[PATCH] or1ksim: Fix bug at UART driver.
Tue Apr 14 15:12:37 UTC 2015
I don't know why but this didn't apply for me. Some
error at line 97 of the patch.
Can you try again?
On 4/14/2015 8:11 AM, Hesham ALMatary wrote:
> Fix some UART register addresses and implementation bugs that
> were causing malfunction of console driver on real hardware.
> hello and ticker samples are tested and working fine now on mor1kx
> based SoC on Atlys FPGA board.
> BSP_OR1K_OR1KSIM_PERIPHCLK has been changed to 50MHz as with mor1kx/atlys
> SoC; this change has no effect on the current simulators that RTEMS run
> on.
>  c/src/lib/libbsp/or1k/or1ksim/configure.ac      |  2 +-
>  c/src/lib/libbsp/or1k/or1ksim/console/uart.c    | 36 +++++++++----------------
>  c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h |  8 +++---
>  3 files changed, 17 insertions(+), 29 deletions(-)
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/configure.ac b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
> index 85d9698..70f76f1 100644
> --- a/c/src/lib/libbsp/or1k/or1ksim/configure.ac
> +++ b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
> @@ -16,7 +16,7 @@ RTEMS_BSP_CONFIGURE
>  RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
>  RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
> -RTEMS_BSPOPTS_SET([BSP_OR1K_OR1KSIM_PERIPHCLK],[*],[100000000U])
> +RTEMS_BSPOPTS_SET([BSP_OR1K_OR1KSIM_PERIPHCLK],[*],[50000000U])
>  RTEMS_BSPOPTS_HELP([BSP_OR1K_OR1KSIM_PERIPHCLK],[or1ksim PERIPHCLK clock frequency in Hz])
>  RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm])
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> index bb86bae..4389949 100644
> --- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> @@ -46,39 +46,34 @@ static uint32_t uart_get_baud(const console_tbl *ct)
>  static void uart_set_baud(int baud)
> -  int divisor = (OR1KSIM_BSP_CLOCK_FREQ) / (16 * baud);
> -  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) |=
> +  uint16_t divisor = (OR1KSIM_BSP_CLOCK_FREQ) / (16 * baud);
> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) =
>      OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB;
>    OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW) = divisor & 0xff;
>    OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH) =
> -    (divisor >> 8) & 0xff;
> -  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) &=
> -    ~(OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB);
> +    (divisor >> 8);
>  static void uart_initialize(int minor)
> -  /* Disable all interrupts */
> -  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_INT_ENABLE) = 0x00;
> +  /* Set baud rate */
> +  uart_set_baud(OR1KSIM_UART_DEFAULT_BAUD);
> +  /* Set data pattern configuration */
> +    OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8;
>    /* Reset receiver and transmitter */
>    OR1KSIM_REG(OR1KSIM_BSP_UART_REG_FIFO_CTRL) =
>      OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO |
>      OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR  |
> -    OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT  |
>      OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14;
> -  /* Set data pattern configuration */
> -  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) =
> -    OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8 &
> -      (OR1KSIM_BSP_UART_REG_LINE_CTRL_STOP |
> -       OR1KSIM_BSP_UART_REG_LINE_CTRL_PARITY);
> +  /* Disable all interrupts */
> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_INT_ENABLE) = 0x00;
> -  /* Set baud rate */
> -  uart_set_baud(OR1KSIM_UART_DEFAULT_BAUD);
>  static int uart_first_open(int major, int minor, void *arg)
> @@ -115,21 +110,14 @@ static int uart_read_polled(int minor)
>  static void uart_write_polled(int minor, char c)
>    unsigned char lsr;
> -  const uint32_t transmit_finished =
> -    (OR1KSIM_BSP_UART_REG_LINE_STATUS_TEMT |
> -     OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE);
>    /* Wait until there is no pending data in the transmitter FIFO (empty) */
>    do {
>        lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
>    } while (!(lsr & OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE));
>    OR1KSIM_REG(OR1KSIM_BSP_UART_REG_TX) = c;
> -  /* Wait until trasmit data is finished */
> -  do {
> -      lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
> -  } while ( (lsr & transmit_finished) != transmit_finished );
>  static ssize_t uart_write(
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
> index 8279566..e5354dd 100644
> --- a/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
> @@ -35,7 +35,7 @@
> - #define OR1KSIM_REG(x)           (*((volatile char *) (x)))
> + #define OR1KSIM_REG(x)           (*((volatile unsigned char *) (x)))
>   #define OR1KSIM_BIT(n)           (1 << (n))
> @@ -45,14 +45,14 @@
> -#define OR1KSIM_BSP_CLOCK_FREQ       100000000UL
> +#define OR1KSIM_BSP_CLOCK_FREQ       50000000UL
>  #define OR1KSIM_BSP_UART_BASE        0x90000000
>  #define OR1KSIM_BSP_UART_REG_TX              (OR1KSIM_BSP_UART_BASE+0)
>  #define OR1KSIM_BSP_UART_REG_RX              (OR1KSIM_BSP_UART_BASE+0)
> -#define OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW   (OR1KSIM_BSP_UART_BASE+1)
> +#define OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW   (OR1KSIM_BSP_UART_BASE+0)
>  #define OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH  (OR1KSIM_BSP_UART_BASE+1)
> -#define OR1KSIM_BSP_UART_REG_INT_ENABLE      (OR1KSIM_BSP_UART_BASE+2)
> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE      (OR1KSIM_BSP_UART_BASE+1)
>  #define OR1KSIM_BSP_UART_REG_INT_ID          (OR1KSIM_BSP_UART_BASE+2)
>  #define OR1KSIM_BSP_UART_REG_FIFO_CTRL       (OR1KSIM_BSP_UART_BASE+2)
>  #define OR1KSIM_BSP_UART_REG_LINE_CTRL       (OR1KSIM_BSP_UART_BASE+3)
> -- 2.1.0 _______________________________________________ devel mailing
> list devel at rtems.org http://lists.rtems.org/mailman/listinfo/devel
