[PATCH 3/4] score: Add Watchdog_Iterator
Fri Apr 17 14:20:15 UTC 2015
I will make it static.  This helps to avoid an accidental usage.
----- Gedare Bloom <gedare at rtems.org> schrieb:
> I'm not a big fan of this "watchdog_remove_it" terminology. Can I
> suggest the state be called something else like WATCHDOG_REMOVING or
> maybe WATCHDOG_TRANSIENT, and perhaps the actual removal function be
> renamed _Watchdog_Remove_internal() or something similar? Also, given
> the refactoring here and that this _Watchdog_Remove_it() is only
> called by Watchdog_Remove/Tickle, perhaps it makes sense to put all
> three functions into a single source file and make the Remove_it()
> function static in that file.
> Gedare
> On Fri, Apr 17, 2015 at 4:55 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Rewrite the _Watchdog_Insert(), _Watchdog_Remove() and
> > _Watchdog_Tickle() functions to use interator items to synchronize
> > concurrent operations.  This makes it possible to get rid of the global
> > variables _Watchdog_Sync_level and _Watchdog_Sync_count which are a
> > blocking point for scalable SMP solutions.
> > Update #2307.
> >  cpukit/rtems/src/timercreate.c                  |   6 ++
> >  cpukit/score/include/rtems/score/watchdogimpl.h |  58 ++++++++---
> >  cpukit/score/src/watchdog.c                     |   2 -
> >  cpukit/score/src/watchdoginsert.c               | 112 +++++++++++---------
> >  cpukit/score/src/watchdogremove.c               |  71 ++++++++++---
> >  cpukit/score/src/watchdogtickle.c               | 130 ++++++++----------------
> >  testsuites/sptests/spsize/size.c                |   4 +-
> >  testsuites/sptests/spwatchdog/init.c            | 103 +++++++++++++++++++
> >  8 files changed, 317 insertions(+), 169 deletions(-)
> > diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
> > index 390c965..ef217e9 100644
> > --- a/cpukit/rtems/src/timercreate.c
> > +++ b/cpukit/rtems/src/timercreate.c
> > @@ -28,6 +28,10 @@
> >  void _Timer_Cancel( Timer_Control *the_timer )
> >    Timer_server_Control *timer_server;
> > +  ISR_Level level;
> > +  /* The timer class must not change during the cancel operation */
> > +  _ISR_Disable( level );
> >    switch ( the_timer->the_class ) {
> >      case TIMER_INTERVAL:
> > @@ -44,6 +48,8 @@ void _Timer_Cancel( Timer_Control *the_timer )
> >      default:
> >        break;
> > +  _ISR_Enable( level );
> >  rtems_status_code rtems_timer_create(
> > diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
> > index f52b55d..304392b 100644
> > --- a/cpukit/score/include/rtems/score/watchdogimpl.h
> > +++ b/cpukit/score/include/rtems/score/watchdogimpl.h
> > @@ -46,6 +46,28 @@ extern "C" {
> > + * @brief Iterator item to synchronize concurrent insert, remove and tickle
> > + * operations.
> > +typedef struct {
> > +   * @brief A node for a Watchdog_Header::Iterators chain.
> > +  Chain_Node Node;
> > +   * @brief The current delta interval of the new watchdog to insert.
> > +  Watchdog_Interval delta_interval;
> > +   * @brief The current watchdog of the chain on the way to insert the new
> > +   * watchdog.
> > +  Chain_Node *current;
> > +} Watchdog_Iterator;
> >   * @brief Watchdog header.
> >  typedef struct {
> > @@ -58,23 +80,15 @@ typedef struct {
> >     * @brief The chain of active or transient watchdogs.
> >    Chain_Control Watchdogs;
> > -} Watchdog_Header;
> > - *  @brief Watchdog synchronization level.
> > - *  This used for synchronization purposes
> > - *  during an insert on a watchdog delta chain.
> > -SCORE_EXTERN volatile uint32_t    _Watchdog_Sync_level;
> > - *  @brief Watchdog synchronization count.
> > -SCORE_EXTERN volatile uint32_t    _Watchdog_Sync_count;
> > +   * @brief Currently active iterators.
> > +   * The iterators are registered in _Watchdog_Insert() and updated in case the
> > +   * watchdog chain changes.
> > +  Chain_Control Iterators;
> > +} Watchdog_Header;
> >   *  @brief Watchdog chain which is managed at ticks.
> > @@ -139,6 +153,16 @@ Watchdog_States _Watchdog_Remove (
> > + * @brief Actually removes an WATCHDOG_ACTIVE or WATCHDOG_REMOVE_IT watchdog.
> > + * @see _Watchdog_Remove() and _Watchdog_Tickle().
> > +void _Watchdog_Remove_it(
> > +  Watchdog_Header  *header,
> > +  Watchdog_Control *the_watchdog
> >   *  @brief Adjusts the header watchdog chain in the backward direction for
> >   *  units ticks.
> > @@ -437,7 +461,9 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Header_initialize(
> > +  _ISR_lock_Initialize( &header->Lock, "Watchdog" );
> >    _Chain_Initialize_empty( &header->Watchdogs );
> > +  _Chain_Initialize_empty( &header->Iterators );
> > diff --git a/cpukit/score/src/watchdog.c b/cpukit/score/src/watchdog.c
> > index 0db60ef..11d3cf2 100644
> > --- a/cpukit/score/src/watchdog.c
> > +++ b/cpukit/score/src/watchdog.c
> > @@ -25,8 +25,6 @@
> >  void _Watchdog_Handler_initialization( void )
> > -  _Watchdog_Sync_count = 0;
> > -  _Watchdog_Sync_level = 0;
> >    _Watchdog_Ticks_since_boot = 0;
> >    _Watchdog_Header_initialize( &_Watchdog_Ticks_header );
> > diff --git a/cpukit/score/src/watchdoginsert.c b/cpukit/score/src/watchdoginsert.c
> > index 0ad59ff..6d2df82 100644
> > --- a/cpukit/score/src/watchdoginsert.c
> > +++ b/cpukit/score/src/watchdoginsert.c
> > @@ -19,76 +19,92 @@
> >  #endif
> >  #include <rtems/score/watchdogimpl.h>
> > -#include <rtems/score/isrlevel.h>
> > -#include <rtems/score/percpu.h>
> > -void _Watchdog_Insert(
> > -  Watchdog_Header       *header,
> > -  Watchdog_Control      *the_watchdog
> > +static void _Watchdog_Insert_fixup(
> > +  Watchdog_Control  *next_watchdog,
> > -  ISR_lock_Context   lock_context;
> > -  Watchdog_Control  *after;
> > -  uint32_t           insert_isr_nest_level;
> > -  Watchdog_Interval  delta_interval;
> > +  const Chain_Node *iterator_tail;
> > +  Chain_Node       *iterator_node;
> > +  next_watchdog->delta_interval -= delta;
> > -  insert_isr_nest_level   = _ISR_Nest_level;
> > +  iterator_node = _Chain_First( &header->Iterators );
> > +  iterator_tail = _Chain_Immutable_tail( &header->Iterators );
> > -  _Watchdog_Acquire( header, &lock_context );
> > +  while ( iterator_node != iterator_tail ) {
> > +    Watchdog_Iterator *iterator;
> > -   *  Check to see if the watchdog has just been inserted by a
> > -   *  higher priority interrupt.  If so, abandon this insert.
> > +    iterator = (Watchdog_Iterator *) iterator_node;
> > -  if ( the_watchdog->state != WATCHDOG_INACTIVE ) {
> > -    _Watchdog_Release( header, &lock_context );
> > -    return;
> > +    if ( iterator->current == &next_watchdog->Node ) {
> > +      iterator->delta_interval -= delta;
> > +    iterator_node = _Chain_Next( iterator_node );
> > -  the_watchdog->state = WATCHDOG_BEING_INSERTED;
> > -  _Watchdog_Sync_count++;
> > +void _Watchdog_Insert(
> > +  ISR_lock_Context lock_context;
> > -restart:
> > -  delta_interval = the_watchdog->initial;
> > +  _Watchdog_Acquire( header, &lock_context );
> > -  for ( after = _Watchdog_First( header ) ;
> > -        after = _Watchdog_Next( after ) ) {
> > +  if ( the_watchdog->state == WATCHDOG_INACTIVE ) {
> > +    Watchdog_Iterator  iterator;
> > +    Chain_Node        *next;
> > +    Watchdog_Interval  delta;
> > -     if ( delta_interval == 0 || !_Watchdog_Next( after ) )
> > -       break;
> > +    the_watchdog->state = WATCHDOG_BEING_INSERTED;
> > -     if ( delta_interval < after->delta_interval ) {
> > -       after->delta_interval -= delta_interval;
> > -       break;
> > +    _Chain_Append_unprotected( &header->Iterators, &iterator.Node );
> > -     delta_interval -= after->delta_interval;
> > +    delta = the_watchdog->initial;
> > +    current = _Chain_Head( &header->Watchdogs );
> > -     _Watchdog_Flash( header, &lock_context );
> > +    while (
> > +      ( next = _Chain_Next( current ) ) != _Chain_Tail( &header->Watchdogs )
> > +      Watchdog_Control  *next_watchdog;
> > +      Watchdog_Interval  delta_next;
> > -     if ( the_watchdog->state != WATCHDOG_BEING_INSERTED ) {
> > -       goto exit_insert;
> > +      next_watchdog = (Watchdog_Control *) next;
> > +      delta_next = next_watchdog->delta_interval;
> > -     if ( _Watchdog_Sync_level > insert_isr_nest_level ) {
> > -       _Watchdog_Sync_level = insert_isr_nest_level;
> > -       goto restart;
> > +      if ( delta < delta_next ) {
> > +        _Watchdog_Insert_fixup( header, next_watchdog, delta );
> > +        break;
> > +      iterator.delta_interval = delta - delta_next;
> > +      iterator.current = next;
> > -  _Watchdog_Activate( the_watchdog );
> > +      _Watchdog_Flash( header, &lock_context );
> > -  the_watchdog->delta_interval = delta_interval;
> > +      if ( the_watchdog->state != WATCHDOG_BEING_INSERTED ) {
> > +        goto abort_insert;
> > -  _Chain_Insert_unprotected( after->Node.previous, &the_watchdog->Node );
> > +      delta = iterator.delta_interval;
> > +      current = iterator.current;
> > -  the_watchdog->start_time = _Watchdog_Ticks_since_boot;
> > +    the_watchdog->delta_interval = delta;
> > +    the_watchdog->start_time = _Watchdog_Ticks_since_boot;
> > +    _Watchdog_Activate( the_watchdog );
> > +    _Chain_Insert_unprotected( current, &the_watchdog->Node );
> > +abort_insert:
> > +    _Chain_Extract_unprotected( &iterator.Node );
> > -exit_insert:
> > -  _Watchdog_Sync_count--;
> > diff --git a/cpukit/score/src/watchdogremove.c b/cpukit/score/src/watchdogremove.c
> > index c765ac5..c896fbb 100644
> > --- a/cpukit/score/src/watchdogremove.c
> > +++ b/cpukit/score/src/watchdogremove.c
> > @@ -18,9 +18,58 @@
> >  #include "config.h"
> >  #endif
> > -#include <rtems/system.h>
> > -#include <rtems/score/isr.h>
> > +#include <rtems/score/assert.h>
> > +  Chain_Node        *next;
> > +  _Assert(
> > +    the_watchdog->state == WATCHDOG_ACTIVE
> > +      || the_watchdog->state == WATCHDOG_REMOVE_IT
> > +  the_watchdog->state = WATCHDOG_INACTIVE;
> > +  the_watchdog->stop_time = _Watchdog_Ticks_since_boot;
> > +  next = _Chain_Next( &the_watchdog->Node );
> > +  delta = the_watchdog->delta_interval;
> > +  if ( next != _Chain_Tail( &header->Watchdogs ) ) {
> > +    next_watchdog->delta_interval += delta;
> > +  _Chain_Extract_unprotected( &the_watchdog->Node );
> > +    if ( iterator->current == next ) {
> > +      iterator->delta_interval += delta;
> > +    if ( iterator->current == &the_watchdog->Node ) {
> > +      iterator->current = _Chain_Previous( &the_watchdog->Node );
> >  Watchdog_States _Watchdog_Remove(
> > @@ -29,7 +78,7 @@ Watchdog_States _Watchdog_Remove(
> >    Watchdog_States   previous_state;
> > -  Watchdog_Control *next_watchdog;
> > +  Watchdog_Interval now;
> >    previous_state = the_watchdog->state;
> > @@ -44,24 +93,16 @@ Watchdog_States _Watchdog_Remove(
> >         *  the Insert operation we interrupted will be aborted.
> > +      now = _Watchdog_Ticks_since_boot;
> > +      the_watchdog->start_time = now;
> > +      the_watchdog->stop_time = now;
> >        break;
> >      case WATCHDOG_ACTIVE:
> >      case WATCHDOG_REMOVE_IT:
> > -      the_watchdog->state = WATCHDOG_INACTIVE;
> > -      next_watchdog = _Watchdog_Next( the_watchdog );
> > -      if ( _Watchdog_Next(next_watchdog) )
> > -        next_watchdog->delta_interval += the_watchdog->delta_interval;
> > -      if ( _Watchdog_Sync_count )
> > -        _Watchdog_Sync_level = _ISR_Nest_level;
> > -      _Chain_Extract_unprotected( &the_watchdog->Node );
> > +      _Watchdog_Remove_it( header, the_watchdog );
> >        break;
> > -  the_watchdog->stop_time = _Watchdog_Ticks_since_boot;
> >    return( previous_state );
> > diff --git a/cpukit/score/src/watchdogtickle.c b/cpukit/score/src/watchdogtickle.c
> > index 2092010..2ae4f94 100644
> > --- a/cpukit/score/src/watchdogtickle.c
> > +++ b/cpukit/score/src/watchdogtickle.c
> > @@ -19,99 +19,59 @@
> >  #endif
> >  void _Watchdog_Tickle(
> > -  Watchdog_Control *the_watchdog;
> > -  Watchdog_States   watchdog_state;
> > -   * See the comment in watchdoginsert.c and watchdogadjust.c
> > -   * about why it's safe not to declare header a pointer to
> > -   * volatile data - till, 2003/7
> > -  if ( _Watchdog_Is_empty( header ) )
> > -    goto leave;
> > -  the_watchdog = _Watchdog_First( header );
> > -   * For some reason, on rare occasions the_watchdog->delta_interval
> > -   * of the head of the watchdog chain is 0.  Before this test was
> > -   * added, on these occasions an event (which usually was supposed
> > -   * to have a timeout of 1 tick would have a delta_interval of 0, which
> > -   * would be decremented to 0xFFFFFFFF by the unprotected
> > -   * "the_watchdog->delta_interval--;" operation.
> > -   * This would mean the event would not timeout, and also the chain would
> > -   * be blocked, because a timeout with a very high number would be at the
> > -   * head, rather than at the end.
> > -   * The test "if (the_watchdog->delta_interval != 0)"
> > -   * here prevents this from occuring.
> > -   * We were not able to categorically identify the situation that causes
> > -   * this, but proved it to be true empirically.  So this check causes
> > -   * correct behaviour in this circumstance.
> > -   * The belief is that a race condition exists whereby an event at the head
> > -   * of the chain is removed (by a pending ISR or higher priority task)
> > -   * during the _ISR_Flash( level ); in _Watchdog_Insert, but the watchdog
> > -   * to be inserted has already had its delta_interval adjusted to 0, and
> > -   * so is added to the head of the chain with a delta_interval of 0.
> > -   * Steven Johnson - 12/2005 (gcc-3.2.3 -O3 on powerpc)
> > -  if (the_watchdog->delta_interval != 0) {
> > -    the_watchdog->delta_interval--;
> > -    if ( the_watchdog->delta_interval != 0 )
> > -      goto leave;
> > +  if ( !_Watchdog_Is_empty( header ) ) {
> > +    Watchdog_Control  *first;
> > +    first = _Watchdog_First( header );
> > +    delta = first->delta_interval;
> > +     * Although it is forbidden to insert watchdogs with a delta interval of
> > +     * zero it is possible to observe watchdogs with a delta interval of zero
> > +     * at this point.  For example lets have a watchdog chain of one watchdog
> > +     * with a delta interval of one and insert a new one with an initial value
> > +     * of one.  At the start of the insert procedure it will advance one step
> > +     * and reduce its delta interval by one yielding zero.  Now a tick happens.
> > +     * This will remove the watchdog on the chain and update the insert
> > +     * iterator.  Now the insert operation continues and will insert the new
> > +     * watchdog with a delta interval of zero.
> > +    if ( delta > 0 ) {
> > +      --delta;
> > +      first->delta_interval = delta;
> > +    while ( delta == 0 ) {
> > +      bool run;
> > +      run = first->state == WATCHDOG_ACTIVE;
> > +      _Watchdog_Remove_it( header, first );
> > +      _Watchdog_Release( header, &lock_context );
> > +      if ( run ) {
> > +        (*first->routine)( first->id, first->user_data );
> > +      if ( _Watchdog_Is_empty( header ) ) {
> > +        break;
> > -  do {
> > -     watchdog_state = _Watchdog_Remove( header, the_watchdog );
> > -     switch( watchdog_state ) {
> > -       case WATCHDOG_ACTIVE:
> > -         (*the_watchdog->routine)(
> > -           the_watchdog->id,
> > -           the_watchdog->user_data
> > -         break;
> > -       case WATCHDOG_INACTIVE:
> > -          *  This state indicates that the watchdog is not on any chain.
> > -          *  Thus, it is NOT on a chain being tickled.  This case should
> > -          *  never occur.
> > -         break;
> > -       case WATCHDOG_BEING_INSERTED:
> > -          *  This state indicates that the watchdog is in the process of
> > -          *  BEING inserted on the chain.  Thus, it can NOT be on a chain
> > -          *  being tickled.  This case should never occur.
> > -         break;
> > -       case WATCHDOG_REMOVE_IT:
> > -         break;
> > -   } while ( !_Watchdog_Is_empty( header ) &&
> > -             (the_watchdog->delta_interval == 0) );
> > -leave:
> > diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
> > index f00da0d..58bcc89 100644
> > --- a/testsuites/sptests/spsize/size.c
> > +++ b/testsuites/sptests/spsize/size.c
> > @@ -399,9 +399,7 @@ uninitialized =
> >  /*userext.h*/   (sizeof _User_extensions_List)            +
> > -/*watchdog.h*/  (sizeof _Watchdog_Sync_level)             +
> > -                (sizeof _Watchdog_Sync_count)             +
> > -                (sizeof _Watchdog_Ticks_since_boot)       +
> > +/*watchdog.h*/  (sizeof _Watchdog_Ticks_since_boot)       +
> >                  (sizeof _Watchdog_Ticks_header)           +
> >                  (sizeof _Watchdog_Seconds_header)         +
> > diff --git a/testsuites/sptests/spwatchdog/init.c b/testsuites/sptests/spwatchdog/init.c
> > index 1d3cb2f..54bd5c3 100644
> > --- a/testsuites/sptests/spwatchdog/init.c
> > +++ b/testsuites/sptests/spwatchdog/init.c
> > @@ -34,6 +34,108 @@ static void test_watchdog_routine( Objects_Id id, void *arg )
> >    rtems_test_assert( 0 );
> > +static void init_watchdogs(
> > +  Watchdog_Control watchdogs[3]
> > +  Watchdog_Control *a = &watchdogs[0];
> > +  Watchdog_Control *b = &watchdogs[1];
> > +  Watchdog_Control *c = &watchdogs[2];
> > +  Watchdog_Control *d = &watchdogs[3];
> > +  _Watchdog_Header_initialize( header );
> > +  rtems_test_assert( _Watchdog_Is_empty( header ) );
> > +  rtems_test_assert( _Chain_Is_empty( &header->Iterators ) );
> > +  _Watchdog_Initialize( c, NULL, 0, NULL );
> > +  c->initial = 6;
> > +  _Watchdog_Insert( header, c );
> > +  rtems_test_assert( c->delta_interval == 6 );
> > +  rtems_test_assert( !_Watchdog_Is_empty( header ) );
> > +  _Watchdog_Initialize( a, NULL, 0, NULL );
> > +  a->initial = 2;
> > +  _Watchdog_Insert( header, a );
> > +  rtems_test_assert( a->delta_interval == 2 );
> > +  rtems_test_assert( c->delta_interval == 4 );
> > +  _Watchdog_Initialize( b, NULL, 0, NULL );
> > +  b->initial = 4;
> > +  _Watchdog_Insert( header, b );
> > +  rtems_test_assert( b->delta_interval == 2 );
> > +  rtems_test_assert( c->delta_interval == 2 );
> > +  _Watchdog_Initialize( d, NULL, 0, NULL );
> > +static void add_iterator(
> > +  Watchdog_Iterator *i,
> > +  Watchdog_Control *w
> > +  _Chain_Append_unprotected( &header->Iterators, &i->Node );
> > +  i->delta_interval = 2;
> > +  i->current = &w->Node;
> > +static void test_watchdog_insert_and_remove( void )
> > +  Watchdog_Header header;
> > +  Watchdog_Control watchdogs[4];
> > +  Watchdog_Iterator i;
> > +  init_watchdogs( &header, watchdogs );
> > +  add_iterator( &header, &i, c );
> > +  /* Remove next watchdog of iterator */
> > +  _Watchdog_Remove( &header, c );
> > +  rtems_test_assert( i.delta_interval == 2 );
> > +  rtems_test_assert( i.current == &b->Node );
> > +  /* Remove watchdog before the current watchdog of iterator */
> > +  _Watchdog_Remove( &header, a );
> > +  rtems_test_assert( i.delta_interval == 4 );
> > +  /* Remove current (= last) watchdog of iterator */
> > +  _Watchdog_Remove( &header, b );
> > +  rtems_test_assert( i.current == _Chain_Head( &header.Watchdogs ) );
> > +  /* Insert first watchdog */
> > +  a->initial = 1;
> > +  _Watchdog_Insert( &header, a );
> > +  add_iterator( &header, &i, b );
> > +  /* Insert right before current watchdog of iterator */
> > +  d->initial = 3;
> > +  _Watchdog_Insert( &header, d );
> > +  rtems_test_assert( i.delta_interval == 1 );
> > +  /* Insert right after current watchdog of iterator */
> > +  d->initial = 5;
> >  static void test_watchdog_static_init( void )
> >    #if defined(RTEMS_USE_16_BIT_OBJECT)
> > @@ -70,6 +172,7 @@ rtems_task Init(
> >    TEST_BEGIN();
> >    test_watchdog_static_init();
> > +  test_watchdog_insert_and_remove();
> >    build_time( &time, 12, 31, 1988, 9, 0, 0, 0 );
> > 1.8.4.5
> > devel mailing list
> > devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
