[PATCH v2] score: Refactor SMP cache manager support
Sebastian Huber
Fri Apr 17 11:10:41 UTC 2015
v2: Update missing instruction routines. Test smpcache01 passes on NGMP.
c/src/lib/libcpu/shared/src/cache_manager.c | 224 +++++++---------------------
cpukit/score/Makefile.am | 1 +
cpukit/score/include/rtems/score/smpimpl.h | 33 +++-
cpukit/score/src/smpmulticastaction.c | 141 +++++++++++++++++
testsuites/smptests/smpcache01/init.c | 23 +--
5 files changed, 225 insertions(+), 197 deletions(-)
create mode 100644 cpukit/score/src/smpmulticastaction.c
diff --git a/c/src/lib/libcpu/shared/src/cache_manager.c b/c/src/lib/libcpu/shared/src/cache_manager.c
index 89ec88f..ab7d5b7 100644
--- a/c/src/lib/libcpu/shared/src/cache_manager.c
+++ b/c/src/lib/libcpu/shared/src/cache_manager.c
@@ -37,161 +37,43 @@
#include "cache_.h"
-#include <rtems/score/smpimpl.h>
-#include <rtems/score/smplock.h>
-#include <rtems/score/chainimpl.h>
-#include <rtems/score/sysstate.h>
-#if defined( RTEMS_SMP )
+#if defined(RTEMS_SMP)
-typedef void (*Cache_manager_Function_ptr)(const void *d_addr, size_t n_bytes);
+#include <rtems/score/smpimpl.h>
typedef struct {
- Chain_Node Node;
- Cache_manager_Function_ptr func;
const void *addr;
size_t size;
- cpu_set_t *recipients;
- size_t setsize;
- Atomic_Ulong done;
-} Cache_manager_SMP_node;
-typedef struct {
- SMP_lock_Control Lock;
- Chain_Control List;
-} Cache_manager_SMP_control;
+} smp_cache_area;
-static Cache_manager_SMP_control _Cache_manager_SMP_control = {
- .Lock = SMP_LOCK_INITIALIZER("cachemgr"),
- .List = CHAIN_INITIALIZER_EMPTY(_Cache_manager_SMP_control.List)
+#if defined(CPU_DATA_CACHE_ALIGNMENT)
-void
-_SMP_Cache_manager_message_handler(void)
+static void smp_cache_data_flush(void *arg)
- SMP_lock_Context lock_context;
- Cache_manager_SMP_node *node;
- Cache_manager_SMP_node *next;
- uint32_t cpu_self_idx;
- _SMP_lock_ISR_disable_and_acquire( &_Cache_manager_SMP_control.Lock,
- &lock_context );
- cpu_self_idx = _SMP_Get_current_processor();
- node = (Cache_manager_SMP_node*)_Chain_First(
- &_Cache_manager_SMP_control.List );
- while ( !_Chain_Is_tail( &_Cache_manager_SMP_control.List, &node->Node ) ) {
- next = (Cache_manager_SMP_node*)_Chain_Next( &node->Node );
- if ( CPU_ISSET_S ( cpu_self_idx, node->setsize, node->recipients ) ) {
- CPU_CLR_S ( cpu_self_idx, node->setsize, node->recipients );
- node->func( node->addr, node->size );
- if ( CPU_COUNT_S( node->setsize, node->recipients ) == 0 ) {
- _Chain_Extract_unprotected( &node->Node );
- _Atomic_Store_ulong( &node->done, 1, ATOMIC_ORDER_RELEASE );
- node = next;
+ smp_cache_area *area = arg;
- _SMP_lock_Release_and_ISR_enable( &_Cache_manager_SMP_control.Lock,
- &lock_context );
+ rtems_cache_flush_multiple_data_lines(area->addr, area->size);
-#if defined(CPU_DATA_CACHE_ALIGNMENT) || \
- (defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) && \
- defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING))
-static void
-_Cache_manager_Process_cache_messages( void )
+static void smp_cache_data_inv(void *arg)
- unsigned long message;
- Per_CPU_Control *cpu_self;
- ISR_Level isr_level;
- _ISR_Disable_without_giant( isr_level );
- cpu_self = _Per_CPU_Get();
- message = _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED );
- if ( message & SMP_MESSAGE_CACHE_MANAGER ) {
- if ( _Atomic_Compare_exchange_ulong( &cpu_self->message, &message,
- message & ~SMP_MESSAGE_CACHE_MANAGER, ATOMIC_ORDER_RELAXED,
- ATOMIC_ORDER_RELAXED ) ) {
- _SMP_Cache_manager_message_handler();
- _ISR_Enable_without_giant( isr_level );
+ rtems_cache_invalidate_multiple_data_lines(area->addr, area->size);
- * We can not make this function static as we need to access it
- * from the test program.
-void
-_Cache_manager_Send_smp_msg(
- const size_t setsize,
- const cpu_set_t *set,
- Cache_manager_Function_ptr func,
- const void * addr,
- size_t size
-void
- size_t size
+static void smp_cache_data_flush_all(void *arg)
- uint32_t i;
- Cache_manager_SMP_node node;
- size_t set_size = CPU_ALLOC_SIZE( _SMP_Get_processor_count() );
- char cpu_set_copy[set_size];
- if ( ! _System_state_Is_up( _System_state_Get() ) ) {
- func( addr, size );
- return;
- memset( cpu_set_copy, 0, set_size );
- if( set == NULL ) {
- for( i=0; i<_SMP_Get_processor_count(); ++i )
- CPU_SET_S( i, set_size, (cpu_set_t *)cpu_set_copy );
- } else {
- if( CPU_ISSET_S( i, set_size, set ) )
- node.func = func;
- node.addr = addr;
- node.size = size;
- node.setsize = set_size;
- node.recipients = (cpu_set_t *)cpu_set_copy;
- _Atomic_Store_ulong( &node.done, 0, ATOMIC_ORDER_RELAXED );
- &lock_context );
- _Chain_Prepend_unprotected( &_Cache_manager_SMP_control.List, &node.Node );
- &lock_context );
- _SMP_Send_message_multicast( set_size, node.recipients,
- SMP_MESSAGE_CACHE_MANAGER );
- _Cache_manager_Process_cache_messages();
+ rtems_cache_flush_entire_data();
- while ( !_Atomic_Load_ulong( &node.done, ATOMIC_ORDER_ACQUIRE ) );
+static void smp_cache_data_inv_all(void *arg)
+ rtems_cache_invalidate_entire_data();
-#endif
+#endif /* defined(CPU_DATA_CACHE_ALIGNMENT) */
void
rtems_cache_flush_multiple_data_lines_processor_set(
@@ -202,8 +84,9 @@ rtems_cache_flush_multiple_data_lines_processor_set(
- _Cache_manager_Send_smp_msg( setsize, set,
- rtems_cache_flush_multiple_data_lines, addr, size );
+ smp_cache_area area = { addr, size };
+ _SMP_Multicast_action( setsize, set, smp_cache_data_flush, &area );
#endif
@@ -216,8 +99,9 @@ rtems_cache_invalidate_multiple_data_lines_processor_set(
- rtems_cache_invalidate_multiple_data_lines, addr, size );
+ _SMP_Multicast_action( setsize, set, smp_cache_data_inv, &area );
#endif
@@ -228,8 +112,7 @@ rtems_cache_flush_entire_data_processor_set(
- (Cache_manager_Function_ptr)rtems_cache_flush_entire_data, 0, 0 );
+ _SMP_Multicast_action( setsize, set, smp_cache_data_flush_all, NULL );
#endif
@@ -240,11 +123,11 @@ rtems_cache_invalidate_entire_data_processor_set(
- (Cache_manager_Function_ptr)rtems_cache_invalidate_entire_data, 0, 0 );
+ _SMP_Multicast_action( setsize, set, smp_cache_data_inv_all, NULL );
#endif
-#endif
+#endif /* defined(RTEMS_SMP) */
* THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE A DATA CACHE
@@ -427,6 +310,23 @@ rtems_cache_disable_data( void )
* THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE AN INSTRUCTION CACHE
+#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT) \
+ && defined(RTEMS_SMP) \
+ && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
+static void smp_cache_inst_inv(void *arg)
+ _CPU_cache_invalidate_instruction_range(area->addr, area->size);
+static void smp_cache_inst_inv_all(void *arg)
+ _CPU_cache_invalidate_entire_instruction();
+#endif
@@ -435,10 +335,10 @@ rtems_cache_disable_data( void )
* and then perform the invalidations.
-#if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
-#if !defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
+ && !defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
static void
-_invalidate_multiple_instruction_lines_no_range_functions(
+_CPU_cache_invalidate_instruction_range(
const void * i_addr,
size_t n_bytes
@@ -463,7 +363,6 @@ _invalidate_multiple_instruction_lines_no_range_functions(
#endif
-#endif
void
rtems_cache_invalidate_multiple_instruction_lines(
@@ -472,25 +371,12 @@ rtems_cache_invalidate_multiple_instruction_lines(
-#if defined(CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS)
#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
- _Cache_manager_Send_smp_msg( 0, 0, _CPU_cache_invalidate_instruction_range,
- i_addr, n_bytes );
-#else
- _CPU_cache_invalidate_instruction_range( i_addr, n_bytes );
-#endif
-#else
+ smp_cache_area area = { i_addr, n_bytes };
-#if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
- _invalidate_multiple_instruction_lines_no_range_functions, i_addr,
- n_bytes );
+ _SMP_Multicast_action( 0, NULL, smp_cache_inst_inv, &area );
#else
- _invalidate_multiple_instruction_lines_no_range_functions( i_addr, n_bytes );
-#endif
+ _CPU_cache_invalidate_instruction_range( i_addr, n_bytes );
#endif
#endif
@@ -504,14 +390,8 @@ void
rtems_cache_invalidate_entire_instruction( void )
- * Call the CPU-specific routine
- (Cache_manager_Function_ptr)_CPU_cache_invalidate_entire_instruction,
- 0, 0 );
+ _SMP_Multicast_action( 0, NULL, smp_cache_inst_inv_all, NULL );
#else
#endif
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index e84d4e5..487ccc0 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -139,6 +139,7 @@ libscore_a_SOURCES += src/schedulerprioritysmp.c
libscore_a_SOURCES += src/schedulersimplesmp.c
libscore_a_SOURCES += src/schedulersmpdebug.c
libscore_a_SOURCES += src/smp.c
+libscore_a_SOURCES += src/smpmulticastaction.c
libscore_a_SOURCES += src/cpuset.c
libscore_a_SOURCES += src/cpusetprintsupport.c
libscore_a_SOURCES += src/schedulerdefaultaskforhelp.c
diff --git a/cpukit/score/include/rtems/score/smpimpl.h b/cpukit/score/include/rtems/score/smpimpl.h
index 98e109c..97c78b0 100644
--- a/cpukit/score/include/rtems/score/smpimpl.h
+++ b/cpukit/score/include/rtems/score/smpimpl.h
@@ -52,11 +52,11 @@ extern "C" {
#define SMP_MESSAGE_TEST 0x2UL
- * @brief SMP message to request a cache manager invocation.
+ * @brief SMP message to request a multicast action.
* @see _SMP_Send_message().
-#define SMP_MESSAGE_CACHE_MANAGER 0x4UL
+#define SMP_MESSAGE_MULTICAST_ACTION 0x4UL
* @brief SMP fatal codes.
@@ -135,10 +135,9 @@ static inline void _SMP_Set_test_message_handler(
- * @brief Handles cache invalidation/flush requests from a remote processor.
+ * @brief Processes all pending multicast actions.
-void _SMP_Cache_manager_message_handler( void );
+void _SMP_Multicast_actions_process( void );
* @brief Interrupt handler for inter-processor interrupts.
@@ -163,10 +162,9 @@ static inline void _SMP_Inter_processor_interrupt_handler( void )
( *_SMP_Test_message_handler )( cpu_self );
- if ( ( message & SMP_MESSAGE_CACHE_MANAGER ) != 0 ) {
+ if ( ( message & SMP_MESSAGE_MULTICAST_ACTION ) != 0 ) {
+ _SMP_Multicast_actions_process();
@@ -220,6 +218,25 @@ void _SMP_Send_message_multicast(
+typedef void ( *SMP_Multicast_action_handler )( void *arg );
+ * @brief Initiates a SMP multicast action to a set of processors.
+ * The current processor may be part of the set.
+ * @param[in] setsize The size of the set of target processors of the message.
+ * @param[in] cpus The set of target processors of the message.
+ * @param[in] handler The multicast action handler.
+ * @param[in] arg The multicast action argument.
+void _SMP_Multicast_action(
+ const size_t setsize,
+ const cpu_set_t *cpus,
+ SMP_Multicast_action_handler handler,
+ void *arg
#endif /* defined( RTEMS_SMP ) */
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
new file mode 100644
index 0000000..2e59262
--- /dev/null
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -0,0 +1,141 @@
+ * Copyright (c) 2014 Aeroflex Gaisler AB. All rights reserved.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/smplock.h>
+#include <rtems/score/chainimpl.h>
+#include <rtems/score/sysstate.h>
+typedef struct {
+ Chain_Node Node;
+ SMP_Multicast_action_handler handler;
+ void *arg;
+ cpu_set_t *recipients;
+ size_t setsize;
+ Atomic_Ulong done;
+} SMP_Multicast_action;
+typedef struct {
+ SMP_lock_Control Lock;
+ Chain_Control List;
+} SMP_Multicast_action_context;
+static SMP_Multicast_action_context _SMP_Multicast_action_context = {
+ .Lock = SMP_LOCK_INITIALIZER("SMP Multicast Action"),
+ .List = CHAIN_INITIALIZER_EMPTY(_SMP_Multicast_action_context.List)
+void
+_SMP_Multicast_actions_process(void)
+ SMP_lock_Context lock_context;
+ SMP_Multicast_action *node;
+ SMP_Multicast_action *next;
+ uint32_t cpu_self_idx;
+ _SMP_lock_ISR_disable_and_acquire( &_SMP_Multicast_action_context.Lock,
+ &lock_context );
+ cpu_self_idx = _SMP_Get_current_processor();
+ node = (SMP_Multicast_action*)_Chain_First(
+ &_SMP_Multicast_action_context.List );
+ while ( !_Chain_Is_tail( &_SMP_Multicast_action_context.List, &node->Node ) ) {
+ next = (SMP_Multicast_action*)_Chain_Next( &node->Node );
+ if ( CPU_ISSET_S ( cpu_self_idx, node->setsize, node->recipients ) ) {
+ CPU_CLR_S ( cpu_self_idx, node->setsize, node->recipients );
+ node->handler( node->arg );
+ if ( CPU_COUNT_S( node->setsize, node->recipients ) == 0 ) {
+ _Chain_Extract_unprotected( &node->Node );
+ _Atomic_Store_ulong( &node->done, 1, ATOMIC_ORDER_RELEASE );
+ node = next;
+ _SMP_lock_Release_and_ISR_enable( &_SMP_Multicast_action_context.Lock,
+ &lock_context );
+static void
+_SMP_Multicast_actions_try_process( void )
+ unsigned long message;
+ Per_CPU_Control *cpu_self;
+ ISR_Level isr_level;
+ _ISR_Disable_without_giant( isr_level );
+ cpu_self = _Per_CPU_Get();
+ message = _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED );
+ if ( message & SMP_MESSAGE_MULTICAST_ACTION ) {
+ if ( _Atomic_Compare_exchange_ulong( &cpu_self->message, &message,
+ message & ~SMP_MESSAGE_MULTICAST_ACTION, ATOMIC_ORDER_RELAXED,
+ ATOMIC_ORDER_RELAXED ) ) {
+ _ISR_Enable_without_giant( isr_level );
+ void *arg
+ uint32_t i;
+ SMP_Multicast_action node;
+ size_t set_size = CPU_ALLOC_SIZE( _SMP_Get_processor_count() );
+ char cpu_set_copy[set_size];
+ if ( ! _System_state_Is_up( _System_state_Get() ) ) {
+ handler( arg );
+ return;
+ memset( cpu_set_copy, 0, set_size );
+ if( cpus == NULL ) {
+ for( i=0; i<_SMP_Get_processor_count(); ++i )
+ CPU_SET_S( i, set_size, (cpu_set_t *)cpu_set_copy );
+ } else {
+ if( CPU_ISSET_S( i, set_size, cpus ) )
+ node.handler = handler;
+ node.arg = arg;
+ node.setsize = set_size;
+ node.recipients = (cpu_set_t *)cpu_set_copy;
+ _Atomic_Store_ulong( &node.done, 0, ATOMIC_ORDER_RELAXED );
+ &lock_context );
+ _Chain_Prepend_unprotected( &_SMP_Multicast_action_context.List, &node.Node );
+ &lock_context );
+ _SMP_Send_message_multicast( set_size, node.recipients,
+ SMP_MESSAGE_MULTICAST_ACTION );
+ _SMP_Multicast_actions_try_process();
+ while ( !_Atomic_Load_ulong( &node.done, ATOMIC_ORDER_ACQUIRE ) );
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 01d6e1e..7ad2ef9 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -12,6 +12,7 @@
#include <rtems/score/atomic.h>
#include <rtems/score/smpbarrier.h>
#include <limits.h>
@@ -26,17 +27,6 @@ CPU_STRUCTURE_ALIGNMENT static int data_to_flush[1024];
#define WORKER_PRIORITY 100
-void
- size_t size
typedef struct {
SMP_barrier_Control barrier;
uint32_t count[CPU_COUNT];
@@ -51,10 +41,9 @@ static void function_to_flush( void )
/* Does nothing. Used to give a pointer to instruction address space. */
-static void test_cache_message( const void *d_addr, size_t n_bytes )
+static void test_cache_message( void *arg )
- rtems_test_assert(n_bytes == 123);
- rtems_test_assert(d_addr == 0);
+ rtems_test_assert(arg == &ctx);
ctx.count[rtems_get_current_processor()]++;
@@ -111,7 +100,7 @@ static void test_func_test( size_t set_size, cpu_set_t *cpu_set,
ctx.count[rtems_get_current_processor()] = 0;
_SMP_barrier_Wait( &ctx.barrier, bs, rtems_get_processor_count() );
- _Cache_manager_Send_smp_msg( set_size, cpu_set, test_cache_message, 0, 123 );
+ _SMP_Multicast_action( set_size, cpu_set, test_cache_message, &ctx );
@@ -129,7 +118,7 @@ static void test_func_isrdisabled_test( size_t set_size, cpu_set_t *cpu_set,
@@ -149,7 +138,7 @@ static void test_func_giant_taken_test( size_t set_size, cpu_set_t *cpu_set,
1.8.4.5
