[PATCH 1/4] score: Add header to _Watchdog_Remove()
Fri Apr 17 08:55:09 UTC 2015
Add watchdog header parameter to _Watchdog_Remove() to be in line with
the other operations.  Add _Watchdog_Remove_ticks() and
_Watchdog_Remove_seconds() for convenience.
Update #2307.
 cpukit/posix/src/alarm.c                        |  2 +-
 cpukit/posix/src/psignalunblockthread.c         |  2 +-
 cpukit/posix/src/pthread.c                      |  2 +-
 cpukit/posix/src/pthreadsetschedparam.c         |  4 ++--
 cpukit/posix/src/timerdelete.c                  |  2 +-
 cpukit/posix/src/timerinserthelper.c            |  2 +-
 cpukit/posix/src/timersettime.c                 |  2 +-
 cpukit/posix/src/ualarm.c                       |  2 +-
 cpukit/rtems/include/rtems/rtems/timerimpl.h    | 13 ++++++++++---
 cpukit/rtems/src/eventseize.c                   |  2 +-
 cpukit/rtems/src/eventsurrender.c               |  2 +-
 cpukit/rtems/src/ratemoncancel.c                |  2 +-
 cpukit/rtems/src/ratemondelete.c                |  2 +-
 cpukit/rtems/src/timercancel.c                  |  3 +--
 cpukit/rtems/src/timercreate.c                  | 21 +++++++++++++++++++++
 cpukit/rtems/src/timerdelete.c                  |  2 +-
 cpukit/rtems/src/timerfireafter.c               |  2 +-
 cpukit/rtems/src/timerfirewhen.c                |  2 +-
 cpukit/rtems/src/timerreset.c                   |  2 +-
 cpukit/rtems/src/timerserver.c                  | 19 ++++++++++++++++---
 cpukit/rtems/src/timerserverfireafter.c         |  2 +-
 cpukit/rtems/src/timerserverfirewhen.c          |  2 +-
 cpukit/score/include/rtems/score/mrspimpl.h     |  2 +-
 cpukit/score/include/rtems/score/watchdogimpl.h | 18 +++++++++++++++++-
 cpukit/score/src/threadqenqueue.c               |  2 +-
 cpukit/score/src/threadrestart.c                |  4 ++--
 cpukit/score/src/watchdogremove.c               |  1 +
 cpukit/score/src/watchdogtickle.c               |  2 +-
 testsuites/sptests/spintrcritical08/init.c      |  2 +-
 testsuites/sptests/spintrcritical09/init.c      |  2 +-
 30 files changed, 92 insertions(+), 35 deletions(-)
diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
index 4803661..6f051d7 100644
--- a/cpukit/posix/src/alarm.c
+++ b/cpukit/posix/src/alarm.c
@@ -73,7 +73,7 @@ unsigned int alarm(
   _Thread_Disable_dispatch();
-  state = _Watchdog_Remove( the_timer );
+  state = _Watchdog_Remove_seconds( the_timer );
   if ( (state == WATCHDOG_ACTIVE) || (state == WATCHDOG_REMOVE_IT) ) {
      *  The stop_time and start_time fields are snapshots of ticks since
diff --git a/cpukit/posix/src/psignalunblockthread.c b/cpukit/posix/src/psignalunblockthread.c
index c56c150..bb7600c 100644
--- a/cpukit/posix/src/psignalunblockthread.c
+++ b/cpukit/posix/src/psignalunblockthread.c
@@ -117,7 +117,7 @@ bool _POSIX_signals_Unblock_thread(
        if ( _States_Is_waiting_on_thread_queue(the_thread->current_state) )
          _Thread_queue_Extract_with_proxy( the_thread );
        else if ( _States_Is_delaying(the_thread->current_state) ) {
-          (void) _Watchdog_Remove( &the_thread->Timer );
+          _Watchdog_Remove_ticks( &the_thread->Timer );
           _Thread_Unblock( the_thread );
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 6b1e555..bafa151 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -287,7 +287,7 @@ static void _POSIX_Threads_Terminate_extension(
       *(void **)the_thread->Wait.return_argument = value_ptr;
   if ( api->schedpolicy == SCHED_SPORADIC )
-    (void) _Watchdog_Remove( &api->Sporadic_timer );
+    _Watchdog_Remove_ticks( &api->Sporadic_timer );
   _Thread_Enable_dispatch();
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index d5d0a5b..dcb70bd 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -70,7 +70,7 @@ int pthread_setschedparam(
       api = the_thread->API_Extensions[ THREAD_API_POSIX ];
       api->schedpolicy = policy;
       api->schedparam  = *param;
@@ -99,7 +99,7 @@ int pthread_setschedparam(
         case SCHED_SPORADIC:
           api->ss_high_priority = api->schedparam.sched_priority;
-          _Watchdog_Remove( &api->Sporadic_timer );
           _POSIX_Threads_Sporadic_budget_TSR( 0, the_thread );
           break;
diff --git a/cpukit/posix/src/timerdelete.c b/cpukit/posix/src/timerdelete.c
index 71b25fa..e090be2 100644
--- a/cpukit/posix/src/timerdelete.c
+++ b/cpukit/posix/src/timerdelete.c
@@ -54,7 +54,7 @@ int timer_delete(
     case OBJECTS_LOCAL:
       _Objects_Close( &_POSIX_Timer_Information, &ptimer->Object );
       ptimer->state = POSIX_TIMER_STATE_FREE;
-      (void) _Watchdog_Remove( &ptimer->Timer );
+      _Watchdog_Remove_ticks( &ptimer->Timer );
       _Objects_Put( &ptimer->Object );
       _POSIX_Timer_Free( ptimer );
       _Objects_Allocator_unlock();
diff --git a/cpukit/posix/src/timerinserthelper.c b/cpukit/posix/src/timerinserthelper.c
index 9d02835..4d7c3fb 100644
--- a/cpukit/posix/src/timerinserthelper.c
+++ b/cpukit/posix/src/timerinserthelper.c
@@ -39,7 +39,7 @@ bool _POSIX_Timer_Insert_helper(
   ISR_Level            level;
-  (void) _Watchdog_Remove( timer );
+  _Watchdog_Remove_ticks( timer );
   _ISR_Disable( level );
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index 6cc3780..2967df6 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -85,7 +85,7 @@ int timer_settime(
       /* First, it verifies if the timer must be stopped */
       if ( normalize.it_value.tv_sec == 0 && normalize.it_value.tv_nsec == 0 ) {
          /* Stop the timer */
          /* The old data of the timer are returned */
          if ( ovalue )
            *ovalue = ptimer->timer_data;
diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
index d9a85e6..9235ef1 100644
--- a/cpukit/posix/src/ualarm.c
+++ b/cpukit/posix/src/ualarm.c
@@ -72,7 +72,7 @@ useconds_t ualarm(
+  state = _Watchdog_Remove_ticks( the_timer );
diff --git a/cpukit/rtems/include/rtems/rtems/timerimpl.h b/cpukit/rtems/include/rtems/rtems/timerimpl.h
index b695d5e..4f200ef 100644
--- a/cpukit/rtems/include/rtems/rtems/timerimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/timerimpl.h
@@ -50,9 +50,9 @@ extern "C" {
 typedef struct Timer_server_Control Timer_server_Control;
- * @brief Method used to schedule the insertion of task based timers.
+ * @brief Method used for task based timers.
-typedef void (*Timer_server_Schedule_operation)(
+typedef void (*Timer_server_Method)(
   Timer_server_Control *timer_server,
   Timer_Control        *timer
@@ -84,9 +84,14 @@ struct Timer_server_Control {
   Thread_Control *thread;
+   * @brief The cancel method of the timer server.
+  Timer_server_Method cancel;
    * @brief The schedule operation method of the timer server.
-  Timer_server_Schedule_operation schedule_operation;
+  Timer_server_Method schedule_operation;
    * @brief Interval watchdogs triggered by the timer server.
@@ -220,6 +225,8 @@ RTEMS_INLINE_ROUTINE bool _Timer_Is_dormant_class (
   return ( the_class == TIMER_DORMANT );
+void _Timer_Cancel( Timer_Control *the_timer );
 #ifdef __cplusplus
diff --git a/cpukit/rtems/src/eventseize.c b/cpukit/rtems/src/eventseize.c
index 59a2b62..3a0a050 100644
--- a/cpukit/rtems/src/eventseize.c
+++ b/cpukit/rtems/src/eventseize.c
@@ -108,7 +108,7 @@ void _Event_Seize(
     wait_class | THREAD_WAIT_STATE_BLOCKED
   if ( !success ) {
-    _Watchdog_Remove( &executing->Timer );
+    _Watchdog_Remove_ticks( &executing->Timer );
     _Thread_Unblock( executing );
diff --git a/cpukit/rtems/src/eventsurrender.c b/cpukit/rtems/src/eventsurrender.c
index 824912b..74bafc8 100644
--- a/cpukit/rtems/src/eventsurrender.c
+++ b/cpukit/rtems/src/eventsurrender.c
@@ -111,7 +111,7 @@ void _Event_Surrender(
     _Giant_Acquire( cpu_self );
-    _Watchdog_Remove( &the_thread->Timer );
     _Giant_Release( cpu_self );
diff --git a/cpukit/rtems/src/ratemoncancel.c b/cpukit/rtems/src/ratemoncancel.c
index d4a9102..67b230f 100644
--- a/cpukit/rtems/src/ratemoncancel.c
+++ b/cpukit/rtems/src/ratemoncancel.c
@@ -38,7 +38,7 @@ rtems_status_code rtems_rate_monotonic_cancel(
         _Objects_Put( &the_period->Object );
         return RTEMS_NOT_OWNER_OF_RESOURCE;
-      (void) _Watchdog_Remove( &the_period->Timer );
+      _Watchdog_Remove_ticks( &the_period->Timer );
       the_period->state = RATE_MONOTONIC_INACTIVE;
       _Scheduler_Release_job( the_period->owner, 0 );
diff --git a/cpukit/rtems/src/ratemondelete.c b/cpukit/rtems/src/ratemondelete.c
index 971ad8e..77cf3fe 100644
--- a/cpukit/rtems/src/ratemondelete.c
+++ b/cpukit/rtems/src/ratemondelete.c
@@ -37,7 +37,7 @@ rtems_status_code rtems_rate_monotonic_delete(
     case OBJECTS_LOCAL:
       _Objects_Close( &_Rate_monotonic_Information, &the_period->Object );
       _Rate_monotonic_Free( the_period );
diff --git a/cpukit/rtems/src/timercancel.c b/cpukit/rtems/src/timercancel.c
index a8ce147..1e737a2 100644
--- a/cpukit/rtems/src/timercancel.c
+++ b/cpukit/rtems/src/timercancel.c
@@ -45,8 +45,7 @@ rtems_status_code rtems_timer_cancel(
   switch ( location ) {
     case OBJECTS_LOCAL:
-      if ( !_Timer_Is_dormant_class( the_timer->the_class ) )
-        (void) _Watchdog_Remove( &the_timer->Ticker );
+      _Timer_Cancel( the_timer );
       _Objects_Put( &the_timer->Object );
       return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index 0b1c44b..390c965 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -25,6 +25,27 @@
 #include <rtems/rtems/timerimpl.h>
+  Timer_server_Control *timer_server;
+  switch ( the_timer->the_class ) {
+    case TIMER_INTERVAL:
+      _Watchdog_Remove_ticks( &the_timer->Ticker );
+      break;
+    case TIMER_TIME_OF_DAY:
+      _Watchdog_Remove_seconds( &the_timer->Ticker );
+      break;
+    case TIMER_INTERVAL_ON_TASK:
+    case TIMER_TIME_OF_DAY_ON_TASK:
+      timer_server = _Timer_server;
+      (*timer_server->cancel)( timer_server, the_timer );
+      break;
+    default:
+      break;
 rtems_status_code rtems_timer_create(
   rtems_name  name,
   rtems_id   *id
diff --git a/cpukit/rtems/src/timerdelete.c b/cpukit/rtems/src/timerdelete.c
index 19232c8..0849ec5 100644
--- a/cpukit/rtems/src/timerdelete.c
+++ b/cpukit/rtems/src/timerdelete.c
@@ -38,7 +38,7 @@ rtems_status_code rtems_timer_delete(
     case OBJECTS_LOCAL:
       _Objects_Close( &_Timer_Information, &the_timer->Object );
       _Timer_Free( the_timer );
diff --git a/cpukit/rtems/src/timerfireafter.c b/cpukit/rtems/src/timerfireafter.c
index 07862cd..84cf46b 100644
--- a/cpukit/rtems/src/timerfireafter.c
+++ b/cpukit/rtems/src/timerfireafter.c
@@ -46,7 +46,7 @@ rtems_status_code rtems_timer_fire_after(
     case OBJECTS_LOCAL:
diff --git a/cpukit/rtems/src/timerfirewhen.c b/cpukit/rtems/src/timerfirewhen.c
index 6ac7d17..1acbaf9 100644
--- a/cpukit/rtems/src/timerfirewhen.c
+++ b/cpukit/rtems/src/timerfirewhen.c
@@ -51,7 +51,7 @@ rtems_status_code rtems_timer_fire_when(
     case OBJECTS_LOCAL:
       the_timer->the_class = TIMER_TIME_OF_DAY;
       _Watchdog_Initialize( &the_timer->Ticker, routine, id, user_data );
       _Watchdog_Insert_seconds(
diff --git a/cpukit/rtems/src/timerreset.c b/cpukit/rtems/src/timerreset.c
index 49c4925..7ab172e 100644
--- a/cpukit/rtems/src/timerreset.c
+++ b/cpukit/rtems/src/timerreset.c
@@ -67,7 +67,7 @@ rtems_status_code rtems_timer_reset(
             return RTEMS_INCORRECT_STATE;
         #endif
-        _Watchdog_Remove( &the_timer->Ticker );
         (*timer_server->schedule_operation)( timer_server, the_timer );
       } else {
diff --git a/cpukit/rtems/src/timerserver.c b/cpukit/rtems/src/timerserver.c
index 25191e4..15cbdfd 100644
--- a/cpukit/rtems/src/timerserver.c
+++ b/cpukit/rtems/src/timerserver.c
@@ -38,7 +38,7 @@ static void _Timer_server_Stop_interval_system_watchdog(
   Timer_server_Control *ts
-  _Watchdog_Remove( &ts->Interval_watchdogs.System_watchdog );
+  _Watchdog_Remove_ticks( &ts->Interval_watchdogs.System_watchdog );
 static void _Timer_server_Reset_interval_system_watchdog(
@@ -71,7 +71,7 @@ static void _Timer_server_Stop_tod_system_watchdog(
-  _Watchdog_Remove( &ts->TOD_watchdogs.System_watchdog );
+  _Watchdog_Remove_seconds( &ts->TOD_watchdogs.System_watchdog );
 static void _Timer_server_Reset_tod_system_watchdog(
@@ -210,6 +210,18 @@ static void _Timer_server_Insert_timer_and_make_snapshot(
+static void _Timer_server_Cancel_method(
+  Timer_server_Control *ts,
+  Timer_Control *timer
+  if ( timer->the_class == TIMER_INTERVAL_ON_TASK ) {
+    _Watchdog_Remove( &ts->Interval_watchdogs.Header, &timer->Ticker );
+  } else if ( timer->the_class == TIMER_TIME_OF_DAY_ON_TASK ) {
+    _Watchdog_Remove( &ts->TOD_watchdogs.Header, &timer->Ticker );
 static void _Timer_server_Schedule_operation_method(
@@ -563,9 +575,10 @@ rtems_status_code rtems_timer_initiate_server(
-   *  Initialize the pointer to the timer schedule method so applications that
+   *  Initialize the pointer to the timer server methods so applications that
    *  do not use the Timer Server do not have to pull it in.
+  ts->cancel = _Timer_server_Cancel_method;
   ts->schedule_operation = _Timer_server_Schedule_operation_method;
   ts->Interval_watchdogs.last_snapshot = _Watchdog_Ticks_since_boot;
diff --git a/cpukit/rtems/src/timerserverfireafter.c b/cpukit/rtems/src/timerserverfireafter.c
index 1256645..0636782 100644
--- a/cpukit/rtems/src/timerserverfireafter.c
+++ b/cpukit/rtems/src/timerserverfireafter.c
@@ -50,7 +50,7 @@ rtems_status_code rtems_timer_server_fire_after(
     case OBJECTS_LOCAL:
diff --git a/cpukit/rtems/src/timerserverfirewhen.c b/cpukit/rtems/src/timerserverfirewhen.c
index 32695fb..0069af1 100644
--- a/cpukit/rtems/src/timerserverfirewhen.c
+++ b/cpukit/rtems/src/timerserverfirewhen.c
@@ -72,7 +72,7 @@ rtems_status_code rtems_timer_server_fire_when(
     case OBJECTS_LOCAL:
       the_timer->the_class = TIMER_TIME_OF_DAY_ON_TASK;
       the_timer->Ticker.initial = seconds - _TOD_Seconds_since_epoch();
diff --git a/cpukit/score/include/rtems/score/mrspimpl.h b/cpukit/score/include/rtems/score/mrspimpl.h
index c1e05e4..afeacf4 100644
--- a/cpukit/score/include/rtems/score/mrspimpl.h
+++ b/cpukit/score/include/rtems/score/mrspimpl.h
@@ -216,7 +216,7 @@ RTEMS_INLINE_ROUTINE MRSP_Status _MRSP_Wait_for_ownership(
   _Thread_Set_life_protection( initial_life_protection );
   if ( timeout > 0 ) {
   return status;
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index e548e7025..ddd1ca4 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -99,10 +99,12 @@ void _Watchdog_Handler_initialization( void );
  *  This routine removes @a the_watchdog from the watchdog chain on which
  *  it resides and returns the state @a the_watchdog timer was in.
+ *  @param[in] header The watchdog chain.
  *  @param[in] the_watchdog will be removed
  *  @retval the state in which @a the_watchdog was in when removed
 Watchdog_States _Watchdog_Remove (
+  Watchdog_Header  *header,
   Watchdog_Control *the_watchdog
@@ -306,6 +308,20 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Insert_seconds(
+RTEMS_INLINE_ROUTINE Watchdog_States _Watchdog_Remove_ticks(
+  Watchdog_Control *the_watchdog
+  return _Watchdog_Remove( &_Watchdog_Ticks_header, the_watchdog );
+RTEMS_INLINE_ROUTINE Watchdog_States _Watchdog_Remove_seconds(
+  return _Watchdog_Remove( &_Watchdog_Seconds_header, the_watchdog );
  * This routine resets THE_WATCHDOG timer to its state at INSERT
  * time.  This routine is valid only on interval watchdog timers
@@ -318,7 +334,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Reset_ticks(
-  (void) _Watchdog_Remove( the_watchdog );
+  _Watchdog_Remove_ticks( the_watchdog );
   _Watchdog_Insert( &_Watchdog_Ticks_header, the_watchdog );
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index c059556..9203186 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -66,7 +66,7 @@ static void _Thread_blocking_operation_Finalize(
   if ( _Watchdog_Is_active( &the_thread->Timer ) ) {
     _Watchdog_Deactivate( &the_thread->Timer );
     _Thread_queue_Release( lock_context );
   } else
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index e759b5b..8dea518 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -62,7 +62,7 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
   _Thread_Set_state( the_thread, STATES_ZOMBIE );
   _ISR_lock_ISR_disable_and_acquire( &zombies->Lock, &lock_context );
   _Chain_Append_unprotected( &zombies->Chain, &the_thread->Object.Node );
@@ -235,7 +235,7 @@ static void _Thread_Start_life_change(
   _Thread_Set_state( the_thread, STATES_RESTARTING );
   _Scheduler_Set_priority_if_higher( scheduler, the_thread, priority );
   _Thread_Add_post_switch_action( the_thread, &the_thread->Life.Action );
   _Thread_Ready( the_thread );
diff --git a/cpukit/score/src/watchdogremove.c b/cpukit/score/src/watchdogremove.c
index 34d97b0..d689e3c 100644
--- a/cpukit/score/src/watchdogremove.c
+++ b/cpukit/score/src/watchdogremove.c
@@ -23,6 +23,7 @@
 Watchdog_States _Watchdog_Remove(
diff --git a/cpukit/score/src/watchdogtickle.c b/cpukit/score/src/watchdogtickle.c
index 8c1a3a7..5b2f258 100644
--- a/cpukit/score/src/watchdogtickle.c
+++ b/cpukit/score/src/watchdogtickle.c
@@ -74,7 +74,7 @@ void _Watchdog_Tickle(
   do {
-     watchdog_state = _Watchdog_Remove( the_watchdog );
+     watchdog_state = _Watchdog_Remove( header, the_watchdog );
      _ISR_Enable( level );
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index 13544b2..f375cd4 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -55,7 +55,7 @@ static rtems_timer_service_routine test_release_from_isr(
       watchdog->delta_interval == 0
         && watchdog->routine == _Rate_monotonic_Timeout
-      Watchdog_States state = _Watchdog_Remove( watchdog );
+      Watchdog_States state = _Watchdog_Remove_ticks( watchdog );
       rtems_test_assert( state == WATCHDOG_ACTIVE );
       (*watchdog->routine)( watchdog->id, watchdog->user_data );
diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
index 2f9caa5..0e38351 100644
--- a/testsuites/sptests/spintrcritical09/init.c
+++ b/testsuites/sptests/spintrcritical09/init.c
@@ -52,7 +52,7 @@ static rtems_timer_service_routine test_release_from_isr(
         && watchdog->routine == _Thread_queue_Timeout
1.8.4.5
