[rtems commit] sp13: Update configuration to account for messages on fourth message queue
Wed Apr 15 19:21:52 UTC 2015
Abusing this topic more, this is the complete analysis. I missed the
final loop of create/delete queue. This is the comment in system.h
I have now.
 *  Created in init.c:
 *    Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) (1600)
 *    Q2 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE )   (160)
 *    Q3 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) (1600)
 *  Q1 and Q2 deleted in task1.c
 *  Q1 recreated in task1.c
 *    Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 )           (2000)
 *  Q1 deleted again in task1.c.
 *  Q1 repeatedly created and deleted for 2 messages of 1-1030 bytes
 *  in length
 *    Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 1030, 2 )           (2000)
 *  Thus the peak message memory needed is technically only:
 *      Q3 + third instance of Q1 at peak of two 1030 byte messages.
#define CONFIGURE_MESSAGE_BUFFER_MEMORY \
   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
On 4/15/2015 1:30 PM, Joel Sherrill wrote:
> On 4/15/2015 12:13 PM, Gedare Bloom wrote:
>> On Wed, Apr 15, 2015 at 2:49 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> Two message queues get deleted before the forth is created. Why did this
>>> work before and what is the root cause for this failure? We will never know
>>> after this patch.
>> Yes I don't understand what this is fixing. The test, or the failure?
> Yes. The test under reserves. Here is a more detailed analysis:
> For the purposes of this analysis, I am ignoring the overhead per
> allocation.
> Before the patch, the configuration was for the initial Q1-Q3 for 3360
> bytes.
> MESSAGE_SIZE is a constant in system.h and 16
>                             NEED TOTAL AVAILABLE
>                                     0    3360
> Q1 - 100 * MESSAGE_SIZE ==> 1600 1600    1760
> Q2 -  10 * MESSAGE_SIZE ==>  160 1760    1600
> Q3 - 100 * MESSAGE_SIZE ==> 1600 3360       0
>   delete Q1                      1760    1600
>   delete Q2                      1600    1760
> Q1 - 100 * 20           ==> 2000
> Since the second instance of Q1 needs more than the first instance,
> it fails.
> Current patch technically over reserves.
> Since second instance of Q1 needs more than the first instance,
> we could get by with Q1 second instance, Q2, and Q3 as the
> reservation.
> Obviously this would need a comment.
> Do you want me to change it that way?
>>> On 14/04/15 21:08, Joel Sherril wrote:
>>>> Module:    rtems
>>>> Branch:    master
>>>> Commit:    351858d75327d5bbda7e720157dced706bbe5688
>>>> Changeset:
>>>> http://git.rtems.org/rtems/commit/?id=351858d75327d5bbda7e720157dced706bbe5688
>>>> Author:    Joel Sherrill <joel.sherrill at oarcorp.com>
>>>> Date:      Tue Apr 14 14:07:35 2015 -0500
>>>>   testsuites/sptests/sp13/system.h | 6 +++++-
>>>>   testsuites/sptests/sp13/task1.c  | 1 +
>>>>   2 files changed, 6 insertions(+), 1 deletion(-)
>>>> diff --git a/testsuites/sptests/sp13/system.h
>>>> b/testsuites/sptests/sp13/system.h
>>>> index 7bb680c..3b170bf 100644
>>>> --- a/testsuites/sptests/sp13/system.h
>>>> +++ b/testsuites/sptests/sp13/system.h
>>>> @@ -65,10 +65,14 @@ TEST_EXTERN rtems_name Queue_name[ 4 ];      /* array
>>>> of queue names */
>>>>     #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>> + *  First three created in init.c, last created in task1.c.
>>>>      CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + \
>>>> +   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
>>>> +   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 )
>>>>     #define CONFIGURE_EXTRA_TASK_STACKS         (3 *
>>>> RTEMS_MINIMUM_STACK_SIZE)
>>>>   diff --git a/testsuites/sptests/sp13/task1.c
>>>> b/testsuites/sptests/sp13/task1.c
>>>> index e783e37..e104e8d 100644
>>>> --- a/testsuites/sptests/sp13/task1.c
>>>> +++ b/testsuites/sptests/sp13/task1.c
>>>> @@ -267,6 +267,7 @@ rtems_test_pause();
>>>>       &Queue_id[ 1 ]
>>>>     directive_failed( status, "rtems_message_queue_create of Q1; 20 bytes
>>>> each" );
>>>>     status = rtems_message_queue_send( Queue_id[ 1 ], big_send_buffer, 40
>>>>     fatal_directive_status(status,
>>>>       RTEMS_INVALID_SIZE,
>>>> _______________________________________________
>>>> vc mailing list
>>>> vc at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/vc
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
