now on mor1kx
based SoC on Atlys FPGA board.
BSP_OR1K_OR1KSIM_PERIPHCLK has been changed to 50MHz as with mor1kx/atlys
SoC; this change has no effect on the current simulators that RTEMS run
on.
c/src/lib/libbsp/or1k/or1ksim/configure.ac | 2 +-
c/src/lib/libbsp/or1k/or1ksim/console/uart.c | 36 +++++++++----------------
c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h | 8 +++---
3 files changed, 17 insertions(+), 29 deletions(-)
diff --git a/c/src/lib/libbsp/or1k/or1ksim/configure.ac b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
index 85d9698..70f76f1 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/configure.ac
+++ b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
@@ -16,7 +16,7 @@ RTEMS_BSP_CONFIGURE
RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
-RTEMS_BSPOPTS_SET([BSP_OR1K_OR1KSIM_PERIPHCLK],[*],[100000000U])
+RTEMS_BSPOPTS_SET([BSP_OR1K_OR1KSIM_PERIPHCLK],[*],[50000000U])
RTEMS_BSPOPTS_HELP([BSP_OR1K_OR1KSIM_PERIPHCLK],[or1ksim PERIPHCLK clock frequency in Hz])
RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm])
diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
index bb86bae..4389949 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
+++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
@@ -46,39 +46,34 @@ static uint32_t uart_get_baud(const console_tbl *ct)
static void uart_set_baud(int baud)
- int divisor = (OR1KSIM_BSP_CLOCK_FREQ) / (16 * baud);
- OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) |=
+ uint16_t divisor = (OR1KSIM_BSP_CLOCK_FREQ) / (16 * baud);
+ OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) =
OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB;
OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW) = divisor & 0xff;
OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH) =
- (divisor >> 8) & 0xff;
- OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) &=
- ~(OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB);
+ (divisor >> 8);
static void uart_initialize(int minor)
- /* Disable all interrupts */
- OR1KSIM_REG(OR1KSIM_BSP_UART_REG_INT_ENABLE) = 0x00;
+ /* Set baud rate */
+ uart_set_baud(OR1KSIM_UART_DEFAULT_BAUD);
+ /* Set data pattern configuration */
+ OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8;
/* Reset receiver and transmitter */
OR1KSIM_REG(OR1KSIM_BSP_UART_REG_FIFO_CTRL) =
OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO |
OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR |
- OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT |
OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14;
- /* Set data pattern configuration */
- OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) =
- OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8 &
- (OR1KSIM_BSP_UART_REG_LINE_CTRL_STOP |
- OR1KSIM_BSP_UART_REG_LINE_CTRL_PARITY);
+ /* Disable all interrupts */
+ OR1KSIM_REG(OR1KSIM_BSP_UART_REG_INT_ENABLE) = 0x00;
- /* Set baud rate */
- uart_set_baud(OR1KSIM_UART_DEFAULT_BAUD);
static int uart_first_open(int major, int minor, void *arg)
@@ -115,21 +110,14 @@ static int uart_read_polled(int minor)
static void uart_write_polled(int minor, char c)
unsigned char lsr;
- const uint32_t transmit_finished =
- (OR1KSIM_BSP_UART_REG_LINE_STATUS_TEMT |
- OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE);
/* Wait until there is no pending data in the transmitter FIFO (empty) */
do {
lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
} while (!(lsr & OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE));
OR1KSIM_REG(OR1KSIM_BSP_UART_REG_TX) = c;
- /* Wait until trasmit data is finished */
- do {
- lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
- } while ( (lsr & transmit_finished) != transmit_finished );
static ssize_t uart_write(
diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
index 8279566..e5354dd 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
+++ b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
@@ -35,7 +35,7 @@
- #define OR1KSIM_REG(x) (*((volatile char *) (x)))
+ #define OR1KSIM_REG(x) (*((volatile unsigned char *) (x)))
#define OR1KSIM_BIT(n) (1 << (n))
@@ -45,14 +45,14 @@
-#define OR1KSIM_BSP_CLOCK_FREQ 100000000UL
+#define OR1KSIM_BSP_CLOCK_FREQ 50000000UL
#define OR1KSIM_BSP_UART_BASE 0x90000000
#define OR1KSIM_BSP_UART_REG_TX (OR1KSIM_BSP_UART_BASE+0)
#define OR1KSIM_BSP_UART_REG_RX (OR1KSIM_BSP_UART_BASE+0)
-#define OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW (OR1KSIM_BSP_UART_BASE+1)
+#define OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW (OR1KSIM_BSP_UART_BASE+0)
#define OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH (OR1KSIM_BSP_UART_BASE+1)
-#define OR1KSIM_BSP_UART_REG_INT_ENABLE (OR1KSIM_BSP_UART_BASE+2)
+#define OR1KSIM_BSP_UART_REG_INT_ENABLE (OR1KSIM_BSP_UART_BASE+1)
#define OR1KSIM_BSP_UART_REG_INT_ID (OR1KSIM_BSP_UART_BASE+2)
#define OR1KSIM_BSP_UART_REG_FIFO_CTRL (OR1KSIM_BSP_UART_BASE+2)
#define OR1KSIM_BSP_UART_REG_LINE_CTRL (OR1KSIM_BSP_UART_BASE+3)
2.1.0
