[PATCH] sp13: Document message buffer usage and adjust configuration
Thu Apr 16 16:14:39 UTC 2015
Do you have any intuition to answer Sebastian's concern about why this
test suddenly exposed a problem? (git-bisect?)
On Thu, Apr 16, 2015 at 11:55 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
>  testsuites/sptests/sp13/system.h | 31 ++++++++++++++++++++++++++-----
>  1 file changed, 26 insertions(+), 5 deletions(-)
> diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
> index 3b170bf..f879096 100644
> --- a/testsuites/sptests/sp13/system.h
> +++ b/testsuites/sptests/sp13/system.h
> @@ -66,13 +66,34 @@ TEST_EXTERN rtems_name Queue_name[ 4 ];      /* array of queue names */
>  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> - *  First three created in init.c, last created in task1.c.
> + *  Created in init.c:
> + *    Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) (1600)
> + *    Q2 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE )   (160)
> + *    Q3 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) (1600)
> + *  Q1 and Q2 deleted in task1.c.
> + *  Q1 recreated in task1.c:
> + *    Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 )           (2000)
> + *  Q1 deleted again in task1.c.
> + *  Q1 repeatedly created and deleted for 2 messages of 1-1030 bytes
> + *  in length. Account for peak usage:
> + *    Q1 - CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 2, 1030 )           (2060)
> + *  Because each message requires memory for the message plus two
> + *  pointers to place the buffer on lists, it is easier to just
> + *  allocate memory for all the message queues. But we can safely
> + *  ignore Q2 and the last instance of Q1 since enough memory is
> + *  free when the third instance of Q1 is created.
>  #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
> -   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
> -   CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + \
> +   /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
> +   /* Q2 */ /* CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 10, MESSAGE_SIZE ) + */ \
> +   /* Q3 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, MESSAGE_SIZE ) + \
> +   /* Q1 */ CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 100, 20 ) + \
> +   /* Q1 */ /* CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( 2,  1030 ) */
>  #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
> 1.9.3
> devel mailing list
> devel at rtems.org
