[PATCH] [RTEMS Tester] Rename or1ksim BSP to generic_or1k
Hesham ALMatary heshamelmatary at gmail.com
Sun Apr 19 11:04:36 UTC 2015
 tester/rtems/testing/bsps/generic_or1k.mc | 53 +++++++++++++++++++++++++++++++
 tester/rtems/testing/bsps/or1ksim.mc      | 53 -------------------------------
 2 files changed, 53 insertions(+), 53 deletions(-)
 create mode 100644 tester/rtems/testing/bsps/generic_or1k.mc
 delete mode 100644 tester/rtems/testing/bsps/or1ksim.mc
diff --git a/tester/rtems/testing/bsps/generic_or1k.mc b/tester/rtems/testing/bsps/generic_or1k.mc
new file mode 100644
index 0000000..c5feffd
--- /dev/null
+++ b/tester/rtems/testing/bsps/generic_or1k.mc
@@ -0,0 +1,53 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# All paths in defaults must be Unix format. Do not store any Windows format
+# paths in the defaults.
+# Every entry must describe the type of checking a host must pass.
+# Records:
+#  key: type, attribute, value
+#   type     : none, dir, exe, triplet
+#   attribute: none, required, optional
+#   value    : 'single line', '''multi line'''
+# The generic_or1k BSP
+[global]
+bsp:                      none,    none,     'generic_or1k'
+[generic_or1k]
+generic_or1k:      none,    none,  '%{_rtscripts}/qemu.cfg'
+generic_or1k_arch: none,    none,  'or32'
+generic_or1k_opts: none,    none,  '%{qemu_opts_base} %{qemu_opts_no_net} -m 32M'
diff --git a/tester/rtems/testing/bsps/or1ksim.mc b/tester/rtems/testing/bsps/or1ksim.mc
deleted file mode 100644
index 7222a7f..0000000
--- a/tester/rtems/testing/bsps/or1ksim.mc
+++ /dev/null
@@ -1,53 +0,0 @@
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-# All paths in defaults must be Unix format. Do not store any Windows format
-# paths in the defaults.
-# Every entry must describe the type of checking a host must pass.
-# Records:
-#  key: type, attribute, value
-#   type     : none, dir, exe, triplet
-#   attribute: none, required, optional
-#   value    : 'single line', '''multi line'''
-# The or1ksim BSP
-[global]
-bsp:                      none,    none,     'or1ksim'
-[or1ksim]
-or1ksim:      none,    none,  '%{_rtscripts}/qemu.cfg'
-or1ksim_arch: none,    none,  'or32'
-or1ksim_opts: none,    none,  '%{qemu_opts_base} %{qemu_opts_no_net} -m 32M'
2.1.0
