[rtems commit] sp13: Update configuration to account for messages on fourth message queue
Gedare Bloom gedare at gwu.edu
Wed Apr 15 17:13:19 UTC 2015
On Wed, Apr 15, 2015 at 2:49 AM, Sebastian Huber
> Two message queues get deleted before the forth is created. Why did this
> work before and what is the root cause for this failure? We will never know
> after this patch.
Yes I don't understand what this is fixing. The test, or the failure?
> On 14/04/15 21:08, Joel Sherril wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    351858d75327d5bbda7e720157dced706bbe5688
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=351858d75327d5bbda7e720157dced706bbe5688
>> Author:    Joel Sherrill <joel.sherrill at oarcorp.com>
>> Date:      Tue Apr 14 14:07:35 2015 -0500
>>   testsuites/sptests/sp13/system.h | 6 +++++-
>>   testsuites/sptests/sp13/task1.c  | 1 +
>>   2 files changed, 6 insertions(+), 1 deletion(-)
>> diff --git a/testsuites/sptests/sp13/system.h
>> b/testsuites/sptests/sp13/system.h
>> index 7bb680c..3b170bf 100644
>> --- a/testsuites/sptests/sp13/system.h
>> +++ b/testsuites/sptests/sp13/system.h
>> @@ -65,10 +65,14 @@ TEST_EXTERN rtems_name Queue_name[ 4 ];      /* array
>> of queue names */
>>     #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> + *  First three created in init.c, last created in task1.c.
>>   #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
>>      CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
>>      CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + \
>> -   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE )
>> +   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
>> +   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 )
>>     #define CONFIGURE_EXTRA_TASK_STACKS         (3 *
>> RTEMS_MINIMUM_STACK_SIZE)
>>   diff --git a/testsuites/sptests/sp13/task1.c
>> b/testsuites/sptests/sp13/task1.c
>> index e783e37..e104e8d 100644
>> --- a/testsuites/sptests/sp13/task1.c
>> +++ b/testsuites/sptests/sp13/task1.c
>> @@ -267,6 +267,7 @@ rtems_test_pause();
>>       &Queue_id[ 1 ]
>>     directive_failed( status, "rtems_message_queue_create of Q1; 20 bytes
>> each" );
>>     status = rtems_message_queue_send( Queue_id[ 1 ], big_send_buffer, 40
>>     fatal_directive_status(status,
>>       RTEMS_INVALID_SIZE,
>> vc mailing list
>> vc at rtems.org
>> http://lists.rtems.org/mailman/listinfo/vc
> devel mailing list
> devel at rtems.org
