[PING][PATCH v2] Change the assert in _Thread_Dispatch_decrement_disable_level
Martin Galvan
martin.galvan at tallertechnologies.com
Thu Apr 16 14:27:51 UTC 2015
While cpu_self->thread_dispatch_disable_level shouldn't ever be zero, it would be better to check it before doing the decrement.
Changes in v2:
* Modified the asserts as requested in https://lists.rtems.org/pipermail/devel/2015-February/009821.html.
cpukit/score/src/threaddispatchdisablelevel.c | 6 +++++-
1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
index 158fc39..6043fe7 100644
--- a/cpukit/score/src/threaddispatchdisablelevel.c
+++ b/cpukit/score/src/threaddispatchdisablelevel.c
@@ -107,11 +107,15 @@ uint32_t _Thread_Dispatch_decrement_disable_level( void )
cpu_self = _Per_CPU_Get();
disable_level = cpu_self->thread_dispatch_disable_level;
+ _Assert( disable_level > 0);
--disable_level;
cpu_self->thread_dispatch_disable_level = disable_level;
_Giant_Do_release( cpu_self );
- _Assert( disable_level != 0 || _Giant.owner_cpu != cpu_self );
+ _Assert( ( disable_level == 0 && _Giant.owner_cpu != cpu_self )
+ || ( disable_level != 0 && _Giant.owner_cpu == cpu_self )
_Profiling_Thread_dispatch_enable( cpu_self, disable_level );
_ISR_Enable_without_giant( isr_level );
2.3.4
