[rtems commit] sp13: Update configuration to account for messages on fourth message queue
Sebastian Huber
Wed Apr 15 06:49:17 UTC 2015
Two message queues get deleted before the forth is created. Why did this
work before and what is the root cause for this failure? We will never
know after this patch.
On 14/04/15 21:08, Joel Sherril wrote:
> Module: rtems
> Branch: master
> Commit: 351858d75327d5bbda7e720157dced706bbe5688
> Changeset: http://git.rtems.org/rtems/commit/?id=351858d75327d5bbda7e720157dced706bbe5688
> Author: Joel Sherrill <joel.sherrill at oarcorp.com>
> Date: Tue Apr 14 14:07:35 2015 -0500
> testsuites/sptests/sp13/system.h | 6 +++++-
> testsuites/sptests/sp13/task1.c | 1 +
> 2 files changed, 6 insertions(+), 1 deletion(-)
> diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
> index 7bb680c..3b170bf 100644
> --- a/testsuites/sptests/sp13/system.h
> +++ b/testsuites/sptests/sp13/system.h
> @@ -65,10 +65,14 @@ TEST_EXTERN rtems_name Queue_name[ 4 ]; /* array of queue names */
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> + * First three created in init.c, last created in task1.c.
> #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
> CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
> CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + \
> - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE )
> + CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
> + CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 )
> #define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
> diff --git a/testsuites/sptests/sp13/task1.c b/testsuites/sptests/sp13/task1.c
> index e783e37..e104e8d 100644
> --- a/testsuites/sptests/sp13/task1.c
> +++ b/testsuites/sptests/sp13/task1.c
> @@ -267,6 +267,7 @@ rtems_test_pause();
> &Queue_id[ 1 ]
> directive_failed( status, "rtems_message_queue_create of Q1; 20 bytes each" );
> status = rtems_message_queue_send( Queue_id[ 1 ], big_send_buffer, 40 );
> fatal_directive_status(status,
> RTEMS_INVALID_SIZE,
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
